Cabover Campers & Camper Trailers (pickups)
Does the new work any better than the old? Uh......probably not, but I feel better about it because I was worried about frame flex/twist using the old one.
Jheil – I’m not at all dissatisfied with the customer service I’ve received from Four Wheel. They’ve been very responsive and helpful.
I think one of their problems is that their business seems to be booming and, as a result, the pressure is increasing to get those campers out the door. Oftentimes when that happens quality control doesn’t immediately follow. A case in point, albeit a small point, is when holes are drilled through plywood care must be taken to prevent the wood from splintering on the back side. There are methods that can be used to prevent that splintering, but extra time must be taken: that time was not taken in a few instances on my camper. It’s no big deal, but it does show a lack of attention to detail.
Ah well, as they say, you pays your money and you takes your chances.
Mledtje - The top of the Four Wheel sits so close to the bed that you can't leave the bed made up and lower the top. If all you have are sheets it's no problem, but you can't leave anything else up there. I have a feeling over time thats going to be a real pain. Hell, I don't make my bed every day at home, it really irks me that I have to do that in the camper.
Jim
I'll drop Hellwig a note and see what they have to say about it.
Thanks for any responses
Ronnie
I changed the mattress in my camper to a pair of Therma-rest air mattress Camp Rest model. 72" x 25" x 2 or 2.5". We leave a mattress pad, two sheets, a thin blanket and a comforter cover on our bed. We do have to remove the pillows and the comforter (winter only) from the bed.
I understand why other popups have a thick front section, the negatives outweigh the advantages for me.
Ronnie,
Can you just put a 1/4" piece of plywood or a piece of sheetmetal at the front of the bed so the camper doesn't rest against the spray in liner?
The additional piece could be mounted to the front of the bed; size it so it wedges under the front lip of the bed. Be sure and leave some sort of an opening that you can grip the piece to remove it when you don't have the camper on board.
Mike L
What I do (when I remember) is to not back all the way up when putting the camper on, lower the camper almost all the way down, then back up the final amount and let the camper all the way down. The reverse must be done when taking it off. I've forgotten enough times that the screw holes are 80% stripped out.
If you want to abandon the bumpers completely you just need to come up with something to sit in the bottom of the bed that will stop the camper from coming forward. My old camper didn't have bumpers so I built a bed protection board. I used a sheet of plywood about the width of the bed and a little higher. At one long edge I screwed a 2x4. Then the board sat vertical between the camper and the front wall of the bed, with the 2x4 at the bottom and pointing toward the front. That way the 2x4 took up the extra space between the plywood and the front (bottom) of the bed caused by the sheetmetal lip at the top of the bed wall. I attached some padding to the camper side of the board to protect the camper finish. You could also glue some carpet on the front if you're worried about the truck paint.
This worked well and prevented the camper from sliding forward and bending the top of the bed. Unfortunately I didn't know I needed this until I slammed the brakes once and the camper bent the bed all the way to the cab! Don't go without some sort of bumper to stop this from happening, the bed wall is really not very strong.
How thick is the standard 4Wheel mattress? Is it just a block of foam (like my Phoenix had), or is it more comfortable than that?
Our camper came with a block of foam that was 4" thick. And the top wouldn't close completely. When we bought the air mattresses I had to readjust the front latches because the top went down another 3/4" to the stops. Like I said, we have plenty of room to leave the bed made - and as a bonus - the ThermaRest mattresses are more comfortable than the foam blocks.
Mike L
I went to a shop that sold foam and priced the highest quality foam (there’s a significant difference in the quality of foam) - $128 to replace the mattress; I haven’t done it yet. I was also considering a 2” high quality foam mattress and then topping that with one of those egg crate foam things. That should allow me to leave the sheets and a down comforter on the bed while still having some degree of comfort.
Jim
"Lie? Me? Never! No, no, no, the truth is far too much fun!" - Captain Hook
I don't know if you have ever slept on a ThermaRest air mattress, but they are quite comfortable. They are a foam pad inside an air mattress shell. The foam pad makes it self inflating, and offers some insulation (the therma part of the name). I let the mattress fill, then lay (on my side) on it and release air until my hip is firmly down, then close the air valve. That way the foam and the air and the ground all support my weight.
Before we bought this camper we had motorcycle/tent camped for 30 years, and the ThermaRest mattress is the most comfortable mattress we've ever used for camping. And it works equally well in the camper. I believe it is as comfortable as the $1000 mattress we have at home. Best of all, I never wake up with a backache from it.
The ThermaRest website is down, but the are available at most camping/sporting goods stores. They can be expensive if you buy the best (CampRest LE) in a 2 or 2.5" thickness. We spent about $200 for our two mattresses. They fit our space within 0.5". Measure yours, and check available sizes at:
http://www.vtarmynavy.com/thermarest.htm
I don't think you would ever regret buying one (or two). The only drawback we've found is when you change altitude, the air pressure inside the mattress needs to be changed also.
Later,
Mike L
I do own a couple of 3/4 lenth lightweight Thermorests and a couple big blue closed cell foam ensolite pads.
But the "super paco pad" is by far the best.
http://www.altrec.com/shop/detail/3991
http://www.altrec.com/shop/detail/6343/
TIA
The 9200 GVWR 2500HD are dang close to 1-tons of old days in terms of capacity.
If going diesel, go 1 ton....
I always recommend against a diesel unless you need the torque to pull a big trailer.
My reasoning for not recommending a diesel?
- It takes 100-150K miles to pay for the option with fuel savings
- The engine is so heavy that you lose significant load capacity
- The heavy engine detracts from on road and off road handling
Mike L
I suspect Mike is right about the low weight capacity. Some of the capacity is used up with the extra doors and then GM has to make the camper rating even lower to accommodate filling up that cab with people. If you want a full blown hardside like a Lance and you'll have people in all the seats, you should go for the 1-ton. A camper like that weighs 2500-3000lbs. If you plan on having something lighter then the 3/4 should do fine.
1) If they interfere with cargo when the camper is off.
2) Having to drill holes in the bed of the truck where exposure to water could lead to rust.
If you end up using them please let us know. I'd love to see a picture.
Mike L
I look at it as the ultimate SUV. A lot of the mfg'r are making slide ins for short box. I will probably go w/ a lighter/smaller 8.5 slide in. I will be using the truck as a daily commuter and occasional cross country RV w/ a family of 4.
My next question is an all important one. SAFTEY.
What is the legality of passengers IN the camper on the hyways/byways?
link
http://www.pickuptruck.com/html/2001/gmc/hd/hd_upclose.html
Is unsafe in any accident. Almost any accident will send alot of misc stuff flying around inside a camper. Sodas, cans of food, table tops, silverware, refrig contents, gameboys, and more. Not a place I would want to be, nor a place I would want anyone I care about to be in an accident. Stuff can be replaced, insurance will replace your truck and camper (you did tell them you had a camper?), but nothing will replace a loved one.
From the above, you can guess my feelings on the subject. Feelings that are not shared by all.
Mike L
MikeL is dead on riding in campers/travel trailers. Ever see one after an accident? The look worse than mobile homes that have been thru F5 tornado's....
I agree w/ you to some extent.
After a little more research I came across the following page.
NY is the only state which forbids riding in a P/U camper.
I was very surprised that some states allow riders in trailers!
http://www.rvsafety.com/Passenger%20Laws.htm
Children have special requirements, but an adult can't even ride in the bed of a PU unless they have a seatbelt fastened.
I suspect you would have to add seatbelts to allow someone to ride in the back.
Still I wouldn't do it or allow it.
Mike L
Judging from that website, it appears that the seatbelt rule doesn't apply to truck campers, with the exception of CA and NY. We have a mandatory seatbelt law in Alaska and I'm pretty sure that you can have passengers in the truck camper, but I'm not positive. I've never done it. I'd have some concerns with kids riding in the camper because of the safety issues in the event of an accident. However, adults have the capacity to know the risks, so if it's legal, I wouldn't think less of someone who permitted adults in the camper. But like I said, to this point, I've never had anyone in the camper when I'm driving.
Another thing that I would add is that I've traveled quite a bit in Class A motorhomes. There are certain seats that have seat belts, but passengers are rarely in their belts other than the driver and the shotgun passenger. Everyone is always milling about, using the restrooms, grabbing a soda from the frig, making lunch, taking naps or playing games. It's really no different with a truck camper as long as you have audio contact with the camper, maybe by something as simple as cheap walkie-talkies.
I'd be interested to see some accident/injury stats from people riding in camper and motorhomes. The campers look pretty thrashed, but I wouldn't be interested to see how common the accidents are, and how severe the injuries are, and how many fatalities there are that can be blamed on the person being in the camper. Alot of times, those real nasty looking accidents involve fatalities and serious injury to the people in the truck as well. I'm not advocating riding in the camper and don't do it. I'm just curious if it is really a significant concern or more of a perceived concern by those of us who have seen the aftermath of a camper accident.
Try connecting the radio directly to the battery and see what happens when you connect the AC power.
Jim
Thanks for the help.
I have a '91 Lance with a Thetford toilet. It had two problems, a small leak when I ran a high pressure garden hose down the top, and the fresh water flush stopped flowing. I had to cut a 1/2 inch wrench in half to make a tool short enough to get one of the bolts loose. After that removal was easy.
The leak is due to an old seal I'm sure. It's just a foam ring that goes around the bottom opening. I'll head to the RV store tomorrow for a new one. The flow problem was due to junk buildup in the water valve outlet. You have to pull the valve to see this. It was full of granular debris and what looked like small rocks?? After cleaning it works fine. I look forward to a good WHOOSH now!
Does anyone have any good ideas for the wiring on a camper not equipped for it? Somewhere I have to penetrate the outer wall and I don't want seal problems. I'm thinking about doing it from underneath. But then the wire has to be run along the outside a ways. Maybe use small white PVC pipe as a conduit?
Anyone want to purchase a set of hydraulic jacks?
The water pump in my camper is annoyingly loud and I want to quiet it a bit. A big part of the problem is that it's mounted to the structure with minimum isolation so the entire sink/counter area becomes a sounding board. I want to isolate the pump from the wood framing better; anyone have any ideas? I'm thinking of rubber isolation somehow, like motor mounts but not so stiff.
My pump has rubber mounts under it, and it still makes more noise than anything else in the camper. If you can't find some acceptable rubber mounts, give me a call and I'll see if I can scare some up. It's amazing what is hiding in my barn.
Mike L
-Mictro
You ever come down this way?
Mike L
Only hook it up when you want to use it. You would have to carry it with your camper, but not attached - no holes, no worries!
Mike L
stabbur, a toaster oven? That must have been a big storage area! I kept wood for leveling in the space around the water tank in my old camper. The Lance has that compartment sealed off. If my mounting fix isn't enough I'll be sure to give your method a try and stuff the sink cabinet with shoes.
I got my electric jacks today. I ended up picking them up at the retail store for the internet price and saved the shipping (and the day off work to wait for the truck--no UPS). The mounting kit comes with some connectors so I'll see if the manufacturer already thought about my situation. The Romex idea is good, I'll use that where it doesn't show. But if I have to run wires along the outside I want it to be a bit more polished. The big no on the removable harness. My constant goal is to create less things to touch while transferring the camper since I do it frequently. More to come...
The toilet is done successfully. Thetford only uses one seal on all their products so it was no problem to find. I wish more things were made that way.
oltroll1, those tests they had you do are reasonable. I hope the new unit fixes the problem.
If you're interested I can take some photos.
Vince
Vince, you should read that WWII Diary I gave to Atilla. It is always hard to realize what those guys (WWII soldiers, like my dad)went through to keep us a free (welll, not free from lawyers) country. We owe them a debt we can never repay! Driving 2000 miles to go to Detroit with my dad is only a small token.
And, by the way, the short term cure for cabin fever is located in Death Valley. And that is only 27 days away!!!!
Mike L
If you have the time and interest... Look for similar mounts used on cars. The air cleaner on late 60's to mid '70s and probably beyond BMWs were mounted with an isolation mount like that. The transmission and shift lever mount had one too. Bet others use 'em too. Had to do something about those 4-banger vibes. They were good vibes, but too much of a good thing....
If you want to come by this weekend, we will compare to what you have and find something that will work.
Mike L
I'll come over to search your junk box eventually Mike, unless I find something in the meantime. If you are out there anyway take a look for something suitable. How about at work?
Mike L
As far as wiring to ANYTHING on a vehicle,
I would suggest stranded wire as opposed
to ROMEX. Romex is made with solid copper
wire and will tend to stiffen then break with
use and vibration. Anyone have a comparison
of campers. Kind of a CONSUMERS REPORT sort
of thing. I am picking up a '01 SD 4x4 short
bed and am looking for a pop-up camper.
Later
