Cheers,
Tess
LoL! Outside of physics or engineering classes I think few people give much consideration to things like thermodynamic efficiency and fundamental limitations so I like to reinforce the point whenever the opportunity arises.
Thanks for the additional reinforcement and ideas!
SUVs and Smart Shopper
It's all in the delivery. Some teachers can do it and some cannot.
You make an excellent point with regard to the complexity of overall fuel efficiency. Ultimately, the solution will likely be lighter and smaller vehicles but I don't think we're quite ready for that.
We may have a solution. All they have to do is to convert the "Heat" to usable, working energy to propel the car!
How hard can that be? :shades:
(Godda go take my medicine.)
Kip
Tess, I had two great physics teachers and I have fond memories of that whole learning experience. I am also in structures (and geotechnical) now. Your mileage is about the same as mine, I can squeeze a couple more mpg on the highway.
I am waiting for the fuel cell automobile. That way, when I come home from work, I plug my house INTO MY CAR for home energy!
Joe
I just bought 2WD VP 08 model last month. I was hoping for the worst but got pretty good avg in 2/3 city 1/3 hwy driving to work . Got right around 22.15 mpg .I thought I calculated it wrong the first time but it was the same the secod time too (355 miles in 16 gal) I am hoping to clock over 26-28 in all hwy driving. I am planning for a 2200 mile round trip during xmas and will surely post the results.
At 70-75 expect closer to 22-23 mpg. Wind resistance at 70 and above really takes it's toll on Pilot mileage.
This info was posted by "just average joe" and as I understanding it, is that (layman terms) wind resistance is basically a measurement of the vehicle frontal area X Velocity Squared. The frontal area is constant with the particular vehicle, so what changes is speed. Therefore at 60 mph the velocity part would be 3600. At 75mph it would increase to 5625. That is about a 50% increase in the wind resistance on the front of the vehicle, it will hurt mileage.
Good luck,
Kip
I believe that they do. There was once considerable discussion in this forum about that. And I am not alone in my belief. You might want to scroll back and see if you can find it. Some good information and speculation there.
I have a 2007 EXL 4WD. It's got about 14,000 miles on it. I'm getting 17.4mpg overall in mixed driving. I'd say my mixed driving is typically 1/3 city (not NYC or anything like that) and 2/3 highway (though mostly short trips ranging from 5 to 20 miles each way). My speed on the highway is generally 60 to 75, depending on the speed limit (which can be as low as 55 where I live). Don't have a lead foot. Acceleration of the Pilot does not excite me (and the handling is downright scary when you're used to driving sports sedans). Don't have a light foot either. I keep up with traffic.
If you do not absolutely need 4WD, the new 2WD Pilot seems quite promising to deliver mpg even better than what you are getting with your 2004 4WD, thanks to the combination of 2WD (lighter weight than 4WD) + VCM technology (using only 3 cylinders at times). I do not believe that the 2WD version was available back in 2004 when you got your 4WD Pilot.
The 4WD CX-9 is rated somewhat worse on gas than the 4WD Pilot, 15/21 as compared to 17/22. But if you want a change and something (at least in my opinion) nicer to look at and perhaps even fun to drive (zoom zoom), then by all means go for a CX-9 next. Makes sense to me. I'd certainly be checking it out if my lease was expiring.
As to driving styles I completely agree. Commuting with my Acura RL is like a racehorse... doing the family thing with the Pilot... the chuckwagon!!! Both are fun.. in there own ways!
Cheers,
Tess
My bro, the Honda Specialist, says wrapping the filter is a myth... Be patient if you can... once the engine gets to 12 - 15K, mpg should start to improve. You have to remember that the EPA ratings are just a rough estimate... from a sample set. Some will get less than estimated... some will get better than estimated. Another thing is that some of those 20+ mpg postings are with 2WD which have a better mpg's than the 4WD's.
HTH's
Cheers,
Tess
I recall, but not in detail, discussion about a change in the gear ratios and new Pilots revving higher than old Pilots at same speeds.
The chuckwagon! I love it.
I suppose that you too must have had those moments where you find yourself inadvertently driving the Pilot too hard, forgetting for a moment which of your vehicles you are driving (even though you are sitting at what feels like 10 feet above the ground). It's downright scary taking corners in a Pilot. As a highway cruiser, I have no complaints. But until you get to the highway, . . . you'd better take it easy. And as I understand it, so far as SUVs go, the Pilot is supposed to be better than most when it comes to handling. Heck, I'm afraid of going off the road or even tipping it over. So I mostly baby it through the turns.
It took me about a month or so to "tune" my driving to the appropiate vehicle. Having at minimum 3 boys in the back, 2 of them teenagers arguing usually brings me back to reality!!
Cheers,
Tess
Think this is what you were referring too.
2004 Pilot specs: http://www.hondanews.com/search/release/1469
2007 Pilot Specs. http://www.hondanews.com/categories/889/releases/3635
Kip
Cheers,
Tess
There is about a 12% difference in the overall ratio final drive ratio of the older and the newer Pilots when everything is locked up in OD. I've not run the numbers in the other gears.
Honda prides themselves as being the "Highest fuel mileage Car Company". I can't imagine why they would change the "Ratios" if it would result in Poorer mileage.
My take is that on flat ground with little wind an 03 might/will get better mileage than an 07. Simply because it is turning 100-250 less rpm, according to speed.
I believe that in areas where rolling hills and worse are the norm, the newer Pilots may/will have the advantage, simply because they will stay in the upper gears longer before downshifting.
My next door neighbor bought a new 07 Ridgeline a few months back. He drives conservative as I do, and his spread sheet shows his 07 Ridgeline getting about the same MPG as my 03 Pilot. He also discovered the vast difference in "Cruising" at 75 mph vs 65 mph. Nearly 5mpg according to him. It affects my 03 about the same.
Riding in the Ridgeline, I have noticed that it tends to stay in OD longer, when going up a long hill, than my Pilot does. It may hold OD all the way to the top, where the Pilot will not.
We have had some really "LIVELY" discussions concerning older vs newer Pilots and their mileage.
Bottom line is that whether the vehicle itself is capable of 15/22 or 17/27, the driver will have great influence on the mileage. Most any vehicle will get better mileage when driven conservatively. Most will return worst numbers when driven aggressively.
People come on here and say things like >" 21 mpg highway is all that can be expected from a Pilot" . I believe they are absolutely correct for their particular circumstances and driving styles.
Others "Post" really good mileage! That is a reflection on their circumstance and driving style.
Kip
You are good at digging up those old posts!
Here are some more interesting facts about this subject:
My 2007 Pilot Final Ratio = 4.375
Your 2004 Pilot Final Ratio = 4.428
The 2007 Ridgeline Final Ratio = 4.533
All 3 weigh about the same. They are all 4WD. They have the same engine, although my 2007 Pilot has a few more horsepower than yours, and the Ridgeline has a few more horsepower than mine.
But your neighbor's Ridgeline runs at a lower RPM at highway speeds than both of our Pilots.
Now let's assume that the Ridgeline has the same wind drag coefficient (which it doesn't and I couldn't even find any information on which was lower) So if everything else is the same, and we all drive at 65 mph, then my Pilot's engine turns more RPMs, moves more air through the engine, and is required to utilize the most fuel.
I really want that sixth gear so that I could idle down the freeway.
Just thought I would through-in some more of my car-dork information.
Joe
Cheers,
Tess
Overall Gear Ratios for these vehicles:
Final * 5th = Total Overall
2004 Pilot 4.428 * 0.52 = 2.30
2007 Pilot 4.375 * 0.595 = 2.60
2007 Ridgeline 4.533 * 0.531 = 2.41
Overall Ratio on the 2007 Pilot is the highest number or the lowest geared vehicle.
Whew!
Joe
2007 Ridgeline. He said that 26.5 was a wake up call of how slower speed= better mileage. On the road, when I've been with him he sets the cruise on 70-75 and gets in the low 20s mpg.
Date Odometer $/gal Gallons Cost Mileage Avg
8/3/2007 30
8/13/2007 299 $2.579 14.93 $38.51 18.01 18.01
8/22/2007 424 $2.649 7.74 $20.50 16.15 17.38
8/22/2007 562 $2.619 6.61 $17.30 20.89 18.17
8/22/2007 742 $2.529 8.90 $22.50 20.23 18.65
8/23/2007 961 $2.649 10.76 $28.50 20.36 19.03
9/3/2007 1196 $2.549 12.79 $32.60 18.37 18.89
9/24/2007 1507 $2.629 17.50 $46.00 17.77 18.64
9/30/2007 1619 $2.629 6.09 $16.01 18.39 18.63
10/12/2007 1775 $2.549 7.45 $19.00 20.93 18.81
10/12/2007 1871 $2.599 4.58 $11.91 20.95 18.91
10/16/2007 1971 $2.519 4.45 $11.20 22.49 19.07
10/18/2007 2075 $2.699 4.63 $12.49 22.47 19.22
10/18/2007 2372 $2.599 12.50 $32.50 23.75 19.69
10/26/2007 2582 $2.589 9.35 $24.20 22.47 19.90
10/28/2007 2838 $2.719 9.64 $26.21 26.56 20.36
11/2/2007 3136 $2.589 13.75 $35.60 21.67 20.48
11/2/2007 3406 $2.589 11.59 $30.00 23.30 20.68
11/15/2007 3673 $2.839 13.70 $38.90 19.49 20.59
11/23/2007 3743 $2.839 4.93 $14.00 14.20 20.41
12/2/2007 3829 $2.879 4.52 $13.00 19.05 20.38
12/5/2007 3878 $2.869 2.37 $6.80 20.67 20.38
12/11/2007 3969 $2.819 4.82 $13.60 18.86 20.35
I put nearly 13,000 on my Pilot in 2007, and averaged 17.42mpg in mixed city/highway driving. Best tank (mostly highway) returned 21.48mpg. Worst tank (mostly city) returned 15.31mpg.
Sometimes a family of 5. Other times just me and a load from places such as Costco.
I'd say the mix is close to 50/50 city/highway, though the highway drives are mostly short drives of 5 to 20 miles each way.
I do not drive my Pilot aggressively, but I do not have a light foot either. I believe that my driving style is moderate, at least when I'm driving my Pilot that is.
It'll get 19 mpg on the freeway, A/C on and cruisse set at 78-80 mph.
I'm traveling this weekend to Chattanooga, and we'll see how she does. If I can keep my foot out of it, and cruise at 75 mph with no A/C, we should be able to get near 20 mpg.
And I believe that is truly about the best anyone can expect from a 4500 lb truck with an EPA rating of 15 city, 20 hwy.
At 78-80 MPH you can expect, and will probably get, in the neighborhood of 18-19 mpg under the best of conditions. The wind resistance is real tough at that speed, and really drags down the mileage. Today, You will also likely be headed into some fairly heavy winds, going North. Even so, "Cruising" at 75 might still yield 19-20. Drop her down to 70 and maybe 22-23. That ain't exactly flat ground up there.
You would probably be amazed at the improvement in mileage if you "Cruise" at the posted speed limits and use a light foot when accelerating .
They are predicting some possible snow/ice in North Georgia and Tennessee. You might be well advised to bring that tire pressure back down to recommended levels.
Kip
There was a previous post that mentioned pumping up the tires to 38 to 40 and how that makes the Pilot drive better. My experience suggests that it may drive better but ride worse, as in 'like a buckboard.' The tires are not only a part of the steering system, they're also part of the suspension system. The fuller (and now harder) tires may also decrease the road-holding ability of the tires under hard cornering or in wet conditions. BUT, yes, mileage should improve, and to each his (her) own.
As to upping the tire pressure... I think I'll try that out.. but in the summer... winter here in the rain and snow I need as much traction as possible!
Cheers,
Tess
15/20 must be the revised EPA rating for the Pilot. My 2007 showed 17/22 on the sticker. If the real EPA rating for the 4WD Pilot is 15/20, then I feel better (even OK) about my real world gas mileage. Your remark about my mpg being right on the money also makes me feel better about my mpg. Thanks.
Kip
Understood, which is why I have come around to the view that my 2007 4WD Pilot is really rated at 15/20, not the 17/22 which appeared on the window sticker. Makes it easier to justify (and not feel badly about) my real world gas mileage. My overall average of 17.4mpg for mixed highway/city driving is virtually right at the mid-point between 15 and 20.
The one that really stood out was:
Each 5mph, over 60mph, effectively adds $0.15 to each gallon of gas.
It did not refer to any particular make or model of car.
Makes sense, as my mileage drops about 12% at 70mph vs 60 mph. Therefore I'm having to buy 12% more gas to travel a given distance. So if I burn 12% more of the $3 gas I will pay "effectively" $3.36 per gallon to run 70 mph vs $3.00 to run 60 mph. .
I find that to be an interesting way to put it.
Kip
Sounds like a great vehicle. How is it equipped? 2wd or 4wd ? Which engine? What gear ratio? How does it handle the Airstream. What size Airstream?
I've been thinking about getting another camper. Hopefully a used Airstream in the 23' . We used to have a 26' Argosy (Painted Airstream), but stupidly sold it. :sick:
It sure did pull good!
Kip
The gas mileage I am getting is nothing close to Honda's claims or what I see in the discussion board here and other places. I drive conservatively and always use the cruise control on the highway at speeds between 55-65. My combined mileage (1/2 around town 1/2) highway is about 14.7 mpg. My highway mileage is about 15.8. I made an appointment at the dealer today to get this looked at. The service manager told me it takes about 5K miles to break the car in and get better mileage. I then spoke with the salesman who said the same thing, and mentioned that in winter (live in CT) my mpg would be about 10% less than in warmer weather.
Is the mileage I am currently experiencing in line with what other owners experienced when their Pilot was new? After the 'break-in' period, can I hope to get possibly 22 mpg highway and 18 mpg combined? Is what I am told about a break-in period correct? Any help is GREATLY appreciated
As for the breaking in period... its been suggested that there is one.. or its a myth. Either way I am at 4400 miles now and I will wait and see if there is a difference in the coming months.
HTH
Cheers,
Tess
I accelerate moderately but I coast a lot as soon as I anticipate that I will need to slow down or even stop. There is no point to continue the speed and stop abruptly in less than 100 feet away from the intersection. Sometimes the light turns green when I approach and I just accelerate again without touching the brake and I pass those in front of me previously.
I pumped the front tires to 36 psi and the rears to 34 psi and I think that helps too. The ride is a little bit bumpier but the handling is slightly better.
At about 12000 miles, I just switched to synthetic oil (Mobil 1) for 2nd oil change and now the engine runs smoother and I anticipate even greater MPG. I will keep you guys posted.
Please see my next post on my latest story on mileage...
Cheers,
Tess
Well... for the first time I got the display on my dash showing my left front tire is underinflated. That is nice and handy TPS feature! Well... I knew I didn't have a dedicated tire pressure guage yet (I know, bad girl, I slapped my wrists already!)
Now I have been shown the light with keeping up with checking my tire pressure, I now wonder if anyone has used nitrogen for their tires and if they have any info to share?
Cheers,
Tess
Just like everybody else, Honda sets a threshold lower than the recommended pressure for the tire monitor light to turn on so you will not see the light on as soon as the pressure drops below recommended setting.
Also, since the front end is heavier, I would pump the front tires with slightly higher pressure to compensate the weight difference. Some manufacturers do suggest higher tire pressure for the front tires since most pessenger vehicles have higher percentage of weight on the front.
Let us know if your mileage increase after correcting the tire pressure.
My initial thought is that it would improve gas mileage for those who spend more time on the highways than in stop-n-go traffic, but I'm wondering if people are indeed getting the 22 mpg which Honda advertises (in part due to this system on the FWD Pilots).
I'm looking to purchase a new (at least to me) SUV in the next week or so, and am debating between a 2006 MDX and 2008 FWD Pilot EX-L. If anyone has positive (or negative) comments about VCM and its effect on overall gas mileage, I would greatly appreciate it as that is the one of main reasons I would select the Pilot over the MDX.
I don't know that the VMC is a wonder mileage maker. It would have to help a bit.
The drivers foot will have more effect than anything else.
As far as real world vs EPA sticker. Read up on it. This entire forum is about that. I've gotten 18+/- mpg on a trip with very little elevation change. The return trip the next day was 26+/- with the same load . Major difference was speed, 80+ vs 60-65. Generally speaking with 2 aboard and 68 mph the mileage will be 23-25 depending on terrain, use of AC and such. Mine is an 03 4WD.
Kip
