Visitor Agreement.
Those two you mentioned above have unlimited funds right
I again say you have started a wave of posts in the new topic, maybe a new record? As long as we are talking about serious off roader SUV's in other countries, I have a little trivia for you guys, first correct response gets a ranger 4.0l torque curve courtesy of Vince! Remember the Nissan Jeep type SUV in the 60's? What was its name and who appeared in the ads for them? To give you a hint, this vehicle is still being produced overseas and is the choice for outback 4x4ing in australia. (Just a little semi-on topic break from stressing out)
On the military side the wheeled suspensions are going to independent on all wheels on all sizes of trucks.The solid ison the way out.True the Hummer is a heavier vehicle,but it is designed to traverse off road terrain at a medium speed and still offer a fairly stable platform.It has a tough suspension.In racing,you are right that they have the money to do the necessary things to beef up their suspensions.But,they do hold up at speed over terrain.
Here is a link to one of the early ones.
http://www.4wdonline.com/Nissan/Patrol/1958.html
I have no idea on the person who was in the commercial.I guess it would depend on which country we were talking about.
As far as the soccer moms, the manufacturers sell image and the buying market wants the SUV look. The manufacturers are just meeting the market demand. Their big problem is trying to please all the buying, government and oversight groups at the same time. As far as the Escape or whatever not being a offroad thriller, it was not designed for that. If you look at it as a replacement for the station wagon of the 60s or the minvan of the 80s, it performs adequately. It has plenty of pep, can haul four people comfortably and can even haul a trailer under 3500 lbs.
As for the debate, a solid axle is preferred if you are rock climbing, running the Rubicon, or just plain running through the rough stuff for a number of reasons. Independent suspensions works well for high speed races (Baha anyone?)
1. The distance between the bottom of the diff and the ground is fixed by the height of the tires, i.e. you always know what it is. Swing arms allow that distance to vary and under full compression, the distance between the ground and the diff (or oil pan) can be dangerously small.
2. You can get a tremendous amount of wheel travel and axle articulation with solid axles. Very important for boulder hopping.
3. Solid axles are very strong. Less likely to bend or break under extreme duty. Swing arms can be very strong too, but at an extreme price.
What makes a vehicle excel on road makes it weak off. What makes one excel off road, hurts on road performance.
Just a couple of other observations. Unit body construction is more rigid that body on frame coonstruction. "Open air" diff? Never heard of one. Looked under a CR-V before and it's rear diff in in an aluminum housing. Looks like the ones Soob uses on it's rears.
They'll be able to help with correcting your speedo gearing or at least point you in the right direction.
It sounds like you might have a bad U-Joint.
Did you change the rear end when you swapped in those tires? That seems like quite a big change on the end ratio to the ground.
If you want to see axles on a military vehicle that will last forever, look at a Duece and a half truck.
Where can I get a set of those? I think since Rancho or Trailmaster doesn't make a lift kit for the Frontier, I'll just go all the way!
If I was going with that big of a swap, I'd use at the very least 3.73s or preferably 4.10s. You've got 3.55s in there now, right?
I could see the computer having some issues if the gearing is too tall and the engine doesn't have enough grunt to compensate.
If u want to be serious about 4wheeling though, u need to do a solid axle swap. Solid axle's are much stronger and more durable then an IFS. Take five minutes to look in a 4x4 magazine and 90% of the vehicles u see rock crawling will have solid axles.
Hey, by the way, just to start another topic, has anyone seen the latest issue of 4wheel & Offroad. They classified the s-10 as one of the biggest turds in 4wd. This is what they said "speaking of turds, are these even real 4x4's? We started naming horible components and found that we had just about built a complete s-10." I personally like s-10's, but does anyone else feel like them??? They also mentioned the GM torsion bar IFS as another monster turd. Proof that torsion bar ifs's suck.
See http://www.4wdonline.com/News/News.1997.html and scroll down to 8 October for a short story.
Gooba, Hummer's are all terrain vehicles, but as I said before, the fully independant suspension it rides on is in no way similar to the IFS on your or my truck. That technology comes at a high price. Even then, It still isn't the best system for every terrain it may encounter. All terrain means some compromises had to be made.
A purpose built vehicle will do better on the terrain it's built for. Would you want to drive across Antarctica in a Hummer or a Heavily modified Landcruiser?
Look our, Ranger owners. Hopefully this atrocity will not spread to other trucks in the Ford lineup.
the experts. "
YOu are so right.
" The Toyota Tacoma TRD handled the rough stuff better than any vehicle we have driven"
--FourWheeler
Allen-
One other question.Are you and vince somehow related?
And why don't you tell everyone here what the 0=60 times are for your 3.3 Supercharged bandaid? How about 9.5-9.9!! LOL... Why can't Nissan make a naturally aspirated engine to compete with Ford/GM/Toyota? Can you imagine a Supercharged SOHC 4.0 in a RAnger?? it would absolutely trounce your weak 3.3 Supercharged! LOL....
Spoog, i agree, from the factory, a tacoma handles a bit better then the others, but a TTB ranger can easily wup a tacoma for about $400.
Fact is, there's no such thing as a good 4x4 from a factory, unless yur buying a hummer. All vehicles, except the hummer, need modifications. Ranger's just need less modifications then a tacoma. IF u really want a good truck, u gotta mix and match parts. The only thing worth beans in the pre-tacoma toyota's was their solid axle. So, find a older toyota, and steal the axles. Then, get a strong frame and body. You cant get much tougher then a '84 style ranger. Swap the axles onto the ranger. Then, get something to move it. Either the new SOHC 4.0 from the coming rangers, or the 4.3l GM will be fine. Or if your really serious about compact truck power, get a 5.9l v8 from a dakota. That combination, in my opinion, would make a killer 4x4. Feel free to differ.
Gooba, you are so lame! I really must have pissed
you off when I showed you just how weak, cheap and
where the Frontier stood in the compact truck food
chain, at the bottom! LOL... Also, a solid diff is
better, ask any offroad shop. Just goes to prove
once again, you don't offroad. When the Ranger
switched in 97 there was quite a controversy.
Once again, Bad Vince, for being happy with your
Ranger...
Good gooba, cncman, mahi, for liking your Nissan.
Same old story, never ends, Ford bad, Nissan good.
I just pissed you guys off showing you why the
Ranger is NUMERO UNO, number one for those of you
who don't speak two languages..
Live with your choice and don't challange any 4.0
5spd Rangers with those weak 3.3's. And another
word of advise, Really, don't challange any new
SOHC 4.0 Rangers... LOL@!!
Mahi, your kidding yourself along with anyone who
knows about towing. A 4,000 lb boat with a truck
that has 170HP and 200ft/lbs of torque! LOL! Nice
story. Anyone can do the math, the two don't add
up. Add your truck weight, people weight, gear
weight...Yes, it may be able to barely pull it, but
not as you wish or dream......
"laughing" how about grunting.... LOL!!!!
Ok, you Nissan whiners, just face it you bought
the compact truck lowest on the food chain!! LOL!
Enjoy your weak 3.3 and 2.4's. Ford has 3
engines, but I guess you don't want to mention that
huh? Nor do you want to mention a 3.0 is only
about 300 dollars more than a 2.5, Nor will you
then mention a 3.0 has 150HP and 192f/lbs of
torque, is available in ANY Ford RAnger, Along with
its 4.0 is Available in ANY Ford RAnger..
Rangers rule! The Frontier doesn't even make the
top 30!! LOL as far as sales numbers.. Nor has ANY
Nissan truck even broke the top 25 mark in sales,
Why Cncman? If the Nissan is so superior why after
over 15 years hasn't Nissan taken the number one
spot in sales? Sales do matter as much as all of
you want to try to say they don't. Sales make
money! Something Nissan hasn't done for years!
LOL...
Yes, I smoked one of your precious 4 door high
tech 3.3 Frontiers with my older pushrod 4.0!
See you in the Cascades
Oh, I don't see Frontiers up there, they can't
make it!! LOL....
Anybody see a pattern?
easily wup a tacoma for about $400. "
Lol! Sure pal...keep dreaming. First of all, the Ranger comes with a highway suspension....its gonna cost you more than 400$ to get rid of that!
Source:
Ford's new compact frontend uses F-150-style short- and long-arm IFS, with torsion bars. The setup offers big gains on pavement--but not without trail sacrifices.
Toyota's double A-arm/coilover frontend handles pavement cornering and trail flex with equal skill. We like the six-lug axles and big-caliper front discs. "
-Four Wheeler.com
Guitar Dude, I don't know why you don't understand this:
Ford does NOT make good 4x4's. They don't bother including it in their overall design philosophy of their trucks, PERIOD. They always have the lowest ground clearance, have more highway geared suspensions, and quite simply, aren't built well enough for continued offroad use.
I WILL agree that the Ranger and Bronco were much better stock offroaders pre-94.
" The Ranger rattled like a Diamondback offroad"
--Edmunds.com
" The Ford Expedition squeaked and rattled offroad, having trouble with terrain the Landcruiser didn't even blink over. In our test, the Expedition was voted most likely to break. In fact, we would like to see Ford start building trucks with more durable materials and more emphasis on doing one thing well instead of attempting to be jacks of all trades, and doing none particularly well"
-Edmunds.com
"Fact is, there's no such thing as a good 4x4 from
a factory, unless yur buying a hummer. "
Wrong. The Jeep Wrangler and Toyota Tacoma TRD are solid factory 4x4's. They will soundly TROUNCE anything else under 30k.
\\All
tacoma.\\
Sure dude!!! BWAHAHAHAHAHAHAA!!!!
Ranger comes with a highway suspension, low ground clearance, no skid plates, no gas tank plate, no clutch start cancel switch, NO LEVER MOUNTED T-case, NO NEUTRAL Position, NO LOCKER< crappy shocks, BAD gearing, a history of defects, soft steering, an engine known for sucking water, and a well documented history of poor build quality, especially when used offroad.
The Ranger is a fine, fine vehicle for work, forest roads, and town. But it is no offroader.
And the Explorer? lol! Anyone , ANYONE knows the explorer is easily the WORST SUV offroad, PERIOD.
YOu can slap all the crap on it you want, but the basic design of it is STILL totally lacking for offroad use!
Spoog, lies, lies, lies.. We have gone over these issues over and over again in the Ranger vs Toyota Room. Ranger does come with skidplates, Ranger does have a limited slip too.. The TRD has a useless locker.. Can only engage it in 4low and at under 5mph per the manual, and when not engaged its an OPEN Axle, pretty expensive option you may use about 3% of your total driving time. The rest of your TRD is Bilsteins and springs.. You got taken bud.. Enjoy that sticker..
Here we go! Someone totally new enters the board
and the Nissan crew jumps all over them. Truth
hurts huh boys! LOL!! The Frontier is whimpy!
Your kidding yourself with the 4K tow, you making
me laugh along with anyone else who tows... Do the
math yourself.... 170HP 200ft/lbs of torque
4K boat + people + gear + trailer... would make it
closer to 5K total... 200ft/lbs doesn't pull 5K
lbs easily my friend, nice try though.....
Gooba, you whine too much..
Don't start getting down on me for the backlash
you guys started! Between the 4 of you all I heard
from the start is Ford bad, Ford garbage, Ford
junk crap. I just showed you different and you
guys didn't like it.
And about the 3.0 option.. WRONG once again.. Its
about a 300 dollar upgrade.. Yes, I will give you
that the 2.4 will whip up on a 2.5... But Nissan
only offers 2 engines, Ford 3..... If you look at
the stats of the 2.5 vs the 3.0 MPG is only about a
1 to 2 MPG difference...
Gooba, nice paste.. you have no life? Frontier in
the shop? YOu have proved to one other person you
know NOTHING about offroading.. Your lame bud..Now
enjoy your bottom of the food chain Frontier..LOL!
Lockers don't help you in icy or snowy conditions.
You want a limited slip diff. Lockers are more
for straight away acceleration and not good for
corners or turning. A limited slip has a clutch
mechanism where one wheel slips and causes the
clutch to engage the other tire. Locker is when
both wheels spin at the same rpm at the same time
constantly. Lockers are usually found on the folks
who do some serious rock climbing or snorkling or
serious offroading. Stats show that over 90% of
4x4's don't even see gravel! I think for you a
locker would be way over kill..
Pattern continues.
I read a little article in YOUR bible(Truck Trend) and it praised the 2001 Frontier. I see your truck must be out of the shop this weekend!!! Have you done any more mods to get it up to par with the competition? Uhhh you still need to increase your exhust flow...since you increased your intake, you haven't accomplished anythig yet. Have you relocated the rear shock mounts...you know like the Nissan and Toyotas. How about that frame? Still C-frame? I thought so...come back when you get a real truck. Sorry you have such a horrible platform to start from...hehehehe
