Visitor Agreement.
I've got the 3.73 and regularly tow 6000lbs without any problems. A little slow on the uphills, but it doesn't seem to be too much of a strain at all. The 5.3 is a great engine.
Just be sure your trailer brakes are working. The real strain happens if you try stopping the 6000lbs without them.
I know you have already done this, but try it again might be suprized.
bobby
I replaced the battery, but the problem has persisted. I usually just have to adjust the cable a little and tighten it, then the truck starts ok for awhile. I will be replacing the cable when I have a little more time.
Manny
I have read all the strings on this board about replacing the intermediate steering shaft and would like to know if this still applies to 2003's. The only TSB that I have seen posted on this site is one from 2000. If I don't get this fixed, I may go crazy. Any info would be appreciated.
now I have a new problem with my 96 Sierra, any ideas before I have it towed.
the starter turns over fine, no run
the fuel pump runs. getting fuel on the rail.
pulled #1 done comp test 150lbs. put the plug on the #1 wire
it's firing.
put some gas in the intake still no run
pulled the cap and rotor button looks good
tell me something good thanks
I have a '02 Denali which had the problem. The fix? I lowered the front end 1" and no more slack in the steering shaft.
The Map Lights are #578 Bulbs and I am haing problems finding a cross reference for this OEM Bulb Number as well as how to remove these bulbs from their housing. I can easily remove the Light's Clear Plastic Cover and from there I am stuck physically removing the bulb?
Can anyone help me out???
Anyone have any ideas?
