Visitor Agreement.
come accross a bump in the road the tires begin to hop as if i dont
have shocks. it is a bad feeling especially when on the freeway in
the middle of a curve, the truck will actually skate / drift while the
tires lose contact with the road . it happens at low speeds too ,
mostly when i encounter a series of bumps. the suspension just
goes into a dribble like a basketball. i checked the tire/air pressure
and it is correct. the dealer says bring it in but ofcourse they are
located far away and i havent had any luck getting a ride back from
the dealership.
I have contacted Ford consumer services, the general manager at the original dealership, and had the local service manager pass on my info to the local Ford Rep with the willingness to negotiate outside of hiring an attorney and have had 0 returned phone calls. I've been very cordial throughout. Since Ford doesn't seem to care about this defect I have elected to hire an attorney and pursue the Lemon Law in order the recover not only vehicle costs but collateral charges as well...trade in, taxes, license and registration and attorney's fees. The BBB's formulas are skewed in favor of the manufacturer since they are paying for the BBB's autoline. Even if you win, YOU LOSE!
I apologize for writing so much but just wanted anyone with the same problem to know what you are up against. Please feel free to email f150vibes@aol.com for any questions or comments, I'll welcome all. I would really like to know if anyone has pursued the same course and what your results were.
Thanks :lemon:
kcram - Pickups Host
I have a 91 f150 with 145k miles on it. Been a rock-solid truck, absolutely no problems until the last month, in which I have dropped $800 in trying to have two mechanics identify why it stalls a few times and then wont start.
It has a 5.8L engine. Regular service and maintenance all of its life. About a month ago, the check engine light came on for what I am quite sure was the first time ever. The engine began running really, really rough. When I put it in gear, it didnt have enough hp to move the truck. I put it in park, turned it off, and restarted. After restarting, everything was cool.
I had the same problem later that day, and the issue got gradually worse over two days, while also getting harder to start until it just wouldnt start. Had it towed to the mechanic. He said it was a faulty plug wire, burnt plugs, and dirty fuel filter. I found this odd, since I just changed the plugs, wires, and distributor cap within 6 months ago. But their change-out of the plugs, wire, and fuel filter fixed the problem....for all of 1 day.
I drove it for that day, and the scenario started over again. This time I had it towed to a different mechanic with more diagnostic equipment. He ran a computer diagnostic on it, replaced the main relay, added fuel additives, changed the emission check valve (unrelated, I think), changed the ignition control module, and replaced the Thick Film Module.
I drove it for a day and a half, and the problem (stalling, half-power, check-engine light)started back up the same day i got it from the shop. By today, it will not start again....
Mechanic says next step is to replece the fuel pumps (dual tanks, so replace both). The problem occurs no matter which tank I am on. It is hard to believe both pumps went out at the exact same time.
I have now put about $800 in a truck that is worth just about what I have paid in repairs. Does anyone have suggestions as to what the cause of the problem could be? The fuel pump replacement will run another $800 (400 ea), and I hesitate going there on a vehicle this old.
Mark
Also had them look at the interior light banging against the roof when hitting a bump. I have the moonroof and they blame it on that and not enough support in the head liner. Said they are "researching" problem for a solution but I may have to just live with it! :mad:
I just purchased a 1994 F350 4x4 quad cab (crew cab?) with a 7.5L engine, and I don't know whether or not it is what people refer to as a "Super Duty". Would it say on the side somewhere? Is it just an option package? Can someone help me out here?
Make : FORD Model : F-250 SUPERDUTY Year : 2005 Manufacturer : FORD MOTOR COMPANY Crash : No Fire : No Number of Injuries: 0 ODI ID Number : 10114952 Number of Deaths: 0 Date of Failure: March 10, 2005 VIN : 1FTNF21545E... Component: SUSPENSION Summary:
F250, SUPER DUTY, 3/4-T, 4X4, 4WD, SHORT BOX. ALL SPEEDS IT IS NOTICEABLE. AT HIGHWAY SPEEDS (75+ MPH), ENCOUNTERING BUMPS, SEVERE SHIMMY IN FRONT END, NEARLY CAUSING LOSS OF CONTROL OF VEHICLE. FLEET OF 7 TRUCKS ALL EXPERIENCE SAME, SOME WORSE THAN OTHERS. DEALER HAS DONE ALL POSSIBLE TO REMEDY, INCLUDING AFTERMARKET HEAVIER DUTY FRONT STEERING STABILIZER (AT OUR EXPENSE). INCIDENT DATE IS LAST DATE IT OCCURRED TO MY CRUISER TRUCK. IT HAPPENS EVERY TIME A BUMP IN THE HIGHWAY IS ENCOUNTERED WITH EVERY TRUCK OUR DEPARTMENT BOUGHT FOR USE AS LAW ENFORCEMENT VEHICLES. THE MAGNITUDE OF THE WOBBLE IS DEPENDANT ON THE SPECIFIC TRUCK AND THE SPEED TRAVELED. REALIZE THAT AS LAW ENFORCEMENT RESPONSE VEHICLES, OFTEN THIS INVOLVES VERY HIGH SPEED. THE HIGHER THE SPEED, THE WORSE THE PROBLEM.
Also, what is the expected life of one of these engines? 200,000 miles or more I hope..
-J
Thanks, Tracey
Any suggestions?
It seems a bit far fetched to think that both fuel pumps went out exactly at the same moment. Any help would be appreciated, thanks.
Good Luck!
I can't believe FOMOCO doesn't have a recall or program to replace the defective plug housings. It seems that the housing retainer breaks from the hardening caused by the high
heat in the intake manifold. I've been a faithful FOMOCO person since I've been driving (>40yrs). Ford better get on the ball with this one (remember the explorer aka exploder) incident? I don't want to bash FORD ...but...(Fix Or Repair Daily?) If they have a problem they should issue a recall and replace the plugs..end of convo!!
The most likely problem if you have a 4X2 is the right side inner tie rod is worn at the pitman arm. (About a $100 part plus labor)
If you have a 4X4, the most likely problem is the track bar is loose at the axle. Remove cotter pin, hold bolt with suitable wrench, tighten nut, install new cotter pin.
There may be other problems too.
Harry
Check the fuses, there are a couple of areas they have the fuses on this truck.
My truck was wrecked, and the fender taken off. This part is now unnatached from the frame, and it is effecting my electrical system.
Does anyone know what this part is called?
Ridgedon
Words alone can not describe the extreme "Earthquake" type shaking/vibrations of my 2004' Black F150 Lariat super crew truck. Since "New" right off the showroom floor this truck "vibrated". I will tell you this, "vibration" is too kind a word to describe this vehicles defect! Without hesitation these trucks define the word "LEMON" along with a manufacturer not willing to accept any responsibility for problems that clearly have crossed the desks of many higher-ups at FORD.
Ridgedon
If severe overheating is detected the engine goes into a 'limp home' mode and will throw a code, i.e. intermittent firing and a 'check engine' light. A faulty temp sensor will produce exactly the same result.
So, is your engine really overheating, or does it just say it is? :shades:
Please advise?
I suspect the tank switching solenoid, as I have checked all the solenoids under the hood, and all are good.
Is there a way I can determine if that is indeed the problem?
any idea what is going on here? Is this going to cost me a lot of money to fix? Should I extend my warranty??
Thanks....
This truck is used and the original dipstick was broken off at the tip when I got it.
I finally got put a replacement dipstick today,that came from a wrecking yard.
I put this new dipstick in 1 time and read it. The level was ok. Then I put it in again and now it will not come out unless I pull hard. I,m afraid something will break. Thanks for any input.. I am a truck novice
This first problem surfaced itself, and I took it to a dealer. The dealer listened to me. The gauge would fluctuate for awhile, and then go to nothing. I would immediately turn the engine off. I had it towed. The service station dropped the pan, and cleaned the screen. Things would be great. By the way, The first thing I did was at the oil station. They did an engine flush. NEVER EVER DO ONE OF THOSE!!!.
After they dropped the pan, they cleaned the screen, and things were fine for the next year and a half. Same problem, took it to the same place, they checked it out. Cleaned the screen. Said it was not gunked up as much as before, and everything was fine for about a year and a half.
The station had told me that it was gunked up the first time, and that I probably made it worse with the engine flush, by breaking loose more gunk.
Well, I am at my third or fourth time of this. I am about to take it in for service. I am contemplating having the screen replaced, and replacing the sender unit. That is about all I can do I think. I do not have alot of money. They say to replace the pump, I just about have to rebuild the engine. I do not have that kind of money.
Any ideas? Anyone else having this same sort of problem ?? Is this a known issue with Ford?? Why is the Ford F150 so susceptible to the oil gunking up ??
A friend of mine had a '00 Expedition with the same problem, only the flashers would go on and alarm would sound when it rained, eventually draining the battery. He fixed it by replacing the truck.
Good luck!
