War of the Compacts:Frontier, Ranger, Tacoma, S10, Dakota, B-Series, & Hombre - II
Any Land Rover will be great. Same with Jeeps. Toyotas offer (IMO) the best compromise between offroading and opn-road manners.
Anything on four wheels can be made into a offroad vehicle. We had a guy stick a Lincoln on a F250 4x4 chassis. When people get into more extreme endeavors, there is always something just a little bit out of reach that can be attained by buying one more item. At least that is the argument I use on my wife when I want new ski gear.
The old Jeep CJ's were awesome, both the 5 and the 7. As a kid growing up I had a friend that had an old CJ-7 and also a Comanche Truck and they were both awesome off roaders. We beat them to all get out, but they still got us through the rough stuff.
No, its not the best looking suv out there, nor is it the most economical. However, it gets me anywhere I need or want to go, fairly comfortably.
Its just SCARY looking! I don't have to worry about people cutting me off, or weaving in & out of traffic in front of me! It is a TRUE sport utility vehicle!
Thats the view from here!
keith24
I would not buy any of the new torsion bar IFS fords for off-road use. And i still hold that there aren't any 4x4's that can go anywhere in stock condition except for the hummer. In fact, the only true 4x4 (solid axle, manual hubs) still being manufactured in the us is the ford F-250/350. Jeeps naturally kick butt, but wranglers have this cheesy little setup called "center axle disconnect". The same failure-prone setup used on kick-butt dodges. They use vacum, which is not something u want on your 4x4. Also, pre-'95 explorers are just as easy to modify as rangers and make excellent 4x4's with little mods. None of these 4x4's, though, will ever compete with willy's, cj's, and early bronco's. Facts are Facts.
I just wanted to get yur attention. I sarted a 'posting' site at driveway.com I purchased the November issue of Truckin'. They have a cool article about a factory shootout between trucks like the Quad Cab Dakota, S-10, Lightning, Frontier and some others. Sorry Toyota and Ranger guys, they didn't test these...not really sure why? Th TRD supercharged 4Runner wasn't available at testing but I'm not sure why they didn't at least test a Splash. Anyway the article makes for some good reading, check it out. Just go to: http://www.driveway.com/web/catalogView.jsp
If that doesn't work go to: www.driveway.com Our member name(username) is: compactwarspace
password is: pickups
Then just double click on the folders. I saved them in med. jpeg quality so it would d/l faster.
Oh btw, I scanned the separate articles on each of the test vehicles, it gives a little more detail of each of the rides...ENJOY!!!
On a serious note. I had conversation today with 3 different people about a product called Zmax. Anyone heard of it? All three of these guys own 4x4's of various types/models. Each claimed this product actually worked. Helped MPG, engine became smoother, acceleration better. So, I picked it up for 40 bucks at the car parts store. I put it in my 4.0 and there was a noticeable calm to the engine. Now, I'll be the first to admit the 4.0 is not known for its smooth running features. (I know I am going to hear bashing from goob, mah, cncman and the normal guys for admitting a fault with the Ranger).. may want to check this product out.. I am logging mileage and keeping records to see if my MPG increases..
See you in the Cascades, fall is arriving here in Oregon and the Mountains are beautiful this time of year..
Of course, the smoother running engine, better acceleration claims are another thing altogether. I also saw a paid advertisement for Zmax that claimed that carbon build-up would be reduced significantly. It probably can't hurt to try it!
ZMAX is an OIL additive, not a GASOLINE additive. Check out their web site for details:
http://www.gozmax.com/
**DuraLube dealt a crippling blow.
The manufacturers of the DuraLube engine additive have also been dealt a smack in the face by a Car & Driver Magazine report into their product. C&D tried the same tests as Consumer Reports did on ProLong, and had similar results, but in a much quicker time. The C&D engines lasted a staggering 11 seconds without oil. You do the math. The Federal Commission has been handed the details and are 'processing' it.
Ford loses records of Explorer tests,
says trials were not on actual SUVs
By Joseph B. White
THE WALL STREET JOURNAL
DETROIT, Sept. 20 — Ford Motor Co. cannot find original records of key 1989 tests of Firestone tires used on Explorer sport-utility vehicles, company officials said in a news conference Wednesday.
FORD ALSO REVEALED that the tests were conducted using a modified Ford F-150 pickup truck designed to mimic the load distribution and performance of a Ford Explorer, not an actual Explorer. Ford spokesmen Jason Vines and Ken Zino said such testing was common practice.
Ford has submitted an affidavit from a retired engineer that tests of the Firestone tires designed for the Explorer were done in 1989, using tires inflated to 26 pounds per square inch. That’s the pressure Ford recommended for the Explorer. Bridgestone/Firestone Inc. officials have since said they recommended the tires be inflated to 30 psi.
Rep. Billy Tauzin (R., La.) and his aides have questioned the adequacy of Ford’s testing of the Firestone tires used on the Explorer. The Ford spokesmen said data they have submitted shows the auto maker conducted extensive testing.
Advertisement
Hope to see you someday in the Cascades!!.........
tacoma_trd mentioned above about seeing too many S-10's fail. I'm not boasting about GM here, but my own personal experience with my 1991 S-10 4x4 was great. I had 160K on it before I unloaded it. I read for years about all the horror stories and braced myself for some hefty Visa bills, but other than regular stuff like the alternator and starter both going around 100K, I never had any trouble with it. Towards the end, it did develop the classic "puff of blue smoke" upon start up that sems to have plagued most S-10's in the 1990's. Then, it was totaled when a guy in a brand new Mercedes ran a light and plowed into me. The damage actually wasn't all that bad, but since the truck was almost 10 years old, my ins company decided to just total it. The Merc was nothing but a twisted piece of metal though.
I'll admit that I did shy away from another one when I got a new truck based on reading all the horror stories. Plus, after 9 years I was ready for something different. Various experiences with other brands and a zillion little subjective things made me end up with the 00 Frontier which I love so far.
So, now we have tires that were never tested on an actual Explorer or Ranger, and now Ford is balking and changing the recommended tire PSI.
Tsk Tsk.
By the way, the Dodge Dakota pickup scored significantly less than the Tacoma in crash tests from 97-99.
Do you do work with your f350, or do you just commute with it?
Spoog check with the NHTSA site again on frontal and side crash data unless you are using information from another source and if you are I'd be interested in that source of data.Dodge Dakota Extended cab rates 5 stars on side impact and 4 stars in frontal crash data from the years 97 to 00.Five stars is best one star is,well,not good for those of you out there that are not familiar with the NHTSA site. www.NHTSA.dot.gov
Dodge Dakota 5-star side impact.
Allen-
What do you think of the looks of the 01 honestly?
I saw one driving by the ford dealer saturday, it looks so plain to me, I know they try to make it look like the big ford trucks, but I think that was a mistake, they shouldn't look that industrial. Maybe the delay on the 5speeds is the same reason for the delay on them in the sport trac? Have they put the manual tranny in the ST yet?
they once were a decent manufacturer but not for
the past couple decades."
So are you saying Ford has konwingly contracted out to an inferior company for years to provide safe tires for it's customers?
lol. Try not to paint yourself into a corner the next time you post.......
Hopefully, Ford has learned from its recent troubles with the Focus and Escape not to release the vehicles before all preproduction glitches are worked out.
I personally like the looks of the new Ranger, especially the Edge. It goes towards the agressive truck look that Rangers used to have back before the poor '93 styling (which was resolved/improved in '98).
You don't think that '01 Frontiers look just as or even more "industrial" than the '01 Rangers?
They're more likely to break your arm than save your life if they aren't the curtain style of airbag, which doesn't deploy directly at the occupant.
I dislike airbags in most vehicles. They're more likely to injure you than save your life.
I've heard of actual decapitations happening to young children in fender benders from airbags deploying.
Who knows, though. We've been hearing the same thing about the Adrenalin for over a year now.
