Why would just the left side not work?
What do you mean by the above?
Recently purchased a 2001 Explorer Sport and the left reading light in the overhead console is burnt out. Owners Manual says to go to a qualified service pro to replace bulb. Anyone know what comes off to change out this bulb?
I talked to a few mechanics and no one seems to know where the problem is. Any sort of help will be greatly appreciated. Thanks in advance.
Victor
Let us know what you find out.
Good Luck,
E.D.
If the friction material or pressure plate has been scattered, this can occur easily by selecting too low a gear when downshifting. Clutch doesn't even have to be engaged. If first gear is engaged in the transmission when fourth was intended, the clutch will over-rev & possibly self-destruct.
If the friction material is worn out or burned up, that's another story. I can destroy a clutch in less than an hour. But, it sounds like you were with the vehicle all the time & didn't observe excessive clutch slipping.
So, if you're sure neither of the above circumstances occurred, you're probably right. However, even the auto manufacturers cinsider the clutch a wear item with a wear rate much dependent on driver habits. After 2 years & 20,000 miles, I doubt that there's a service shop on the planet that would give you a free replacement.
I suspect that the clutch was on its last legs when you bought the vehicle. A more thorough inspection & evaluation might have saved you a lot of grief & $$.
FWIW, I think the mechanic is way off base trying to blame your son.
I cut a boot on my CV joint, so I installed a remanufactured left Half Shaft (Cardone 60-2101) and a new axle seal (National 710429, which matches the OEM seal exactly) into my 97 Mountaineer. Now the axle seal leaks. The remanufactured axle journal fits very loosely into the axle seal. The journal measures 1.401 inches. Does anyone know what a Ford left half shaft axle journal measures (I had to return my OEM shaft for the core)? A brand new Cardone left Half Shaft measures the same as the Cardone remanufactured.
Thanks for the help... if the OEM journal is larger than 1.401, I'll have to order up a Ford OEM shaft ($200 vs the $60 for the remanufactured).
thanks,,,,
replace one of my O2 sensors (there are 3) the one after the converter, could this be the problem source. BTW thanks for the response....
Do you think O2 replacement would take care of the problem,
We have not done a comp test yet.
Any ideas what might be the problem?
Thannks in advance
I recently purchased a 1997 Ford Explorer XLT V8. The day after I purchased it the truck started sputtering and the check engine light came on. I ran the codes and it came up with "misfire detected on cylinder # 6". The next day I changed the spark plugs and wires and after that it was running so much better and was running perfectly fine for about 4 days. Then it started sputtering again and the check engine light came on. This time the code is "misfire detected on cylinder # 3". I am getting very frustrated as I just purchased this truck. Can anyone please suggest what the problem may be and what I should do to eliminate these problems from continuing? Thank you very much!
Your manual will give you firing order info so you know which cylinders are 6 and 3.
Replacement is simple - unplug the wires ( marking them so you get them back in the correct positions is very important) and unbolt the coil pack. Put in the new one!
I have a 1997 EB Explorer with the same problem. The right low beam does not work. Fuses are fine, etc. I can use the high beams when I push the switch forward (activating the bright position) or pull back on the switch (flash to pass). Any help would be greatly appreciated.
