I bought an Accord 05 DX(Basic Model). It has power windows, but no power door locks. I wantd to get keyless entry installed on it. I bought the door actuators, the trunk pop actuator and an alarm to go with it, but the mechanic at frys told me that this car has cable locks unlike the normal rod lcoks that these cars have and so it is very difficult ot get power door locks on it. Please give me some ideas on how I could get it installed on the my car. I appreciate your help!
Thanks and Happy New Year!
Go here and read the part on the Security option (and it not adding keyless entry to the DX model):
http://www.handaccessories.com/accelect03.html
Go here and see an exploded view of the DX lock mechanism:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- - - cgry1=Accord&catcgry2=2005&catcgry3=4DR+DX&catcgry4=KA5AT&catcgry5=FRONT+DOOR+LO- - - CKS
Compare to the LX:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- - - cgry1=Accord&catcgry2=2005&catcgry3=4DR+LX&catcgry4=KA5AT&catcgry5=FRONT+DOOR+LO- - - CKS
Perhaps there is a way to purchase the necessary additional or substitute parts to change the lock in the driver's door. Maybe by comparing the images (they look the same to me) and parts (probably the DX and LX differ by the additional mechanism attached to the lock assembly for actuating it electronically), but, you'd have to determine if the other wiring to the door is there to support the addition of keyless) and then speaking with a parts department specialist, you can see if it's possible or not.
I have had to replace both so far (2 years apart so they were different problems).
Glad you got 'er done!
I have used the NGK plugs in the past and been very happy. I was thinking about going with platinum tips this time (I think iridium is overkill for a stock N/A motor, esp w/140k).
I am also looking for an OEM or slightly better spark plug wire set (not Nology or something overkill like that).
Lastly, the muffler is starting to get eaten. I might patch it to get through the winter but come spring I should probably look at replacing it. It was pretty easy to find an over-axle pipe/muffler assembly for the Civic, but not so much for the Accord. I wanted it to be bolt on so I could do it myself (borrowing a welder is kind of a PITA for me).
Any thoughts?
do you note a lack of power? maybe the hole in your muffler is really big.
i'm thinking maybe stuck/clogged injectors, or the cat needs replacing. i suppose of that vintage, i'd go aftermarket cat.
hard to say what is contributing.
definitely. You have to remove two screws. One in the door opening handle, and one in the door closing handle. Then carefully pry the panel off, then lift up. Good luck
This is one of the best online parts sources. I guessed that your car was a 4dr/auto so you might have to go back and change it (or to double check)
HTH
How did you know that it was the oil cooler o-ring you needed to replace?
(I have 92 Accord EX going on same amount of miles, good little machine)
I have the exact same problem.
Mine's in the shop being diagnosed.
Pls reply: jr2_stl@myrealbox.com
Kindest regards,
Jim Rothwell
St. Ann, MO
You have a vacuum leak somewhere, or debris is in the system. Changing the intake shouldn't affect idle speed at all (unless you had to disconnect the battery, then the computer might have to relearn the idle speed).
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- cgry1=Accord&catcgry2=1990&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=FRONT+DOOR+LO- CK
do you live near a pull-it place?
Last week my car stopped on a road. I change a fuel filter& pump and engine could start again. It worked for 1 day and now I can start engine if I'll push on gas pedal only. As only I'll relise the pedal it'll stop to work. Does anybody know what it could be.
Please help.
Every time it rains , my trunk gets flooded. My best guess is the water gets in between the glass and the rubber joint(The rear lights have been sealed with silicone).
I have tried crazy glue, liquid cement but the water keeps getting in. I am thinking of drilling a small hole inside the trunk so the water can get out.
Any other suggestion? Should I replace the whole rear windshield? :sick: :sick:
You might try crawling into the trunk with a flashlight and have someone spray the window with a hose to verify where the water is getting in.
What about the seal around the trunk lid?
Mrbill
This seems reasonably common in the Japanese cars I have owned. Make sure they use a temperature stable sealing cement. The Accord got a new windshield while living in CA. Now it lives in MI and the windshield creeks and crackles as it warms up and cools off.
Okay so about a few months ago my car started making this odd klunking noise whenever I gave it gas, only when I gave it gas. It was so powerful I could easily feel the klunking and I figured it was my drivers side driveaxle, got a new driver's side driveaxle.
Okay so I was driving home today on the highway with my new Driver's side driveaxle and thought the problem was fixed - WRONG! It started making the horrible klunking noise again! I'm pretty sure it's not the passenegr side driveaxle... like 95% sure it's not.
Please help me, thank you!
Other than that, you'd want to check motor mounts. But don't despair if you replaced the wrong side; generally it's a great idea to do both at the same time.
Can I do the repair myself? any glue that can hold and seal the opening?
cheers
So I am driving to work yesterday morning and I smell burning oil. I look up and there is an F250 superduty in front of me so I don't think much of it. Then I look down and the oil light is blinking. I pull over immediately and stop, shut off the motor and pop the hood. I pull the dipstick, which registered absolutely empty. I look down and the Exxon Valdeez is being re-enacted at my feet. The car is puking its guts out.
AAA tow to the Honda dealer...dealer says counterbalance shaft oil seal went, need to do the timing belt change service (previously done at ~80k) to get to the part...blah blah blah...$700 later I have all new belts and seals and a new water pump. Its at 140k right now, it damn well better get to 200 after that.
The dealer also said it had a bad control arm and wanted $350 to swap that out. I picked a TRW control arm up from the auto parts place for $90 and put it on this morning. I will be out another $40 for the alignment but 130 is better than 350.
The only thing left is it needs a muffler and over-axle pipe, which is about $100 but I keep patching it and putting it off.
It got a new master cylinder a few months back too for about $350. It also just got new tires but that is a wear item and not really fair to charge against the car. Mantenance costs are running about $1000-1200/year since most of it I still take care of myself, but I guess ~$100/mo isn't terrible for maintenance costs.
