The solenoid pack fails, because the incorrect transmission fluid was installed at the factory on a large group of transmissions. If they catch the affected transmission in time, and put in an additive that changes the chemistry of the transmission fluid, the solenoid will not fail, but if they don't catch it in time, it will fail, and will require replacement, which they will then do.
What about this feels like Ford isn't accepting responsibility for the problem?
It is very easy to replace, and very inexpensive to try.
Find a forum like fordtruck, or similar, do a search for idle air control valve, and there will be instructions for replacing it. It should be located right on top of the engine compartment, has one or two bolts, one electical connection. I replaced my wife's on her 98 Explorer b/c it was getting stuck open and sounded like a fog horn. Cost was about $60 for the part.
About 6 months earlier, I had the same part on my ford car replaced by ford (before I knew what was causing this) at a cost of $200
This vehicle does not seem to have a fuse that covers only the interior lights, or I would leave them off.
A second issue that may or may not be related is that the daytime running lights have ceased to function entirely. This was first noticed a few months ago.
ECV
this exact same problem just occured w/ my 2003 explorer eddie bauer, i took it to the dealership and they are telling me the engine is "warped" and is completely shot, my car is at 37,000 miles only 1,000 miles past warrenty and there telling me that ford won't cover any of the price for a either a crate engine, rebuilt engine, or a salvage motor..... what should i do....get in contact w/ a lemon attortney ?
Thanks for reading!
- J
Hope that helps,
E.D.
It was because Ford and the Board did resolve the issue that I purchased another Ford product. ">
I just bought a 97 with 111k miles. It started doing the same thing. The dealer wants $2063 out the door for a new transfer case. This is too much for me. Could you email me and let me know how you did yours. I have the haynes book on the truck and I am very good with tools and fixing things. Had dirt bikes and have worked on my 140 hp johnson outboard. I would rather have someone else do it but cannot spend 2000 on the job. Can a local 4x4 truck repair shop do the work ok? or does it have to be someone that is trained on Fords? please give me an email.
kevinpaula@arilion.com
If you subscribe to alldatadiy.com you will have access to detailed repair instructions, torque specs, etc. Some special tools required - gear pullers, snap ring pliers, and some others. About 250 ft lbs of torque on the output shaft nut is required, so access to more than a 3/8 drive socket set will be needed.
You might also check the wrecking yards, and pull one out of a rollover. Check around for prices, I think you will find this will cost near the same price as the parts kit. I now get most of the expensive stuff out of the junk yards for my 99.
And finally, I cannot remember the name of the place online, but you can order a rebuilt one with warranty for $600 to $800 or so.
You need to know the model of your transfer case for all this of course. You will be able to do that when you research parts kits and rebuilts online - some of the sites have info to help you with this. Twisting your own wrenches can definitely save you some money on this one.
I am very happy with the Explorer. No rear axle whine, and no bad transmission shifting. As soon as I bought it, took it to the dealer to take care of a whine which was a bad left front wheel bearing. It also had a bad rear axle to drive shaft seal. Both were replaced under warranty. When I bought it, clocked the gas mileage while driving 70 ( occasionally 75), it got 20.8 mpg.
Drove it on a long trip the other day, and stayed with 70mph and it got 21.33mpg. On another trip, pulled a pop up camper and it got 16-17mpg.
This Explorer is exactly what I was looking for. It don't think. Explorer is one of those most refined SUV's out there, but for its looks and room, it meets my needs.
I don't know why 03 Explorer doesn't have low gas light, but it has " loose gas cap" light !!
Joe
Good Luck,
E.D.
I gave the dealer all receipt of about 6 change of oil from certified local shops. They still refusing repair my car and are asking me 3,000.00 dollars for the repairs. Is THERE ANY WAY I CAN CONTACT FORD WARRANTY DEPARTMENT DIRECTLY? Does any of you have a previous experience with a situation like this?
Good luck!
Ladyc
I think the best bet is to get a 1996 or newer Explorer with the V8, as it has the strong 4R70W transmission behind it. Both the 5.0 L V8 engine and the 4R70W tranmission have proven to be strong and reliable for years. I have a 1997 and a 2000, both with V8 and they run perfect with no problem. I could not be happier! Unless of course, I could get 25mpg around town! But of course, I can dream!
Sorry for your misfortune, wish you well.
E.D.
Any idea what's going on in there?
I'm not too familiar with the newer Ford trannys but It sounds like the clutch plates are slipping.
I had a similar problemn with an older Ford automatic back in the late 80's. It did the same thing...as the tranny got hotter (from driving) the tranny would slip more. Mine was so bad that it would be in gear and not even move. If I let it cool down , it was driveable...but only until it heated up again.
Check your fluid first...is there enough? what color is it? (it should be red? at least older Ford autos used the red stuff)
She said she had the tranny rebuilt a year ago. It would appear (unless there is abuse here) that the rebuild was bad--not the transmission. If the rebuild was done properly, it would have gone a lot longer than a year, no matter how bad you say they are....
Yes....Exactly my point. My former post indicated the criticalness of rebuilding the tranny right, or it will not work for long. The point I made about how bad they are is twofold.
First, is the inheirent weakness of the design, with so my design flaws, they made many production changes from 1991 to 1994, first changing the band from the double wrap to the single wrap, changing clutch drums, planetaries, pump and thrust washers. They were full of weaknesses, and are a big part of tranny shops bread and butter.
Second, is the critical need to have everything exactly perfect in the tranny. You can't just let a part "slide " or "get by" because it looks ok, it must be critically examined, and measured, to be as good as new or else replace it. These trannys typically require so many new hard parts, that they typically need to be REMANUFACTURED with almost all new parts. Throwing them together with a set of soft parts and a few thrust washers will usually result in what Ladyc got, a failed transmission after a relatively short period of time. AND once it fails again, it must be completely redone over again, as everything is contaminated and ruined, meaning another new or rebuilt torque converter, cleaning and flushing the cooler and lines, tearing in down completely again and checking everything to the very last detail.
As I said, I built several of these, and I have delt with others who have built them. These trannys can hold up if they are used for light duty only, but the idea of a SUV built on a light truck frame is for service heavier than light duty. Myself, I drive rather hard and agressive, so they do not hold up well for me. An easygoing driver may have better luck with them. However, once they start to have problems, easygoing or not, they will eventually self distruct.
For those of you that are not familiar with transmissions, let me say that all transmissions are NOT created equal. They are like cars, some are better than others. Each has their own unique qualities, strengths and weaknesses. A good transmission technician know these qualities, and knows what to look for in a particular tranny, if he is experienced with that particular tranny.
Again, good luck,
E.D.
E.D.
I've got a 1997 Explorer XLT with 140,000 miles. I think the transmission is going, but some of the things it's doing make me wonder. In the mornings it's usually okay, except when I accelarate hard, then it kind of jerks a bit, almost like it's missing, but once I get to speed it's okay. In the evenings (where the heavy LA traffic is) it does the same. If I turn on the Air Conditioner, it does not was to 'take off' from a light, but once I get up to 25-30 I can feel a surge of power in the truck, and I really take off from there fine. I really feels to me like the engine while working is having a problem with a load or something. After a couple of weeks of this, the other day the check engine light came on. It usually goes into gear when I start the car, but sometimes theres a delay before it engages (which is why I think at least part of this is transmission?)
Anyone have any ideas of anything OTHER than transmission that could cause this?
Thanks a bunch!
Jim
"In the mornings it's usually okay, except when I accelarate hard, then it kind of jerks a bit, almost like it's missing, but once I get to speed it's okay." That may indeed be due to a miss in the engine. Check Spark Plugs, make sure they are the correct type and gap, make sure the spark plug wires are in good shape. Bad spark plugs and spark plug wires can cause what you describe. Be sure to take your vehicle to a shop with a good diagnostic code reader, to find out what is wrong in the engine first, then check the transmission after the engine is running good.
"In the evenings (where the heavy LA traffic is) it does the same. If I turn on the Air Conditioner, it does not was to 'take off' from a light, but once I get up to 25-30 I can feel a surge of power in the truck, and I really take off from there fine. I really feels to me like the engine while working is having a problem with a load or something." In heavy traffic you seem to have a problem taking off, maybe lack of power or under some load pulling the engine down? This sounds most likely like the transmission is starting off in second gear instead of first gear. This could be caused by several things, valve body, soleniods, ect. You need to have a shop with a good transmission code reader pull the transmission codes to see what is wrong with it, then go from there.
Good Luck,
E.D.
