GMC Sierra: Problems & Solutions
http://forums.vmag.com/suvtahyuk0301/messages/5078.html
Thanks! :mad:
Rotors can get warped by uneven lug nut tightening with an air impact gun (unless they use a torque extension with it). Did you have your tires rotated and did they use an air gun on your lug nuts to tighten them? However, warped rotors usually cause pulsation it the brake pedal and chatter when braking hard at high speeds. Brake chatter at low speeds under light braking conditions can also be caused by sticking cliper sliding pins.
Thanks barry
I know of no site where they're listed. Maybe someone else does.
DTC B0229 relates to HVAC Recirculation Door Position. Whether it's induced by your programmer or is just one of those maddening coincidences is anyone's guess; since both PCM and HVAC Control Module involve 'memory' it may not be coincidence. If your recirculation controls are working properly I'd clear the DTC and not worry about it unless it recurs.
If your controls are not working properly you may need recalibration or some other action which means a trip to the dealer, (after restoring factory program).
-David
Dave
What you are describing sounds to me like a problem with the ABS system. Either way it is a warranty issue and should be addressed by the dealer.
When did GM begin using Multiplex wiring?
Has anyone else experienced this type of problem?
I just recently baught a 2006 GMC Sierra crew cab 5.3L. I am just wondering, if any of the problems from the past years such as 2003 on are still problems on the new 2006's. If so what are the problems and what should i be keeping an eye on. Any help would be appreciated. thanks
I have a 2003 gmc sierra truck that has the same speedometer problem , jumps up to 120 and then sticks at 30 or so when stoped . Does anyone know the resolution to this problem? :mad: :mad: :mad: reply here or to davesworldd2002@yahoo.com
I experienced the same problem with my 2005 1500 Sierra. I have the extended cab 4x4. At around 6,000 miles I noticed a vibration only in the steering wheel, not so much in the brake pedal though. I took it to a local dealership. The service techs test drove it and diagnosed the problem as "warped rotors" due to lateral run-out. Gave me a quote of around $170.00 to fix the problem. Slightly enraged...because I had purchased the extended warranty I felt that I should not incure any out of pocket expenses. Long story short...I got in contact with the service rep. as a one time courtesy GMC fixed the problem by turning the rotors. This has caused the vibration in the steering wheel to go away...for now! I figure it is only a matter of time before the problem resurfaces. Try contacting the service rep. and insist that they replace the rotors with new ones. I should note that when I took my truck in for the problem I was out of the "friction parts" warranty period by 500-1000 miles, due to my work schedule. So do not delay.
thanks, rex
My truck only has 15k on it and I'm kinda in shock about it.
What did you find out??? :confuse:
check in. When my truck was under warranty I had to
continually take it back for things I thought should not
have been a problem. Latest is the drivers side bulb.
I have always noticed the large amount of similar trucks with burnt out bulb and have wondered when my turn would come. Well it just did, and the bulb and socket looked like it had really got hot. Anybody else seen this. Excuse me if this has been asked. I am new to the site.
Russ
in NY !!!!!! Hows the AV treating ya? I note your
posts at the AOC threads. Gonna visit "home" this year?...............geo
Russ
THe runing light will need a new socket soon as it is fried. Other than these two problems I am happy with the truck. 150000 miles and still runs great with no repairs
I had read that before but could not remember where I saw it or what it said.
cwinchester
i have had very few real problems,listed below
1. two starters
2. fuel pump
3. windshield wiper motor and control. wagoner had his secretary call me personally to tell me gm won't pay for it.
4. two exhaust systems
5. replaced front pads, rear shoes still have life
6. numerous batteries lost count
overall this was a good buy. the v6 gets over 20mph on the highway. the engine still runs smoothly and does not burn oil. the auto trans serviced at normal intervals is starting to show some feebleness.
negatives, wiper motor should last for the life of the vehicle. the am portion of the radio works poorly.
main question? where can one get a new arm rest on the drivers side for a reasonable price?
bob
AND does any one a a fix.
Now the only problems I have had so far with this truck are.
1. Fan motor & wiring burnt & replaced
2. R/front hud assembly relaced.
3. Headlights burn out every 60 to 90 days when using Silver star headlights.
headlight "bulbs" are NOT supposed to be touched by bare
fingers because the skin oils are transfered to the bulbs
causing premature failure...............
This is usually noted on the package warnings..........
I've also heard from other sources not to touch HID bulbs with bare fingers; It's likely the source of many failures.
-David
