I'm looking into buying a small travel trailer and anticipate towing 4,000 pounds cross country in search of the world's largest ball of twine (after I find the largest frying pan). Anybody out there have any real world gas mileage figures while towing with your Ridgeline? Thank you very much.
I know. I've been warned also.
This is their board, and their rules. They pay for this board, it costs us nothing.
I abide by their rules now. I will only tell people to 'google' their question, and follow the results to obtain other information areas.
Some of the message areas on the board are excellent. Some are weak. Look for the gold among the chaff.
And overall, Edmunds is an excellent internet site.
And, I am not 'moderating', so I hope the hosts will not delete my post. I'm just giving my opinion, as someone that has been reading the forums for many years. And, has gotten some warnings from the host for my posts.
Anyway, it looks like one of the few things Honda does not know about is how to keep dust out of a Ridgeline.
If your dealer has an opinion and/or a solution, please post it here.
i doubt very much if the A/C system has a pollen filter, that the dust is getting past that.
I don't know where it comes in. The entire interior was covered in dust, so I think it came in around ALL the doors!
Anyone else hear about issues like this? Am I just incredibly unlucky and the cracks were caused by a rock hit I could not see?
Love the truck other than that (and I hope the gas mileage improves as I drive it more). :shades:
Your strut assembly diagnosis was right on ! Got it fixed.
Makes ya wonder when a "Service Manager" indicates that the thunking noise is attributable to something floating around in the gas tank!
Many thanks to you...
Jim
Happy Holidays.
Lew
I expected more from Honda. The amount of rattles in this truck are more than any car or truck I have owned.
If this was made by Ford or Chevy it would be panned, because it is a Honda product owners seem to make excuses rather than complain.
All vehicles have some issues but my expectations were higher for this Honda than my other vehicles
Frank
My 2006 with 16,000 miles has developed it's first rattle (except see below) somewhere on the right passenger side. Overall I'm happy with it.
Ridgelines, at least those of my model, are known to have a bad rattle from the small radio speaker grills in the dash top. This can be easily checked by just reaching up and holding the grill as you drive. If the rattle stops, this where is't coming from. It can also easily be fixed. Push the grill toward the front and pull the rear edge up. The grill, with the speaker attached, comes out. Put some kind of padding around the small clips on all 4 corners. The design has made these fit too loosely in their opening, and the grill/speaker will rattle. I used the small round fabric and adhesive backed pads sold to put on vases, etc to stop scratches on furniture. I cut one of these in half and put a piece on each of the clips and put the speaker back in. Stopped this rattle.
Sorry for all the following detail, but I am sure there are a few people that would like to see what I went through to fix it - especially if their problem looks similar.
My RL is a 2007 and I noticed four weeks ago that I had wet carpets on the passenger side front and a little less wet on the passenger side rear. I was getting pools of water in the front right side of the carpet. I sucked it up with a wet vac cleaner and left it a little less wet. Did the same with the back. Went off to Vegas for a week (not in truck), came back to find pools of water again in the front passenger side. I was hesistant to take it to my dealer as I don't particularly like them and their way of doing business.
So a buddy came over and we took a longh look at it and tried to prove the problem via logic. The truck was facing downhill and slanted to the right - thus all the water on the right side and mostly at the front. However, the rear was very much less wet than the front. I reckon the leak was at the back and running to the front, hence the pooling at the front and not at the back. We looked in the truck bed and saw water standing in the right front corner as it always has done and also in my Tundra for the past 7 years. So I didn't think that was a problem. But as there was a front panel to the truck bed, I decided to take it off and look behind it. Took a bit of getting off but as soon as it was off we found the problem.
For those of you who have not taken that panel off, behind it are two vent type housings with rubber flaps designed to close under pressure from water and/or air. But the right one was soaking wet. Aha, I thought to myself...and looking further I saw a faint water line from some loose debris - this waterline was ABOVE the lower part of the vent. It looked very much like the water had RISEN up behind the panel and seeped into the vent housing. Then rotted part of the sound-proofing insulation, and run down under the carpet in the back and down through to the front to collect in a pool.
Why was it not draining away though? There was no obvious reason, but I did notice that Honda have a series of drain holes along the front of the bottom of the panel lip but nothing at all at the sides and corners. Does Honda believe that everyone parks straight, level and flat all the time?
So, I drilled a series of holes and extended them from the standard holes round the corners. This should now let water out no matter where it is. I threw a bottle of water down the offending corner and there was not much drainage there. I reverted to an air line and rammed that pretty much everywhere I could see. Out came a lot of debris - stuff like general dirt, but more importantly, a ton of pine needles which had been blocking the travel and exit path of the water in the truck bed. I threw another bottle of water in there and it came out very quickly and drainage was back to normal.
Everything went back together OK and took about 2 hours in total. However, the panel did a good job of scratching the truck bed.
So far after a few nights rain, no further leaking or collecting of water. But it does need some time to dry out properly before I can truly say I fixed it. I am pretty sure I did though.
Greetings from Mount Rainier Country.
Britmark
Ken
Wild, wild guess would be something in the transmission.
Does the 'D' display, the little light that indicates your are in drive 'flash' when you are driving? On many Hondas, if the D flashes, the computer is indicating there is a transmission problem.
Thank you for your replies,
Ken
Not being able to pull 'recent' codes is BS. Codes are stored in 'history' until several start/stop cycles have passed. Some codes will stay in history for long periods.
Ready to leave and go home....oh, oh...truck would not start, acted like a dead battery, checked all connections under hood, ok, no corrosion, battery water ok, no indications that it should be dead. Called Honda dealership, said it was probably the immobilizer. Per the manual it acted like the symptoms there too.
Would not start and finally went dead, lost nav and FX radio codes...etc. Son in law insisted on giving me a jump, hooked up for just a sec, it started like nothing was wrong and started later last night and this morning...no indication of dead/weak battery. Anyone else have this happen to them or similiar situation.
Otto
My question is, do anyone know how to get the assembly apart to just replace the glass?
wwest abolition hesitation -dfg
For all you might ever want to know about the re-acceleration downshift delay in these newer, post 1998, FWD and F/awd transaxles.
Ford has a breakthrough solution in that they have adopted a variable displacement ATF oil pump for the Edge while everyone else seems to be stuck trying to get drivers to adapt to their "future intent" detection technique.
Release, Fully Release, the gas pedal FAST/QUICKLY/RAPIDLY and the engine/transaxle ECU control firmware will "judge" (assume..??) that your intent is to slow using engine compression braking and thereby remain in the lower gear you were just using for acceleration, low to MODERATE acceleration. On the other hand ease up on the gas pedal slowly and the ECU will command an upshift.
Once that upshift is (inadvertently) commanded it MUST be completed before a downshift can be commanded and now with the engine idling and the new HIGHLY EFFICIENT ATF real time line pressure control system there will not be enough fluid pressure in reserve to complete a second sequential gear shift/change.
So DBW is used to delay the onset of rising engine torque until the required downshift can be completed.
1-2 second downshift delays are being reported as typical.
Are you trying to warranty this?
If so, what Honda says is what you are interested in.
Otherwise, you should be interested in what your insurance says.
Or, there are links on the front anti-sway bars to also cause problems. I'm not sure if these are also on the rear.
A good alignment/suspension shop should be able to quickly find the source of a noise like this.
Putting gas in one day I noticed that there is RUST in the lower seam of the compartment where the inner metal boot that the gas tank fill tube is in meets the outer body. Now this is a seam where two metals over lap one another, I would think welded together I don't know.
I took it to the body shop for some answers and they said to do it properly the whole quarter panel would need to be replaced because of the thin metal used in the body. At the same time they asked if I had taken it to the Honda dealer....DUR I felt like a total dip. So my next stop was the dealer pulled into service was greeted by one of the service manager's and showed him the situation nicely. Just so happens there was a Honda reagonal rep there so he came out to look took pictures then returned to the office. The service mgr came back to inform me that honda will fix the problem probably by grinding it down and painting it. This might look good now but what are the chances of it returning again, and if it does what would be my options then.
So I have two questions:
1. Is grinding the way to go? Or try to push for proper panel replacement.
2. Should Honda loan me a loaner car to get to work and back?
This my transportation truck to work and after all it's not my fault the truck started rusting. I don't know I'm just a man of principle I guess.
