Complaining about dealership pricing for tires? Dealerships don't generally sell tires and when they do, they price it up considerably as that's pure profit from an easy mark.
Whining about the dealership being closed on Saturday - something he/she should have checked out prior to getting the car.
Expecting more than 25k miles on a sport package equipped car that's not cared for properly?
The post on that forum or blog or whatever had a lot of blame to throw around but not a single bit of it reflected back at the most guilty party: the car's owner. She should have been checking her tires and had she been performing the most generic of maintenance, she would have seen the wear and contacted Tire Rack for new tires. Her complete lack of responsibility led to the entire problem.
Now at 27,000+ miles the dreaded low tire pressure icon appeared on the screen. Checking pressure revealed the left-front tire was down to 21, and the culprit, a philips-head screw, smiled up at me from the center tread.
Would this really mean $350-400$ to replace an unrepairable tire? I called Kost Tire, a dealer in the Upstate New York area; they confirmed they dealt with RF's, and told me to bring it in. After only a 20 minute wait, they pulled the screw, didn't need to patch the tire, and didn't charge me!
After initializing the system, the tire, which retained its pressure overnight, seems OK. Am I dreaming?
If you're worried, get a new set of tires. You can't run one new tire and one 27k tire on the same car.
That was fast.. :surprise:
Back to RFTs...
Besides, here comes your answer to a near perfect car for you...
link title
OW
cruising down the highway, the thing sounds like our old 60's International dump truck.
I'd say BMW has a problem with all of these RFT's, it's just the tip of the iceberg. Inside of front tire cupped, just like on a car with worn shocks.
Inside makes sense 'cause of negative camber, ........ cupping? IMHO the shocks are a bad match for the stiff sidewalls and cannot absorb the vibration. But who am I to speculate, but sure would like a better answer than "replace the tires". :mad:
FWIW, I drove my 2002 530i in Manhattan several times per week and never had a problem with that car, however, when I had a 1995 Passat GLX I went through seven tires and five wheels compliments of the Manhattan pot holes. :-/
Analyzing this a little further, the tires mounted on the three cars in question are as follows:
Tire Size ------ Sidewall --- Type --- Vehicle
215/50 R15 ---- 4.232" ---- GFTs -- 1995 VW Passat GLX
235/45 R17 ---- 4.163" ---- GFTs -- 2002 BMW 530i SP
225/50 R17 ---- 4.429" ---- RFTs -- 2006 BMW 530xi
Hmmm, interesting. The Passat actually had a taller sidewall than the 530i and yet the 5er didn't have a single problem. That said, your 530xi has even taller sidewalls than the Passat. I'm thinking that the RFTs might could well be a smoking gun here. In the end, even if switching to GFTs doesn't fix your tire damage problems (and it might), they'll sure be a whole lot easier (and less expensive) to replace when damage does occur.
Not sure this helps, but there it is.
Best Regards,
Shipo
My thought is that the RFT/sport suspension combo cooks the tires. My neighbor's C-70 Volvo cooked tires in Manhattan and many rims as well!
OW
You mentioned run flat tire. Do you have the optional 18" wheels with 245-40/18 RFT performance tires? Or do you have the standard 17" GFTs?
If you happen to have the 18" RFTs, then my guess is you would be better off replacing them with the standard 17" wheels and tires.
Bruce
Based on our past experience, you do not have 100 Miles when it goes flat and there will be a big chance only BMW will have your size in stock (~$500 installed). If you're lucky the next flat won't happen too far away from home or on a weekend trip...
1)Cost
2)Lack of availability should you develop a flat on a trip away from a major metro region
3)Inability to repair
4)Poor ride quality
Consumer Reports has a powerful voice which I believe reverberates strongly among auto manufactures including BMW. Unfortunately, I suspect the support they have just thrown behind RFT's will ultimately embolden BMW to continue to supply RFT's on their new cars.
Those who read this forum and feel strongly about this issue should consider sending a letter to Consumer Reports reiterating all the downsides.
Idoc2
I've got to say that I like the way my 325i ZSP handles with its 17" runflats. In fairness, Blueguy, who swapped to GFTs on his 330i, has done considerable grumbling about the softness and lack of response of that car compared to his previous E46. I respectfully offer (Blueguy clearly knows his cars) that that may be because the car is tuned for run-flats. I know, I can't substantiate the detail of what that means in engineering terms -- I just know that the manufacturer clearly states such. I have read at least one post on a mini forum stating just such a switch to GFTs ruined a Cooper S's handling.
I do like the overall feel of my car, and my liking for it improves with time, unlike my old Acura TL, which I could not wait to get out of. I like the softwall stiffness -- the fact that there's no rollover during hard cornering. However, the downside is that there is little give over sharp knocks. The biggest plus for me is reducing the affect of a high speed blowout, and reducing the risk associated with a flat when navigating shoulderless NYC parkways. Also, changing alloys can be a pain, or impossible without a hefty implement to knock the wheels off, as they can bond to the steel hub through electrolysis. I understand that there are things you can do to prevent this, but in the real world....
I find that impossible to believe. The 07 Cooper S with RFTs is decent but my 07 Cooper S tends to skip and tramline with the standard 17 RFTs performance tires. It's not as bad as the e90s roadfeel but I can't fathom how a grippier, lighter, more pliant tire with a real sidewall would "ruin" handling.
Eventually, I'll make the switch on my Cooper and know for certain...
I come from a 540i M-Tech suspension touring and would have had sport suspension as first choice on my 330d, but the harsh ride and skitter was far too punishing to use on Highland roads.
I’ve added Koni FSD dampers and now have a car that rides much more compliant and with more control over undulations and in cornering.
I’ve tried the RFT’s on this setup and find it much better, has stopped the crashing, but still harsh. RFT’s are not in the same league as non RFT’s on my model of BMW.
A couple of weeks a go I had a brand new LCI (facelift) 535d M-sport Touring, for a week, on my local roads. What a transformation BMW have now succeeded in giving us back the real BMW drive. This car is on 18” RFT’s but I’d challenge anyone to know, without reading the tyre label. The car ran as compliant and planted on the road as my 540i touring, on 17” normal rubber.
Dealers in this country are gaining knowledge that 17” wheels are not the best size for E90/1 cars. 18” appear to give the better ride and revised suspension settings, (October 2006 in the UK) has improved the ride quality. I had a day with an E92 coupe on the same suspension set up as my car, and running 18” wheels, what an improvement on a 2007 build model.
I’m still not sure BMW and the tyre makers have sorted the wear problems, we will see.
HighlandPete
As I ponder acquiring my first BMW, it's good to realize that the pioneers (you, among others) are enduring the agony that is the RFT development process. It appears to have been, let's say, ugly.
If I lease my next car (who'd a thunk), I'll pull the RFT's off after 5-10K miles & install a set of GFT's. I won't lease the thing unless I plan to stick with the brand for a number of years, so I can put the dreaded RFT's back on the car before the lease expires (& save the GFT'S for the next BMW) or sell them to someone on e-bay if I buy the car at the end of the lease (not likely, since the NA diesels should be getting mature about then).
There are still issues I want to see addressed.
I still need a spare wheel. Wear that is acceptable. Tyres that work below 10-degrees centigrade,where the present ones become rocks.
HighlandPete
I know that does not change the issue but the conti's are a different animal and are wearing so even I hardly notice after 7K miles. The EL42 wear at this point made me think there might be issues with the alignment.
I rotated the conti's at 6K (the dealer had to rotate one side because I stripped one lug nut with a stupid craftsman 12-point socket!) Guess what they charged me? I was expecting at least $30-$40....but the SR said just give us $2 for the lug nut.
I have NO problem so far with these new tires and I am very happy so far. I can easily see 20K on this tire and beyond but I will report periodically.
You can do what you feel best but I would not base a buy decision on the RFT or not. Your solution is fine and I considered it but I am not sorry I stayed the course.
BTW, it will be extremely hard for me NOT to do business with this dealer. Until this point in my lifetime dealer experience, this is nirvana to me.
OW
And Highlandpete, I have driven extensively in the UK (grew up in Derby) and know what you mean about the very different road conditions -- frequent camber changes, hot rolled tar versus loose chipping-on tar surfaces etc. Overall, rural driving there is a delight, despite the best efforts of the miserable, treasonous nanny crew running the place now to put a stop to it.
I've had a Bridgestone field engineer in my car and he comfirmed my opinion, that the tyres were safe, but also agreed I had issues in using them in my driving environment.
The good news is the latest cars are so much better, just heard today of another 3-series driver... his new 325 is so much better than the previous car also on RFT's. A 335i touring driver is over the moon with the latest ride quality on RFT's, after removing the RFT's from previous BMW's.
HighlandPete
I always figured that the technology would improve over time. Perhaps this is some advanced indication. Time will tell.
OW
I just picked up a new 2007 328I with these bridgstone run flats, I hate them I have only had the car a week and went back to the dealer the other day I have 400 miles on it. I seem to get a wobbel in the steering wheel like I have a bad tire or out of balance tire they tell me this is common and as the tire warms up it goes away what did you do to correct this
Dave at hr425@aol. com in Rochester, NY
Good luck!
Can I ask what tyres you're using now, and are you using the standard wheels?
If you have a car with RFTs and you want to try running it with GFTs, I suggest you look at a set of Kumhos in the same size as your factory tires. They're inexpensive, get good marks from those that use them and are available in a wide variety of sizes, tread patterns and rubber compounds.
http://www.kumhousa.com
Best Regards,
Shipo
I've just got a second hand 320d with the Conti RFTs on - when I test drove it it was fine, but it was tramlining awfully when driving back from the dealer
I'm probably going to try it for a bit more to see if I can get used to it, but if not, I'll put on some GFTs and get a can of goo and inflater like most other cars without a spare do.
After reading many of the posts on this thread, I am unclear as to which models this RFT tire issue affects.
I am interested in the 335i or xi (I live in CT).
If I went with the xi, is this not an issue since I assume they put All Season tires on? Would you recommend the Sport option on the xi or not?
On the i version, is it the Sport option that creates a problem with the tires or the lack of the Sport option on the i model?
Your opinion would be appreciated.
As you can see, both versions of rubber are of the RFT variety, and both have their issues. The All-Season (a misnomer in and of itself) tires have had significant noise issues from premature cupping and have even been subject to a kind of a hidden recall where dealers have been authorized to replace noisy tires for some money or no money depending upon the miles on the OEM rubber. While the summer performance rubber hasn't had that particular problem, there have been complaints of jittery control when cornering on anything less than new pavement. Then of course there is the wear issue with performance tires of any make, basically plan on replacing the rubber every 15,000 miles and consider yourself lucky indeed if you get over 20,000 miles on them.
Me personally, I'd order a 335i SP, put five to ten thousand miles on the factory rubber, rip them off and store them in the basement and replace them with a nice set of identical sized GFTs. For the winter time I'd order a set of winter rubber along with a separate set of wheels. Then, as the lease was ending, I'd put the factory rubber back on and turn the car back in. In that way, I'd have a car that I could take maximum advantage of year round. ;-)
Best Regards,
Shipo
Have you driven the 335i with RFTs? Base or sport suspension?
While I don't know for sure, I rather doubt it. :-( I'm thinking that the only option for a spare tire in an E90 is one of those "Spare Tire in a Can" deals.
Best Regards,
Shipo
All non-sport RWD 3-series models come with all-season tires.
All sport package RWD 3-series models come with summer tires.
No changes..
Best Regards,
Shipo
HighlandPete
I feel unsafe in this car doing what I used to do with my 2003 Toyota SUV !!!
I love the car but the handling is unacceptable...what could it be? surely there must be another problem, this cannot be run flats issue?
I am taking car in on friday 8th June.
If you have grooved roads (California...) then RFTs have been known to generate diabolical handling characteristics.
Best Regards,
Shipo
AND Thats My Experience.
I will rotate at 10K but do not plan to re-balance them.
OW
My local Tire Dealer in Easton Md charges $20 to rotate and $30 to Balance and Rotate, he highly recommends it. For $10 more ill go that Route.
PS:Make sure they readjust the Air pressure.
6
