2008 Honda Accord Coupe and Sedan
In my 2006 Accord 4-cyl Auto (and my dad's 2007 Civic EX Auto, incidentally) the engine turns 1,000 RPM per 30MPH in 5th. 70MPH = 2,333RPM.
My car doesn't feel gutless, but it doesn't take off like it does when it downshifts.
98% of the time, I want the car running as efficiently as possible when in top gear and if I need to pass, I really don't care if it has to drop a gear. That's why I've got it! :
I'd say the Civic Si is going to be a lot more like your Sentra than the Accord Coupe. You should drive it anyway, maybe you'd like it better than the Accord. It is not much like the V6 Accord though.
Some automakers seem reluctant to have the transmission up shift for high speed acceleration. Not Honda. If you’re cruising along in an Accord or even TL at 55-60 mph and want to accelerate a little, the transmission will shift to fourth for added power. But, if you want a more aggressive acceleration, it will shift to third (and may be second) for all those horses on tap. This allows them to have better highway passing prowess.
While going thru CR test data couple of years ago, I was shocked to see that Accord I-4/auto was just as quick as Camry V6/auto, not in 0-60 test but in rolling acceleration. They both completed 40-60 run in low 5 seconds. The Camry was actually a tick slower, despite of having a 50 HP and torque advantage from the V6. The I-4 Camry was even slower, doing so in about 6.5s (although it had similar power rating as the Accord I-4). The Accord V6 was 1 second quicker than Camry V6 and Accord I-4.
The key to good acceleration is horsepower. By up shifting into a lower gear at any speed, you’re getting more of those horses to the wheels. And that’s the idea behind shifting. This is exactly the reason why I have long felt that V6 is unnecessary.
Ten years ago, I picked EX-L over EXV6 and LXV6 (which was actually cheaper). If I were to get another Accord, EX-L would be it again.
Well, when you think about it, you wouldn't want to do so in theory. If I'm cruising along at 55MPH and see the need to get moving QUICK (say an 18-wheeler is speeding up behind you WAY too fast), you're gonna floor it. Do you want to be in fifth (where you may find 100-110hp at best?) Personally, I want the car to downshift pretty aggressively to move me as fast as possible!
Whoa, I said Integra, not Sentra! I really like having a hatchback - it makes my car an APV (all purpose vehicle), so I may go test drive a Scion tC. Much less expensive, but way more sporty than the Accord coupe.
That's actually lower then my previous car, a 5spd V6 Mazda6 Wagon which turned just shy of 3k RPMs at the same speed (and returned a whopping 23mpg (combined) in the process :mad:
I'm really hoping to see a combined average of 30mpg in this car. :shades:
And if you choose to stay in the top gear, something as minor as accelerating from 30 mph to 50 mph can take 10-12 seconds. And this car may even be equipped with a powerful V8.
Shifting of gears allows you to manage power. And power is what gets you the thrust necessary to maintain speed as well as to accelerate.
I said that a typical car will get you 0.11g (maximum) in top gear (let us assume fifth gear). If you were to use fourth, the thrust will typically go up to about 0.14g-0.15g (maximum). I keep saying “maximum” because the calculation is at peak torque (and under wide-open-throttle).
A diesel engine will generally cruise around 1900-2000 rpm, which is the point they typically have peak torque. As a matter of fact, they can’t afford to cruise at much lower rpm due to an issue. They use turbo, which typically shows up around 1500-1700 rpm. It also allows them to keep the turbo spooled up for reduced lag. Now, under WOT, you also happen to have maximum torque right at cruising rpm (60-65 mph). The thrust in top gear will be, generally, similar to comparable gasoline car in fourth gear. So, they don’t need a shift under light throttle (if horsepower on tap is “enough” for the demand).
The downside to this is that, due to lower redline, at lower speeds they will also require more shifts. In your gasoline powered Accord, it will take only two gears to accelerate from 0 to 75 mph. In diesel, it will definitely need three, and potentially four.
This happened back with 1998 Accord as well. Demand greatly exceeded supply. In fact, back then even EXV6 sedan trims were affected as well, and to a lesser extent, EX-L sedan (I was one of the lucky ones who, being one of the first on the lot, wasn't subjected to a wait list which shortly followed).
I'm very happy with my 177hp, 5spd so far. It is perfectly happy to run around at 2k but the power builds quickly once you get above 4k. I'm taking it easy breaking it in so I've only revved above 5k a couple of times. Looking forward to exploring the upper reaches after the first five or six hundred miles are on the odo.
An extra 13 hp available at the tippy top rpms would be so seldom accessed in my case that it certainly wasn't worth it value or dollarwise. Torque is nearly identical and the 177hp's peak torque actually comes in at a slightly lower RPM.
Maybe tomorrow?
You should definitely test drive the Civic Si. You might find it a lot more fun to drive than your Integra.
Also, it's definitely worth finding an Accord coupe V6 to drive. With the MT, you'll have a lot more fun than the AT.
Maybe Des Moines isn't a hotbed for V6 coupe sales as in other parts of the country?
IIRC (and I think I do), the gearing of the 08 in 5th was the same as the 2003-2007.
That puts them about 300 RPM lower at 80 than the 1998-2002.
EDIT:
I just calculated things...
The 2003-2007 2.4L 5A runs 1000 RPM per 30 MPH (or 2667 RPM at 80). My grandmother's 2002 2.3L 4A runs approx. 1100 RPM per 30 MPH (or 2933 RPM at 80). That would make a noticeable difference.
For the record, highway numbers for the 1998-2002 2.3L Auto are 4 MPG lower!
The cool thing about diesels is that it's relatively easy to get big power gains from them. From the factory, they are usually tuned to deliver gobs of torque with mediocre HP figures....but with some tuning, you can increase HP to match or exceed gas counterparts - especially now that they incorporate the use of turbocharging. And the real magic is that the torque jumps dramatically too. I'd say if low end grunt is your top priority, it just might be worth the wait for the diesel. The BMW 330d is the perfect car - 286 HP and 427 lb-ft in European tune, and still gets a combined 35 MPG (http://wardsauto.com/ar/bmw_diesel_us). The Accord is obviously not going to be that aggressive, but it has potential to be entertaining and seriously economical. If you can forget about the diesels of 10-20 years ago and drive one of the modern turbodiesels, you'll be hooked.
Like I said earlier, no matter how much torque an engine generates, the gearing is such that the maximum thrust possible in top gear is generally around 0.11g, rarely more and usually a little less. In other words, it would take approximately the same force to stop my TL running in top gear at 45 mph as it would take my Accord, despite a huge difference in power/torque output.
Regardless of engine output, Honda’s grade logic comes into play. It detects an incline and will select the lower gear to reduce gear hunting.
Other automatic transmission grab (and release) lower gear when the driver depresses the throttle. They may not "hold" the lower gear long enough, which results in gear hunting.
Perhaps. If you drive with the cruise on in a manual equipped car, it could, in theory, floor the car in fifth gear. It wouldn't be very perceptable to the occupants of the car. In an auto, it downshifts to make the car run more efficiently (I guess).
Also, with your auto, you have a power-sapping torque converter which translates to some driveline loss. I'm going to play with some numbers and post again shortly.
If you take power to weight, the raw numbers equate to:
1998 EX-L: 21.3lbs per horsepower
2008 EX-L Auto: 18.0 lbs per horsepower
If you translate a 12% driveline loss for the automatic, though, you get
2008 EX-L Auto*: 20.55 lbs per horsepower.
Couple that with taller gearing and higher power peaks, and what you are feeling is probably very real, because you came from a manual transmission and moved to an automatic.
Anyone PLEASE FEEL FREE to jump in, adjust my numbers, or correct me. : I'm just playing with numbers.
However, not big enough that one could leave the transmission in top gear at 60-65 mph to make a pass on freeway. It will take almost 12 seconds to complete the pass, something that might be done in less than half in second or third gear.
To put that in perspective, I will use numbers from a European publication on Accord Diesel (138 HP/251 lb-ft, 5-speed manual).
40 mph - 60 mph
In fourth gear: 6.1s
In fifth gear: 10.2s
I wish they had it measured in third gear as well. At least those folks know there is life beyond high rpm cluth drop 0-60 run that Edmunds and like take pride in.
Supposed to be coming in the next year, IIRC.
Dealer was polling Honda for the vin number but couldn't get anything. This morning the salesman saw the delivery truck show up, and there it was. He thinks it was built yesterday.
I pick it up Saturday.
2008 Accord Coupe EX-L V6 MT w/nav
Black on black
I think I got lucky with this car.
