Visitor Agreement.
Don't know about the gas in spark plugs issue, but good luck all
I also have the check engine light on. I had it looked into, and I was told that it is due to a bad Oxygen Sensor. It's not going to cause the car to break down, but it is slightly damaging my gas mileage, and causing that check engine light to stay on.
Does anyone know if it is possible to clean the inside of the fog lights? I have some rusting due to water intrusion. I am getting ready to replace both lamps via a new assembly kit, but I am trying to avoid spending $150.
Usually when I fill the tank with gas the Check Engine Light goes out. and ABS, it just goes off for a long time, then comes back on for a few days.... I thought it was when I did alot of braking going downhill mostly, and that seems when it comes on more, but also just stays on after all that and am on flat land... :?? Car runs fine, except now I am starting to see very low gas mileage
SAME THING THEY SAY THE FUEL SENDING UNIT NEEDS TO BE REPLACED.
TO GET MY CAR INSPECTED NOW. I HAVE TO FILL MY TANK, DRIVE IT FOR
A FEW SHORT TRIPS. THE CHECK ENGINE LIGHT GOES OFF AND I GET IT
INSPECTED. I HAVE BEEN QUOTED ABOUT 5-600 FOR THE REPAIR.
What else would be common with all these lights?
Thanks, Grandpagator
http://www.scangauge.com/
I thought it was my breaks but have had them checked and no problem.
My car is still under warranty so hope this is covered. My electric car key is also not working, but that has been the case for almost 2 years.
This recent problem has just started. I have only 38,000 miles on my car, but had it shipped from hawaii to california recently.
1 I checked all the fuses and they were good
2.checked the flasher and replaced it just to be safe.
3.Hazard flashers are operational
4. Think that could possibly be a ground wire gone bad. but were to start?
I am looking for any other good Ideas on what to check ...this problem is going to be a big drill down so I am look anyone who has experience these problems.
the other problem is best handled by a auto-electric shop or a dealership is sounds like you have a short in the wiring somewhere
P.S.
I tried the gas cap thing. No luck.
