:lemon:
SUVs and Smart Shopper
You may just need to take it to the dealership and have them look at it since it could be a programming problem.
I had one guy say he thought it was the catalytic converter, but I can't get that tested unless the "check engine" light is on.
The dealers are the one's that suggested I drive her till she won't start again. Not very insightful. lol
They did something to the AC relay.
Works fine now !!
If a good battery keeps running down then it's also possible that you have a constant drain on the battery due to an electronic problem.
I have an 06 Sierra and have the same problem
Once its on it will stay on. Let it sit overnight and she's toast.
Good Luck.
Texas
Thank you for any help.
Good Luck.
