Visitor Agreement.
It turns out it is my birthday on Sat.
Must be time to celebrate!!!!
The big 55!
Later,
Mike L
To the West Coast: come meet me at Butano State Park near the town of Pescadaro this weekend! Redwoods and ocean yes, showers no.
How much clearance does it have? 1/16", more, less??
Seems like you put your factory wheels on to verify the out of balance/round of the new wheels/tires. I would have to assume that you did not have the ticking sound with the factory wheels and tires, correct?
Mike L
Mike L
Kevin
My vote is for the Line-X brand. I have it in my truck and also have a slide in camper. Once the camper is in position, it provides "traction" and helps keep it from sliding.
I personally think the Line-X looks better than Rhino. Rhino has more of a cottage cheese look to it and Line-X looks like a more professional/factory finish.
Mike
A spray in shouldn't be an issue. My preference would be a thick rubber mat for the camper to sit on ~ $50.
Later, if you have messed up the paint in the be, you can still spray in the rhinoliner.
Mike L
Frank
On bad washboard roads (Vince, remember going out to Goler Wash?) the camper will still move slightly side to side. But it won't move in normal use.
Mike L
Frank
Guggenheim - Las Vegas
http://community.webshots.com/album/23621145SqrUfKKuMp
The exhibits will be there through June. Visit them if you get the chance, they are magnificent! We go in before it was open to the public (my friend has a motorcycle in the exhibit) and spent 5 hours going through the empty halls. 65,000 sqft of exhibit hall, 40' high ceilings, two levels, megabucks spent on displays.
There are also some picturs of camping in the Sierra's and Death Valley at:
Death Valley
http://community.webshots.com/album/8462467uzEJwXMptJ
Snow Camping
http://community.webshots.com/album/1745543FgfioFuOtD
Mike L
oltroll you have 15k on the new truck already? It seems like you've only had it 6 months or less. You have been a busy boy.
To be fair regarding the wear issue, you need to mention that your camper is a popup and is therefore a light load for your HD truck.
My 99 1500 4x4 has 30,000 miles on it, 20,000 with the same 2000lb load (6440lbs loaded) and I have never rotated those tires either. Due to a couple of thousand miles of rough gravel roads in Alaska the tires look noticeably worn, more than 1/2 gone. But I expect to get another 10-15,000 out of them.
Love those Firestone Steeltex A/t's!
Mike L
Don't ever buy a front wheel drive.
Actually, some of the front wheel drive cars recommended not rotating tires. Seems the fronts needed to be replaced every 50K or so and the rears would last the life of the vehicle if they were not rotated.
Mike L
The Air Lift Ride Control (standard duty - 2500 lbs) is a little less expensive, much harder to install and requires 10psi minumum to protect the air bags. The Air Lift Super Duty (heavy duty - 5000 lbs) is much easier to install and requires 5 psi to protect the air bags.
Now that I have installed both, I would never do the standard duty kit again.
Whichever system you use, make sure you run individual air lines for each side. If you tie both bags to one air filler you will have problems when you go around corners. The outside air bag will see more load and will transfer air to the inside air bag which will increase the lean and increase the load on the outside and transfer more air to the inside, etc.
Two air lines, two filler ports is a much better idea.
Mike L
Mike L
The Hellwig bags are the Firestone bags, just relabeled. The AirLift brand is different, someone once said they are made by Goodyear but I don't know. Here are some sites.
http://www.airliftcompany.com/
http://www.firestoneindustrial.com/home.htm
My 1400# popup camper with supplies and my wife and myself push my 1500 Silverado over the Max Gross Vehicle Weight Rating. All told the load on the truck is over 2050#. And when I look at Chevy's camper rating on the truck, it is rated for a 1340# camper. And if we had a 1340# camper, we would be just under the MGVWR of 6400#.
And even with airbags and a rear sway bar, the handling was marginal. With a hardside camper having more weight up top, I don't think you will be happy with the handling at all.
I doubt that you can put 15-1600# camper on a 1500 without exceeding the truck's ratings. We moved the same camper to a 2500 and it has a 1200# margin to the limits. A Bigfoot 10.6 has a base weight of 2470#, 900# more than the 8.2. The 10.6 on a 2500 would have 300# more to play with than the 1500.
At any rate, don't trust a salesman. They want to make the sale. Double check the numbers yourself.
For short trips and intermittent use, a small used trailer might make more sense. Even a small trailer has more room inside than a big camper. And you don't have the hassle of loading and unloading the camper when you aren't using it. I see used 18-20' campers all the time for $5-10K.
Mike L
If you think your use may increase in the future, then think about the alternatives. Maybe a popup camper?
How you doing? It's cooling off out here. Down into the 40's at night and only the mid 60's in the day. Maybe a little cooler in Iowa.
You probably have your camper fully winterized by now. I'm sure my dad does, his last camping trip was late October. I've been trying to talk him into getting an Airstream. I thought the 19' would be perfect for him. He said it's too small (he needs his space) an is looking at the 26' model. This from a guy who has an 800 SqFt house. Go figure.
Has the new flying rules restricted your flying at all? I wondered how the rules would be enforced in an airport with no tower.
Later,
Mike L
While reviewing the last 750 posts I think vince installed electric jacks, if so is there a retro kit that replaces the standard jacks?
One last item on tires. For those of you with Firestone Steeltex I would consider changing to a different brand. I've had 2 blowouts on tires with about 15,000 miles on them. Not fun when your carring an 10.9 foot camper. Always run 80 psi, and not overloaded. You might want to look at the NHTSA web site for details and comments.
Thanks for you help.
Chat when I get back.
Loren
Checked with our people in Odessa this morn and they had 6" on the ground with another 6" expected -- Not to mention probable severe icing coming down on DFW. He said there wouldn't be an auto left by the end of today without bent fenders.
Mike - General Aviation was of course shut-down immediately after Sept. 11th. You may remember when we made our landing at MIW, I was being vectored by Waterloo radar approach control.
Even though we as most smaller town airports - certainly those without air carrier service - don't have on field FAA Controlers, all airspace above 700 feet is controlled. In other word (some exceptions) you inter FAA controled airspace at 700' above the ground. Now you don't have to be under direct control by Center as you can enter that air space VFR.
However the point is during the FAA Shut down of all Aviation anyone intering controled airspace and for that matter just taking off from any airport once they hit a radar screen DID RECIEVE F16 ESCORT TO THE NEAREST AIRPORT and they ment business.
Loren
I remember we were on radar control from Waterloo, but I thought that was by choice. So, what are the restrictions on flying now? Are you back to flying as you were, or must you file flight plans and be tracked on radar? Or, are you still shut down?
I don't remember the final resolution on your aux battery problem - maybe I was still on the road and missed your post. Hopefully, it is all resolved and working the way you think it should. I remember something about the option being put on hold and later being released, but haven't heard what changed in the operation of the factory aux battery setup. Do you know what the factory did?
Later,
Mike L
