Visitor Agreement.
___________________________________________________________
Your LTZ has full-time 4 wheel drive and as I recall you have the bigger 6.0 V-8 and the 3.73 rear axle. With the 20" rims and wide tires your mpg will be much less than the LS and LT models with the 5.3 V-8. My 2006 has the 5.3 engine, 3.42 rear axle and 16" wheels. At 65 mph I am getting 22mpg. At 60 mph I get 23mpg. City driving is around 18 mpg. This is in 2 wheel drive, AC not on, and no stop lite drag racing.
I should be getting my Tahoe in the next few weeks, just want to be prepared for the swap, if it's possible...
I have approximately 3800 miles of mixed driving (including towing boats,snowmobiles and utility trailer) and I am averaging 16.1 MPG year to date. I have validated accuracy of MPG by using a calculator at fill ups.
As we all know, Honda has a outstanding reputation for reliability etc. I was a toyota SUV and truck owner for the last 14 years, so it was hard for me to leep from the security of reliability and minimal depreciation of toyota to GM, but I am totally pleased to date with my Yukon. I am also very pleased with fit and finish. Zero issues to date
I am willing to be a ginnea pig for this first year model makeover for reliability and depreciation and I do not think I will be dissappointed. Good luck in your search.
Apparently, the player is using more memory evaluating the 100+ songs on the CD, so the clock doesn't load when you startup.
I have no idea why it can't load the clock, but once I remove the CD, get out of the vehicle and let the player re-set. Once I startup the next time, the clock re-appears and stays on as long as I keep the MP3 CD out of the player.
It doesn't disappear all the time. But I have learned to expect it when playing an MP3 CD.
Let me know if this solves the problem for you too. GM will hopefully get a software fix for it later if it happens to alot of people.
Oops, sorry 'bout that. I was looking at the Suburban specs and not the Tahoe. You are correct about the engine and drive train. However, full time all-wheel drive is standard on the Suburban LTZ, likewise the 6000 engine.
The 3/4 ton version has the 6.0, and has trim models of LT1,2 and 3. The 3/4 ton version also uses leaf springs (LT1,2 and 3).
However, the 4WD is optional across the entire Suburban line.
These specs are available at www.Chevrolet.com.
" ENGINE, VORTEC 6.0L V8 SFI with Active Fuel Management (366 hp [272.9 kW] @ 5500 rpm, 380 lb-ft of torque [513.0 N-m] @ 4300 rpm, aluminum block (Requires (M70) 4-speed automatic transmission, (GT5) 4.10 rear axle ratio and (Z55) Autoride Suspension Package.)(Requires 3LT Preferred Equipment Group) Code: L76"
This is not on the Chevy site yet, and there was no cost associated with it yet.
Another tidbit I just saw
as another note on the LTZ you can do the assist steps too
ASSIST STEPS, POWER-RETRACTABLE Code: BRS
invoice MSRP
$825.85 $995.00
Unfortunatly, I did not realize the stigma that comes with having an Escalade until after I started driving it. Don't get me wrong, its a great ride, but ....
Dave
Collins
Has anyone added Sirius to their vehicles?
if the gasser gets 22 mpg with cylinder-shutdown i wonder how much better a duramax with cylinder-shutdown would do? those are 6 cylinder engines though aren't they? running on 3/6 or 4/6 cylinders might not be so smooth
All this information was provided to me via email and by phone!
First I did a research about the whole thing ABOUT adding a whole aftermarket sound system.
First like 3 weeks ago alot of people told me that the Interface it's still under development. And about a week later I found this information about it!
It was posted in 4-19-2006.
Click this link!
http://www.jltroy.com/downloads/GM%20Lan.pdf
Please keep reading.!
So this means it's a LAN data bus thing!
And if you looked you saw that it says that is under Development right? But dated 4-19-2006
So I sent an email this guy at Metra Elec. And here is what he sed.
" If you are bypassing the Bose system, then yes, we have a harness for
> you, GMOS-LAN-01. You will need a SP-2003 speaker as well, and you
> will have to slightly modify the GMOS-LAN-01. Please call Tech support "
He also sed that Lan bus thing it's on some 2006 Chevy models so they add it to the 2007! So this means that the interface for those 2006 model with Lan Network will fit the Tahoe 2007!?! SO we can have the Onstar working !?!..
Finally he sent me another Email....
" Yes, if they can get the harness, and they have the knowledge to
bypass the amp and modfy our piece.
The interface has been out for about a month now, but I would assume
because of the high demand for it, and the fact that pre-orders have to
be filled first, it will some time before you may get one.
The parts explained below, 99-3305 or 95-3305 for the kit and 40-CR10
for the antenna adapter is all the parts needed. 99-3305 is for single
DIN installs whereas 95-3305 is for double.
SO here you have it guys!!!
It took me a few weeks to get all this fresh info and of course I am posting it here for you.
Now I will be at this guys's shop tommorrow where they normally install all my sound systems and let them know about the information I got for the 07 Tahoe and they might be able to install my Eclipse sound system withing weeks.
If you have something that I do not know OR if I am wrong in something please let me know, becuase we are all here to help each other and make it right by gathering the right infrormation.
Thanks for reading,
FJ
Devon
I've been looking for the luggage rack cross bars to fit my 2007 tahoe, but have had no luck. I remember seeing it once on the auction site, and so i'll probably try checking back with that, but could anyone direct me to a site that sells them? Thanks in advance.
T.
Collins
By doing it this way, it disables the high/low beam feature that would turn off the low beams when you switch to high. Because of this...Now when I turn on my high beams, both the HID's and the high beams are on at the same time!!! Talk about lighting up the road!! :shades:
Hope this helps...What K temp did you get? I got the 6000K and now kind of wish I might have got the 5 or 4500K. Not really a problem, but the 6000K is a little more bluer than I thought they would be. Nonetheless...They work and look GREAT!!
Anyone else have a storage compartment on the left rear side? (07 LTZ)
