Visitor Agreement.
The owners manual says that it probably means a misfire or something like that. If it blinks on and off it says that could mean something more serious. Next oil change I'm going to have them put it on the computer and see if there are any codes in the trucks computer
kip
http://www.autotap.com/products.html
kip
kip
I know of at least 5 other people who are having the same type problem but none of us are getting any help from our respective dealerships.
Any advise or knowledge would be helpful.
Billy
Well at 53,000 miles my truck engine died. Took this into the dealership($300) found out that 8 cly had no compression. took off the valve covers found that the spring had broken. and now the valves on that cyl will not keep the seal. So to fix that is $1,400. I though these were good trucks/engines? before I bought this, I had a ford got 165,000 miles on it never one problem.
Anyone else ever hear of this problem at only 53k? I know this will be the last gm I ever own.
GM Makes a 327 engine?
The 5.3 is actually a 325
Ray T.
My dealer has replaced the master cylinder, rotors, pads and bled the system many times with no improvement.
As a result of trying to resolve this problem several brake problems which are routinely found on GM vehicles (especially trucks) came into discussion.
1. Brake rotors rust very quickly. Several days of no use can develop corrosion on the friction surface. (For example: My 2K GMC and 95 Buick).
2. Brake calipers (especially the inside rear) will frequently hang-up and quickly rust in place. This will definitely cause the rotor to rust.
3. Depending on the corrosion potential, regular cleaning and lubrication of the caliper sliding surfaces could eliminate the problem. In New Hampshire, every 6 months will be my schedule.
Before ABS systems, a soft pedal would be the result of air in the hydraulic lines. I was assured that the bleeding system they use is completely effective, I'm not so sure. They bleed from the master cylinder to the ABS module, then activate the ABS to pressure the rest of the system.
I would appreciate any information that would help to correct my brake problem.
Ed
Ray T.
Hope this off sets some of the negative reviews you have read. And makes your decision easier.
I am sorry to say I now have a 2002 GMC Sierra
5.3 and it has bad piston slap at 15,000 miles and GM is not (at this time) going to remedy this problem and pawning it off as carbon buildup. So if I had it to do over again I would wait until GM has a fix for this problem.
Check out this website http://gmpistonslap.tripod.com/
Thanks - Matt
Ray T.
I put a small bead of silicone sealer between the gasket and the glass on the sides of the windshield and no more noise.
Mike L
2K GMC SIERRA 5.3 Regular Cab, Short Box
Ed
Ray T.
I just ignore it.
Shoot, if these trucks were as noisy as any of the old 60's and 70's cars or trucks you wouldn't be able to hear the knocking.
Mike L
- Rain?
- Dry road?
- Heavy snow?
- Dirt road?
Mike L
My moms blazer also does the same thing. Her 4wd module did go out recently but that didnt have anything to do with the growl
Since you are going 60mph, the ice and snow are not covering the entire road, probably not even most of it. With most of the road being clear pavement, is it possible that you have enough traction that the 4wd system is starting to bind up? You have to have some slippage to allow the front and rear drives to synchronize. When turning, the two ends drive at slightly different speeds, and that causes the 4wd system to start to bind up.
You could verify this by shifting back to 2wd for a second. That would relieve any binding in the 4wd system. Then shift back into 4wd. If the noise is gone for awhile, that is probably what is happening. If the noise doesn't go away at all, then something else is happening.
I've never had my 4wd engaged at speed. Most of the time in 4wd I'm off the road at low speeds. If I'm on the highway and in 4wd, it is snowing heavily, the road is covered and packed and my speed is closer to 25mph.
Mike L
