Visitor Agreement.
roadways that are busy get a light coating of tire rubber and slime oil from drips and burners, and it takes a few minutes of a good rain to wash that off. in that time, the road can get as greasy as snot on satin even without enough water on the road to make you think there is a hydroplaning risk.
link
and a slightly different version:
NHTSA denies request for investigation into Explorer
Steve
OK- I've been all over just about all the boards trying to figure out the deal with the V6 vs. the V8. I've seen some places that the type of V6 that Ford uses has historically had problems, but I thought I saw the same thing about the V8 on another board. HELP!! I don't really care that much about better acceleration or MPG or the extra 800 bucks or whatever for the V8- I just want to get the engine that's LEAST likely to have problems- anyone have a definitive answer on this? Thanks in advance.
My Explorer shifts into O/D just north of 40 mph. I live in southern California where the norm is about 50 MPH on wide city streets, between red lights. (and we sure have a lot of red lights out here). As I say, my experience with another Ford product with hi mileage on the transmission (without any problems), has convinced me that staying out of O/D until I have a clean shot at staying at speed like a Freeway or Interstate has provided that longivity IMO. I started this practice on the advise of a good transmission repair man also. I also enjoy the braking and better performance feel of the vehicle, when it is not in O/D while driving in traffic. Just a suggestion for those who have experienced early transmission problems to consider.
Anyone have any thoughts on this, or what to look for? I had my dealer look at the seating of the windshield at one point last year, because that looked like a possible cause, but everything checked out okay. This noise is driving my wife and I crazy - any help is much appreciated.
vibrations when going up hills anymore. But I am interested to know if anyone could think of why the gasket would fail at 25K (mileage at time of purchase) aside from defect?
have read about failures of this device before, but not often, on these boards. more proof that as everything talks to the computers, they plot behind our backs... the voices told me so.
>>>> OR ELSE >>>>
it's just another way a component failure can affect the operations of the tranny with similar effects, and that's why you don't get hard estimates for transmission repair.
It seems like it is something that is loose, but I cannot find anything specific. The sound seems to come from inside the dash, but I'm not sure that's the case. I can sometimes duplicate the sound when the vehicle is stopped by opening the passenger door wide so that it "bounces back"; I've also been able to duplicate it by pressing down on the plastic "screen" at the bottom of the windshield (outside the vehicle). Of course this only works when the noise has already started. As I've mentioned, the dealership checked the seating of the windshield itself, and found no problems.
As the weather warms, the sound increases in frequency. This seems counter-intuitive, as you would think that heat would expand any loose parts slightly.
Thanks for your help!
I'd check the front inner fender shield. You might also have something dangling inside the space between the inner body structure and the outer body fender panel, which you could only find by pulling back the inner fender shield. Obviously it is something that is not readily visable.
No fault codes are detected by my OBD2 scanner.
Any experiences with this problem?
it's about time to get after creepy cheapo hardware at the fringes of the system again, as I have another minor intermittent. it's squeaking in my key, so it's not a major deal, and not loud either, but the first dry nice day, back at it.
Ford Dealer I have dealt with charges $45 bucks to make a duplicate computer chip key. Don't know what a new remote will set you back.
I'm going to do some thorough checking on the next sunny Saturday I'm not doing anything (like that ever happens). Certainly appreciate all the suggestions so far...I'm willing to listen to any theories, no matter how way out, 'cause I'm certainly not going to have the dealer or a mechanic try to duplicate this problem at $70/hr! On the other hand - this sound/noise is driving me mad!
nickm2 & vtburg - I had to respond due to so many posts concerning engines and transmissions. I've got 3 Explorers, a 1991, a 1993 and a 1997, all do very well. The 91 and 93 have the 4.0L V6 pushrod engine, both with 152K miles, VERY reliable engines. The A4LD trannys in the 91 and 93 are weak, the 91 being replaced at 100K miles and the 93 still original, but may fail within two or three years, from old age. The 97 has the 5.0L V8 and is VERY RELIABLE at 101K miles, as is the strong and VERY RELIABLE 4R70W Transmission. I expect the 97 to have NO engine or transmission problems until WELL AFTER 200K miles. One big secret is careful, thorough service. Nobody touches it but me! I use Mobil One Synthetic Oil in Engine every 6000 miles, with a Mobil One or Pure One Synthetic Oil Filter at each oil change. NO synthetic in the Transmission, BUT do a complete transmission flush with filter and oil change EVERY YEAR, don't wait 2 years, the Fords can't take it! Use the recommended dextron fluid in the ranny. Change the lube in the Differential (Rear End) every 2 years (pull off the back cover and clean it out)Use synthetic gear lube for a regular rear end, and regular gear lube for a limited slip rear end. Big secret to making them last is to keep them COOL and CLEAN, inside and out. Keep radiator, fans, thermostat, hoses and cooling system in good shape. Do your services on time.
I would recommend buying the V8 engine over the V6. The V8 comes with the better transmission, the v6's come with the weaker transmission. NEVER buy a V6 SOHC Engine, nothing but trouble. Do your research well before you buy, your best friend and ally is your good knowledge. The more you know, the better off you are.
About the transmission shifing and overdrive, that depends largely on what rear end ratio is in your vehicle. The 3.73 limited slips are good,have to get up to about 45 to get overdrive and converter lockup, but some vehicles have the 3.08, which have to get up to about 55 to get to overdrive and converter lockup. Keeping it out of overdrive saves the wear on the O/D overrunning sprag clutch, which has these little metal pieces called "dogbones" that wear out and cause the transmission to fail in two ways, first they create microscopic metal particles that circulate in the fluid, sticking valves and wearing out other parts, and second the sprag itself will give out and cause the transmission to not move. You can simply avoid all this hassle by buying the V8 engine with the stronger transmission, and service transmission with a COMPLETE fluid flush, new filter & new fluid once a year.
everybody is shaving tenths of a penny on every part, so expect a lot more tranny problems.
AWD. At 43,400 miles the rear end went out. Has anyone heard of this happening? Also what other problems has anyone experienced with this year and model.
Alaska huh? Sure is beautiful up there in the summer. Uncle lived in Wasila.
I had to be towed out. The dealer said there was almost two quarts of water in the intake and the engine is frozen - it will not turn with a breaker bar and the spark plugs out.
OK. So, I was not going exactly a snail's pace through the water, but, I was not going over 15 mph. Is this a strange phenomenon in which there must be a hole in the intake (bad luck) or is there a really bad design that sprays water up directly into the engine when going over 5 mph (or did I just learn an expensive lesson to only and always creep through water)?
I don't really want to invest (~$3500) in a refurbished engine only to have some similar problem. What should I do?
most vehicles I'm aware of have air intake behind the fan... nowadays it is also located a few inches below the top of the radiator. which means everything out there can flip water off the fan and put this fine spray right at the air intake. it isn't just the explorer.
if you are in water, you should be going slow, and if the water is high enough to reach the oil pan or the fan, you should be creeping. if it gets higher, you should be smart, turn the vehicle off, and dogpaddle. leave the fording of rivers to the army engineers... their deuce-and-a-half trucks might make it.
Moral of the story... the Explorer is not a boat.
For those of you who have the Goodyear Wrangler RT/S tires on your Explorers, have you observed the tires' tendency to pick up more road debris than usual? I am constantly finding and removing very large rocks and pebbles stuck in the tread. Also, I picked up 2 nails in the tread of one of my rear tires recently (it goes in to the Goodyear dealer on Saturday to have the nails removed and to be patched from the inside). To the tire's credit, it is holding air despite having two nails embedded in it. Thinking back to the tires I have had on previous cars, this was a common occurrence for my Goodyear equipped cars. Eagle GT+4, Eagle RS-A, and now the Wrangler RT/S.
Also to the tires' credit, they have 20,000 miles on them and are holding up very well.
Another quick question...does anyone have Continental ContiTrac SUV tires on their Explorers? There are currently very good prices on them and I wondered what the experience has been. I have observed they are/were standard on Lincoln Navigators.
Ryster
PS - thanks to everyone who responded to my clicking noise problem - I haven't had a chance to dive into the guts of it yet, but will report back when I do.
somebody, I think TireRack, had them as a slightly better than average tire, but I'm really happy with mine so far.
I even got $2k more than I would have accepted from the dealer and only slightly less than I probably would have been able to get selling it myself (without the hassles involved in that). Perhaps I had an overly poor perception of its value having owned it for 5 years.
Now, on to a new car. YEAH !!!!!!
Just be sure to come back often to inspire others!
tidester
SUVs
