Ford Explorer Maintenance and Repair
1108109111113114125
  • 70ss454_man70ss454_man Member Posts: 107
    are the power locks on a 1993 explorer vaccum driven by any chance? Cause I'm having problems with the passenger door unlocking, and after a few tries it pops right up and down. Near the handle and key slot (outside) i felt air escaping.
  • mehddimehddi Member Posts: 2
    My 1994 4wd's fuel gage reads empty. I also noticed that Fuse 17 which sends power to gage was causing a short, and removed it. I wonder how can I get access to the wires going to the gage and fuel level sender's wires. It seems that there is a connector in newer models, but I couldn't find such a thing on the wires coming from the fuel tank in the driver side's frame. do I need to remove the tank?
  • atlantis2atlantis2 Member Posts: 2
    My 1999 Explorer with a 4.0 engine makes a loud howling sound when accelerating. It only does it when the outside air temp is around freezing or below and when the engine is at operating temp. It does it when I put in gear or take off from a stop. The sound continues for a short time and then stops like it was switched off. If I take it out of gear it will also stop. It isnt the transmission or the power steering pump. There are no codes or other problems. It wont do it all summer long but when the fall hits and the temp drops it starts. Sounds like a horn :sick: :sick:
  • tfmrtfmr Member Posts: 10
    I have a very similar problem with my new 2006 Ford Explorer, 4.0L engine, with only 7500 miles on it. At around 4000 miles I started to hear a squealing noise coming from the engine when I accelerate above 2000 rpm and the noise continues to 3100 rpm. Below this rpm it is smooth and quiet. When the gear changes (at > 3000 rpm) from 4th to 5th or from 2nd to 3rd, the whistling goes away immediately. When I press on the gas to raise the rpm back to around 3000 rpm, which shifts it down one gear, the noise returns until the rpm increases above 3000 rpm when the gear shifts to the next higher, rpm goes down and noise immediately fades out.
    I must add that this whistling noise can be heard clearly when the outside temperature is cold. The squeal disappears when the outside temperature is above 80 degrees. When the outside temperature drops, the squeal returns.
    I am suspecting a bad Mass Airflow Sensor. Hope someone here can give some hints as to what could be the culprit.
  • scottsplacescottsplace Member Posts: 1
    I have a 1998 5.0L/AWD with 160K miles, and I've never changed the axle lubricant. The service guide states:
    Rear axles containing synthetic lubricant are lubricated for life. These lubricants are not to be checked or changed...
    Rear axles containing non-synthetic lubricant must be changed every 100,000 miles...
    So, if I can't check the lubricant, how do I know if it's synthetic? And what about the front axle?
    Note that the axle has not been submerged, nor trailers towed. The vehicle has been virtually trouble free.
    Thanks for any useful suggestions.
    I have a very similar problem with my new 2006 Ford Explorer, 4.0L engine, with only 7500 miles on it. At around 4000 miles I started to hear a whistle/squeal noise coming from the engine when I accelerate above 2000 rpm and the noise continues to 3100 rpm. Below this rpm it is smooth and quiet. When the gear changes (at > 3000 rpm) from 4th to 5th or from 2nd to 3rd, the whistling goes away immediately. When I press on the gas to raise the rpm back to around 3000 rpm, which shifts it down one gear, the noise returns until the rpm increases above 3000 rpm when the gear shifts to the next higher, rpm goes down and noise immediately fades out.
    I am suspecting a bad Mass Airflow Sensor. What did you find out in your case?
    Could be a pending BCM failure, which you do not want to have to fix. But it also could just be a random power surge. If it does it again, reboot the car (disconnect the battery, and reconnect after a minute) and see if that fixes it.
    I had the mass air flow sensor fail on an older model explorer, and when they go, the vehicle is undriveable. If your mass air flow sensor was bad, you would be blowing black and the engine would fight to stay running.
    ~tom
    it could be your transmission howling. they tend to do this when either the fluid is sludgy or is low. my explorer did this now that i think about it and i had it flushed and the noise went away instantly and hasnt done it since.
    ~tom
    Thanks Tom, but I changed my transmission fluid (needed 5 bottles of it),and no change. The strange thing is that is only whistles in the winter season when the outside temperature drops. In the summer you can't hear it.
  • ryana97ryana97 Member Posts: 8
    Actually it happened again this morning. Outside temperature around 19F. This time the ABS light was on first then the ABS light came an and stayed on even when all of the various heater functions pressed. Even in the defroster mode the fan is not coming on until I actually adjusted the fan speed on the heater then the lights went off. Thank you, I will try to reboot the car. The car is under an extended warranty do you know of any TSB to mention to the dealer when I bring it in?
    Hmmm...that is strange.
    Have you taken it into a mechanic or the dealer?
    ~tom
    I'm planning on taking it to the dealer this weekend. Just trying to get some background info. You know how dealers are, if it doesn't happen for them while it is in the shop then the problem doesn't exist. Also, no codes have flashed.
    I found some TSBs related to air bag and ABS lights, one sounded right on, TSB 16665. Do you know where I can find out more info on the TSB?
    I realized that fuse 17 was not related to this problem and replaced it. but I am still confused about the way that wiring works with this 1994 explorer.
    atlantis2, I'm wondering if you found the cause of your engine howling noise when its cold? Please share your information for others to benefit.
    --tfmr
    No I have not. :sick: :sick:
  • fatbackfatback Member Posts: 1
    My 2001 Ford Explorers engine quit while driving on the highway. I determined the fuel pump was not working. I have replaced the fuel filter, fuel pump relay, the PCM relay, checked the fuse and the fuel shut-off switch. I then removed the fuel tank and fuel pump. I bench tested the pump with a battery charger and it seemed to work fine. Next I used my multimeter to test voltage at the plug while cycling the ignition switch. No voltage. I then connected the fuel pump externally to see if it would run. Nothing. For some reason I am not getting current to the fuel pump. Does anyone have an idea what I can try next. At this time I don't think I need to replace the fuel pump costing $250.
  • wmh001wmh001 Member Posts: 1
    My 2000 explorer has no marker lights/dash light or license plate lights. I have changed all fuses in main panel and under hood but still have no lights. What do i do now?
    I'd check the light switch now, see if the voltage is getting to the switch, and when it's turned on it's passing the voltage out to the light wiring. You could try wiggling the switch, it might make intermittent contact. If so, that would prove your switch is going bad. You will probably want to try and locate a wiring schematic, to see if any relays are also involved in the circuit.
  • sawyer2sawyer2 Member Posts: 2
    I have a 2004 Explorer, 2000 miles out of warrantee (of course!) and now when turning a low speed, like into a parking space, the rear wheel on the side I'm turning toward feels like its grabbing, or losing traction or something like that. My mechanic checked the fluid in the rear and its fine. It seems worse if I have a lost of people in the truck. Any ideas?
    Suspect the rear differential. Sounds like 'limited slip', isn't slipping. If he just checked to see if it was the right level, I would try replacing the fluid. When you go around a bend, the inside tire travels less than the outside, so you need some slippage.
    Is this fluid something that would usually have to be changed? It never has been, as far as I know. Is it something that may be causing permanent damage to expensive parts?
    Yes, check your owners manual for the recommended service interval. It varies by make and model vehicle. You want to make sure you get exactly the right fluid for the make/year/ and type of differential you have. Owners manual will give you the specs.
  • ahoronahoron Member Posts: 30
    Did the hood pop up at all? If it opened about an inch you have to release the second latch to open the hood.If not pull the lever hold it and have someone tap on the hood where the latch is. As far as the starting problem sounds like a dead battery. Turn on the head lights and try to start it if the lights get dim or go out try to jump start it. MAKE SURE THE BATTERY IS NOT FROZEN BEFORE ATTEMPTING TO JUMP IT!!!
  • mfinefrockmfinefrock Member Posts: 4
    I had this problem in my 97 Explorer, My hood release cable had stretched. A temp fix is to bend the bracket that holds the cable under the dash away from the handle a little.
  • ersariersari Member Posts: 3
    Thanks for your efforts...I tried that...no success...I eventually found out I had free towing trough my insurance...had the thing towed to a local shop and now...I'm awaiting to here what damages they can accumaulate to lay on me...Thanks agaiin...ersari
  • flasher751162flasher751162 Member Posts: 1
    I have an 2001 Ford Explorer, when you have the truck running you smell gas outside but if you have the heat on you smell the gas smell inside the truck.I haven't noticed any fuel leaking on the ground. Anyone have any ideas of what I can check to eliminate this problem.
    Where there is gas smell......there's......
    I'd get it to a shop quickly.
    I would suspect a gas leak in the engine compartment. When the heat is on I believe it is drawing air in thru the vents on the hood above the engine compartment.
  • wifemmwifemm Member Posts: 16
    Hi, can you tell me exactly what they did with the wiring (perhaps from your service receipt), I have the same problem with my 02 Mountaineer and they're blaming it on the aftermarket radio, thanks!!
  • explorerx4explorerx4 Member Posts: 21,307
    kids got home tonight and said the cd player was having 'some issues'. it wouldn't eject any cds out of the 6 disk changer.
    i went out to try it, i pushed all kind of buttons and combinations of buttons. it made a noise like it was trying to change cds but it just seemed like it was stuck. it then would display 'cd error'.
    feeling a bit frustrated, i pushed cd button, selected the cd number originally displayed, pushed the eject button and banged on the top of the dashboard while it was trying to switch to that cd.
    it popped out and so did the next one. it turns out the second cd, also homemade, was put in upside down. i took out all the homemade cd's for now. it seems to be working as normal. :)
  • henco35henco35 Member Posts: 3
    Great post!! Thanks. Wanted to add my 2 cents worth. I have 02 Explorer Sport Trac with blend door problems. After running the electrical, I determined that it was, in fact, the problem. Ford must have figured out the snap down post system you described did not support their built in maintenance program, so they had changed to screws (two on the front of the actuator and one in the back. They still utilize 2 more posts in the back. Upon tearing the dash apart attempting to get to the rear screw and realizing it was futile, that the only way to access this screw was to remove the plenum, I decided that if I was to break off the back screw and take my chances on getting the actuator to work properly, worst case---I was no worse off than right now and seeing where it would easily cost $800 in a Ford house, I decided to lunge forth. After removing the 2 front screws, I used a flat bar and firmly pried up on the back of the actuator from underneath while pulling the actuator forward. The actuator plastic housing broke cleanly at the screw and I was able to remove the screw after the actuator was out. I never could see clearly enough inside the plenum to determine what postition the mix door was in, so I decided to drill the D shaped pin just as you had in the pictures. I did so 1/4" from the bottom, thinking I need to get as much inside the opening as possible since I was unsure how stable the actuator would be without that back screw. I drilled a .130 hole and used a .120 pin (stainless nail). As the D pin is .300, I decided to make the pin .530 long. At first, I could not get the pin to seat. I then took my flat bar and put firm pressure down on the actuator centralinzed at the pin. I then slowly turned the selector nob and suddenly the whole actuator started moving. I then knew I had the pin in the correct position. I seated down probably another 3/16, put the two front screws back on and laughed during my test run, realizing how Ford had once again gotten screwed. Thanks so much for your post and all the detail. You are very wise, Budda!!
  • savannahboyersavannahboyer Member Posts: 1
    I need to know what the name of a certain part is so that I can fix my vechicle...Its about 8 inches long, its a shaft, its by the radiator, under the plugs in the engine. It has a sensor that goes on top of it. Inside the shaft where the sensor goes is destroyed. Its a U piece of metal. Here is a picture:
    http://i76.photobucket.com/albums/j1/savannahboyer/Ford2.jpg
    http://i76.photobucket.com/albums/j1/savannahboyer/Ford1.jpg
  • electricdesignelectricdesign Member Posts: 681
    That part is called the camshaft position sensor. That is basically the bottom part of what used to be the distributor. Since a distributor is not required for the ignition, now that they have the coil packs, this shaft is now shortened and has a sensor on top that tells the computer the exact location of the camshaft. This is used for the timing of the fuel injectors. If this part is rotated out of time, the fuel injectors can fire out of time. Why did you take it out? I can't see the damage in the photo. Was it squealing and making noise? Mine did that and I did not remove it, I just squirted some oil in the top of it, and it has been fine for many thousands of miles. It seems that the shaft does not seem to recieve lubrication from the engine very well.
    Good Luck,
    E.D ISF
  • juntsjunts Member Posts: 1
    I currently own 2 Explorers, a 91 and 92. Spare tire fell out of the 91 in 2004. Received recall notice for the 92 last fall for spare tire replacement. Checked the spare and it was missing. Had all 4 tires replaced a month before and it was in place. Know of at least 3 other people who have lost their spare. The cable holding it up rusts off. How many other people has this happened to?
  • fordexploderfordexploder Member Posts: 11
    Do you happen to have a Sport or Sport Trac that would qualify? There's a recall repair that if performed might solve your problem??
    "2001 FORD EXPLORER SPORT TRAC STRUCTURE:BODY:HOOD:HINGE AND ATTACHMENTS
    Recall Date: 11/28/2000
    Summary:
    VEHICLE DESCRIPTION: SPORT UTILITY VEHICLES WITH STEEL HOODS AND CERTAIN PICKUP TRUCKS EQUIPPED WITH SHEET MOLDING COMPOUND HOODS. A WIRE FORMED HOOD STRIKER COULD BE SUSCEPTIBLE TO FATIGUE FRACTURES. IF THE HOOD STRIKER FRACTURES, THE HOOD COULD FLY OPEN WHILE THE VEHICLE IS BEING DRIVEN.
    Consequence:
    A HOOD FLY-UP WHILE THE VEHICLE IS BEING OPERATED COULD RESULT IN REDUCED DRIVER VISIBILITY.
    Remedy:
    DEALERS WILL REPLACE THE HOOD STRIKER.
    Potential Units Affected: 137700
    Notes: FORD EXPLORER SPORT TRAC 00S45"
    Are you near chicago??? south side??? Spare tires are easy to steal when mounted under the vehicle. What they do is put a pair of visegrips on the cable and twist until it breaks. I have had spare tires stolen off all my vehicles that have them mounted underneath. The cable didn't rust off it was cut. I'm not saying this is what happened to you but it is possible. My mother had her tire stolen twice. I just keep them inside the vehicle now. It is a pain but I guess not having the spare when I need it is worse. I had put a lock on my moms after the first time. I had to cut it off on the side of I-80 not recommended. The next lock was stolen with the tire. I don't think it even slowed them down. My tire was stolen at work. I know because I went to my truck at lunch and the bracket and spring that holds the tire were on the ground behind my truck. My truck had a lock from the factory, Great gm design lol. Go to a used tire/rim shop to get the rim I got mine for $40 with a tire. You will feel better when they steal that over a $200 one from the dealer.
  • lmmasonlmmason Member Posts: 2
    I just so happen to know that the dealerships are paid by each individual repair they make. there are limitations to how much they are paid. and they only get 15 minutes to diagnose problems. I get the connot duplicate thing alot. They get paid X amount for the repair done not hourly and parts total like you and I
  • bmimsbmims Member Posts: 5
    also have a 2006 explorer and in the last week (yes with colder weather) I noticed the squealing noise when acceleration reached between 2-3,000 rpm. Took it to the dealer on Friday, they changed the tensioner and pulley. They obviously did not test drive it because that did not remedy the problem. Let me know if you have found out anything else. Oh, and it shifts fine but does seem to stop squealing after it goes into the next gear.
  • fixitrodfixitrod Member Posts: 67
    I don't know the miles on your truck but the idler pulley also should be ruled out and its unlikely that the belts been stretched but if all that work is being done just change the belt on the same ticket but now your looking at a new labor charge...hmmm. I wouldn't go into a dealer unless I was being paid. I've actually had them confess to charging for work they did not perform or were authorized for)Paid me back for that.
    I'm on my fourth Explr(ist one was Bronco II) same truck actually. The RPMs change when you go through the gears so it not unlikely that your squeal will change also...its a turning problem.
    Put a mechanics stetchescope(hope I got the meaning across at least :) )and listen to where the squeal is coming from. Also can be done with a length of tubing or if your real sensitive a screwdriver. Look at the air filter and make sure its not clogging up.Next I would have applied a blast or two of $1.96 belt lubricant. Get a Haynes/Chilton and arm yourself with information. Remember the service techs also get a cut of whatever they write! Hope this helps...good luck
  • roughrider_08roughrider_08 Member Posts: 1
    my explorer is a 1996 V6 4.0 Liter. my car has started to quit when it comes to the battery and the alternator. I first noticed it when my battery meter started to move up and down. It has been a few weeks and it hasnt done it since. I went to get the alternator tested and they said that the alternator couldnt be better. the diods tested out perfect. it was a 15volt test. when i use alot of electrics it starts to die. The battery is brand new so i have no idea what is going can some one please help :mad:
    Based on what did your dealer replace the tensioner and pulley? My dealer have no clue, but I also figured out that the problem is with a loose tension on the serpentine belt. I do not know where the tensioner is on my explorer. Is it the triangular arm connected to the alternator pulley? If it is then this is where the problem lies. When I push this triangular shaped arm left and right it moves (so it must be loose). When I pushed it to the left (to apply more pressure on the belt so as to tighten it a bit) the squeal seemed to go away for some time, and when it returned it was not as loud as it was before I pushed that bar (I am assuming this is the bar connected to the tensioner pulley). One possibility with your case is that your dealer did not tighten the tensioner properly and the belt is still loose. Let me know if you have any luck tightening the tensioner.
  • vegas2125vegas2125 Member Posts: 3
    Hello all,
    My 2002 Explorer Limited has started to blow hot air from the vents on the passenger side. Cold air blows through the drivers side and both overhead vents in the back seat. Any help on solving this problem would be greatly appreciated. Thanks
    You have a stuck or broken blend door on the passenger side of the air plenum. It's going to involve removal of the dash to access it to replace it or the actuator, unfortunately... Have you considered only carrying passengers during the winter?? :blush:
    I have a 2006 Explorer 4.0 and have had it in twice in the last week for the whistling. They are stumped at this point and have changed the tensioner and pulley but not the problem. The whistling starts at 2000 rpm, peaks at 2250 but can still be heard at 3 and it doesn't matter what speed you are at as long as your are in the acceleration mode. According to my brother in law who works for Chevy they had the same problem are have just been notified that they need to replace the throttle body. Hope that is it and that Ford recognizes it if it is the same. So far I have passed on the informtion to my dealer rep but am waiting on their solution to the problem.
    2006 4.0 engine with whistling noise. Starts when accelerating and getting up between 2-3000 rpm. Have had it to the dealer twice of which they have also duplicated the problem in the bay and they originally changed the pulley and tensioner (not the problem) and now are looking into the area of the EGR. Ford (as of yesterday) doesn't seem to have any mention of any kind of this problem . Chevy on the other hand just issued a notice for the same thing and are having to replace the throttle body. Hum. Wonder if the manufacture of the part supplies to both Chevy and Ford. Good luck and if I can get them to replace part under warranty and that remedies it I will let you know.
    Interesting - I have had 6 Explorers/Mountaineers since 94, and only the 94 and the 02 had the 4.0L engine. The 02 whistled, and they never really got it out. Which is why I went back to the 4.6L in the next two. Best way to avoid it, I figure.
  • rmncoknmermncoknme Member Posts: 18
    Could be a bad catalytic converter, but you would probably have a check engine alarm. Try turning the key to the running position, engine off. Then get under the car and in the engine area and smell/look for leaks. Don't smoke while you do this. If you smell gas while driving, it's not from the catalytic converter, most likely kiawah is right, some leak around an injector or something like that.
  • 98explorer98explorer Member Posts: 8
    We have a 98 explorer 4x4(v6), for a while it was not idling it would die if you took your foot off the gas. We changed the spark plugs and it quit doing that, but it now sputters and misses and acts up horrible. It hasn't died yet, but it doesn't want to go and is really burning gas. Any advice would be appreciated.
    Clean the mass airflow (MAF) sensor. May not be it but a good start.
