Subaru B9 Tribeca: Problems & Solutions
Good, affordable option. We fight over ours, me and my wife. Time to buy a 2nd one!
-juice
I've found slightly lower prices but service was poor so I'd consider trying them out.
-juice
I bought mine at buydig.com. It came with the suction cup mount, which works great. It also has the adhesive disk in case you want a permanant mount. I love the touch screen. quick and easy. My final cost was $532.49 and free shiping.
You can find some on ebay that are refirbushed a little cheaper.
-Marilyn
-juice
Steve
Some roads are time-restricted, i.e. they are on-way in rush hour in the AM, and then the other way in the PM. Some GPS systems will avoid those because it's not sure if they are open or closed. That may have been why.
Perhaps the parking lot used to be connected, and the maps just need updating.
Subaru buys the maps, but I'm sure they'll forward your corrections to whoever owns them.
-juice
Fastest means fastest NOT shortest. Being routed onto a super highway may be longer but it will also get you there faster.
Conversely, using shortest could actually take longer and use more gas.
It routes me OFF a larger road onto a small backroad for a 3 mile loop then back onto the same larger road 1 mile down :mad:
it is DEFINITELY not faster. they have either an error in their software OR an error in their map data reading the size of the roads. I am hoping its an error in the map data and the updated DVD will be improved.
They get you there, reliably, not necessarily the best route, but you arrive, and it removes the stress because you don't have to worry about how.
Even when I know a route, I like having the miles-to-next-turn feature so I can relax in between turns.
Also, use the map display to your advantage, you have context sensitive help right in front of your eyes. Looks for alternate paths, maybe even more fun twisty roads you did not know about!
Those are neither quickest nor fastest, but rather the BEST route to take.
-juice
Would I buy the option again if I had to do it over again? I would say Definitely NO. It is a poor unit and no where near the speed at recalculation nor the processing power to pick the BEST route in simple conditions.
Like I said, I am hoping its a mapping problem in the map database that will get corrected with the next DVD Map update for the Tribeca and I hope its soon they release it!
Mine was a loaner, which we had for about 5 days overall.
The one we own is a Garmin StreetPilot c320. It actually routes pretty well and recalculates on the fly quickly. The software is better, but since it's not integrated it gets lost in tunnels, plus the screen is smallish (3.5").
I do have an occasional issue with the route it takes, but that's only once in a while, and it might only cost me a few extra seconds.
-juice
What were they thinking with the cargo cover? Does anybody have a workaround solution other than the old blanket I'm using?
Is there another manufactures cover (toyota) that might be able to fit this?
Thanks! Great board.
How the system features are changed is with a OS disc. That is how they would put temp on the screen or improve the way POI data is presented (which with the B9 really sucks)
My previous car was a Q45 - the nav sys in that car had more bugs than a house with termites. Infiniti finally issued a free system upgrade but the mapping was on a seperate disc and that was not free.
-juice
The system was trash they had no option but to fix it for free.
I have had 3 built in systems (1 acura, 1 chrysler pac, and this one) so based on the other two BUILT in systems, this must be Kenwoods bottom line model...
Oh and yes they can update the software with the map DVD. the alpine system in my previous chrsler added the option to be able to enter points while moving up to 10 mph. the car originally did not allow you to enter points at all when the car was moving even 1 mph. the DVD also had updated maps and POIs.
My main point, though, was that you sort of learn to compensate for their weaknesses as well.
In your case, you've become a pro at identifying what those weaknesses are. :P
-juice
I love :shades: GPS systems. just not the B9 Tribeca. I am actually waiting for the Garmin Nuvi's latest model to be released next month with Bluetooth handsfree and cordless for when I travel on business. just smack it the windshield and drive! plus it acts as a handsfree phone for your cell and shows the phone number of incoming calls!
I wish that the Tribeca had something like that... The Acura RL and TL does and I think the higher end Toyotas (Avalon?)...
Indeed there is. You can find it here: Navigation / GPS Systems
I am doing the deal by phone and can not see the B9 in person and will be exporting it to Montreal were I live. The savings are huge in Canada same vehicle is $54,000cdn tx in. any comments appreciated
Dan
For that kind of savings I would jump on a plane and go inspect it and drive it home.
We have heard from others who bought one and I am not aware of any reports of buyer remorse.
good luck
That deal sounds great, wish I were in the market....
-juice
She tightened the screws and the rattle was gone.
You might want to try that.
For some time I thought I had a severe rattle somewhere in the back of my B9 Ltd and it turned out that if you keep the center row seat backs sharply reclined - there is a loud rattle or more accurately a clunking sound, when going over bumps.
-juice
-juice
thanx...
-juice
What does it flash?
:confuse:
thanx
We would have not bought this car had we known the paint was not warranteed. The dealer said he would Simoniz the car instead.
How big - or little - a deal is this ? Thanks ---
If they said it was warranteed, the next question is by whom? It may not be a factory warranty and if they implied it was a factory one or it does not have an equivalent warranty then I would refuse to sign it. Its one thing to buy it knowing there is no warranty, and to be honest, if the deal was that good I would probably go for it even in that situation. Subaru paint problems are rare though.
thank
doubled
