Volkswagen Golf Electrical/Lighting Questions
hockeybird
Member Posts: 1
in Volkswagen
I've recently started having what I consider an electrical problem in my 99 golf gls. I've determined already that it is not the alternator. My digital clock, odometer, and tripometer remain on when the car is off and the key is taken out. It has always gone off before and I can't find anything in my manual about it. Does anyone know what this could be? Maybe I changed a setting I didn't know I had??
I've also read postings from several others about the pause inbetween shifting. I've had that problem since I bought the car and no service shop could tell me what caused it. It is a nuissance (sp??), and could be a dangerous one if you're not used to it, but I'm glad to hear that's its 'normal' I guess. Also had the problem with the mirror knob breaking off, headlights and taillights repeatedly burn out, rear cv boot/control arm needing premature replacement, my window track cracked and window fell down into the door, etc... If anyone else has problem with the window track DONT try and fix it yourself, VW has a service bulletin out for it and will fix it for free if you ask. I had a mechanic friend take my door off to look at it, then when I realized what it was I took it to VW and they refused to touch it since I'd taken the door off (even though I didn't touch the window mech., those jerks).
I added an Alpine 4-channel amplifier to the car, which helped the sound a lot, but I would still like to get some better speakers, especially in the back. My first choice would be speakers that would replace the stock units with no cutting or other alterations.
Many thanks for your help with this!
I'm having exactly the same problem with my Golf. I have taken it a the garage to see if the mechanic can find the fault, and it all works fine when he's there. It's been going on for a year. I dread the rain because I know my car won't start. I have found that if I leave the car turning for ages, it does eventually start. However, before it has done this, there is loads of smoke coming out of the exhaust - I don't think that it can be doing the car much good. By the way, I did change the glowplugs, so that's not the problem.
Could you please get back to me if anyone has found a solution to your/my problem.
Thanks, and merry Christmas!
As you know requirement to start a diesel is, fuel , air,
and if you want it to start faster, preheat with glowplugs.
Since your car starts after many revolutions, you likely have some problem with your glowplug system that only seams to manifest its self when it rains.
Check to make sure the glowplugs get power, 12 volts, when you pre heat them when it rains and this hard starting happens.
I would think the glowplug relay could be a prime suspect or
the wiring that controls it, one input is the engine temp,
this could be shorted out some how when it rains, causing the glowplug relay to never pre heat the glow plugs.
You could just hook up a 60amp relay, to the glow plugs with a switch to its coil and heavy duty fuse, connected to the battery run the control wire inside, when it rains, turn this on for
20 -60 seconds and try starting as per ussual.
good luck.
Sounds like the ignition switch is going bad. A good independent shop should be able to fix that for little $$$.
I have a Golf 2001 Tdi also and my hatchback wont open.
What did you have to do for yours?
Corinne
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1- c/92/7b/0900823d801c927b.jsp
Upon returning I got into the car as usual with the remote but noticed the interior safety light (lower left on door panel) remained on after closing the door. A few days later the remote quit working, (light was still staying on), I tried to reset the remote, no luck. The door lock control on the arm rest will still lock and unlock the doors, with the exception of the drivers door. The key will lock and unlock the drivers door only. Also the mirror adjustment has stopped working and the security system. I tried to take the panel off to investigate and only got a far as getting it loose from the door frame and where it locks over the window edge, couldn't figure out how to release it from the armrest. Any suggestions appreciated.
Mark
Thanks for any suggestions
two main problems.
speedomter stoped working today.. checked fuses.. and non burned out that i could seee.. i don't really know what the problem is...
then sinse i checked the fuses everytime i'd turn a corner my feul light would come on and beep. though there is just under half a tank of fuel..
anyone know what's happening?
i honestly know nothing about cars, im a student don't have much money but i need to get this fixed.
later.
jef.
I have a 1997 glof that wont start. What happenes in when you get in the car and go to start it, the alarm starts to go off. if yo jump the starter to start it the car runs great and when you shut it off you can start it back up. But it it sits for a while it wont start and just set off the alarm Any help ?????
Friend of mine has an "error" display in the left LCD (Odometer?) of the gauge panel. Tells me the entire panel is erratic. Mechanic/dealer says to replace the entire assembly ($$$). My guess was chassis grounding but I'm advised that the codes have been read, wiring has been checked, grounding verified, etc. Does anyone have any suggestions as to what this might be and a potential fix? Note that we are in Southern Mexico and availability of common Stateside fixes will be impossible.
Any suggestions will be appreciated; thanks!
Hope this helps - note at least 1 VW dealer failed to identify this problem !!!
I got this 97 Golf K2 and its been doing well, however recently its given me weird problems. First the coil was bad, got that replaced. Then plunged in $$$ to change all the spark plugs and wiring. Now, just this morning, I push down on the clutch to start the car, and turn on the ignition.... there is rough grrrrr grrrr sound... and it doesnt start right away, after a few attempts it runs just fine.
The gurrring seems to be coming from area under the clutch.
Please help. I am a student and really broke. Could it be a timing belt issue, since I already have 137,000 on it?
Suds
i have a manual 2001 golf, before a while the rpm meter started swinging whenever it;s on neutral, the problem seems to get more serious; now the swinging is huge, that sometimes the engine goes off!! and i have to start it again... does anyone know anything about that??
thanx
Do you think its the pump and needs replacing or the vacuum hoses that and loose or split making the pump over work??
I am currently removing my complete dash cover from my Mark5 Golf.
To get it from the car, it requires (for ease of removal) to take the indicator & Wiper stalks from the steering column.
I already have the steering wheel & Airbag out, but I'm not sure from here as to how to remove the airbag clockspring & more importantly..the stalks...
Any ideas would be appreciated
Cheers
Asavs
I got a 97 golf gti. Now I met a weird problem. After I driving my car for a while, if I turn the steeing to the left, the horn is beeping, but to the right, nothing happened.
what should I do?
thx in advance.
hao
It has only gotten worse since then. I have lost the functioning of the windsheild wipers(unless it is on high) the ding when the door is open and the key is in the ignition stopped working... and recently my dials on the dashboard have gone crazy and randomly flip out, the clock goes to 12 and the trip odometer goes to zero. My engine temp gauge has a mind of it's own and tells me I have an overheating engine and a cold engine all in the matter of 5 -10 minutes.
My question is- is this a very expensive electrical issue that is worth fixing or should I just fix it temporarily and sell it? And if anyone knows a good mechanic in Chicago that specializes in electrical issues with VW's please let me know who to go to!
Thanks much.
I have recently passed my car driving test, and I bought a second hand VW GOLF 1.4 S edition 1999 T reg, for the first couple of weeks of driving the car was OK, but know the engine cuts out and the car stalls, it usually happens when I am slowing down, this is now happening a lot, I took the car to 3 VW recommend garages, and they cant seem to find anything wrong with my car, CAN ANYONE HELP ME!!!!!! Because of this problem I have nearly crashed the car twice now PLEASE HELP!!!!!!!!
We just purchased a 95 golf cl. It seems to be a good car overall, but lately it has been having problems starting. There seems to be a correlation between that and shutting it off while the rpm's are above 1000 (seem ok, when we let it idle for a few seconds before shutting it off). We took it to a mechanic and he replaced the ignition switch, saying that this is a problem he's seen before, but that didn't resolve it... any ideas?
I brought my car to my mechanics and I told him that my engine jerking when I drive (especially when wet). The engine was actually mis-firing.
What was checked was:
- spark plugs (got those replaced)When was the last time you checked your sparkplugs? You could have a faulty spark plug and causing mis-firing or there is carbon build up.
- Distributer cap (got this replaced)
- Distributer roter (got this replaced)
Your ignition coil may not have to be replaced but it's good to know that it's new. ibid for the spark plug wires. Had this done myself because I found a rip in one of the wires.
In exchange, can someone help me. The question I have is something to do with my wiring of my reer right lights (not my break lights or blinkers but the lights when the car idles or when your driving at night). I replace the bulb..nada. I used the working lights from my left lights and tested on the right...nada. I'm thinking it may be my fuse. Anyone know?? Any insight would be helpful. My obsessive, compulive behaviour is worsening by the day to get this fixed. :confuse:
The second problem i am experiencing is with the oil. the oil warning light came on and started beeping and didnt go off. i checked the oil when the engine had cooled and the oil level was fine. so I thought it could be something to do with the oil pressure. but even though the oil level was fine, with the engine bay open whilst checking the oil, i just so happened to look down and noticed a huge area of what seemed to be oil that had leaked from my car.lots and lots of it! I took it to a garage,and after checking where the leak was coming from, they said the oil pressure switches had gone, and so replaced two of them. they then told me the oil would still leak a little, but would eventually settle down and then stop leaking. which i thought it had, because its been fine up unitl now. but here we go again, nearly two weeks later its still leaking-not as much, but still leaking, and the oil warning light kepps coming on and beeping still, but it goes off this time. checked the oil level, and yep, its absolutely fine. it seems to be mainly only when i have travelled, not a big distance, but more than distance i usually travel e.g. going out for long drives, but is fine just going to work and back. Bearing in mind this car has a full, stamped vw service manual and has been serviced and had regular oil changes throughout its entire life.
Pleeeeeeeeeeeeeeaaaaaaaseeeeeeeeeeee Help me!!!!!!!!!!!
:confuse: :sick:
so...whats that mean? It's an emissions issue...but what needs replacing?? Any help appreciated... 2002 Golf 2.0
Oxygen sensor? EGR valve? what?!? lol...
Jen :confuse:
I have had a 97 VW golf (manual) for about a year now. It has been doin very well until lately a weird problem has risen. Everytime it rains, or it gets cold, the steering wheel jams i.e. it gets really really tight and almost makes it impossible to turn the car. As long as its going straight its fine but even a small turn is very difficult. However when the weather is dry and hot again, it does just fine. I was told that there maybe an issue with the Power Steering fliud but I got that checked and its alright. I am not loosing any fluid either.
I was also told that there might be a problem with the suspension. However I havent really had a supension guy look at it. I am afraid they will give a huge estimate.
Does anyone has a similar issue, or a solution to this problem. I am worried about this since very soon winter will be here and it will become an everyday affair. I am a student and short on $$. Hopefully someone has a cheap solution or knows more about this problem.
I am a new driver and dont know much about cars, this is my first car. Any help will be highly appritiated.
Thanks guys
Sudeepa
I have taken the car to 3 dealers, one VW garage and they have tested it on the diagnostic testing system and all the readings are fine.
When the car is low of fuel it seems worse and also the car doesnt seem to run very smooth.
Can anybody help?
