Dodge Dakota Problems. Please help!
If any one else has had this problem I'd love to hear any suggestion since we are not comfortable to take the truck on a trip. (Other than that we love the truck. (apologies for the long post
Does it "sound" like a high rev of the engine, or do you see the tachometer actually go high.
Bob
If you rev a bit higher /longer, the silicone-filled clutch will disengage due the centripetal force.
This is completely normal function. I'll bet you have not driven many vehicles with belt-driven fans ;-)
4.7 club cab, 45RFE running between 65-70 with AC on.
Add ons>>>>>tonneau cover and K&N air filter.
Final note (not accusing) I run brand name gas, never "cut rate" stuff regardless of how much cheaper it may be. What you save at the pump, you pay for in mileage and potential repairs down the road.
I have about 17K on the truck. When it was new, the mileage was lousy but over time, it has improved a lot. I can get 14.5-14.9 in town.
My daily commute is approx 19 miles comprised of 6 miles rural interstate 8miles of interstate (65 - 70 mph) and 5 miles city. I come to a stop approx 10 - 13 times each trip and have several long hills to traverse.
Overall, I'm pretty happy with the mileage concidering it's just now getting broken in.
I would like to get 20 on long trips as i imagine that I will have several 800 milers per year.
Blue
CHRIS in VA.
After they re-programed the 4WD system, the truck seems to run smoother too.
I have never seen over 18.5 MPG until I recently installed a tonneau cover. In fact, historically my local MPG (at 55 mph) matched or exceeded my highway MPG. I have the 2.55 tires with the 3:55 axle LSD, and 4.7 w/Auto. Since putting on the tonneau, my tank mpg has seen 20.2 mpg- and that was through the mountains of Penn state.
On a recent 2,500 mile trip to NJ and back, the trip average was 20.0 or so!!!! And that was at 70-77 mph, depending on the state I was in. In the past I only saw 17.5-18.0 at interstate highway speeds of 75-80. Basically, it appeared that the more I exceeded 60 MPH, the worse the MPG I got! Not any more!!!
I have tracked and graphed my mileage in a spreadsheet since I have owned the truck. I track mileage by: the tankfull; average over previous 5 tankfills, and; also track the MPG since purchase (now @ 25,000 + miles).
Pre tonneau- overall mpg (over 25,000 miles)was at approx 17.8 mpg. Now, the overall is on the rise again, thanks to the tonneau!! I am currently at 17.98 or so. Also, my local MPG increased to almost 19 mpg.
I am now a believer in Tonneaus regardless of the type or model. If you are interested, I can send you my tracking spreadsheet so that you can see the data for yourself- just send me a direct e-mail.
CHRIS
although mine is right on the money, i see alot of these computers being way off. i have a friend with a minivan and he averages something like 6 mpg by his computer, way off by the way LOL...
would love to hear from you.
robert
My truck has no overhead computer etc as the the a/c and auto trans are my only extras. I have since wired in fog lights because of westcoast climate driving. don't try this yourself though as ford has made this an almost impossible task in order to spite you for not paying them to sell it pre-installed at their exorbitant rates.
robert
If not... your fog lights were current-starved. If one wishes to "get the light one paid for", high-current fog-lights need to be powered directly from the battery.
Any fog-lights I have seen come with the relay right in the box along with wiring diagrams.
The quality of the insulation on a wire is the determining factor when it begins to break down due to the heat. Cheap wire uses plastic insulation that melts at a relatively low temperature. There are many "grades" of wire and all of them specify the characteristics of the insulation.... not the conductor itself which is a simple wire-gauge.
Check out this URL for more info on wire ratings.
http://www.sacelec.com/Current_Ratings.html
For the safety of the folks that follow this forum... Please understand that the ratings on a switch or a relay are absolute maximum limits. Beyond these limits there is a fire hazard. Wire is MUCH more tricky to 'size' for the job because the length has to be considerd as well as the gauge.
To answer your question...how do you "current starve" something?
For foglights, if you measure the voltage at the bulb and it is not over 12 volts....then it is current starved. (The resistance of the wiring and associated circuitry is excessive.)
A more proper way to take this measurement is to measure from the battery+ to the bulb+ . The resultant reading is the voltage drop in the positive side of the circuit.
BTW... Your math is a little fuzzy...(P=I/E) 55/12=4.58Amps (not 6Amps)
BOTTOM LINE;
If you always use a heavy wire guage for your fog lights .... all of the other stuff becomes a moot point. No heat concerns. (plus your foglights will put out more light too!)
bpeebles,
that is an interesting link I use the NEC and according to chart 310-17 a 16 gauge wire is rated at 24A at 194F and ambient temp of 86F wonder why there is such a difference.
I do agree with both of you though a 55w buld in a 12 volt system will not draw 6A but I like the leeway.
Since DC is (by definition) a CONSTANT voltage, the allowable ratings for a given wire gauge may be differ than those calculations specified for RMS AC voltage.
Since this is not an "electricity" forum... I will close this thread here... I promise 8-}
I have a 2001 Dakota QC 4x4. I live in So.Cal and my truck is driven 1-4 times a
week (around 25-50 miles each time).
Whenever I switch from AC to normal Air, and particularly after
using the AC, I get a nasty rotten stink from the blower vents.
(it is there for a moment when AC is first turned on, and after
blower has ran for a while without AC on, the smell is gone)
Any idea what would be causing this ?
Can I fix this problem myself ?
If I have to take it in to the dealer, any idea what they would do
to fix the problem ?
Thank You All !
Ole
Take a good look under the hood..if its an animal,,you'll find the smell...Good Luck, Ger.
I would like to buy it if you folks think its a good deal.
Please share your thoughts here or email me at:
rascal2064@yahoo.com
Rascal
When the AC is nice and cold they are not typically airborn, but when the AC shuts off and the ductwork starts to warm up again they will make themself known to your nose. This is even durther aggravated by moisture in the vents mixing with the smelly entities.
and it is supposed to kill bacteria, molds and such.
Bookitty
No problems....
Got the oil change last week and as soon as I got home and put the transmission on reverse. I heard this loud "CHUG" then metal grind... Had it towed to dealership 2 hours later...
Service adviser said "tranny" went out....
Is this common with 2001 Dakotas?
Or did I get a LEMON?
Signed,
Very Upset Dakota owner
See what some of the others have to say.
Some people say that dodge auto tranny's are problematic.
Your tranny failure seems premature to me. The warranty should cover it though.
The 45RFE is a totally new design (and not my favorite automatic from Chrysler)
Bobs5>>>>>yes, I have to agree with you that CHrysler pissed away a strength they once had in the design and enginiering of their automatics (727, 904, etc)SUffice it to say, they have a poor record with automatics today. Based on the way my 45RFE shifts, I expect it to self destruct anytime. Matter of fact, I pray daily it will so I can have the dealer come get it and replace the eintire transmission. I'll also have the satisfaction of telling the smart aleck technician that no, its not "functioning as designed" Then I'd have him bend over so I can take his work order and.....well you get the idea. Should I buy another Dodge truck, I'll go the route bpeebles and others did and get a five speed.
