I will call my dealer tomorrow and mention this and keep everyone posted.
Phinfan63
I planned a trip for the Memorial Day weekend. During our trip, after breaking (or sort of) with L, I switched back to D and the wrench and transmission signs came on and the car felt like in neutral. There was also no acceleration. Reading previous posts about this kind of behavior I was not worried. I managed to exit the freeway and waited about half an hour, hoping the problem will go away.
It didn't. The accelerator worked fine in P, but once I switched to other position that would stop working too.
The car was towed back to the dealer ($170 :confuse: Ford covers 35 miles only). I was sure the metatronic was to blame.
Today I've got the diagnostic: "Front end pump". Parts are ordered - it will take few days.
The dealer gave us a free rental until the dead FS is ready.
05 FS SEL FWD 7K.
Do you have any questions for my dealer?
Victor
What's a metatronic?
and..
What "Front end pump"? Can you be more specific in a later post when you perhaps know more about what went wrong?
Anyway in my case it does not mater, because the mechanic said "Front End Pump". I assume it is an oil pump inside the transmission.
for whatever reason i would fear to damage something in the gear box when switching "gears" during driving and i think the CVT does a pretty good job wrt engine breaking in the D position. but compared to a manual diesels i drove before the engine breaking is almost non-existent and it took me quite a while to get used to it. is it really improved in the L position? just wondering how it would work, sounds a bit like you would shift into 1st gear on a manual at high speed.
Carsten
Now, L stands for "low" and it is the means of downshifting and engine breaking. Highly recommended on going on long downhill. Much better then brakes on slippery roads etc.
Unfortunately I had to use auto transmissions in the last 5 years and I had always make use of lower gears. Actually, on long downhill using L is mandatory. Brakes will boil by the time you are done.
The L gave me good breaking power, but not like a manual. In D there is no breaking. There is a lot of coasting. Using L helps breaking performance even in the city in sticky situations.
I'll post a quote from the manual.
But just how steep of a grade does it have to be to require the use of "L"? It has always seemed to me that just regular "D" provides considerable braking force when going downhill.
1. Auto headlights would not go completely off. They would continue to flicker. The dealer took 2 days to figure out what was wrong.
2. Humming that turn to grinding sound in the transmission. The humming sound was passed off by the dealer as "typical of a CVT". Then it turns to grinding and RPM's fluctuating all over the place. Three days out of commission.
3. Front end vibration and alignment. Vibration at highway speeds. Dealer took an over night to figure it out.
Are we unlucky or is this typical of the Freestyle?
Getting frustrated.
#1 is a known issue, I believe. There should be a TSB out on it.
Seen one or two people complaining here of symptoms like #2, as well as #3.
Love the car and the gas mileage!
Using L for long downhills is different than using it for standard braking. The use of low gear requires a complete shifting of the internals inside the tranny. Fluid needs to be diverted to different channels for shifting and THAT's why the front end pump died. The front end pump is most likely an internal pump inside the tranny that provides fluid pressure back and forth inside the tranny.
When you know you're going to be going down a long steep hill, you should put the tranny in L and leave it.
If you drop it into L halfway down a hill, bad things are going to happen.
You might as well take a manual transmission and drop it into 1st gear at 60 mph!
sheeesh...stop abusing your car
You have to keep in mind that we are dealing with a CVT here which only has the 2 variable pullies. All gear changing is electronically controlled. When shifting into low, the computer is just going to adjust those pullies and the engine speed appropriately to provide more braking. There should be no problem shifting into low at normal highway speeds. The owners guide states:
"L (Low)
Provides more engine braking when the accelerator pedal is released than D (Drive)."
A typical AT may have a 1 or 2 instead of a low, in which case, shifting into a particular gear could be harmful (although I would guess the ones that just say low probably pick an appropriately lower gear based on speed).
In general, if you are driving down long hills, using the L feature will be much safer by not overheating your brakes.
sheeesh...stop abusing your car"
Sorry, I must disagree. If the transmission cannot handle mid-downhill shifts, Ford should have used the computer to prohibit such shifts until it was safe for the CVT.
I have switched to "L" many times on the downhill, without any problems.
I agree, but you shouldn't drop it into Low at the bottom of the hill. It's a shock to the system. The cones and pulleys have to jump to their respective positions. The pump that provides the hydraulics to do this has to work overtime to move averything in such a short span.....and under LOAD! That was my main point that I was tryingto get across.
Doing it at the top of a hill is one thing...doing it at the bootom or when there will be a lot of load is another.
This is what I read online about the FS
Engines (standard): 3.0-liter dohc 24v V6
Engines (options): 3.0-liter double overhead cam 24-valve V6
Horsepower: 203 @ 5750
Torque: 207 @ 4500
EPA Fuel Economy: 19/24
Turn Circle: 40
Front Suspension: independent strut, coil springs, stabilizer bar
Rear Suspension: independent, multi-link, coil springs, stabilizer bar
Towing Capacity: 2000
Tires: P215/60R17
Front / Rear Brakes: disc/disc with ABS and EBD
Fuel Capacity: 19
FORD is a joke with this car.....old useless motor, CVT is a joke and a bandage for lack of power. WE WILL NOT BUY FORD AGAIN.
Sorry about your experience. So when did things start to fall apart? I like the car but it's a new design and does not have a track record of reliability. The engine is not refined and the CVT is new. Curious, how many miles did you drive before the breakdowns.
I'm curious as to why you refer to the 3.0L Duratec as "not refined". Sounds suspiciously like something you might have read in Consumer's. Actually, the Duratec's a pretty well-respected engine out there in the automotive world.
Just as I shouldn't claim that Fords are the best vehicles on the road just because of my good experience, you shouldn't claim they are the worst because of yours.
By the way, my wife and I believe that the Freestyle is one of the best family vehicles on the road, hardly a joke as you claim. We love the CVT, the interior space management, the sensible exterior size, and the good gas mileage. I have never been a big Ford fan, but the Freestyle is a winner. If you really hate yours that much it is probably more to do with it not being the right vehicle for you than anything inherently wrong with it.
Chad
I've slammed with criticism for using L. If it's there, you can use it! The change is not sudden by any means, and the result is taking the engine from 2000 or 2500 RPM to 3000, when it works. This car got 12 MPG in the past on a long 1400 mile trip and showed inconsistent acceleration, but good L breaking. After re-flashing the computer at 5000 miles, the acceleration problems went away, the MPG improved to a 17 average, but L breaking was almost gone.
L does not simulate the 1st or 2nd gear of a manual. It simulates "the lower" gear. So if you would shift into the 4th from the 5th while driving at 50-60 Mph, you should also use L.
We decided to buy American again for the first time in a long while and it just let us down. We are crossing our fingers that this is a bump in the road and the worst is behind us.
Now if they can just get those back ordered parts!!!!!!!!!
1) you like the engine performance and CVT.
2) you bought it for it's space, looks, and gas mileage.
3) you like driving it.
4) you're quite happy with it.
Why would you care what anybody in any magazine has to say? You know more about the Freestyle than they do because you own and drive one. If they told you who to vote for in the next election, would you take that advice blindly and vote for that person?
The Duratec is a proven powerplant that has been around since 1996. It has been considerably improved upon and updated since that time. Ford uses many variations of it in it's family line-up, including Jaguar and Lincoln. The version in the Freestyle has been especially tailored for use in this vehicle in conjuction with the CVT transmission. The transmission itself is a marvel of modern technology that was jointly developed by Ford and the same German firm (ZF Friedrichshafen AG) that makes CVT's for Audi. It's assembled in Batavia, Ohio by Ford, and it's worth noting that some CVT's made in this plant are exported to Europe for use in vehicles there. (CVT's are more popular overseas than they are here.) The Duratec itself is made in Cleveland and will last virtually forever if you take reasonable care of it.
PS 35,000 miles and zero problems
link title
In an older article I read that Porsche developed it and Ford bought it for their European division. It has an excellent track.
My dealer gave us a Fusion to drive until the FS is fixed. It's a 6 cyl SE. The surprise is that the sticker was in the glove compartment and I saw the MPG: 21-27. It has the same engine as the FS. How is the FS with all the added weight to be able to achieve the same MPG as a Fusion?
The ride in this car is a dream. I've never seen such well tuned suspension. But there are quirks, like the steering wheel and the trunk require too much effort etc. Maybe a Millan has a better mix.
CVT transmission.
"The PG indicator for the most part has never gone higher then 20.4 MPG but yesterday it dropped to 16.7 MPG"
Possible reasons might include:
1) The ethanol now being used in most automotive gasoline.
2) Shorter trips? Greater A/C use?
3) A longshot. Fuel leak at the new fuel filter? (Who did the work?)
dram615 wrote:
"...the steering would knock when the wheels were cranked all the way."
Ouch! Don't ever hold the steering wheel at it's furthest travel. (i.e.,against it's stop) Most owner's manuals (including the Freestyle's) will warn against this.
34K in eight months? Holy cow.
Any input is appreciated...
There's nothing wrong with the Freestyle (or it's trany), but as with any used vehicle, ask questions and be cautious.
Is the seller a dealer or an individual?
Front-wheel-drive or All-wheel-drive?
What's the vehicle's history? Is it a program vehicle?
Does the seller have maint. records to show you?
2006 Freestyle TSBs on Ownersite.com
For full text, sometimes you can find that at the NHTSA site; otherwise you can buy it at Alldata.com or ask your friendly service writer to give you a copy.
