You post a lot here and from the problems you had with your Honda, I don't blame you for having a sour view on them. :sick:
As I've mentioned before, I'm just trying to add a little balance as my experiences with my Honda have been quite positive.
The Odyssey had about 33,000 miles on it at the time of travel.
We had a 2000 Odyssey (3.5L 210hp that wanted premium). It delivered below city mileage (17 or so) but could get 26 MPG at 75MPH on the highway with little effort. My Accord, on the other hand, can beat EPA highway numbers by as much as 6MPG when I'm going 70-75MPH, so I think the Odyssey has more MPG issues than most Hondas based on our experience.
I'm not trying to challenge anyone, just reporting experiences within my family. Not overachieving like some of our other Hondas can do, but not terrible like some people seem to have either.
Proper air pressure to spec., electronic guage is best accurate.
Heavy vs light foot, on gas pedal.
Gradual acceleration, earlier off the gas pedal before the red light.
10% Ethanol added on gas or not. Some say the Ethanol add-on reduces MPG.
Motor Oil/Oil Filter/Air Filter condition - are they fresh right after service or already there for 4,900 miles.
Season of year - winter time warm up the engine reduces MPG
Traffic Jam - sitting on traffic with lots of idling reduces MPG.
I also think more braking means less MPG.
A/C seems to also make the big difference, fuel type not so much. So I'm pleased with the mpg, they certainly could do better though. Seems the market demands power though, and the capability to tow 3500lb might come in handy..
So Consumer Reports got 12mpg? I really don't look to that mag for Car information, stick with Edmunds. Their user feedback is useful though (electrical, tranny, etc)
If this system is malfunctioning and is applying some braking it would drastically affect MPG. If you have abnormally fast brake pad wear and very poor MPG this could be something to look at.
VSC can be turned off and if you run 2-3 tanks of gas tru it and your MPG improves a lot, you've found it.
This is only a theory, so don't beat me up too much.
We too a trip to Ontario, CA over the Labor Day weekend. Our EX-L was 2 weeks old and not broken in yet on the way there. We took it easy.
But on the way back, we crossed the border in Buffalo, NY and drove to Chicago, IL overnight.
With the Cruise Control ON, driving somewhere between 65~75 MPH for the most part (sometimes even more), we did average almost 27 MPG.
Don’t know what our tire pressure was, etc. The only thing I know, I’m always buying Premium gas and Cruise Control was ON for 95% of the time.
I always buy Premium on a long trip, engine runs a hair quieter and ads more kick to it.
Van was loaded, 2 adults and 3 children on board with all the works . .
You'd really do yourself a favor by saving the money and using regular.
My ice cream all around with the money you save!
I will say the only time I got decent mileage was when I travelled outside of Oklahoma, which was the only time I got 25 on highway, every other measurement was the 17.
In theory you’re right. In practice, that’s a different story.
Let me tell you something from my own experience. I used to own ’99 Olds Silhouette and I loved that minivan. Around 25,000 miles on the odometer, the minivan started to misfire, didn’t matter if it was from the cold start or in the middle of the drive, like stopping at the stop lights.
Idle or low RPM was triggering that.
Couldn’t get rid of it. Several trips to my friend’s shop reassured me that there must be a serious problem, like bad injectors, head gasket or the intake manifold gasket.
You’re talking major $$$ to fix. But since no one was sure what the problem was, he just put in a bottle of a really good fuel injector cleaner in the gas tank to see what develops.
The van was running great! So I’m thinking, why not try the Shell V-Power gas, as advertised HERE::
It was running fine, so I’m thinking to my self – let’s try Shell Regular gas. Once again, it turned out to be just fine.
OK, so I had dirty injectors, they got cleaned & everything is fine, right? Wrong!
The only Reg. gasoline I could drive on without hiccups or misfire was Shell Regular. All I had to do is fill up anywhere else, the problem returned almost instantly.
We put 30,000 miles more since then on the van without fixing anything.
And always, regardless what car I’m driving on the Expressway, I can hear the engine running differently on the high speed drive. Maybe because the Regular quality is below the specs, or somehow more water gets mixed with it, or ?????
PS. Absolutely no need to prove me right or wrong, this is just my own experience. And my Olds with 3.3L(?) engine did average around 25 MPG driving down to Florida, doing 75~85 MPH most the way at night, mostly NOT using Cruise Control and running on Premium.... .
I'm not looking to do so. What works for you in your area, works! Maybe the gas in your area is formulated differently than in my area.
Personally, I always use Chevron regular because it has the detergents in the lowest grade of gas, not limited to the premium grade. Maybe that would help?
We have purchased gas in CA, UT, NV, with no change in MPG for our Ody. Best ever hwy was 19.9 on a 2k mile round trip, loaded with 4 small kids (all between 2 and 7 yrs), and probably 150 lbs of luggage. It's a plausible theory, but where we bought gas did not affect our mileage in our case. Our previous best was about 18, with about 80% hwy on local roads.
I've taken several long roadtrips in the van now (it's currently got 5500 miles) and have observed the following:
1) MPG reported by the computers is within about 2% of what I calculate by dividing odometer mileage by gallons of fuel for each fill up. So I feel pretty confident that it's not a matter of the computer reporting bad mileage ... the van is just really, really thirsty.
2) Turning off VSA does nothing for my mileage. I didn't suspect that it would, but at least that would have given me something to hang my hat on. I turned it off for an entire tank and saw no measurable improvement in mileage.
3) Turning off a/c made about a 4.5% difference in mileage. Nothing to write home about and not unexpected at all.
4) Tire pressure is 33 front / 35 rear as spec'ed.
My latest road trip (yesterday) was about 100 miles each way and I noticed some interesting behavior. I reset the trip odometer once i was at speed, cruise control set at 65 on a level stretch of highway. This time, I decided to watch the instant fuel economy to try to watch for any anomalies and I found something interesting. On a level stretch of highway, with A/C off, the van will stay in 'eco' mode for a LONG time. It gets ~25-27mpg this way but about 15% of the time, the instantaneous mileage will drop to just over 10mpg and stay that way for 20-30 seconds at a time. During this time, the 'eco' light stays on as if the van is being tremendously efficient.
At first, I thought I had accidentally left some accessory on, but double checked no a/c, no radio, no defroster, no dvd, no heated seats, no vsa ... nothing on. I then suspected that perhaps cruise control was giving it more gas to maintain speed due to a hill i didn't notice. So, I turned off cruise and with a _very_ light foot did what was necessary to maintain 65mph. The same thing happened. I noticed that if I hit the gas when I see the instant economy drop, the engine drops out of 'eco' mode and the mileage jumps up to about 20mpg. Letting the foot back off the gas drops the engine back into 'eco' mode and mileage goes back to 25-27. Doing this the entire way home I was able to average 24.5 mpg over about 100 miles. That's Almost 4.5mpg better than I've ever managed before. But it took a LOT of effort on my part to get that.
So, it appears that something is going on when the van's been in eco mode for a while to tank the mileage. The effect is very reproducible and I'll be showing my dealer. I'd like to know if anyone else sees this same effect. Anybody up for running an experiment?
Otherwise, I'll just put on my tinfoil hat and head in to argue with the dealer
I have honda ode ex ,has 2000miles sofar in town and highway (50/50) i get 18 and
i have seen 14-15 when i was using city only that is so bad for economy i am waiting for hybrid toyota seinna but not until 2009?
hp
I believe that is incorrect. The ECO light comes on whenever you are in Economy mode, which expressly means that the VCM is active, therefore fuel demand is reduced and economy increased. The ECO light is only on VCM equipped models because it indicates when VCM is saving fuel.
On extended trips the van has the following mileages:
395 miles 25.99mpg
403 miles 25.70mpg
233 miles 27.64mpg
392 miles 26.42mpg
432 miles 25.71mpg
376 miles 25.07mpg
414 miles 24.78mpg
393 miles 26.06mpg
403 miles 26.69 mpg
403 miles 26.92 mpg
These trips were all on I-90 in Washington State at about 70-75 mpg and driving through the Cascade mountain Range.
The only way that I could see getting 18 mpg at a steady 75 mph is if the vehicle was left in the third gear setting! The engine is smooth enough that you may not notice that.
This was not an easy conclusion as I have been told at the dealership that Honda breaks in their engines before they put them in their cars. Well, two months later and about 4K miles more, the same reliable milage (250 mi / 17 gal = 14.7 mi/gal) is the norm for mostly suburban driving without any stop-n-go traffic. Granted there is some elevation difference in my 7 mile commute to work.
Now, to the variability amongst the multitude of owners. I wonder if someone can comment on the fact that the Odyssey has fly-by-wire control (I am talking about the accelerator pedal here) . This means that even if ones holds the acceleration level indicator steady, thus doing the easy driving, the electronic brains could very well be stepping on the gas pedal to the beat of the song playing on the radio.
I have noticed that my Odessey has a tendency to remain in the lower gear and causing extra noise in the cabin coming mostly from the exhaust system when the engine is in low RPMs climbing some low grade hill. Is it possible that these low RPM are not es efficient for the engine and the milage suffers?
I'd be VERY interested to know your previous vehicle and what mileage you acheived in the same conditions as your Odyssey.
I can't try it as all 4 of my ODYs have gotten close to EPA numbers.
On city, I'm reliably getting 15 MPG with only the driver (me) in the van. The van had 1500 miles on it before the trip. I know the gas mileage of Ody is bad but I expect more than that. Is there something wrong with my van? :confuse:
THE 2007 HANDLES NICE, BUT I HAVE LEARNED TO LIVE WITH THE WIND NOISE FROM THE REAR WINDOWS,THE "HOLD-BACK" DOWNSHIFTING WHEN I MOVE BETWEEN THE ACCELERATOR AND THE BRAKE!, AND OF COURSE HAVING TO VISIT A GAS STATION ALMOST EVERY TIME WE GO OUT!
I HAVE ONLY **4,800** MILES (NOT A MIS-PRINT)! ON THE VEHICLE SINCE I DROVE OFF THE LOT IN MID-MAY 2007...AND I HAVE PROBABLY LAID OUT AT LEAST 150.00 A MONTH FOR GAS!---UN-ACCEPTABLE...RIDICULOUS...EMBARASSING..!!!!
I know how to calcualte mileage, I dont accelerate at green light, so I expect my figures to atleast match EPA figures.
Other problem (or pecularity) I experienced (compared to Camry) is that odysey feels like it is running in higher gear between 30 -50 mpg and engine sounds laggard in that speed range. I also ocassionaly noticed slight jerk on braking. Any of these is norm ?
Overall I am very happy with the van but if the mileage wont improve over time I would be very disappointed.
