Nissan Titan vs Chevy Silverado
Nissan's first entry into the full-sized truck category holds its own against the competition. It has an impressively large cabin, is relatively agile, has a fairly comfortable ride, and has a very smooth transmission. Safety features include optional electronic stability control and curtain air bags. The cargo bed of the crew cab is fairly small compared with the competition, and payload capacity is a meager 1,105 pounds. The Titan's muscular V8 provides strong acceleration, but the constant engine and exhaust noise can become tiresome. The truck gets a facelift for 2007. Reliability has been well below average. (SOURCE MSN: Autos/Consumer Reports Summary)
Also, staying on topic the reliability rating for the Chevy 2500HD is much higher. So bottomline, on average, in term of reliability your better off with the 2500HD, or any other truck for that matter, since TITAN is rated the lowest in reliability category.
Last time we compared full-size pickups, in January 2004, the TITAN won. Since then, every other truck here has been redesigned. No matter — the TITAN retains its title. At the dragstrip, with 1000 pounds in the bed, the TITAN crossed the quarter-mile mark two-hundredths of a second after the rocket-sled Tundra. Though the Tundra has 64 more horsepower, the Titan weighs less. It's the lightest truck here, which helped its fuel economy numbers. The TITAN was midpack in all our handling tests, even though it had the tallest tires with the most aggressive off-road biased tread. Our test TITAN is the best equipped for going off-road; in fact, it was the best in the dirt and the only truck here to come with a pushbutton locking rear differential. The TITAN also has the most useful bed of the group, with huge, movable tiedown cleats, a bed liner and a unique bedside lockbox. Inside, the TITAN is roomy and comfortable, rivaling the limousine-like Tundra for rear-seat legroom. The only strike against the Nissan is the use of hard and cheap-looking interior plastics. Nonetheless, each night every tester wanted to drive the Titan back to the hotel. Nuff said.
Last time we compared full-size pickups, in January 2004, the TITAN won (Mick14) How did you compare reliability of the Nissan Titan versus other trucks in January 2004, since it debuted in 2004, and it takes time, in years, to rate reliability? You should have looked at the reference before posting a reply. How did the testers drivers determine reliability? The consumer reports reference clearly states how they determine reliability ratings.
The only strike against the Nissan is the use of hard and cheap-looking interior plastics. (Mick14) Not true, after testing reliability the consumer report wrote the following about Nissan Titans: Reliability has been well below average (SOURCE MSN: Autos/ Consumer Reports). Or you can check out the previous post for the article.
Nonetheless, each night every tester wanted to drive the Titan back to the hotel (Mick14). Are they driving the Titan to the hotel because they couldn't make it home?
-mike
http://www.edmunds.com/insideline/do/Drives/LongTerm/articleId=101898
As well as the new model Titan:
http://www.edmunds.com/nissan/titan/2007/review.html
I wish they would do a test now for the 2004 with more than 24K. Mine has 36K and is running as smooth and powerful as ever!!!
-mike
Just another opinion. Myself, I put as much emphasis on CR as I do Lemon-Aid. Yet, they are sometimes very contradictory.
I want facts. I know the truth.
I do think that Frank would have designed an aesthetically pleasing automobile, but it wouldn't have gone anywhere.
http://x.nissanhelp.com/forums/costestimator3.php?section=engine&name=Replace%20- Fuel%20Pump
Guess his must've been diamond studded.
Even if the fuel pump is located in the fuel tank. You're talking 9 hours of labor to drop the tank and replace the fuel pump? Tech should be fired if he takes that long.
And I haven't had a fuel pump go since my 1981 Volvo refused to fire up back in the winter of 88.
So maybe a grand for a Titan is not that far out of line.
Dusty
As far as fuel mileage goes Most of the road tests I have seen have rated Ford, Toyota and GM ahead of Dodge and Nissan. What has bothered me about the Nissan was the same thing that used to bother me about the Tundra. For some reason the Asian powers that be decided we only needed one engine choise. Now even Toyota gives you three just like GM and Ford. Nissan still seems to think they Know better than their customers so we get one choice. It may be a fine engine but I want to make the choice. Still I wouldn't kick a Titan out of my driveway if I wanted a 1/2 ton.
If you're looking for mpg and less up front costs, buy the GM.
You don't state what exactly you want the truck to do so based on what you've posted the only logical choice is the GM.
But there is no way a 97 and a 09 are even related. That 97 was really an 88. :P
