Toyota Prius MPG-Real World Numbers
13468920
  • ericlitericlit Member Posts: 1
    I bought my 2006 Prius in February of this year and already have over 27,000 miles on it. At about the 24,000 mile mark, I noticed that I was getting noticably fewer gallons out of each tick on the fuel gauge...from around 130 on the first tick to maybe 95. I took it in for the 25,000 mile check-up and they said that they would clean the fuel injectors and change the air filter, which should take care of it. It did for only the first tank of gas, and has since gone down even further. At this point, I'm only getting about 70 miles to the first tick, and 25 to 30 for each one after that. Has anyone else experinced this? I'd really appreciate an e-mail at elitiwller@hotmail.com if you have!!
  • pathstar1pathstar1 Member Posts: 1,015
    The decrease in mileage is probably caused by the drop in ambient temps. (winter is coming). Cleaning of the fuel injectors may be necessary at 100,000 mi. but not at 25,000! It's a bogus service to enhance the dealers margins. Dirty injectors will usually cause the engine to run rough and loose power at high speed.
  • ck90211ck90211 Member Posts: 161
    I second the temp effect on mileage. For past month my Prius (new) has been giving me 49+ mpg, mostly with AC off; sometimes with heat on. But lately temp in Los Angeles has been in the 80-90's, so with the AC on, mileage went back down to 45, 47.
    Top Gear (a car show on BBC) reviewed Prius recently and slammed it for 36 mpg. Not sure if that's US gallon or empirical gallon, and if a mile there equals a mile here. But they like their diesel VW's (65mpg+).
  • terry92270terry92270 Member Posts: 1,247
    Europe uses the Metric System, partially, but a mile is a mile there (UK) as here. However Imperial Gallons are larger than in the US:
    1 US gallon = 0.8327 Imperial Gallon
    1 mile =1760 yd = 1.6093 km
  • christinetchristinet Member Posts: 2
    Hello all-
    I am new to the discussion so I apologize if something like this has come up before. I had a strange thing happen to me and I was wondering if anyone had any comments. Here's the story:
    I was driving my new '07 prius (it has a total of ~2800 miles) on a small highway at ~55mph. The gas gauge indicated that I needed gas but I had been putting it off because my odometer reading for that tank showed 401 miles, and the average MPG was reading 48.4. I assumed this meant that I had used about 8.3 gallons so I had enough left to get me to my destination (not very far away). Then suddenly, the check engine light flashed on and the triangle with exclamation point warning light came on too. The car started losing velocity and I couldn't make it keep going, so I pulled over and stopped, turned the car off and waited a minute. I turned it back on and the lights were still on but I was able to drive it the remaining mile to a gas station. When I filled up, the pump didn't click off until 10.6 gallons. That means I was getting only ~37.8 MPG. This is the biggest discrepancy I've experienced but from what I've read in previous discussions it could be because of the fuel bladder? Anyway, when I turned the car on the lights back to normal so I assume this is what the car does when it's out of gas. Was this just a freak occurrence or is the computer always that inaccurate? Any comments will be appreciated. :confuse:
    The Prius MFD computer is actually quite accurate, usually better than 5%.
    The most probable reason your calculations are off is you didn't get the tank full the last time you got gas - and this was probably due to the bladder.
    Don't feel bad about running out - lots of people have done it. I don't think it's good for the car if you keep doing it. It puts unneeded stress on the battery.
    Always fill up before you get to one pip, or at least before it starts flashing!
    To get a more realistic mileage reading, combine the last two or three tanks, as this will average out the bladder early cutoff effect.
  • kdhspyderkdhspyder Member Posts: 7,160
    "Triangle of Death" Event.
    Welcome to Prius World. I had the same thing happen to me on my third tank when I too was trying to stretch things with the gas light on. Essentially you ran out of gas. You didn't actually run out of gas but the computer thought that there was a risk you might so it shut you down first. Why? Driving on the traction battery alone not using the gas engine is possible but it is very very very dangerous to the overall health of the battery. Thus before you get into a true out-of-gas situation, you get shut down.
    I'm certain that you found that when you filled up, all the lights went out and you just continued on, right?
    I learned this over on Prius Chat. When the warning light comes on.. just fill up....Soon.
    If you push your luck with running near empty, you will soon run out of both gas and luck. ;)
    Always refill as soon as possible, as soon as paractical, with any vehicle, after it drops past half.
    Thanks everyone for your comments. Next time I won't wait so long to fill up! And yes, when I filled up the lights were gone =)
  • crazedcommutercrazedcommuter Member Posts: 281
    Hey gang-I currently drive an '05 Scion XB and am toying with the notion of switching to the Prius. I have several questions regarding the Prius as I am just researching the hybrid technology.
    First, I drive 110 miles daily to and from the Wash, DC area. I live in the eastern edge of West Virginia and drive with the 70 mph cruisers and in the grid lock. Is the Prius the correct type of vehicle for my needs?
    Since getting to and from work is the major concern of most commuters, I run with the 70 mph folks when traffic allows and crawl in stop and go when I have to. I currently get 31-35 mpg with my Scion and am curious if I will acheive significantly greater mpg with the Prius based on my commuting practices. Will the Prius mpg be vastly lowered by cruising at 70 mph and sitting in stop and go? Do any of you Prius owners drive the same way?
    If the Prius offers a significant mpg improvement I may switch to it from the XB. However, if the mpg will be on a par with the XB then I'll probably keep the Scion. Thanks.
  • ssreekakssreekak Member Posts: 5
    The price if an XB is significantly lower - Even you get 45 mpg with your driving criteria, the prius is not worth it IMHO. I dont think you will get much more than 45 with the kind of driving you are describing.
    One can get low 50's in DC area (70's mixed with stop n' go), and my car is not broken in yet. If you are strictly going by miles/$, xB, or even Corolla, would be a better choice. But if you like a quiet, supple ride, Prius is lot better than xB. I was considering xB too but just felt the ride was too buzzy/nervous at speed 60+.
  • eprupiseprupis Member Posts: 30
    There's more to a choice of a car than MPG. The prius is big car roomy for 2 adults and it can be converted to a cargo carrier by folding the rear seats. Gas savings alone won't make up the cost difference but at present, residual value keeps the cost of the Prius quite reasonable.
    There's more to a choice of a car than MPG. The prius is big car roomy for 4 adults and it can be converted to a cargo carrier by folding the rear seats. Gas savings alone won't make up the cost difference but at present, residual value keeps the cost of the Prius quite reasonable.
  • vu2000vu2000 Member Posts: 58
    Just bought a blue Prius 2 weeks ago. After 1st tank of gas, I calculated 47mpg(computer said 47.5mpg). The Prius does not handle/ride nearly as nice or have the pick up as my 2005 Accord 4Cyl EX(30mpg average), but for this excellent gas mileage I am deffinitely willing to live with it. The best thing is knowing that my Prius is one the the least polluting vehicle on the road. If more of us owned vehicles like these, we would be less dependent on the oil companies or OPEC. :) PS I love all the gadgets on this thing, so does my kids.
    Thanks for the feedback on the Prius and XB. My daughter will be getting her license next year and the XB might be a present to her. The Prius will be on my short list of wanted vehicles.
    Thank you for the update on the Prius. I see that dealers have quite a lot more of them on their lots now than they did several months ago and that prices are stabilizing a bit. How soon people forget about the $3.35 gal. gas! Last month SUV sales were up for the 1st time in a year. The short sighted buying of these SUV's at any price just does not compute.
    Roominess, price, and mpg are the reasons that I bought the XB. That combination can't be beat. My search is for precisly what the Prius offers in terms of mpg, comfort and utility. But there are several other vehicles that also fit my criteria so this will be a difficult choice when I do decide to buy. My daughter will have her DL next year and I may give her the XB, so I'm starting my research now.
    As the prior posters noted this is a very personal choice in that if it purely an economics decision staying in the xB is a better choice.
    If there are other considerations like a nicer riding vehicle for such a long commute or environmental concerns or the fact that it typically will be a safer vehicle in a collision then the Prius may move to the fore.
    Fuel Economy guidelines ..
    At a constant 70 mph on the interstates you will likely get 'only' 45 mpg in the Prius. In a rolling stop-and-go on the Beltway you may get upwards of 65-80 mpg depending on how often you must stop dead ( the fewer times you have to stop dead the better ). You will be able to do a weighted average of your personal composite FE Avg by estimating how many miles you do 70 and how many miles you are stuck in Beltway traffic.
    I sell them in SE VA and commute up from the Outer Banks every day 75 mi each way. There is no Beltway gridlock for me but neither can I even think of driving 70 unless I want to lock myself up for 100 yrs. On GreenHybrid my annual FE is 48.4 mpg. I came out of a 2000 Camry and love the feel and capability and techi-ness of this vehicle.
  • jimkingjimking Member Posts: 3
    I have a Honda CR/V now and the road noise is killing me. I'd like to upgrade to a quieter, more efficient vehicle with decent head and legroom. Any suggestions? How does the PRIUS stack up to the quiet Camry, the Accord and the quiet Sonata?
    There is a Mid-Sized Sedans comparison discussion that might be a good place for this question.
    The Prius feels like a midsized auto on the road. It's a 'tweener, not as big as a Camry but it's bigger than a Corolla/Civic.
    If you cruise a lot on the highway it's nearly dead silent; when deceerating it is dead silent; sitting at a stop it's OFF so it is dead silent; only in accelerating does it sound like a small 4c.
  • cheryl06priuscheryl06prius Member Posts: 50
    I've noticed that since about the beginning of November of this year, that the MPG computation based upon the actual amount of gas pumped into the tank varies from the MPG figure shown on the trip computer, by an average of 3-4MPG, if the gauge shows 56MPG, the manual calculation will be 52-53MPG.
    I've been using the same fill up technique since June and until November the readings were generally within 1MPG of each other.
    Has anyone else noticed this? Could the colder temperatures affect the trip computer accuracy?
    The cold weather causes the fuel bladder to get stiffer. This means you can't get as much fuel in. That's why the accuracy suffers. It should eventually even out, once the ambient temp stabilizes or starts to rise. The MFD computes fuel based on how much it injected into the engine. It is usually pretty accurate. It is also subject to temp. however. Fuel shrinks when it gets colder and expands when it gets warmer. It isn't a lot, but it can cause +or- errors of around 5% (compared to the fuel you pump, which is at a different temp than the fuel the engine is injecting).
  • allargonallargon Member Posts: 75
    It's noisier than all of the above mid-sized sedans. It's a hatch so you will hear the road noise from the rear wheels. You didn't mention the lovely Saturn Aura, Ford Fusion or Mazda 6? :)
    Seriously, the road noise will be more pronounced with the Prius since the engine is so quiet. Do you mean wind noise or road noise? There's a LOT of wind noise in my new Prius. (I drive my Prius. I don't hug the right lane and drive 45 mph.) However, I'm wondering if it's the Prius, or do I need to smack my dealer and make them fix it... :confuse:
  • riposteriposte Member Posts: 160
    I wouldn't go smacking ANYONE, but I'd definitely take it back to your dealer.
    My Prius is EXTREMELY quiet at all speeds.
    Hey guys,
    This is jimking who started this thread. I bought the PRIUS. Very quiet (barely makes a sound during startup and while resting at traffic lights and stop signs), hums along while cruising. Absolutely love it. 45 mpg to date. Very comfortable seating.
    Mine (a 2007 Touring) just turned 1,000 miles yesterday. So far, I'm averaging 52.0 in mixed driving.
    Last night, we were driving around some neighborhoods and side streets, looking at Christmas lights (my girlfriend wanted to do this, not me). I had a string of awesome MPG averages in the 5-minute display. My favorite one read "100 MPG", which meant, of course, that I was on battery power, with the ICE totally off, for the entire 5 minutes.
    I find mine is nearly dead quiet except for the mediocre tires. That road noise is apparent. When they go at 50-60K then I will get quieter tires. I also have them pumped up to 42Fr/40Rr. Other than that just a small rattle on cold days until the dash warms up.
    The road noise is probably from OVER INFLATIING your tires. THey should be pressurized below 30 psi. Check your manual and enjoy the quiet ride of a PRIUS.
    :P
    I know what the manual says.. but I choose to over inflate to just under the limit in order to get slightly better FE. The rougher ride is not that important.
    Thank you for your synopsis of the Prius. I respect your opinion as expert and salesman. Maybe after the holiday season I'll drive one. Also, my commute may get to be about 30 miles longer soon, from the WV panhandle to Arlington. I may need that Prius in the stop and go mess of the our advanced highway system! My friend lives in Wheeling, WV, and he had one of the 1st Prius that came ashore in 2004 ( was that the present body style redesign?). He raved about it then. Last month he called to inform me that he just turned 63,000 miles on it and to celebrate he bought Prius #2 for his wife. He raves about the greeness of the cars and the performance, but his idea of a commute is a 30 mile stroll down along the Ohio River at 45 mph. I have not driven one yet but I'm itching to do so. Maybe not on the Beltway but somewhere a little more rural.
    Overall i'm quite pleased with my '06 Prius but i'm perplexed by inconsistencies between the trip MPG meter and the actual amount of gas actully pumped. I'm Obssessive-Compulsive when it comes to calculating FE, but with the Prius gauge readings vary +3 to -3mpg with the same weather conditions. This makes it difficult to ascertain the precise MPG for any trip.
    Case in point: My last fill up was at 342 miles, at the pump the tank took 6.2 gallons, calculating to 55.1 mpg, with the trip gauge showing 51.5 mpg.
    On the prior trip it was 412 miles at 8.1 gal. translating to 50MPG but with a trip reading of 53.1 MPG, both were in cold weather.
    These discrepancies have impeded my ability to be aware of the precise fuel mileage. When the '06 HCH first was introduced its MPG tripmeter was seriously defective but a recall was had and the new gauge tends to read between l-l.5 mpg lower than the measured reading. It is also easy to tell when the HCH tank is full without worry of gas surging out.
    I think it is time for Toyota to either replace the tripmeter or issue a definitive explanation for the discrepancies. I'd still buy another Prius but we Obssessive Compulsives are entitled to our peace of mind when it comes to computing mpg.
    I'm very much interested in hearing from other Prius owners with the same concerns.
  • larsblarsb Member Posts: 8,204
    You'll just need to get over it I'm afraid. That difference is par for the course because of the bladder configuration of the Prius gas tank.
    The best way to calculate your MPG is to just use the tried-and-true "miles driven divided by gallons used" calculation and not rely on the car's FCD data.
    I'm on my second hybrid and there is usally a 1-3 MPG difference between the car and the actual fuel used on every tank.
    My 2007 TCH (12 tanks so far) averages a difference of 1.018905 between the manual calculation and the FCD, which is pretty darn close.
    My 2004 HCH averaged a diff of 1.33, so the TCH is slightly more accurate.
  • joannerjoanner Member Posts: 10
    I just picked up my 2007 Prius package 2 this afternoon. I had to drive across the state to pick it up. I got 45 miles per gallon, which I am delighted with. Wish the ride was a bit smoother--but I have been driving my dad's Buick LeSabre and used to that.
    Also one thing I didn't like is that there seems to be a second or so of a blind spot with a car passing me. I will have to do some more adjusting on the outside mirror.
  • south4south4 Member Posts: 32
    I just bought a 2007 Prius. I had nitrogen in the tires on my other car. Did you ever switch to it on your Prius? Does anyone else out there use it? The Toyota dealer didn't mention it and my other car was a Honda.
    I purchased new tires from Costco for my 2004 Prius and they filled all the tires with nitrogen. I haven't noticed any effect but an internet search said that nitrogen-filled tires will hold their pressure better than those with air and will cause less corrosion of the wheels.
    Thank you for your reply.I'll ask the Toyota dealer if they can put nitrogen in mine-otherwise I'll see if SC has A Costco.Don't think I can ask my old Honda dealer to help me out on a Toyota..........
    The basic consensis I've seen is that it's a lot of "hooey". Air contains 80% nitrogen. Being that the tire starts out with air in it when they start pumping nitrogen in, you will still have some O2 in there. The real "reason" N2 is used, is it started on the racetrack. There, as they had to buy bottles of compressed air, they got N2 instead, as it was very slightly "better" for almost no increase in cost. It doesn't reduce corrosion - have you ever seen -any- corrosion inside the tire on the wheel or tire? They've always looked new to me after even 10 years. What using N2 from bottles does mainly is exclude H2O vapour from the tire (the bottling plants have to dry the gases they compress more than just an air pump does to protect the plant). Exclusion of H2O from the tire will make the tire pressure vary a little less than normal. I doubt anyone making an honest comparison would notice the difference.
    Use it if it makes you happy. Be aware, many places will charge money for it. Oh, and if you notice a tire is a bit low, how are you going to pump it back up with N2 unless you're at the place that has the nitrogen?
    Thanks for your input.I used nitrogen with my Pilot and had a great result. I'd had trouble with my tires looking low and had to check them too much. After putting nitrogen in , I no longer had the variation. One time I did have a tire hit something and leak. You just put nitrogen in with the nitrogen-no problem. Then, when I returned to town, the place where I bought the nitrogen originally swiched it out for free.
    I think I'll start out without it this time and only seek it out again if I have a lot of variation in tire pressure. It must not be an issue with the Prius. Thanks again for your thoughts on this.
  • carbotcarbot Member Posts: 14
    I am new on this forum, but not new to hybrid cars. I drive all day, every day, in my work (self employed). From 3/3/03 to 1/15/04 I drove an '03 Prius. I logged over 37000 miles in 9 1/2 months. When I'm not rolling, I'm not making money, so I do not baby my cars for mileage. My composit mileage figures for that car were: Gage 46.1 MPG, Actual 43.7 MPG. I sold the car to a friend who still has it with over 130,000 miles on it. I think he has replaced the accessory battery and nothing else. My current work car is a "loaded" '04 Prius, with 134,000 miles. I just replaced the accessory battery. I am still on my original brakes. Tomorrow is the 3rd anniversary of owning this car. I have every intention of keeping it until Toyota comes out with a "Plug-in". The mileage figures for this car are: Gage 48.1 MPG, Actual 47.4 MPG. I use the nav. system at least a dozen times a day. The touch screen is much better that the toggle system in my wife's Murano. I also use the Bluetooth phone dozens of times a day. It is the perfect car for my purposes. Can you tell I love this car? Sorry about being longwinded, but I get that way when I tell people about my car.
    Joe
    PS. I have 9 friends with Prii, and they all love them.
  • shalwechatshalwechat Member Posts: 25
    "PS
    Be careful in that sub compact. I read where some fellow got killed on the Parks when he hit a moose. Took the top right off his small car."
    Moose or any other large animal can take the top of any car or truck. A motorist was killed in the Chicago area when he struck a deer on his full sized puck-up. it "took the top" off of his vehicle.
  • railroadjamesrailroadjames Member Posts: 560
    What "sub-compact"??? Prius is considered a "mid-sized" vehicle categorically.
    I've got 56K on my '04 Prius and get an overall decent 46 mpg's but somewhat less during cold winters due to the "ICE" engine running considerably more to maintain heat. What is an issue is the "bladder tank"....It can be baffeling especially in the winter. Sometimes the gauge doesn't even show the "full" mark after a fill-up. I have to wonder if this complex fuel tank with its' rubber bladder is the better way to go. Time will tell. I suppose there are advantages to it as Toyota would say. :confuse:
    The fuel tank bladder is how Toyota was able to get the extremely low emission rating they got on the Prius. It eliminates evaporative fuel losses to the atmosphere. I agree, it does baffle the owners as well as the fuel vapours. ;)
    Dealing with this anomaly is a bit perplexing. I understand the technical reasoning behind the "bladder" tank sys. I just don't think they've gotten all the bugs out yet. In theory it makes sense but there are quirks with it. I know because after three yrs and one recall I still find the bladder "baffling." :blush::blush:
  • shammshamm Member Posts: 10
    First, this discussion is not about the Prius, hybrids, or even about small cars. It is about driving around animals. And we all drive around animals everyday.
    We've all heard about the car, truck, semi that hit a deer, horse, cow, pig, badger, etc and the animal either takes the roof off the car (along with the driver's head) or the animal goes under the car and vaults it out of control. These are true. It does happen. It can happen to any sized car.
    I've driven small cars most of my life (I'm 57 now) and I have hit an elk while driving a roadster. The street was wet with an early spring snow, it was night, I was driving a bit too fast... there's an elk in the middle of the two lane road... because the small car was agile, because I was a good driver, because I figured the elk would try and leave and she would go in the direction she was currently walking, I pulled the car into the opposite lane and attempted to squeeze between the shoulder and the elk's hind end. She bolted. Her hoof hit my headlight. She was spun around and went off the road into the ditch. She fell down. From the tracks that I could clearly see later, she got up and ran up the hill to safety.
    My roadster also spun around and I skidded the car sideways for about 50 yards. I drove back to see the elk's tracks. I examined my car. The headlight was not broken but pushed about 3 inches into the fender. No other damage was noted.
    Moral of the story:
    If I was a bad driver I might have hit the elk so my bumper took her legs out from under her and she would have fallen into the windshield.
    If the car was not agile, I might have tried to move behind her and lost control and ended up skidding sideways into the elk. No telling what that would have done.
    If the car was larger, I might not have had the option of moving on the two lane street so I could have slipped behind the elk.
    But, because the car was small and agile and my driving skills back then were very good, I avoided a serious accident.
    Add a bit of defensive driving and my speed would have been a bit slower that night, I would not have been overdriving my headlights (by just a little) and would have seen the elk in time to safely stop. Thus defensive driving would have avoided the whole thing!
    I feel I was extremely lucky to have been in a small car when I hit the elk. So take your notion that small cars are dangerous, your Ralph Nadar wrist watch and go away. The bottom line, be a good driver and live longer. Be a defensive driver and good driver and live even longer yet.
    Now, let's talk about hybrids and did you see the Future Car series on Discovery Channel last week. I want one of those!
    "First, this discussion is not about the Prius, hybrids, or even about small cars. It is about driving around animals. And we all drive around animals everyday."
    Odd, looking at the top of the screen it says this discussion is about Toyota Prius MPG.
    ... still going...
    Toyota Feb Sales
    Snippet:
    Toyota Reports February Sales
    03/01/2007 Torrance, CA
    March 1, 2007 – Torrance, CA - Spurred by record hybrid sales, Toyota Motor Sales (TMS), U.S.A., Inc., today reported best-ever February sales of 187,330 vehicles, an increase of 12.2 percent over February 2006.
    "Sales were brisk at both ends of our product lineup," said Jim Lentz, TMS executive vice president. "Setting an all-time record, the Prius hybrid led the way, nearly doubling last February's sales pace; while the new full-size Tundra got off to an impressive start since hitting showrooms February 5th."
    and
    TMS calendar-year-to-date hybrid sales totaled 31,933 units, an increase of 67 percent over the year-ago. In February, TMS posted sales of 18,860 hybrid vehicles, up 92 percent over last February. Toyota Division posted sales of 17,451 hybrids, up 90 percent over the same period last year, while the Lexus Division posted sales of 1,409 hybrids.
  • billd6billd6 Member Posts: 3
    Finally back after forgetting which forum I posted the last message on. Now that I've accounted for the bladder factor I've stopped panicking about the mpgs. The colder weather has dropped them into the low 40s for my daily commute, and the smaller tank means that my range is way down, too. Highway is still low 50s. Best is cruising between 40 and 50 w/o too many stops; 70 mpgs is possible. Unfortunately I don't get much of that. Looking forward to the warmer weather. Fuel economy aside, I'm five months in and still love being in the car. Absolutely no regrets.
  • pushanpushan Member Posts: 15
    I have 2006 base model Prius, and my typical commute is 6 miles one way. So far, I have put 5K miles on the car.
    I noticed that during warmer weather I get around 48 MPG. During winter time I am getting 36 MPG. One of the reason for low MPG during winter, I believe is the engine keeps running to keep the car warm even though the car is stopped.
    I am happy to have this car.
  • boraboraborabora Member Posts: 16
    just drove the brand new 07 prius out of the dealer's lot. a 13 mile trip only for 29.8 MPG. how come? shall i drive it more to get it higher? Please tip.
