Toyota Highlander
13031333536211
  • dianne4toyotadianne4toyota Member Posts: 343
    "Moose avoidance test"!?
    ROFLMAO!!!
    I can see where geographical differences make for different obstacles!
    In SoCal, that's a "SoccerMom on CelPhone on the 405 with fighting kids in an SUV Avoidance Test!!!"
    --Dianne
  • sirfilesirfile Member Posts: 42
    Yes, you are correct . . . if you have a four-speed, either standard or automatic, and the fourth gear ratio is less than 1.00, you have an overdrive ratio. Most overdrives today are about .90 overdrive. Remember the good old days when new cars were $2500 and came with a three-speed automatic? Third gear was generally a 1.00:1 ratio, and with a 3.00:1 rear axle would allow the driveshaft to turn at 1/3 the speed of the axle. Axle ratios are critical to performance and economy. As teenagers, we thought it was great to put much larger tires on the back of our cars to improve appearance. It took a while to realize that by doing so, we were making the rear axle ratio higher [numericaly lower] and losing performance. Changing tire and wheel sizes is the quickest, and least expensive way, to change gearing but you have to understand the principles to do it correctly. If your former students are interested, it can be an fascinating subject.
    If you were driving a vehicle with a four-speed overdrive, I would recommend that you only use the overdrive at speeds above 40 mph and on relatively flat road surfaces. I believe your new HL is geared correctly, and you can leave it in fourth gear for general driving and lockout fourth when driving in mountainous terrain. The HL is one of the few vehicles I have driven recently that I didn't feel that I had to shift into third gear just for general use.
    Fuel economy losses with your HL will be minimal without overdrive. The manufacturers are very sensitive to mileage ratings but they also know that performance is critical, so everything is a compromise. I believe Toyota has done a terrific job with your HL, so just put it in fourth and drive smoothly and carefully!
    ...is a very difficult colored Highlander to come by. The build ratio for that color is very small ratio in comparision to other colors like the white, green, gold, and silvers.
    Di
  • drew_drew_ Member Posts: 3,382
    That's what they call it over in Europe. The moose avoidance test....it's basically a double emergency lane change maneuver, where you swerve to avoid the obstacle, and then immediately swerve back into your own lane to avoid the oncoming vehicle. It's quite demanding of a vehicle because of the rapid side to side transition where the suspension has to cope with the body movements very quickly. A soft suspension really doesn't help here at all, since the body movements will be exagerated.
    This is also basically the dynamic test that Consumer Reports basically uses to test the stability of SUVs...far better than the NHTSA's static mathematical rollover formula, IMHO. It's also quite a plausable situation in real life, as you can imagine. A stability control system (ex. ESP) pays huge dividends in this test, especially if the road is slippery. Most drivers lack the ability to control the vehicle after swerving the first time, and end up falling victim to snap oversteer (where the backend comes around the second time) possibly when they overcorrect...sounds familiar, eh, mkstring ;-)
    Drew
  • rubytuesdayrubytuesday Member Posts: 21
    to Localboy49 who says " Its funny but I haven't seen any other HL on the road in my area in Honolulu except at the dealers."
    we're out there, but HLs are very rare sightings on Oahu indeed! My un-official count to date in Honolulu is: 2 Bluestones (one Limited), 3 Silvers (all Limited), 1 White, 2 Gold, 1 Black. I think there's an Indigo Ink out there, but I haven't seen it on the road. The black one I saw getting licensed at the dealer - it was sold but I haven't seen it actually on the highway.
    Also of interest, I have not seen any red HLs here, even in the Toyota processing yard.
  • mlx52mlx52 Member Posts: 72
    I'm thinking of buying a Highlander Limited 4x4 for my son to take to collage. However, I have a few questions about the car:
    1. Can you get an auto-dimming mirror?
    2. If you get the leather package can you get an Ivory colored dashboard instead of the black one?
    3. Have any of you experienced any problems with the car?
    4. Have any of you experienced rattling or squeaking in the car?
    5. If I choose VSC, which I would like, do I get the LSD, because when I configure the car online the LSD is no longer an option when I choose VSC.
    6. What is your experience with the JBL sound system, does it sound good? A very important option for my son!
    7. Is the cabin well isolated at highway speeds?
    8. Is the ride soft and comfortable yet controlled?
    9. Does the car fell tipsy?
    10. Is there any info on the 2002 models and when they will be released?
    11. Is the power from the V6 smooth yet aggressive?
    12. Has any one driven the car in the snow? How did it hand and how easy was it to manage the snow?
    13. Are there any safety reports for the Highlander?
    14. Is the alarm included in the Limited Package?
    15. Is the remote keyless entry included with the Limited Package?
    I’m sorry for all of the questions, but this is a big deal to my son being his first car and all.
    Jamie
  • deelanderdeelander Member Posts: 3
    I too agree with the previous posts . . .blind spot, fully loaded very comparable, etc. One of the biggest differences for me (IMHO) was the driver's view and the ability in cornering and ease of controlling the vehicle.
    I know the two that I test drove (one I ended up buying) I did a parking lot test(yes it was empty) going around the tree planters basically a cone test of sorts to feel the handling and ability to control the vehicle. The second test was the 0 - 60 test and slam on the brakes. I was amazed that the vehicle did not even swerve at all. The vehicle went completely straight. The salesman who was with me suggested this to check out the ABS.
    For the money the Highlander was my choice!!!!! I picked it up last Friday and of course on all our errands this weekend we went in the Highlander.
  • jreajrea Member Posts: 26
    Can anyone give advice on the relative merits of the stability control (VSC) vs a limited slip differential (LSD) for frequent travel on muddy dirt roads?
  • hobie1981hobie1981 Member Posts: 23
    okay.. Here goes
    1.) Yes, after market about $200. But why bother, flip the mirror! See "after market' posts.
    2.) Don't know.
    3.) Nope.. I've got 5200 miles on my AWD V6, Ltd.
    4.)Nope
    5.)VSC...just say no to LSD..:-)
    6.) JBL is great... listen from everything from PR radio to Stones. I did add an Infinity "Basslink" subwoofer to increase the bottom end a bit. Check out Nexxon.com for great price.
    7.) The car is quiet at 70 mph...The JBL will cover up any noise anyhow.
    8.) Ride is fine...You can upgrade to Bilstein shocks at a later date if you want firmer ride.
    9.) No..see #8 above.
    10.) 2001s have only been out 2 months.
    11.)220 HP. Add Borella "cat back" exhaust for more agressive exhaust note.
    12.) Great in snow with VSC...Depending on where car is to be used, you may wanna look at a more agressive tire however.
    13.) It's safe...
    14.)Yes.
    15.)Yes.
    You wouldnt be looking to adopt another kid would you. Already been to college...just looking for someone to bankroll my HL. LOL. Might even tell you where to get fender flares at jobber cost.
    Good Luck... Hobie1981
    MLX52:
    1. Don't know
    2. Top of the dash is dark, bottom half is ivory
    3. No problems, love it !
    4. No rattles, no squeaks, it's quiet!
    5. I think the VSD makes LSD null and void?
    6. The JBL is fine, better than the Bose I had in my Honda.
    7. Quiet so far, unless you roll down the back windows at highway speed with the front windows up.
    8. Comfy !
    9. No, very stable - drives like a car. Just take it easy on turns, all SUVs can roll easier due to their height.
    10. As Hobie1981 says, it's only 2 months old...
    11. V6 is great, can be aggressive when you need to punch it.
    12. Snow ?????????????? ? ?? ?
    13. Compare safety reports for the Lexus RX300, it's built basically the same.
    14. Yes. No glass breakage sensor.
    15. Yes.
    Aloha!
    FYI, I had the glass breakage sensor added on as a PIO. The button on the dash does not change like when you add on the entire alarm system (RS3200) at PIO, but I couldn't find the sensor (small speaker-looking gadget)after it was installed. Until this weekend. It fell off from where it was placed - basically wired into the alarm system, and stuck on with double-stick tape under the dash on the passenger side. Apparently the installer didn't press down on the tape hard enough so it came loose. So, this installation must take all of 5 minutes. Not bad for $ 76.00, eh? WHY this isn't part of the factory alarm, I have no idea.
  • b717b717 Member Posts: 38
    Thanks for the postings from all, particularly the Hawaii HL purchasers and Cliffy and Dianne.
    Mine should be ready for delivery Wednesday or Thursday, it is at VPC getting prepped and also the "doublestick tape treatment". Wish I could get a picture of the salesman scratching their heads when the first place I look is under the dash at the sticky tape, thanks for the tip with location of the Glass breakage sensor. I agree with the comment, why isn't this part of the alarm...
    Sightings in Hawaii, Kaimuki's demo is Red and there is an unsold Bluestone (6914 LL VD DJ) on display at the UH credit union on King St. next door to McCully Chop Suey. It is the Bluestone I had an agreement on, but swapped for my soon to be delivered White one. Looking forward to seeing each other out on the road, Aloha
  • hialeahmariahialeahmaria Member Posts: 45
    Help! (re: message #1557)I know you guys don't want to hear another sob story from me, but this is really out of control. I was called by the dealer yesterday and was asked if I could bring my car back for re-appraisal. I did go and what they told me was that my car had "major frame damage" and that the back end had been welded on! I bought this car with about 2000 mi on it and no one who serviced it has ever mentioned anything, nor has it ever given me a problem. Guaranteed clean title. Imagine my thoughts!
    Well, they said that they could not resell that car at the dealership in that condition and it would have to go to auction. Is this true?
    Please advise...I really want this HL and if what they say is true, maybe I won't be able to get above $13K for my car. Help!
    Nutso in Miami
  • mkstringmkstring Member Posts: 53
    Just to add to hobie's and ruby's posts:
    1) It's a PIO - Port Installed Option. I have it on mine. You can also add it later (aka aftermarket).
    2)
    3) after the 1600 posts on this discussion list, they only issue I heard was the tire overinflation issue from the factory/dealer (40 psi, rather than 32)
    4) I think I'm hearing the suspension settling in when I'm at a sharp turn angle and backing out of my driveway (I have a large drop). If it persists after 1000 miles, I'm having it looked at.
    5) I WISH I had VSD. It not only helps in snow, but in emergency maneuvers on dry surfaces.
    6) I have the 3-in-1 upgrade, not the full JBL system, and it's plenty loud without distortion, but not like a system with 12" subs in the back and hi/mids in the front.
    7) From road noise, no - tires play a big role in this. In strong cross winds, there's a decent amount of wind noise (to be expected), and with only certain windows down, there's a pressure variance that causes a repeated annoying low thump. Just lower other windows a bit and it goes away.
    8) soft and comfortable are just the words I would pick...
    9) Going at 75-85, I have this feeling that if I need to turn suddenly (not a good idea anyway), the momentum will cause the vehicle to lose traction - THIS is mainly due to my accident with it - and I'm paranoid about that now BUT then I lost control of it (my fault, btw), it didn't even feel like is was going to roll - it just fishtailed. And, after the accident, I REALLY had a good feeling of the HL's safety.
    10) Toyota runs a August to July model year. Look for 2002 info around the change, especially at car shows (carpoint covers most of them).
    11) yep - there's been some really good posts about that over the past week
    12) i don't have snow in Houston - but the comments from those that do were it is really stable on snow - I reiterate the comment about the tires - get good ones to get good snow handling
    13) For safety, I would look at the Lexus RX300 - it and Highlander share a lot in design - same platform, built in same plant, etc.
    14) repeating: yes and ruby posted that the glass breakage sensor is a PIO
    15) again: yes. I have it on my base model as an option.
    If you have about 3 hours, go back and read thru all the posts in this list - there a LOT of great info on the Highlander from owners and they can after many of your questions as well. And, my accident story's in there. Again, it was mainly due to inexperience with the vehicle. I'm looking for a driving class in Texas for me and my wife (thanks Drew for the pics!).
    Buenos tacos!
  • cliffy1cliffy1 Member Posts: 3,581
    You've got a problem. First, let me say that used car managers sometimes do exaggerate, but the words "frame damage" are real. On unibody construction vehicles, any welding to the structural sections of the car is frame damage. I doubt the back end was re attached, but you probably do have some repaired damage. Since they know about the problem, they would have to disclose it to their customer upon purchase. Frame damaged cars loose a ton of value.
    Now, you say the car had 2000 miles when you bought it. You may have some recourse against the selling dealer if you wanted to pursue it. This will take a lot of time and a lawyer and it might not be worth it at this point. If the car was untitled, they had to have known about the damage and would have been required to tell you about it. If it had been titled, they might be able to argue that they didn't know about it.
    Honestly, if "book" value is around $15K and they are giving $13K with frame damage, they are being fair. If you are in doubt about the condition, take it to a shop to verify it. You can also call me at 703-269-1478 and I'll talk to you about some tips on how you can tell if it has been wacked. Its a bit too much to post here but in 5 minutes, I can tell you how to spot paint work and weld spots.
  • sotagearsotagear Member Posts: 17
    Anyone know where there is a picture of the HL with the fender flares that was mentioned earlier?
    Would love to see what it looks like.
    Thanks to all who responded to my post. The info is a great help.
    Jamie
    You're in luck, I did a search for you regarding driving ed. events in Texas, and there are plenty of them coming up soon. Have a look at the following:
    1. Texas World Speedway events
    2. Motorsport Ranch
    Click on the event that you're interested in for more details. No excuses now for not being able to find one ;-) ;-) Frankly, you guys are lucky to be able to have the opportunity to learn at a world class facility such as the Speedway.
    I hope this helps!
    Drew
  • smallzsmallz Member Posts: 24
    -sotagear (#1620)
    There is a picture of a Green HL with (PIO) fender flares at www.villagetoyota.com. Look under their New Inventory link for HLs. (Sorry, no direct address link to the picture.)
    I too am interested in any other pictures of HLs with flares, particularly Silver.
  • impeimpe Member Posts: 33
    My dealer put in a factory order on March 6th for a Black V6 FWD with just about everything on it, (that being the reason for the factory order).
    My dealer said that it would be 120 days but implied that it could be as few as 60-90 days.
    QUESTION:
    Anyone out there with experience on factory orders i.e. amount of time they are taking etc?
    DISCLAIMER:
    As I stated in a previous post, I could have found one that I would be happy with, but my wife, the lovely Miss Linda (TLML) aka Miss Me First Always, insisted on certain options including side air bags, VSC, and after-market gray leather.
    Impe
  • dizzywdealsdizzywdeals Member Posts: 6
    Just got off the phone with a couple dealers I'm dealing with and told them I'll take a 3% over invoice on a loaded MSRP $35,065 Highlander LTD for $31,800 + T&T out da door.I have a taker.Do you guys think this is a fair deal? I'll check back in a few hours and see what the board says....
  • sbell4sbell4 Member Posts: 446
    If the car is equiped the way you would like, and if they are good people to do business with, the money part is alway easy. If you want it, buy it!
  • golfnitgolfnit Member Posts: 7
    Does anyone know the easiest way to access our speakers? It looks like the cover could be popped off, but I'm not going to screw around with anything. I'm looking to upgrade the speakers, any suggestions or websites?? Thanks.
  • dniehusdniehus Member Posts: 83
    Are you sure that it is a "true" factory order? Is your order also a Limited with practically all options. My understanding is that is how Toyota is building a good number of vehicles. In our area, dealers typically will "preference" a vehicle with the base, options, color that the customer has requested -- unless it is really an oddball combination. That means the dealer will check in-coming units within the district and request that the matching vehicle be sent to their dealership. Perhaps Southeast Toyota (again) does things differently? I just "preferenced" a vehicle last week and was told it would take 4-6 weeks, much less time than you were told.
  • seemomgoseemomgo Member Posts: 27
    I put in a preference order for a silver HL back on Feb. 26 and am still waiting. My sales person called today just to let me know it still hasn't been "matched" at the factory. So I guess I really can't answer your question except to say I'm in the same boat. I did get the impression that he honestly believed it would only take about 8 weeks, but clearly it's going to take longer.
    I think it's worth the wait if you get what you want. I'm also getting the gray leather installed at the port which takes even longer.
    Anyhow, you and TLML are smart for ordering and waiting on side air bags and VSC. If you start to question your decision, do what I do...drive to the dealership and look at the HL again - it will erase your doubts!
    Good luck - seemomgo
  • damaja02damaja02 Member Posts: 1
    My wife and I are interested in the HL and would prefer the gray leather to the ivory. Could anyone give me an idea of how much extra this adds to the price? Thanks.
  • daltexdaltex Member Posts: 19
    C'mon now. If you instigated the offer, you must have thought it was a good deal for you. You will always hear about someone who got a "better deal". Count on it.
    Look at it this way, how would you feel if a dealer quoted you a price of 3% over invoice and then tried to squeeze another 2% or so out of you just because he got the higher price from another customer? Just buy it.
  • sctangsctang Member Posts: 6
    I placed an order with my dealer on February 14 and am still waiting for my vehicle which is a fully loaded red Limited with leather. They are going to try to get the vehicle in on their allocation which I take to mean that they have "preferenced" the vehicle but in case they don't they have also placed a factory build order. The worst case scenario is a 4-5 month wait for the factory build vehicle, sooner if they get it in on allocation. Unfortunately, the last two months they have not been able to get it in on their allocation list. So, I'm waiting.....sigh...
  • davidbonodavidbono Member Posts: 1
    We test drove a Highlander this weekend and found the drive nice. Except for the seats, that is. I found both the driver & passenger seats uncomfortable -- at 6'3" and 250 lbs., maybe that's to be expected. My wife looked over at me and could see that he seats just didn't fit.
    -damaja02 (#1630)
    Ivory leather is a $1015 (MSRP) option. The PIO gray leather I have seen is $1429 (MSRP).
  • jdlaw2jdlaw2 Member Posts: 16
    I wanted a Black Limited w/ airbags, and no sunroof, and no running boards. Since most of the limiteds have sunroofs, or some extra feature that I did not want to pay for, I had to place a factory order. Of course the dealer searched the current and incoming Southeast Toyota inventory, but did not see the HL that I wanted coming in.
    I ordered mine the first week of February. The dealer said that the factory would build it in April and have it ready for a May delivery. May falls in that 90 to 120 day window.
    Thanks to all who have responded re. my question on Factory Order.
    My dealer never used the term "preferenced", therefore I am almost sure that this was an specific order request to the factory. In the meantime, I have been checking where I can to see if there is anything close in an incoming inventory; but I think that I will give up looking because I have now justified in my mind that I need every single option that we specified; and yes, I may go to the dealer and take another test drive which I am sure will confirm our decision to get the Highlander.
    Concerning the Aftermarket Leather that I mentioned, I need to clarify that it will not be installed at POI, but will be installed at a custom leather installer after it arrives at the dealership. The dealer says that it will be loaded on a truck and taken to and from the custom installer so as not to put mileage on the vehicle. The dealer also said that the custom installer is authorized by Toyota to do this work, and there will be no problem with the side-impact airbag option. We will see. The reason that we went with aftermarket leatheris that my wife, (TLML) did not like the color of the gray POI leather; she chose a graphite (very dark, almost black color). the cost of this will be $1075.00. If Dianne or Cliffy have any observations or caveats on this, it would be good to hear from you.
    One more item - I saw a picture of a black HL with the lower body cladding in silver and I thought it was really wonderful looking - really rich. However, TLML does not like it at all so it is a no-no for us.
    Impe
  • coleboycoleboy Member Posts: 13
    After looking at various SUV's, I have decided to purchase a Highlander. The dealers in my area(western Massachusetts)are all selling their Highlanders at MSRP with no break! I am not looking for a fully loaded one but where all all those dealers that are selling theirs at at $1500-2000 over invoice or better?
    Fly South. Dealers here in the DC area are not doing anything like 3% over invoice, but we're not too far over that. We certainly are not at MSRP.
  • boulderhlboulderhl Member Posts: 18
    Just got my HL last Friday and really love it. I was wondering if anyone could answer a question regarding the Auto Climate Control...does the AC light stay on whenever the Auto CC is engaged? I've got it set it around 73 degrees, and I for the past couple of mornings, I've noticed that even when the outside temp is in the 40's, the AC light is always on?? In fact I don't think its ever gone off. Is that normal or am I just doing something wrong. As I read the manual, it sounded like all I had to do was engage the Auto CC and set the temp and everything else took care of itself.
  • jar1945jar1945 Member Posts: 22
    I was just quoted a price of 32500 including everything except tax on a fully loaded 4wd silver HL. How does that color compare with the gold which I have not seen except in pictures and is this a fair price or should I look for a lower one?
    Yes, whenever the auto mode is selected, the AC will be on. This is normal and useful because the air will be much drier and will prevent fogging. You will still get very hot air through the ducts because it runs through the compressor before the heat coils.
  • raybearraybear Member Posts: 1,795
    Define fully loaded.
    Sounds good, but what are the options? How much over invoice or under MSRP?
  • gwkisergwkiser Member Posts: 326
    FYI,
    If you are in the Gulf States distribution area, PIO gray leather is still $1015 (MSRP). Our bluestone Ltd. will have it when we get it (hopefully in the next few days!). Be advised that it is a very light gray.
  • aruseraruser Member Posts: 5
    I've had a Highlander V6 FWD for about 6 weeks. I loved when I had it. But a week ago my check engine light came on. First word I got from a service rep at the dealer was "a torque converter problem". At the end of the day I picked it up and was told they had to flush the transmission because there was probably some dirt in one of the solenoid valves in the transmission.
    The next day the Check engine light came on again so I left the HL at the dealer again. That was 8 days ago. Now they tell me they need to replace the solenoid valves in the transmission. Fist, Toyota sent them the wrong parts. Then the parts were on back order and when they did come in they were wrong again. I raised holly hell with the Manager of the dealership and told them it is a lemon and want a new car or my money back.
    Extremely disappointed in Toyota.
  • palmerswansonpalmerswanson Member Posts: 9
    I'm looking to buy one too and am negotiating with the dealer. He said he'd sell me a fully loaded V6 4WD (color: black) for $34,000. The MSRP is $35,200. I think the invoice is $30K, but he told me it was $31,500. I tried to get him to sell it to me for $32,000, but he said at $34K he was pricing it aggressively other dealers in the area are selling at MSRP. I too am in Massachusetts. What gives?? I feel like a sucker since others on this site are quoting prices much lower than $34K, but I really want the SUV.
  • sjzsjz Member Posts: 33
    aruser-
    Don't know if it applies to you, but I thought I read somewhere that there was a recall involving the check engine light. Seems that it comes on in error if the ambient temperature is below freezing. Did the tranny seem faulty, or were they just acting on the codes?
    -Steve
    Thanks for the info Steve. I told them that I sometimes noticed a slight slippage or missing only when I was doing 60 on an incline with cruise control on. But they have been only reacting to the codes. I'm in northern California and the weather has been in the 60's so I don't think it's the ambient temp problem.
    - Allan -
  • abuyer1abuyer1 Member Posts: 31
    My experience was similar to that of the people in Massachusetts, although I am in St. Louis. Then I went to AutoByTel, which referred me to a dealer who immediately gave me a price of $1500 over invoice for a loaded HL. The other dealers rapidly changed their tune, when I told them about that. But I went ahead and bought from the AutoByTel dealer. You might want to try that in Massachusetts. Maybe AutoByTel has a dealer there who will do right by you.
  • dan1555dan1555 Member Posts: 9
    my dad recently bought me a new highlander. It's fully loaded with all the options, but it has no center console. I saw a couple at the dealership in other colors that had consoles, and the guy who sold us the car assured us that we could order one and they would install it. Now it is a week later, and I just called them about it. They say that the center consoles only come on new cars, and if you want to order one extra you will have to wait like a year because toyota does not make them extra. I was a little upset by this, because the salesman told us we could get one. I was wondering if anyone had had any experience with adding in a console maybe if not from toyota then another one which would fit in the highlander? - Thanks
  • nudominionnudominion Member Posts: 1
    Cliffy1's right: the AC will come on automatically to condition the air.
    But, if you hit the AC button, the AC will turn off while the Auto Climate Control will remain on. I had this same question and just played with it a little to see what I could do. I turn the AC off when I don't really think it's needed. It's your call.
    Hope this helps!
  • rfhourfhou Member Posts: 47
    There has been some discussion of the HL reving a little high at freeway speeds. I checked my RPM's today doing 80, and the tach read 3,000. This is the same as the 98 V6 Camry that I traded in on my HL. So this doesn't seem too high to me. I do recall being at almost 3,000 RPM's at little over 75 mph on a windy day (makes since-added drag). My HL is the FWD model. Could those experiencing higher RPM's be driving the AWD model?
    V6 AWD
    2500 RPM at 60 MPH
    Next time I'm on the highway, I'll try and get readings from 50 to 80.
    -Steve
    I contacted the dealer (villagetoyota) that "smallz" told me about. He had seen a picture of a HL with fender flares on their site. Unfortunately, it's been 2 days & I have not heard back from them. I called the Toyota buyer for my region (Northern Ca) & he said there are no Toyota fender flares for the HL & that Southeast Toyota markets & sells them on their own. Is there a contact besides Village Toyota to contact about purchasing them?
    I didn't realize that the Southeast & Gulf states toyota ports are on their own & sell some options that are different than the rest of the country. The Toyota buyer told me that these 2 ports buy the HL completely stripped & install all add-ons themselves & take 100% of the profits from those add-ons. He said that they usually market & install different aluminum wheels, rear spoilers, etc, than the rest of the country. Interesting stuff.
    cliffy1: thanks for your advice. I had it checked out and it did have frame damage. Well, your advice helped me so much and put me at peace with my trade-in, that I took delivery today on the HL I tried to negotiate for on Saturday! I'm soooo happy. It's late and I'm pooped out, but tomorrow I'll come back with details and info on my new HL
    I'm so very grateful to ALL who post on this board. Your information is invaluable. Later!
