Visitor Agreement.
Normally I get 20-21 doing 75-85.
If I fly around in the S/C, it is 18-19.
Just wondering. Works on a big truck.
It's that just there isnt much flexibility available to the designers when it comes to the front grills, since all trucks have the same thing upfront (lights, logo), sort of limits the options. It's bound that there'll be a lot of similar grill designs.
Also, the Tacoma extended cab does not offer a 4 door version like Ford does with the Ranger.
There is a Tacoma 'double cab' but this is is more comparable to Fords Explorer sport track. Both have 4 real doors, and extra short beds.. These are catagorized as 'crew cab' trucks not 'extended cab' trucks.
I am interested in how Ford positions/markets the Sport trac vs. Ranger crew cab in 2003, as these basically sound like they will be very similar in capabilities.. Will Ford do away with the sport trac?
Maybe the Ranger crew cab will have the option for a 5' bed (or maybe even 6'), instead of the ultra short beds most of the mini crew cab trucks have..
Again, Nissan has already indicated that they will have this, (if they don't already).
At least I'm happy you've realized IT IS an open diff when not locked.
Your apology is duly noted. LOL!!!
here's the link:
http://www.off-road.com/fordracing/fx4/
im sorry guys, i knew i said i wouldn't post anymore, but in this case, pluto is trying to run down the ranger again, and again his statements are negative and ill-informed. thx
The only type of failure of the LSD is that over long periods of time, the LSD clutches can wear, which results in the diff acting exactly like an open diff. So when the LSD fails, it is no worse than the open diff..
It is also my understanding that locking diffs also require more maintenance than an open diff in order to keep them functioning properly.
Allknowing, unfortunately you are right. If you have a Ford truck with limited slip diff that has over 100k miles on it, you probably should check it to make sure it is still functioning properly.
This is asking no more than anyone who has a 4x4 system to make sure it is still functioning properly.. I know that we all have heard of cases with all of the 4x4 models where there are vacum failures, and other mechanical failures that cause the front hubs or the transfer case to not engauge when needed..
Thanks for posting a link proving my point.
It's still just a matter of preference.
The hardcore off-road guys like to have a fully locked differential for the really tough stuff, and an open differential other wise. Others like the safety of the Limited Slip because it's always there, off-road or not. Especially helpful for any turns on wet or sloping asphalt. Ice in town, whatever. Overall I think the Limited Slip will still help you perform off-road, and keep you straight on the road.
But of course with our "low hanging rear shock mounts" we Ranger owners go through about 2-3 axles a season, so we always have a fresh differential to use...
LSD is of only minor assistance anyway. It's best on snow packed or iced streets. Not really effective in most off-road situations. Since most of your time spent is on the street, this is as it should be.
Also, I thought Tbunder was done doing posts! What's up with that? Proof positive that his posts are not always entirely accurate
I'll see you in the middle of nowhere........Steelman.
It's all about filling a niche of consumer demand. Consumers buy what the consumer wants. If the price difference was low and quality difference was as high as many Yota fan's believe, then why do Ranger's outsell the Tacoma?
I'm sorry, but more people pick the Ranger over the Tacoma, even despite Toyota's reputation for quality.
Let's just appreciate the diversity, because if everyone had the same truck and mindset, the world would be a boring place.
You know what is amazing? Ford's November sales increased 4.4%(Trucks 6.7%) over Nov 2000. Yearly sales for 2001 are down 6.0% (Trucks down 2.8%)from 2000. But we all know about all the bad press floating around in the first 3 quarters of 2000. I think the cost-cutting paradigm was hurting the quality of Ford products, but with the recent CEO/management change, that issue will be completely addressed. It's been some tough lumps to swallow, but it will only make Ford stronger. So make your arguments now while you still can!
steelman- to compare a $30K BMW to a $11K Escort is ludicrous. maybe a lincoln LS would be more fair. and to be honest, the lincoln would run circles around most bmw's in its price range.
quadrunner- i disagree with you on lsd's not helping off-road. why do you think this? do you think they shut down the minute they hit the dirt or what? they're always available automatically. lockers have advantages too, but imo the lsd has the most real world usability.
greg116 "4WD & AWD systems explained" Feb 5, 2001 6:01pm
Enjoy!
-you realize this is entirely due to 0% financing...
yeah, i thought id get back in on the convo again. its been going pretty good around here, ill try and keep my opinions to myself if everyone else will.
So...to make a long story short...you are right. It is the most time consuming part, but not always necessary.
Not taking sides here, because my truck has neither, no locker, no limited slip. My last truck had the eaton locker. That seems to be the best compromise between a true locker and limited slip. A locker that only works below 5 mph like the taco has limitations also. Okay for rock crawling.
Stang - Liked your shock comment-pretty funny.
Quad -I realize that you can easily check the LSD but I doubt that many people check it regularly. I was just surprised that it may go without any warning. In reality though, I've never had a LSD fail under 90-100K.
I just got to hear this logic. Size....yes the Lincoln wins. V8 yes the LS wins....but why would you want a V8 with worse performance then an I6 in the first place?
Just curious.
Saddaddy--->Good point (post 3180). I guess LSD owners would have to rely on good ole momentum, or just the other axle to get them through any tough spot.
allknowing/quadrunner--->What about the burnout test for an LSD? I thought you could do that and see if you left one or two tire marks, or does this typically out do the clutches as well?
I saw a little piece on the news about a month/two ago, where they gave a pretty interesting point of view:
reason why all big 3 are giving 0% is because of GM. At this point Ford and Chevy are competing against GM for market share: GM is keeping the 0% financing deal going, and Ford/Chevy have to keep it up, otherwise they'll hit a sales slump themselves, and lose market share. Combined with the vigorous ad campaign for GM Sierra and other GM trucks, I think this is valid. Companies are in business to make money, for themselves and their shareholders, and unfortunately, saying "Well, the economy is bad, so we lost xx% market share, and our stock slipped by 50%" is committing suicide.
Think about this...0% financing is a killer on a business. We are talking companies giving you non-interest loan for the next 5 years, when they could make $2000 off you. Combine that with the fact that many people these days are shopping over the net and getting nice deals ($100 over invoice, $300 over invoice), we are talking about basically non-profitable business. Is that a good way to stimulate economy? I'm sure that collapse of some big automotive brand is all this country needs at this point in time.
Toyota is giving 0% on Tundras for the same reason: it wants to grab market share in the fullsize pickup market. As for why there arent any big discounts offered on Tacoma: there needn't be any (from the company's point of view). Unlike Tundras, Tacomas sell no matter what. There is a demand for those neat little trucks, and people will buy them anyway. Check out the ratio of Tacomas to Tundras (or to anything else on a Toyota dealers lot). There's less Tacomas than anything else, Tundra (about 3-4 to 1), 4Runner (again, about 3-4 to 1). What Toyota has done is opposite of Ford: we'll keep the supply down a little, and with constant demand, we don't need to give any rebates, the demand will be there. Ford did the opposite: lets flood the market with Rangers, and give out big rebates.
Eagle,
It's the same used on the ZR2. If that's the gov-lok, then that's what it is. Here is a link to the Eaton locker http://www.torquecontrol.eaton.com/
"They are never going to sell you a vehicle at a loss."
-most of ford and chevy's cars are sold at a loss and have been for some time. they have been making up for it with their trucks/suv's.
