I have not had the A/C long enough to drip yet, I guess. Have not heard this sound. I does cool the truck down nicely the few times the A/C was used. Still want to get the rear axle fluid changed as well. Also have to take the truck in for the front seatbelt anchor bolt recall notice. Bolts seem tight to me so no rush. Only 4975 miles on it now. Last fill up resulted in 16.75mpg. Filled it up at 1.45 a gal as opposed to 1.63 a gal last time. Bob
(hairydog) It is common for new lamp assemplies to have water leaks. Every new vehicle I have purchaced had at least one lamp assembly that filled with water droplets.
Just returned from Dorset and we experienced perfect weather, superb people, just beautiful. Went to Stratton Mountain and we saw a Dodge 4x4 dressed to kill, it was an eye catcher. As a matter of fact, we saw many Dodge pickups everywhere we visited. We returned to Florida and the heat index is 108. When we left Dorset I was wearing a jacket 54 degrees. No question, Vermont is a great state. We shall return.
I have a 2000 Dakota CC 2 whl. 3.9 auto LSD rear axle 3.55 gears w/tire & handling package with 27,000 miles on the truck. Within the last 2 months I noticed that after the truck sits for awhile, I get a growling noise when I leave from a parking spot and I take a sharp left or right hand turn. It feels like something is vibrating in the floor and I hear and feel a noise that sounds like it is coming from either the transmission or the rear axle. I also have the typical noise in the steering column and the sqeaking noise from the brakes. When I brought it back to the dealer for the recall, they looked at the steering column and said they will order a new column for me and replace mine. The brakes I can fix myself, but the interesting thing about the rear axle is they discovered that THE WRONG FLUID WAS IN THE REAR AXLE FROM THE FACTORY!!! I think they are supposed to put in an additive to the regular fluid to help the clutch packs in there and they forgot to do it. I was told that no damage was done, but I have it all documented in case I have problems a few years from now. The service manager said he has only seen that happen a few times. After they put in the correct fluid (additive?) the growling noise went away. Has this problem happened to any one else and did they have a problem with the rear axle after a few years? I put about 2000-2500 miles on it after I started getting the noise. Should I have them give me new rear gears? Sorry for the long posting, but I have never heard of this happening before. Thanks for any info anyone can give.
(gilboucher) Sounds fishy to me... Just EXACTLY how did they determine that the wrong fluid was in the rear axle??? How in the world can anyone tell if the additive was added ot not? Just EXACTLY what did they do... (just add some LSD additive or perhaps change ALL of the fluid.)
There has been some reports of noisy rear axles. Several theories abound.
Also, a TSB is available that speaks of the special (meshing tester) compound that is used at the factory where the differentials are asembled. Over time, this stuff mixes with the gear-oil and makes it milky-colored. DC claims that is DOES NOT AFFECT the performance of the gear oil in any way.
To answer your question more specifically; If the LSD additive was NOT put in... there may me some clutch chatter around turns but the gears are totally unaffected. Said another way... the gears in the rear diff ARE NOT AFFECTED by the additive so lack thereof would not cause any harm to them. The additive is ONLY for the clutch pack (as you suggested).
I posted about a month ago about some tranny slippage in my 99 4X4 Dakota. After changing to the mopar fluid (filter and gasket as well) I've had no slippage problems. Thanks for the help.
I've never felt any heat from the thumbwheel, or anywhere on the instument pannel.
The fluid is a different color when the correct additive is used for the LSD rear axle (or so I am told). I'm not sure if they changed the fluid or just put in the additive, I'll check the paper work from the dealer and see if anything is written about that. What are the chances that the clutch pack has been damaged? Should I do anything now about it. I will have to bring the truck back to the dealer to have the new steering column put in, is there any tests they can do to check the clutch pack. Thanks for the help.
Again... IF the additive was not used, the clutches may chatter around SHARP (Parking lot manuvers)turns. puttign in the additive will "fix" any clutch chatter after some sharp turns are made to distribute the additive.
It is unlikely that there is any measureable "damage" and you should not be concerned about future problems.
I am still skeptical about their claimed "fix" for your noise problem. Nontheless... you, as a customer, seem satisfied with the results of their efforts and that is all that really counts.
Has anyone heard of an upcoming recall on the Dodge Dakotas for a steering related problem. A friend of mine had indicated he had heard something about it and it may include the Ram too. He thought it was the '97 and up Dakota models. My 2000 Dakota CC 4wd with auto and the 4.7 has a creek in the steering most noticeable in cold weather and turning to the right. Anyone else encounter this??? Also is it true that rotors will warp from too much torque on the wheel lugs?
I recently bought a 1995 Dakota ext. cab with a 5.2l v-8 with slt package. I've been experiencing intermittent problems with the instrument cluster. Sometimes just the tach will quit, but usually all the gauges will drop out. I thought it was tied to a build up of heat as it wasn't happening until it had been running for awhile but now it seems to have a mind of its own and just does it whenever it wants to. Sometimes the piezo alarm buzzes with it. Anyone who has tackled this problem and can help me fix mine, I'd love to hear how you did it. FRUSTRATED IN FLORIDA!!!!
Try the ON-OFF-ON-OFF-ON sequence with the ignition switch. check www.allpar.com for more details for code retrevial. This should show you what is malfunctioning. Otherwise a fuse may be making intermittant connection which feeds power to the instrument cluster. Good luck, Bob
Recently my engine (4.7L) has developed a loud "puffing" sound that seems to come from the right side of the engine (right when you are looking in from the front of the truck). It gets faster as the throttle is applied, but at idle it is a steady 'puff puff puff puff' about twice a second. I can't figure out what it might be, all the fluid levels seem fine, and it is hard to pinpoint the exact sound. If you squat down by the left front tire you can hear it pretty good. It went away for a minute at one point at the gas station today, but came right back after I got home. Any ideas?
I'm going to have the dealer check it out when I go in for the seatbelt recall, but I wanted to maybe give them some ideas since dealers have a tendency to proclaim everything "normal".
From what you are describing, my first thought would be a exhaust gasket leak. To verify, whith the engine running, I would run my hand (use the back side of your hand, it's more sensitive than the palm) first around the manifold-to pipe connection, then the head to manifold area. Careful! it's hot.don't touch the exhaust, just hold your hand near. It can be hard in such a small engine compartment, but you should feel hot air on your hand if it leaking.
I have a 2001 Dakota Sport Plus with a 3.9V6, 5 spd trans. and 3.55 rear gears. I love the truck, but it has been more problems then it is worth. During the first 4 months I had the truck, it spent over 30 days in the dealers shop. There have been several minor problems that have been annoying and the dealer has attributed to a bad design by Dodge, these being the blower motor does not work very well, the auto headlight dimmer that does not, and check engine light that the dealer just reset and called it a day. The problem that has been the worst is the transmission, since it was new it would "grind" when going into second gear when it was cold and then it started to whine at highway speed (65-70mph). After taking it in four times, the finally re built it, that was only because I did not believe the many excuses they gave me. Well, I had the truck back for about 3 weeks and it started again. I guess its time for some C4....
Seems to me the problem is with your dealer and not the truck. Plugging in the diagnostic computer would reveal to him the reason for the check engine light being on. Usually, grinding gears would indicate bad synchros. I don't know what he could have done in the four tries he had to fix it, other than park it out back then call you later to pick it up. Maybe he only changed the lube. The whining is a little more subjective. i.e. what may seem normal to some is obnoxious to others. Change dealers !!
I have a 2000 Dakota with a 4.7L V8 with a automatic transmission. (45RFE) At 19,000 miles it is leaking at the front bell housing. I brought it to the dealer and they claim it was over filled by 1-1/2 qts. of transmission fluid which would have been done at my local garage for oil changes but so far they didn't fill any transmission fluid. They were the ones who found the leak since its near the oil drain bolt. I wan't to know is this was BS from my Dodge dealer because that service was not covered under warranty. Or has anyone experienced this problem and what it really is. Is it a bad gasket on the bell housing or a bad casting in the transmission or the the transmission itself. The dealer claims that this transmission is pressure sensitive but the day after that it was serviced by the dealer the transmission still leaks and the transmission fluid on the dip stick still shows at hot level actually a little bit above it but this always read this since I owned it. It may be true that this transmission is pressure sensitive but how does this still explain the bell housing area leak. Also when I did check the transmission level it was cold the engine. I would appreciate any input.
(bbigda1) I assume you have officially logged a problem with the dealer about this leakage. It sounds as if your first complaint to them was blamed on an overfill condition.... (Sounds like their first attempt to "dodge" the problem)
Now that your dealer has looked at and logged the problem and the overfill condition has been resolved... NOW is the time to keep a close eye open for further leakage. At the first sign of leakage, your dealer is now "on the hook" to correct it whatever it takes. Since you logged the complainet BEFORE the warantee ran out... they are responsible for resolving any leakage in that area. (Know the law!)
Read your warantee documents CAREFULLY and be prepared to 'escalate' as needed to resolve the problem to your satisfaction.
Many transmissions have a "overflow valve" to allow leakage if overfilled, usually at the top of the inner bellhousing. I encountered this with a 727 Torqueflite equipped Duster I built a few years ago. After servicing the trans, I miscalculated the number of quarts I put in, and when the trans got to operating temp, out spewed the fluid, all over the exhaust. Well, seeing the "leak" I of course put more fluid in to make sure I could get back home. Such began a cycle until I was able to get home and let it cool down and realized how much overfull it was. It does seem strange that after all this time/milage it would decide to weep out unless you were running it exteamly hot. I'm assuming that is'nt the case. The dealer is probably assuming that it was overfilled when they saw the dipstick reading high, not knowing,as you do, that it has always read high. To the best of my knowledge, there are only two gaskets in that area. The front main seal and the front pump gasket. one of these may be bad. I would definatly take Bpeebles advice and keep close track of this and don't let the dealer try and jerk you around.
I have a 01 q/c sport plus, 2wd,auto 3.55 lsd T&H PKG etc.. the truck has about a 1/2 lean in the left front end. the dealer has replaced the left front spring/shock assem a few months ago however that didnot correct the problem.this past fri 8/31 dealer replaced both rear leaf springs and the left front end is still lower then the right. the dealer called d/c tech line and they adv them that the tolarace for the industry is within 1/2 in from side to side. i don't know where else to look any suggestions? dealer and I looked at others on the lot and they seem to all sit the same way...what else could be causing this lean? does any body else have this same lean? ******** i also noticed while looking around under the front end that i have torn dust boot that cover the bushing on the upper control arm. when i did my first oil chg months ago i noticed it looked different from the right. sort of looked pinched or had a rib in the middle and was pushed in. anyways showed dealer and they will order new upper control arm assem instead of just a new boot. the bushings in this truck are nylon. is this good or bad?
Fluid keeps dropping below "ADD" line. Can't detect any leaks. Added about a pint in the last month of driving. Where could the stuff be going? '01 Quad 4.7L 2X4
Well, I got the puffing noise fixed. Turned out to be a "Vacuum Hose". Guy at the service desk didn't know what that meant, but that's what it said on the paperwork. All fixed. Now my Quad doesn't sound like it's out of breath all the time!
'98 dak, 5.2, manny tranny, 3.55, 4x4, c/c, t/h pkg. i got "abs" and "brake" warning lights on the instrument panel. simultaneously, the thing is stalling at about every third stop light right when stopping. these two things happened at the exact day! fires right back up and will run like nothing ever happened, but stalls at about every third stop. i took it out tonite for a short run just to make sure over to the corner store, and it stalled twice. stalling has never happened on this truck before. how the heck could those 2 things be related? makes me wonder if the gas i got was bad, and it is just a coincidence that this tank happened when the abs and brake lights came on. that would be pretty long odds on a truck that never stalled before. i've never had any problems with any of the vehicles i've ever owned. the dodge electrical system is suspect. i had electrical problems at 27,000 miles, a amlfunctioned multi-pin connector, now 32,000 problems. how can i trust a vehicle that would have problems with such low mileage? no way can you put 120,000 on it if it can't even go 32,000. not to mention the fact that the only way i can eliminate engine knock is to run premium gas and only get 12.5 mpg. a friend has a 2500 chev that gets 13! if dodge screws me, i'm selling the dodge 318 and getting a different truck. i dont care what it costs for another brand. its unsatisfactory to have problems at 32,000 and poor performance to boot.
Try having the dealer flash your PCM prom. There are TSB's out for this. I have a '99 Dak, 5.2, 5-sp. equipped like yours and had similar problems with pinging and although it stalled rarely, it came close many times. After the dealer reprogrammed it these problems disappeared. BTW, I have ~36,000 and get ~15mpg mixed.
Hey guys, I have a 2000 Quad Cab 2wd w/4.7 and automatic. The rear end of my Quad Cab has developed a growl/whine. I think it is in the rear end/limited slip maybe. It is under warranty. Anyone else had this issue? Anything to tell the dealership to look for? Also, upon cold start my 4.7 likes to almost stall or will stall, then when you start it back up it is fine. I am sure this is a minor thing, but I am concerned about the rear end as I tow often, though usually never over 3000 lbs. 3.55 LS rear end
I have a 98 club cab 4x4 318 w/automatic tranny, and was thinking of having the transmission upgraded. I was wondering what different ways there were to upgrade other than a shift kit. Does increasing the volume and/or pressure that the fluid is pumped make a difference. Any ideas or personal experiences are appreciated.
did you change the fluid in your rearend to synthetic like the manual says? the rearend has proven to wear fast if you work it without synth. also make sure when you get this fixed they put in the lsd treatment also. just tell the dealer the rear started acting up and decribe the noises to him.
some dealers will try not to cover the rearend because the owners did not use synthertic like the manual says. they tried that on me when i had the problem but luckily i had asked my dealer when i got the truck about it because i have the heavy duty towing package and he stated that the package comes with synth in the rear already. NOT! so when my rear went bad the new dealer said that dodge will not cover the problem because i didnt do what the manual said. luckily my old dealer remembered our conversation and actually fessed up on his misinformation and dodge covered it for me including a total of 5 rebuilds and 1 new rear and they decided to just buy back my truck because they never could get everything fixed and the different noises that came with all the rebuilds out. the new one is great so far.
sorry so long. just be careful and everyone put syth fluid in your rear.
My 2001 Dakota makes a noise when cold that sounds like a lifter that bleeds down. Took it to the dealer, they think it's a connecting rod problem, but it doesn't sound as hard as a rod knock. Also, once warm, the noise goes away. Factory rep also thinks its in the bottom end. I want a new engine out of the crate, but they insist on trying to fix it. Any one have a similar problem, and can I force them to put in a new motor? Truck only has 3,000 miles. Runs good otherwise, and is getting 18 mpg highway. Thanks in advance for any input
I have a 2000 Dakota Quad Cab Sport 4x2 with 23,000 miles and no major problems except the ride feels way too soft and squishy. This is my first pickup, so for all I know it's supposed to ride like this (my last car was a '91 Nissan Maxima). But every little bump puts the truck's body (and my stomach) in motion. If I back out of the driveway and brake at all firmly, the truck practically bounces off the chassis. I can't top 35 on a cloverleaf on-ramp without feeling a roll coming on. I bought it used four months ago and have been thinking I would get used to it, and now I'm ready to fix it or dump it. Any ideas? Sandbags over the rear axle? Stiffer shocks? Rear sway bar? I haven't had it checked out because I figured the dealer would tell me it's supposed to ride like that.
I've got to agree with you on this. When I first got my 2000 Dakota regular cab, I was surprised at the "soft" feel of the suspension. It made for a nice hiway ride, but going over railroad tracks or speed bumps too quickly could be down right dangerous. Off-roading (I've got a 4x4) was also kind of hairy. I have greatly improved the handling of my Dak with the additiion of Rancho 9000 adjustable shocks (all four shocks). The Rancho's are pricey at 70 dollars each, but what I like about them is that they are 5-way adjustable. With a turn of a dial on each shock, you can determine how soft or stiff you want the ride to be. For everyday use, I set them at #1 (the softest setting). For off-roading, I set them to #3 or #4. The stiffest setting is #5 and is often used for towing and/or hauling. Adjusting the shocks takes all of 60 to 90 seconds. The #1 setting is stiffer than the stock shocks, but not unpleasant. It really helps eliminate that extra "bounce" that you feel under certain conditions with the stock ones. I also feel that the "body roll" has been reduced. Anyway, just my 2 cents for what it's worth. Good luck and let us know what you decide...
I put Edelbrock IASs on my 97 Dakota (2 wheel drive) and the difference between this and my 01 with OEM Shocks and less than 6000 miles is night and day. If I had the money to spend I would put these on my 01 now and not wait till the OEM ones wear out.
I had a chance to drive both trucks back to back and the difference was that pronounced.
In my opinion, if you can afford it, put good aftermarket shocks on your Dakota.
Thanks for the suggestions. I'm not the only one who doesn't want a Cadillac Fleetwood ride in a pickup truck. Time to shop, I guess. Edelbrock looks to be out since they don't list the IAS for 4x2 Quad Cabs. As for Ranchos that might be the way to go if they make one that fits. Also this week I did get a lot of improvement from a low-tech solution: 200 lbs. of sandbags in the bed. Dampened most of the bounce but wastes space, cuts mpg and is less than safe in a crash. Then again, when the snow flies, I might need it. Anyway, thanks again for the advice.
give up on Edelbrock IAS yet. Go to www.shockwarehouse.com, they list them for 70 a copy. I put them on my Dakota and was VERY pleased with the results - good control, good ride.
Hint: Don't worry about which engine is listed. The suspensions are what you are dealing with. The suspension for the all the engines is the same. There may be some variation in spring rate but the shocks for a Quad Cab 5.2 or 5.9 will fit and work in one with a 4.7.
The only difference in the Quad cab is the weight distribution so the shock valving is a little different. Otherwise they are the same.
'98 Dakota, 3.9 V6 Engine will run for about 2 minutes, at around 850 RPM. Then it just dies completely and won't restart unless the battery is disconnected for a bit. I'm guessing there's a bad sensor somewhere causing it, but I have no idea which one. Anyone else run into this?
The following is mostly a gripe/vent session. If you have no interest just skip to next entry.
I've had my 01 4x4 SLT+ for about 4 months now. I have always dreamed of getting a V8 4x4 pickup. I really don't drive the truck that much due to a company car (only 4-5k each year), so I fully expected this to last me for at LEAST 10 yrs maybe double that.
To celebrate my four month anniversary with my Dak, I thought I would put it in for its FOURTH trip to the service dept to fix it. The first three times involved an evaporative/emissions issue that clicked on the engine light. Well, yesterday I went out to go make an errand and the drivers power window didn't work. I push the lock button a couple of times and it starts working again. On the trip back, it just stopped altogether (luckily it was up).
I know. This is small stuff. But you know, this will make 7 days that I have been "truckless" while the service people do their thing. Seven days in 4 months and 1500 miles. Is this NORMAL in a brand new 22k dollar vehicle?
Here's my confession. I came into this purchase with a chip on my shoulder. For the last 15 yrs I have owned no vehicle engineered outside Japan. They were not perfect but I pretty much just turned the key and went. Change the oil and service'm (not as much as called for) and go. Never had an engine light come on. I didn't trust American engineered vehicles but wanted to do the "buy American" thing. Heck, this Dakota is a neat package, and I thought, a good bargain. The Tundra was 4-5k more for an equal truck. V8, fully assesorized.....
I'm really frustrated right now. Instead of getting in my dream truck now, every time I crank it up, I look to make sure all the lights come on that should. Then go off again. Test all the power buttons to make sure they are still working. See if the transmission makes that funny sound...........
I know this problem will be fixed on Monday with no dramas. But again, is this Normal? Is the QC on all domestic autos this poor?
If you are still reading, thanks for letting me vent.
My truck is equipped with manual windows (didn't want all the power stuff) and on the first day of ownership, the drivers side rear window would not roll up easily. I was already home at the time after picking the truck up. I finally got the window up after a struggle, about ten minutes before a thunderstorm came in.
It was fixed under warranty with "little problem".
Little problem = There was a miscommunication somehow with the dealer, as I was told they needed to order the replacement window regulator part. After waiting a few months, I inquired about this, and was told the part was in stock all that time. Well, the guy who made the mistake was no longer employed there. This kind of irritated me due to the length of time involved. Once a compentent person got involved, it was replaced at my next service interval, along with an oil & filter change at no charge.
The only other glitch was a one time problem with the engine which turned the MIL on. The engine would idle erratically and would lose power at 2500 rpm. By the time I got to the dealer, the light was out and this problem was never repeated. This happened on the way to work one morning, it sat in the parking lot all day, and when the truck was restarted after work, no problem. Still scratching my head about that one. This problem did not leave me stranded.
2 flat tires in 2 months, but I cannot blame Dodge for that. My luck I guess.
Overall, I am very pleased with the truck.
It stinks that a brand new vehicle would have ANY problems, but stuff happens. The truck is under warranty, so be patient with the service department. Some vehicles have a few bugs at the start.
I am curious as to your evaporative/emissions issue, What did it turn out to be? Why did it take them 3 attempts to fix?
ALl the following happened in the first year: 1. 1 MOnth into ownership, intermittent wiper switch fails, wipers do their thing regardless of setting. 2. THree visits for a check engine light, finally a camshaft pos. sensor goes out and that is replaced, no more check engine light. 3. One broken clip on the airbox, not a functional issue but hey I paid 22K here so I want it right. 4. First of MANY issues with the warping rotors and drums. To date, FOUR complete replacements of rotors and drums and finally the pads and shoes replaced with different sets to help dissipate heat buildup. Jury still out on whether this is the solution or not. 5. Lumpy erratic idle and stalling on cold start. SEVERAL trips to get this one figured out. Finally a re program of PCM fixes this but for how long? 6. AIS motor replaced after truck would NOT hold idle in drive when at full operating temp. 7. Erratic, harsh and plain old screwy shifting from the oh-so-wonderful 45RFE......last time I was told by tech "transmission functioning as designed".....fine.....when it blows, I will rememember that comment and hope he can handle a size 13 you know where. 8. Creaking in front end during slow turns with brakes applied, seems ok now after pads and rotors were replaced. 9. Clunk in steering column going over bumpy fields or gravel roads....have yet to address this with dealer.
So, I hear ya....kinda makes you wonder who is in charge at DC quality control? If I had it to do over again, no, I would not buy a Dakota. I can only imagine what crap will come my way when the warranty runs out.
Don't take this the wrong way, but I have to ask. You went through FOUR complete replacements of your brakes, and they all warped/whatever again? Over how many miles did these 4 brake changs encompass?
This just sounds like lunacy. What I have to ask: did you or did you not just go out and ROMP on each set of those new brakes to see if they would do the same thing? I only have 9k on my Quad now, but I live in Montgomery County, PA, and nearly all of my driving is short trips, lots of stop-and-go. My brakes are damn near PERFECT yet. I have the 5-speed and I don't drive really fast, and I actually believe in looking more than 2 feet in front of your vehicle to anticipate stopping situations so I don't have to hammer on my brakes all the time. I'm sure downshifting helps quite a bit as well.
Like I said, I don't want to accuse you of anything, but if you managed to burn through 4 sets of new brakes in a negligible amount of miles, then there has to be some other factor besides craftmanship involved.
enlighten me please! I live in Butler Co PA and there are lots of hills here. No, I don't romp on the brakes just to see if I can screw them up. I've been around cars/trucks far too long to know better. If you think this is lunacy, I could not even begin to type out my feelings on this. Edmunds would probably ban me for sure. Still, if you think I am full of it, go to dodgedakotas.com and do a search on brake rotors. I'll bet a cup of coffee or beer of your choice you'll find over 100 posts there on the same issue. So unless I have been cloned over 100 times, there must be something wrong besides my driving. At any rate, how is it possible to go thru three company lease cars in 5 years (one Ford Taurus, 2 Intrepids) with each getting over 90K before I turned them in and NO brake problems. This includes driving in the Rockies to the Appilacians (sp?), certianly more hilly than around here. Two final thoughts. I have 21K on the truck now. I also look several dozens of feet ahead of me when I drive. I have learned since living in this state that red lights mean very little to other drivers!
Well, I went and searched dodgedakotas.com like you said, and it really is shocking how many reports of bad brakes there are. It seems like its always the rotors, not the pads necessarily wearing down prematurely. There are even some reports of manufacturing flaws in the rear drums.
Who here has a 2000/2001 dakota, what is your mileage, and when did you first need rotor/drum work?
Mopar67 - like I said, I didn't want to accuse you of anything, but driving style and actual usage always plays a part in the life of wear components. But if there is a problem with the parts, which it appears there may be, it only compounds the matter.
It sounds like the moral of the story is that if you're over 12k miles and you need brake work, you have to bite the bullet and buy aftermarket, since it seems like the Mopar parts are garbage. I guess I'll find out eventually...
but I am in agreement with you that when these let go, which they probably will, then yes, its aftermarket. Only good thing I can say is the dealer worked with me all the way on this and were it not for them, they DC would be buying the truck back. I would be lying my you know what off if I said that each and every time I stop its a nice slow easy stop. From time to time I have to hit them hard or else rear end someone who always seems to wait until the last minute to pull out. Now back to romping the brakes, you missed your projection by about 20 years! Long ago, when Ronnie and Nancy occupied the Oval Office, I drove just like that on my Dodge Dart (with the swiss cheese sheet metal) and I can honestly tell you (cross my heart and hope to die) that I NEVER once had brake issues on that car. Not one iota. So when I drive my Dakota like a regular joe and have this kind of crap, it totally pisses me off and has pretty much taken away any excitement I once had owning a new vehicle. Good luck to others and if you have never had brake problems on your Dakota, my prayers are that you never will.
Footnote: The service manager told me in confidence that they see way more full size rams and Jeep Grand Cherokees than they do Dakotas for brake problems. Makes sense at least on the ram as DC went to 13 inch rotors on the 2002 model.
on my rig last week.. thanks to my commute. We shared the Crank Pos Sensor and idle problems at least; So your recent post about post-warranty performance made me think... any problems will filter thru my wallet now.. . The beer cooler is on ready-alert..
Mine started to pulse at about 16K. Still driving with the pulse on my '00 QC. Dealer told me that anything wrong with the brakes after 12K was on my nickel.
Bob
Any suggestions would be appreciated.
Is this another item for the dealer to resolve?
9400k on the vechicle. Fog lights came with the vechicle.
Your dealer should replace them under warantee.
Thank You
(see my profile)
Good luck,
Bob
Change dealers !!
Jim H.
that the
know where
lot and they
'01 Quad 4.7L 2X4
Erich
robert
KarenS "Dodge Dakota Owners: Events" Sep 24, 2001 8:16am
Tim
Edelbrock has a shock for the quad, but only with the 5.2 and 5.9.
Anybody find a set? I would love a set fo billsteins but they don't make them.
Any help would be great.
Blue
Travis
Good luck,
Bob
Two final thoughts.
