Visitor Agreement.
I like the Mazda5 & Rondo configuration, but I wish they were about 6" longer to have more space behind the 3rd row, so the headrests weren't touching the rear glass and to give more cargo space.
3rd row seats don't touch the glass though (I do believe is the same case for the Rondo). Yes, not too much space left when in use, but I've managed to get a flattened large stroller in the back of the 3rd seat when needed.
6" more sounds like a minivan is needed, May be a Caravan or similar is in order (unfortunately)?
This is the one I was thinking about: 2007 Caravan (w/o the Grand), 189.3" Exterior Length. This trim may have disappeared with the new 2008 boxy style though :confuse:
http://autos.yahoo.com/dodge_caravan_swb_se-specs/?p=ext
I'm looking for something that can get in the mid-30s highway MPG and be the size of a small Caravan.
27.9, 31.26(3 tanks), 24.48(3 tanks), 29.7, 25.50, 27.66,
28.71, 29.75, 33.45, 30.92, 32.08, 32.08
Total average (29.98)
typical driving 1 adult 4 children, Best mileage probably due to highway 65mph on cruise control. AC on partial due to window tinting. 5 speed manual.
Highest 33.45 lowest 24.48.
I managed to take a pic for this during the week. 5 adults, 1 baby and a stroller (plus some other cargo pics).
Link:
coolmazda5, "Mazda5 Interior/Seating" #11, 2 Sep 2007 3:09 am
I have an auto and drive it almost exclusively on
the freeways.
But my mileage is no more than 25.
Can you let me know what your auto revs
at:
50 mph (2000 for me)
60 mph (2600 for me)
70 mph (3000 for me)
I want to hear the RPMS from people who are getting
30+ mpg. I've never got even close to that, not once
in over 6000 miles.
I wonder if their autos are configured differently
or perhaps they are measuring their consumption incorrectly.
Has anyone done any testing to determine what
the sweetspot in terms of speed is to maximize
highway mileage?
I have about 15 miles on the open highway to
work each day. What should I set the crusie control
to?
a car that had done 1,000 miles on it. The sales
people also lied to you (shock! horror!) by saying it
will get at least 30 mpg. The official rating for the automatic is 26 and stick shift is 27.
Most people on this forum report b/w 24 and 28 mpg.
In reality, this type of comparison probably better then trying to be so precise with a MPG number, plus it's easier to calculate. As long as your driving habits remain the same, you can just compare how much you spent on gas in an old car to the new one just to compare if you're getting better or worse MPG.
I should probably point something else out that I mentioned in the tire forum. This Mazda has BIG tires, and the way the Mazda drives can make the pressure fluctuate all over the place. Tire pressure changes DO AFFECT your gas mileage. You will probably get better mileage if you keep your tires at the appropriate pressure at all times, or better yet, get some nitrogen put in them. My dad put nitrogen in my tires the 2nd or third day I had the car, so maybe that's one of the reasons mine is doing decently?
Checking milage is simple. I top up on every tank, right to where the fuels about to overflow out the filler, and then divide miles traveled by gallons used. Not much room for error here.
The epa now recalculates window milage stickers on a much more realistic method, and has on their website redone the 06 and 06 5's numbers. They are 19city/25hwy with a 22 average.
If theres a sweetspot for the 5, its under 3 k rpm, ( about 60 mph). At 3ooo rpm, the engine shifts from its low speed camshaft lobes to its high speed one, making more power, but also using more fuel. Under heavy acceleration, you can really hear the shift as the tach sweeps past 3000 rpm. Its a good sound.
"If theres a sweetspot for the 5, its under 3 k rpm, ( about 60 mph). At 3ooo rpm, the engine shifts from its low speed camshaft lobes to its high speed one, making more power, but also using more fuel. Under heavy acceleration, you can really hear the shift as the tach sweeps past 3000 rpm. Its a good sound. Around twon I never get past 3 so that does help my city"
But I've heard people say 70mph is the sweetspot.
Could the diff be because of automatic versus stick?
On my 07 auto: 60 = 2600 rpm and 70 = 3100 rpm
So if your seeing 2600 at 60 mph, the stick would be at 2782, and 70 mph = 3100 is 3317 for the stick.
Horsepower needs go up fast with speed, so slower is better. I read once that most cars will see best milage at around 45 mph.
I know that with mine speed really matters on fuel economy. Under 60 I get 32-34 mpg, at 65 I get 30 and at 70 I only see 28.
Btw, last weeked I hauled a trailer around at 65 mph for about 2/3rds of the tank, and still got 28mpg. :shades:
Dean
Any Car? That's a fairly sweeping statement. Using your logic,
then why not 50 miles per hour and why not 40 miles per hour.
The m5 auto kicks into 4th gear at about 35 mph.
I'm doing a bit of study right now, but the results seem to contradict
the earlier poster. Will post details soon.
The m5 auto kicks into 4th gear at about 35 mph. "
My example was just comparing 70mph and 60mph, but this logic doesn't go down forever, especially when you start getting into the mountains. Once a car gets moving, it's fairly easy to get it into 5th gear pretty quick on flat ground. But I'd say at any highway speeds (above 55mph) it's always going to provide better MPG to drive slower, down to I'd say 55mph (or 50mph in a 55mph zone), at which point going slower just becomes dangerous.
You can try it. Just drive no faster than 55mph on your highway drives for a tank and just see...if anyone can drive that slow! If I'm interested in MPG, I'll just stick to the posted speed limit. Any slower and it just feels dangerous to me.
The Mazda Club Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
Just wanted to report that 30.35 MPG was, so far, the highest mileage I have gotten out of my new 08 Mazda 5 GT. (Drove 425 mi., and filled up w/14 gal.) We recently had a road trip out to North Carolina from NYC, and that's the best tank that I got - though, I do think I could have squeezed more miles out of it if I didn't get so nervous since the light was on and the needle was squarely on empty). The figure is based on about 90 to 95% highway driving. I was driving mostly anywhere between 65 to 75 mph (used cruise most of the way, but due to some congestion I had to slow down or speed up accordingly).
I figure that once the car breaks in even further, the mileage will get even better! I just find it great that we can easily get more highway mpg out of our 5's than is estimated by the EPA (27mpg). I also think that 70mph is still the sweetspot for the 5. The new one, as you all know, has a new 5 spd auto, which I do believe makes a difference - esp in city figures. The lower revs at highway speeds is immediately noticeable. Wheres as my old 06 5 revved at 3000rpm when travelling at 70mph, my new one revs at slightly above 2500rpm when travelling at 70mph. If I bring the engine speed up to 3000rpm in my 08, the speed goes up to close to 80mph (about 78mph). So, that makes a big difference.
I calculated 29.8 on the northbound trip to NJ, with a small amount of suburban driving once we were there. I filled it this morning just as we left NJ and filled again when we arrived in our hometown. 34.9!! OK, honest! Cruise set at 70 mph on the NJ Turnpike and I-95 from NJ to northern Virginia. Even the fuel gauge showed the difference - we still had more than half a tank when we arrived back in VA. My 2005 Saab 9-3ss gets 36 on the same trip, so I'm a very happy camper. We're taking the 5GT to Florida this month with 2 kids and luggage for 4, so we'll see how it does on that kind of trip. But, so far we are very pleased with the vehicle - comfortable, smooth, quiet, and stable in today's 25 mph crosswinds.
And yes the 5 speed will always get better mileage a 4 speed of the same ilk.
My average overall is about 28 so far with about 15k miles on, and I've been over 30 many times. Winter gas here ( WI) has ethanol in it and makes it tough to make it past 30 mpg. Come summer gas though, things will be back to normal again.
I am taking a roadtrip to seattle this summer and expect I will be over 30 average for the trip.
BTW, the car still drives like new.
My best tank ever was last summer, ( no ethanol in gas) with a large portion of trip off interstate with crusie set at 60 mph, plus did'nt need air conditioning and no headwind, and I saw 34.7.
You can really tell the cars loafing at those lower speeds as engine noise is almost gone, and the milage proves it.
I wonder what the best possible roadspeed for fuel economy would be? I know if you go too slow it also drops, same as going too fast. I'll take a guess at 45-50 mph range.
I'm new on this forum, but I've used it to make my decision to buy the car. So thanks to all of you for your postings.
I have been driving the 08 Touring for the last couple of weeks in suburban driving, and my average MPG so far is 21.
I went for this car because of the safety standard features it offers at this price range ($ 21500 Out the Door).
Yes, ESC would have been nice, but for a car that is driven by responsible family people, (Who else would buy this car?), the standard safety features should be enough.
I do however have a gripe with the tires and wheels it comes with. I think that it is a mistake to have such a low profile tires on such a car as they are more prone to damage by curbs that would not have damaged a regular tire.
I'm looking forward to a better MPG.
I get 22-25MPG combined in both my cars (06 and 08). Around 30MPG highway (depending of the cruise speed)...
Oh, and Canada sells many Mazda5s and there are no big ESC gripes, plus in other forums you can find that not only families buy them, also several young-single people are buying them because of the Zoom Zoom looking, handling and versatility for cargo
I think there were some fuel economy tips around, as long as they are safe and do not make me a boring driver, I'm all for them
2008 Mazda 5 Sport
5 Speed Manual
I can't say enough about the way the vehicle cruised - very smooth, quiet, and comfortable. It felt like a large luxury vehicle with the load we were transporting. This is our fifth Mazda, and perhaps it will be the best we have owned. My 1990 MPV is my favorite so far, but this vehicle may surpass that - time will tell.
Also, A/C should be a problem if you really need power, as the A/C should disengage if you have to floor it.
And honestly again, I get 34-36 MPG with my Saab 93ss. I'm just a steady driver on long trips.
mrbwa1: Did you pick up your white Touring yet? If so, how do you like it? Good luck. I'm still very pleased with our 5. The neighbors are asking a lot of questions too.
