I have a few questions that maybe someone out there can help me with. I have the leather package, moonroof, the JBL in dash 6 cd changer.
1. Can the information on the radio stay on longer when the Text button is pushed.
2. Can the doors be programed to open and close automatically when you put the car in gear and when you take it out of gear.
3.In the owners manual it shows a 115volt outlet behind the console with a switch on the dashboard to turn it on, it also shows a/c vents in back of front seats. My car has neither of these 2 features, Are they options or are they supposed to be standard on the car. Any info would be appreciated.
1. I also would like the info to stay on the radio display longer, if anyone knows how, PLEASE post.
2. I know you really mean you want the door locks to unlock and lock automatically, I wouldn't want the doors to open....sorry, couldn't resist! :-) I don't think so, as others here have commented on this.
3. The manuals tend to cover all models/options, even options that are not available in this country. (ex: daytime running lights are required in Canada, even on the base model HL, so the info is in the manual) I believe this is the case of the rear A/C vents and 115V outlet.
Hope this helps, and enjoy your new HL, we have an 03 and an 05!
The insurance appraiser told us later that he suspects it was an electrical fire, but his job description did not include investigating why it happened. So we called Toyota Canada. They have yet to return our call.
Meanwhile, we bought another 2005 Highlander. Call us optimists, more like blind loyalists. Everyone in our family drives Toyota. Both our cars are Toyotas.
Anybody heard of a Toyota Highlander going up in flames? The insurance appraiser told us that he has seen many trucks burn, mostly Fords. This is the first time he has seen a Toyota burn.
Kenm1
1) More comfortable front seats.
2) Quieter ride.
3) Seems easier to manuver
We also like the open feeling of the cockpit and in the limited version it comes across quite luxurious.
Th MSRP is 35828 (no dealer add ons, everthing but NAV and DVD) and the very best price I can seem to get here in Utah is $31500. Is that reasonable? I think that is close to invoice price but it seems that in some parts of the country (or maybe better negotiators) you can get it for below invoice?
There were a few reports a couple of years ago of fires in one or two Siennas but after investigation, the cause was determined to be unrelated to mechanical or electrical deficiencies.
Be cautious in relying on comments by an insurance company official. Insurance adjusters aren't qualified nor mandated to assess causes of fires. Their job is only to determine extent of damage and subsequent action by their company.
Normally in an unusual situation like this one, the fire dept. attending must investigate and determine cause. I'm surprised that you didn't get any feedback from them. In our country (Canada) this would be almost automatic in cases like that.
The fire could have resulted from any number of factors. Spontanious combustion in an on board garbage bag is one. Debris packed around the catalytic converter in the exhaust system is another. Smokers cause many fires when they throw cigarette butts out windows. Debris in the engine compartment is another common cause. Yet another, previous damage to the vehicle may have resulted in an electrical anomaly. Even a ham handed oil change person could have inadvertently dislodged an electrical wire when doing the oil change--it happens.
Don't limit your choices to only one possibility. There are many besides the more common ones I mentioned..
The fact that you were camping at some point when this incident occurred is an indication of where the cause may lie. I would start looking at that.
With the $800 cash incentive (which expired August 1st - we'll see if they have another one this month) I think you should be able to get about $500-$600 under invoice.
Popular Toyota Models Get Price Hike (Inside Line)
Or maybe you're in the South?
Why does the car I'm looking at have a different invoice price or MSRP than what's listed on Edmunds.com?
To clear Random play, put the player onto a CD and press RAND quickly. I think this is the preset button 4 (radio channel 4 when used as CD player)
Cheers
Graham
Please do not misunderstand. No one is asking you to leave this discussion! The Edmunds.com Owners Clubs are built by its members, with the help of your friendly neighborhood host. :-) I hope you'll reconsider and give it a chance to thrive.
KarenS
Owner's Clubs
Hope this helps.
Ken
That seems exorbitant, and I've never been asked ot change out water pumps and seals as part of a timing belt change, so that makes me suspicious that they're trying to rob folks here in Virginia.
Hope this helps.
Ken
This engine, like the Chrysler/Mitsubishi 3.0 V6 and Subaru 2.2/2.5L engines has a water pump driven from the timing belt. While they have it apart, after 100K, it's a good maintainence item to do, as well as the seals and some pulleys. Reason will follow. To do either the Water Pump or seals later requires the timing belt to be removed.
1- This IS an interference engine, that is, if the timing belt breaks, the pistons WILL slam into the valves destroying the engine, hence the change interval.
2 - If the water pump 'seizes', it will destroy the belt in record time and there is a good change the above will happen.
3 - Oil leaks and Water pump leaks do destroy a timing belt prematurely. I had one Subaru jump timing less than a month after the owner noticed the leaks in his driveway. He was fortunate, jumped enough to make it run badly without destroying the engine.
Now to the price.....I think 1K is outrageous, I would go back to doing this full time if I could command those prices, but I do it when I can, and if the neighbors can wait, they usually know I do it as if it were my own car. I would shop around for an independent dealer who has done a Toyota V6. They are a tight squeeze and tedious.
My $.02
Mckeown said it best though......good advice.
NOTICE:
With the Timing Belt Removed:
The crankshaft pulley MUST be at the correct angle to avoid
damage in later steps. If the crankshaft pulley is at the
wrong angle and then the camshaft timing pulley and the
Camshaft are moved, the piston head and valve head may
Come in contact and be damaged.
So if they are concerned with them coming into contact with each other during a timing belt replacement, I would not want to see the pistons/valves if the belt broke at highway speeds.
The 4 Cylinder has Timing chains..one from the crank to an intermediate shaft, then another from there to the twin cam cogs. I don't see that same warning under the chain replacement.
Here is a link to the Gates Timing belt replacement list. PAY ATTENTION to the * listed after the engine. You will see a lot of Newer Toyota's ARE interference Engines, Looks like 98 and newer all V6's which means ALL V6 Highlanders.
Don't get upset, or shoot the messenger, just heed the Maintainence Intervals and you should have years of good service.
http://www.gates.com/downloads/download_common.cfm?file=GatesTBR.pdf&folder=brochure
So trust, but verify. :-)
This tire is the best I have found. You will not have any traction problems when towing.
You can read countless professional reviews and lots and lots of consumer comments that say the car is a dream to drive. I can tell you I am very happy with ours. So it is just impossible that Every Highlander is afflicted with a "Deadly Design Flaw". It just does not stack up.
Again, for those of you with real problems, I wish you every success in resolving them. But to exaggerate blow the issue way out of proportion actually discredits the whole issue. We love our Highlander and I have two co-workers who love theirs as well. It runs and shifts just fine.
" It is sluggish, has difficulty accelerating up hills, feels light weight, the brakes grab.......bad ventilation in the back seat, seat heaters are inadequate, no daytime running lights.......it shifts into overdrive too frequently and very roughly, it feels like a cheap unsafe vehicle "
All of those items would have come out if you did your homework correctly with a sufficient test drive.
