Visitor Agreement.
Here's a little trick when you're stuck like that: Depress the parking brake (won't work with regular brakes) about a quarter to a third of the way; you don't want to lock the rear wheels, you just want to slow down the spinning rear wheel and provide it a little resistance. Once that wheel isn't freely spinning, then the limited slip can shift the torque over to the side that has better traction.
Go find yourself a patch of ice in a parking lot and go practice it. You may have to try it a number of times before you figure out the right amount of brake pressure you need to get out, but it does work. Your differential is a"limited" slip - it doesn't totally prevent slip, for that you need a "locker" . I haven't gotten stuck since I learned that trick
This will usually occur after hitting a bump while driving in 4X2 mode. This may be due to a
worn or damaged axle shaft support needle bearing allowing the axle to wobble or vibrate in the
within the hub. The entire hub assembly should be removed and the bearing and seals inspected
for damage. If the truck is equipped with manual shift transfer case, ensure the vacuum fitting is
capped to prevent contamination. The axle needle bearing P/N is C6TZ-3123-A. SSM
#13697/8. More info can be found at this site: http://www.intellidog.com/dieselmann/home.html
I print the information from this site when I have problems with my truck and hand it to the Service Manager. They have become familair with the website, it has plenty of info for everyone.
1. Replaced the cup-holder twice
2. Replaced the coin-holder
3. Wrong 4x4 hubs installed from the factory
4. Steering wheel leather be-lamination
5. Squeaky front springs (TSB)
6. Alignment (TSB)
7. Exhaust noise (TSB)
8. Drive-line clunk
My previous GM had 70K miles and not a single warranty item.
Don't get me wrong this truck is bad-[non-permissible content removed] but Ford needs to address the quality control.
So the truck is at the dealer again for the drive-line clunk. Has anybody experienced this problem and found a solution? The noise is heard when shifting form forward to reverse and vise versa.
In the past I have provided the dealer with all the TSBs and pages from the service manuals to correct the previously mentioned warranty problems and still they could not find their way out of a wet paper bag. The dealer is Garden Grove Ford in southern California. Does anybody know of a good truck service dealer in this area.
I'm a Technical Training Manager in the motorcycle industry so I no the mechanics of how things work. Its pretty sad when the customer brings you the technical bulletins and pages from the manual and tell's you what's wrong and you still can't fix it. As you can tell I'm very frustrated.
Truck is going in tonight for the front springs.
Is there anyone else out there having this problem. If so please let me know.
I own a 250 CC, v-10, 4X4. I've experienced the same problem with the limited slip rear end. The dealer checked it and said it was within specs (surprise!!!!!). The trick that wpalkowski suggests is one that is used on vehicles without limited slip or posi-trac. By applying friction to the spinning wheel with the brake, some of the power will be transferred to the wheel with traction. Well, I agree. What is the point of limited slip if this is what we need to do? I still think something is wrong with the SD limited slip rear. My father-in-law's f-150 has limited slip and you can feel it lock up when one of the rear wheels break traction. No brakes required. Maybe enough of us will complain and get Ford to check into this. We aren't the only ones with this problem.
Long time, no post, Hi to bowhuntwi and bess especially. How's it going? I have 28,000 on the 250. I like it as well it likes gas... (except for the squeaks).
They (Ford)were testing four wheel steer 250 & 150 4x4's with trailer tow set ups. Sweet. Parked like a Miata.
Sorry about the late post, I've been off here for a while. I saw where I posted about the springs back in December. Time to go back to the dealer.....
I share your pain in going in for warranty work, what angers me is I have to go in and wait four hours or so to have them tell me they need to order parts. So every problem takes two trips despite the fact I tell them the part numbers. Their answer is "we" internet savvy people don't necessary know whats happening, yet I've always known more about my truck, from day one before I even ordered it. Of course, if quality was job 1, we wouldn't be there in the first place.
Here in Georgia, there's a "Lemon Law" that says the dealer has three tries in two years to fix the same problem or you can make them buy it back. At what price, I don't know. I still like my truck, but to pay $32,000 and have it sound like an old wagon is outrageous.All you have to say is "Lemon Law" and they react.
It's fast, it's comfortable,it looks good, and pulls my trailer like a locomotive. IF I have to keep it squeaks and all, I will and I'll replace the spring tip isolators with 2002 versions or whatever I can get.
But by gosh, I'll threaten, document and get every new part I can before that two years is up. On my 94 F150, I had rotor warpage that was eventually traceable to the compounds used in the pads. Just before my warranty expired, I was in for the third time to get the rotors turned. I made them put new discs (which incorporated the locking hubs @ $150 each and specified non-Ford pads. I drove that set of discs another 90,000 without turning them but once. Why they couldn't do it right the first two times is beyond me.
This is my third time on the springs. I noticed today that when the air temperature hits 65-70 degrees, it stops. To me, that's the wrong compound in the bushing. The new springs on the rear are MUCH better than the front ones or the old rears. I'll bet you $20 this is a problem that's pretty unique to 2000 when they were so far behind on production and they used multiple vendors to catch up.
Ford better get it's pocketbook ready. I want new front springs. I have an idle problem which is particular the V10 and involves somthing called the oxygen valve. I guess they bought it from Oprah' online site (har,har). The dealer told me to make a list, and I am.
I had an electrical"bug" happen in the rain the other day. All my instrument lights, the OD light, the ABS light, AND the speedometer flashed or quit. I 'bout died, myself. I truly know that Jaguar and Lucas, Lord of Darkness, must be helping Ford design electrical components. It acted just like an old Triumph TR6 in the rain.
I'm making a list and checking it twice. Ford better be nice.
I've even considered the Dodge or Chevy, but I just find it hard to commit that heresy.
Spraying the spring area with teflon spray absolutely silences it (for about 4 days).
This reminds me of a control arm bushing problem they had 7 years ago. Seems they had two different hardnesses of rubber and the compression rate was different, so the front end steered itself to the softer bushing when you braked. Scared me to death.
Sorry for the long post. I needed to vent a little. I'm going in on Wednesday next week. I'll let you know what happens.
When going 65 mph pulling the trailer, I was at 3000 rpm. That seems too high to me. When I turned overdrive back on, I went down to 2500 rpm. Someone told me that NOT turning off the overdrive when hauling caused them to burn out a transmission. My truck seemed to do best on the hightway with the overdrive ON. What am I missing about this?
The tranny 'builds heat' only when its slipping.. So when your towing if its constantly switching in and out of the converter lock, or shifting between 3rd and 4th, then you should turn off the O/D (to keep it in 3rd).
But if it pulls just the load in 4th (and the torque converter lock stays enguaged), then your just fine..
Some folks will put a extra tranny temp guage on their trucks as a good way to see if your overheating the tranny.. This is the best way to tell if you can safely pull in OD or not..
Sorry for the long post, just venting some steam.
I believe dealers can start taking 2002 orders sometime after the middle of May. Supposedly May 11th is the last day Ford will guarantee orders for a 2001, after that date you'll probably get bumped over to a 2002.
Here's a link to 2002 order guides:
http://www.sunrisefordfleet.com/guides/
Some new colors, and other incremental improvements - new headlights, better seat padding, and a 6-speed manual for the gassers.
4R100 heating. The 4R100 in my 99 F350 V10, 4.30 never operates with the torque converter unlocked except during a shift as long as I am going above 30 mph in any gear once it locks up the first time. This and the aux cooler, which is in front of the radiator, should keep heat significantly lower than earlier models. I do turn the OD off when in the mountains but mainly to provide needed deceleration when going downhill. I tow a 14,000 lb. 5W trailer.
Ya got me curious enough that for sure I'll take another peek..
The other case was where Ford recommended lightly applying the e-brake in certain cases to help get the Limited slip rear end work better if your in a real stuck situation.
I didn't think there was a chiltons available on the SuperDuty yet.. (only the F150's).
Also, the SuperDuty didn't even exist until 1999. Remember that the SuperDuty platform is completely different from the light duty F150/F250 platform. So it is unlikely that they'd have one manual to cover both the light dutyF150/F250 and the Superduty..
If your only driving 5 miles each way to work everyday, then there might be other issues to think of, but this is the case with almost any engine..
From my understanding, only the engine itself is warrantied from the factory for 100k miles. The rest of the powertrain, and truck are 3/36.
I have some concerns about towing with an '01 F250 CC 5.4 V8. I understand the truck comes standard with a "Tow Package," but what does that include? NONE of the dealers here in So California can give me any specifics. Trans and oil coolers I'm assuming, on top of other things?
I will be towing a "lite" trailer that is appx 5K lbs wet weight, along with all my camping and recreational gear and family.
I realize a 250 may be "Too much truck" for this task, but I have a relative at Ford! I just want to be sure I get the truck properly equipped right from the start.
Any thoughts and experiences would be appreciated.
The 'trailer towing package' adds:
- wireing harness
- Front stablizer bar (4x2)
- trailer brake wiring/feed kit
- heavyduty 115 amp alternator (gas engines)
*source= 2000 Ford Commecrial Vehicle guide which includes the specs for the SuperDuty line.
The truck your considering will have no problems with your trailer.. Enjoy the time with the family.
Roger
00' F250 SC xlt 4x2 5.4L 5sp 4.10LS
Go over to www.ford-diesel.com and search in the "general questions" forum for "spring isolaters" or "spring noises." Ford has been replacing springs with some revised version - works for a while, but guys are reporting that the noises come back after a few thousand miles
Other thought, I have '01 F-350, V10, CC, and I was getting thunking noises from under the truck when going over bumps and also on tight turns. It turned out it was the cab mounting bolts that were a bit loose. Dealer torqued all the bolts to spec and noises went away - unfortunately it's a pain in the butt job because seat and carpets have to come out to get to a few of the bolts from what they told me. I had to go back again because they managed to jam up rear safety belts when reinstalling my seats. Now if they could just fix the V10 exhaust flutter...... :-( I'd have an absolutely perfect truck.
If you think there's a problem with the alignment, then take it to the service department and ask if the alignment is at no charge givin there is less than 12k miles on it..
I have the 01 F250 SC. The recall was about the front outboard belts. It said that when the belt is buckled in a slow manner, the red button wouldn't pop back out all the way indicating a complete catch. I haven't tested mine (I buckle too fast I guess.) I have the seats where the belt is in the seat instead of hanging from the ceiling (a mid-2001 change.) Maybe only these are affected?
I've read on here problems with every pickup out there. Some are just luckier then others. Only 6 weeks into ownership, but no problems so far. The recall I mentioned earlier must have been for pre-mid-2001 models. My seat belts are just fine.
I just bought 01 350 CC DRW Diesel. Wanted to know if anyone had any suggestions (go to sites) for purchasing an attractive toolbox that would go across the bed (along the rear window). I found a few diamond plate boxes ranging in price from $300.00 & up. Any suggestions would be appreciated????
