2007 Chevrolet Silverado and GMC Sierra - First Impressions
Typically GM has been a technology innovator and leader. They introduced the automatic with torque converter in the late 40's(Buick) and I believe was one of the first to introduce the locking torque converter on its automatics - sort of like a "5th" gear. The big shots at GM also did ignore/misjudge the "marketing value"/perception of technology leadership some of the evolutions/innovations might bring. They had the technology, but chose to not implement it on volume vehicle lines.
The last I looked for 2007 Ford only has a 4 spd. auto, Dodge has a 5 spd. but it is optional depending on models, Nissan & Toyota introduced 5 speeds to try an match the performance of the others and they have much lower volumes and charge more $.
Is having a 5/6 speed auto tranny necessary? What are the advantages/disadvantages? There is also the comparison of cost to performance. A 5 speed or 6 speed tranny will cost more than a comparable 4 speed to make. If the 5 spd/6 spd gives better performance, mileage, etc... it makes sense. If it doesn't its just more $. A 6 speed in a truck can also be aggravating if the gear matching and shift programs aren't done well. The more speeds the more the tranny may shift up/down under load/speed conditions.
I like not to confuse hype/perception with reality/application. An example is a Pontiac Grand Prix I had and my neighbor had a Camry. Both had V6's (3.8 in mine and 3.0 in his). My GP had the 4 speed auto and his Camry the 5 speed auto. The GP seemed a little quicker and got better mileage(and cost less). Yes, we were different drivers, but the best hwy mileage he ever got using cruise and the speed limit was 29mpg. I consistently got 30-32mpg. So, the 5 speed tranny wouldn't have given the GP any advantage.
Rocky
I also think that buying one of these trucks right now is not the best idea. You can get a fully loaded '06 Duramax 2500 4X4 crew cab for thousands less than you will pay for an '07 1/2 ton 4X4 LTZ crew cab.
I know I wished they offered it pal. A 6-speed Allisson manual is sitting on the parts shelf. It unfortunately is only available for the 3/4-ton and bigger trucks. :sick:
Rocky
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I think an American truck buyer that is given the choice of a toyota and a chevy will pick the Chevy. The only ones who don't will be the ones who think America is the cause of all the worlds problems, and they need to move to France anyway!
This new truck will blow you away! Two all new Interiors with materials and fit and finish that are world class. The body with stamped panels for increased strength and a fully boxed frame that is 230% stronger than last years! On top of everything, class leading engines that get the best fuel economy of any fullsize truck, which they were doing already on the 2006 model truck that I bought!
All-in-all I think GM has once again set the standard and everyone else will follow for the next 5 years (at least). I truly believe that this truck will single handedly pull GM back into the black and dominate once again.
Rocky
I've owned 1990 and 2000 4x4 1/2 tons. They will be the last Chevys I ever own. I'm saying goodbye to warped rotors, fuel pumps that are guaranteed to fail, and power steering pumps that go every 100K miles like clockwork.
Drum brakes? Are you kidding? No manual transmissions AT ALL? A 4 speed auto when others have 5 or 6?
Bankruptcy. Five years at most.
As far as drum brakes in the rear... unless you live in an area that doesn't get snow, ice, and mud, the drum brakes help protect the rear brakes and tend to last longer than disc brakes (plus no warped rotors). In areas that have snow, ice, dirt, mud, etc. the rear disc brakes tended to get full of this debris and caused problems. So unless you live and drive only on pavement, the rear drums make more sense.
As far as the 4 speed automatic, GM will probably be coming out with them in the next year or two. Then they might be getting up to 22 miles per gallon? The only reason that the competition is coming out with 5 and 6 speed automatic transmissions is to try and keep up with GM trucks in the fuel mileage category. Which I might add they fall short, very short. Even with a 4 speed automatic transmission, the Silverado is about 2 miles per gallon better than the closest competition... and that is with a more powerful engine!.
It should read,"when you're 5'11", and forced to the third row you need all the room you can get!"
I wished GM, would of allowed us to select the ventilated seats and Bose 5.1 option boxes off the Escalade to make the perfect pick-up.
Regardless its still a very nice pick-up but just not perfect because of 2 items missing.
Rocky
Lou
I noticed a 5 (or maybe 6) speed auto in a 2007 Yukon Denali but all of their trucks do not offer it.
I checked the Chevy dealer and I didn't see a 5 or 6 speed auto in the Suburban, Tahoe or Silverado.
I'm waiting until they offer the new trans before I purchase one.
Thank you for contacting Chevrolet and your interest in the Silverado! We appreciate you taking the time to contact us.
Unfortunately, the half-ton 2007 Chevrolet Silverado will not offer a 6-speed transmission. From time to time mid-cycle changes and additions are made to vehicles, but at this time, there have been no announcements regarding a 6-speed transmission in the half-ton pickups. However, the 2007 2500HD and 3500HD will offer a heavy-duty 6-speed automatic and an Allison 1000 6-Speed automatic with OD. We apologize for any inconvenience this may cause.
For more information on the 2007 Chevrolet Silverado, please visit www.chevrolet.com or contact your local dealership to schedule a test drive. If you are not familiar with the dealers in your area, an easy way to find one is by using the dealer locater web tool at www.chevrolet.com.
The six-speeds will be going in as soon as they are fully ramped-up in production.
By the way, I think they look much better in real-life pictures.
I cannot wait for the hybrids.
What do you think about the hybrids?
since 2005-2006 in Tahoes/Caddies??????Any problems ?I haven't been able to find too much info. on this subject. I am worried about long term problems down the road. I cant believe GM doesn't offer a regular 5.3 without A.F.M. as an option. Any thoughts??
Bobberino
I along with those 2 requests also requested tonight via phone call once again to GMC to make a 3/4 ton version of the Sierra Denali so I could get a Duramax Diesel :shades:
Rocky
The Sierra Denali will have a 6-speed automatic transmission and yes the engine is the same new 6.2 VVT V8 found in the Escalade. My wife wants to buy a Truck or a SUV as our next car while I want to buy a 2008' Cadillac CTS or 09' CTS-V. I might cave in and wait for the 2008' Sierra Denali hybrid and buy that. I however would like to see if GM. is going to make a Duramax Sierra Denali for the 3/4 ton.
Rocky
I will ask you though:
That was well nigh twenty years ago. When will you let go of old stereotypes?
Back then there was nothing like the internet and very few people had personal computers.
Back then, cell phones came with a large carrying bag remember?
You'll be just fine.
And for added security, you have a 100,000 mile warranty.
Thank-you, I couldn't of said it better myself.
Rocky
P.S. I was told in the ELLPS forum that I didn't have a job and should only give opinions on Bikes and Bigwheels :surprise: It's amazing how cold some people can be torwards someone who likes and defends domestic cars. :sick:
Do you like how it switches from 4 to 8 cyl. I am just thinking that sticking with what works and is proven(4.8ltr) is better than this newer motor that is essentially unproven
over the long haul. I only tow a small boat so I don't need mega power. Hell, my old 94
4.3V6 has only 160 HP and it was OK for what I Needed (a bit underpowered I admit).
But its still kicking with 164,000 with an iffy tranny.
GM obviously has alot of confidence with it to make it standard on some trucks???
Rocky
I would like to know where you found or took these pictures at ????? What autoshow is this ?????
Thanx,
Rocky
P.S. If you happen to find any more cool pictures like these of the 07' GMC Sierra Denali please post them or send me a e-mail of them....wow :shades:
Also incl. with the L76 pkg. are external auxiliary engine oil and transmission oil coolers. I think this is a good idea and long overdue. Oil is the lifeblood of engines and transmissions. Keeping it cool will help performance and longevity.
So, the L76 pkg. has several goodies besides the bigger motor. A good deal if you need these items, the L76 pkg. is $1,095 MSRP/$908 Invoice.
You cannot learn these various quirks on the internet sites. They are only clear on the proprietary and very detailed software that the Chevy dealer has.
Rocky
Rocky
Rocky
Rocky
Rocky
Ordered a 2007 LT2/ 6.0 ltr Silverado last Thursday. Should take 10 to 12 weeks to receive. Since I will be towing a 5300 pound airstream, I needed the extra HP and the heavy duty trailering equipt/ package. To find a 6.0 ltr with the options that I wanted on the truck would have been nearlt impossible here in San Diego. Every 6.0 ltr on the internet seems to be white or black and under optioned. I went with blue granite metalic. Hope it doesn't show the dirt. Anyway when I get the truck I will post my opinion especially about the towing capabilities. I may have paid $500.00 more than I should have but I am okay with that when I order a vehicle " custo " ....367 hp, ya that will be enough.....
Chromedome
Rocky
P.S. I wouldn't expect before March based on what I know and have spoken to people from GMC's customer service reps.....
