Toyota Highlander
19798100102103211
  • tweetynatortweetynator Member Posts: 19
    NAV systems still have some ironing out to do, you have to remember that its a computer trying to calculate the route based on latitude/longtitude info. Sometimes they are good, sometimes they get way off. Nothing beats the human eye and a good old-fashioned map.
    wwest: Wow, you offered to help him and he got mad? Sheesh, you would think that he would thank you for your help!
    The nav computer had the correct roadway distance in both cases but for some reason calculated the longest distance route as being the shortest time.
    I probably over-stated, he was clearly already frustrated that his brand new AWD wouldn't go, and he simply didn't want my "help" in pointing out its shortcomings.
    I might have felt the same way in his circumstance.
  • outrunoutrun Member Posts: 539
    Interesting that a crappy van like the Aerostar does better in inclement conditions than a Toyota 4Runner. I know which vehcile I'D pick if I had a choice.
    The shorter time is usually the longest distance due to faster speeds on highways that don't take you "directly" to your destination (if highways are a part of your travel). I commute about 25 miles to work (each way) taking highways (Route 9 and 495 in MA). I could find some schleppy backroads to save about 5 miles, but it would take me about 90 minutes instead of 30. It's a rather simple concept. And of course, the NAV correctly picked the Route 9 to 495 route for me when I tested it out. But I could have also TOLD it to not pick highways, and it would have led me via backroads, albeit a longer traveling time.
    TRAC will never help distribution. All it does is stop a tire from spinning by applying the breaks to the spinning tire and/or cutting engine power. If anything, it's going to REDUCE overall torque, which is actually what you want. If one tire is slipping, you do NOT want more torque to go to another wheel, as that will cause instability. No?
    And Willy, Oregon? I don't think that the Nav manufacturer spent much time there to map every dirt road available.
    -Craig
    Which part did you disagree on me? The part that NAV systems calculate based on lat/long or that I said that the human eye is better? Perhaps I over-simplified, indeed there are other variables involved in the calculation. Or perhaps it is a software bug... the best way to find out is try the competition's NAV system on a dealer's lot (say an Acura) and see if you get the same result.
    "I probably over-stated, he was clearly already frustrated that his brand new AWD wouldn't go, and he simply didn't want my "help" in pointing out its shortcomings."
    Well there ya go. "Rubbing it in" to him isnt exactly gonna make anybody happy. I thought you meant you tried to lend him a helping hand and he got upset.
    outrun: The AeroStar aint a crappy van, I have a friend who has had one and it was pretty reliable. It had 170,000 miles on it before he sold it and traded it in for a Winstar ... the Winstar though is another story altogether... he has had bad luck with it.
    I had no trouble at all with the Nav's map information anywhere in Oregon, but I was primary on "main" roads.
    The nav calculation mistake was not due to gaps in the coverage nor "byways", both routes, "shortest distance" and "shortest time" were major roadbeds. It clearly indicated that the route it chose for shortest time was a substantially greater distance and it indicated that it was an hour less travel time than the path it chose for the shortest distance.
    "TRAC will never help torque distribution."
    I disagree.
    On the rear wheels TRAC simply supplants the need for a mechanical LSD. Does an LSD create instability?
    If a driven rear wheel slips and spins freely that clearly limits the level of effective HP/torque the engine can generate. On the other hand if that slipping wheel has its brake applied by TRAC then the wheel on the other end of that open rear differential MUST turn. And yes, a lot of the engine torque is heating that brake but unless the other wheel also loses traction (hopefully the VC tightens when that happens) the effective HP the engine can now generate is limited only by the operator.
    I actually can't figure out how TRAC acts on the front wheels. I do know that with the FWD model and TRAC it does not use differential braking on the front wheels (maybe both as it does on the rear of my 92 LS) but it definitely dethrottles the engine if a front wheel slips.
    I suspect that the AWD model likely acts the same way as far as the front wheels are concerned. If TRAC were to be used to brake a single slipping front wheel the "feedback" to the steering wheel might be great enough to break thumbs or knuckles.
    I didn't say that I was rubbing it in, I was truly just trying to lend a helping hand. I didn't realize at the time that the driver might be so embarrassed about being seen with someone "pushing" his new SUV up a slight incline.
    Lot's of men, I believe, do equate their vehicles with their "manhood", but I don't think that was what was at work here. Maybe.
    Many years ago my wife and I boarded a ferry on a nice summer day in out 78 911 Targa. The ferry crew went out of their way to place us at the heard of the line so we might be the first off the ferry.
    When we docked on the opposite shore low and behold that 78 911, that had never given us a moment's worry, wouldn't start. So the ferry crew and I sat about pushing and shoving moving it first out of this line and then out of that.
    In the end they brought a jitney on board to tow us up the ramp and off into a remote part of the parking area. As we were towed from the ferry I remember someone shouting "get a horse!"
    A VERY frustrating event especially given what the crew had done to place us there. I think I took it all in good humor but I do wonder about others.
    Oh, it was a blown fuse for the fuel pump.
  • llofgrenllofgren Member Posts: 129
    Listen up people.....the vehicle of choice in those mountain passes is NOT a 4Runner or HL or RX 300....it is the Aeorstar. I bet it can out climb a Hummer or a Landcruiser too. I feel enlightened:)
    Is a 2003 AWD RX300 with a redesigned VC system that actually works to apportion torque to all four wheels on low traction surfaces rather than just when all four wheels only have a substantial level of traction.
    A redesigned rear suspension to eliminate the potential HAZARDS of using snow chains only on the front.
    A climate control system that compensates for radiant cooling effects on the human body in the wintertime and therefore does not needlessly run the A/C compressor unless actual cabin cooling is needed.
    A defog/demist system that actually works, like the Canadian LS430, even when the OAT is below freezing.
    An A/C evaporator moisture "extraction" system, like many Saturns, so that moisture leftover in the evaporator plenum does not promote the growth of mold and mildew nor the precipitous fogging of the windshield at random times.
  • jmikerjmiker Member Posts: 21
    Since when did this board change to the RX300 board????
    Please take the discussion of this vehicle to the appropriate board, I am sick of hearing about it!!
  • wd5938wd5938 Member Posts: 19
    I recently added the color matched Toyota running boards to my Highlander. I have an indigo-ink blue Limited 4WD. I purchased them from Toyotaguys. Had them installed and they really dress-up the looks of the vehicle. They fit tight and will keep stones from chipping the bottom of the doors, which appears to be a vulnerable area even with the factory mud guards. Sorry I don't have any pictures, but if you get the Toyota running boards, I think you will like them.
  • john_lisejohn_lise Member Posts: 22
    My main man wwest. I can't help but stick in my two cents!!! I, unlike you, have owned an HL AWD V6 LTD for over 1 year. I live in freakin Canada...we invented snow and cold!!!! The HL, which you stated correctly is very similar to the RX, is exceptional in deep snow and/or up steep inclines. Unlike you I drive in such conditions constantly with exceptional performance and comfort.
    So basically the answer to the question "Have you ever gotten stuck with your RX?" is NO. The other fluff in your message was a waste of my time...but man have you made this board interesting! It's always great to have an antogonist!!
    I can just picture the commercial for FORD - a whole bunch of RXs and HLs stuck on the side of the snowy "slight" incline while the Ford MiniVan tromps through like a sure-footed mountain lion!!!
    Screw this HL, I own.....I'm convinced...I'm trading up to a Ford product....a Minivan no less!!! I just hope I will be able to sell it...probably won't get much for it. I better call up Consumer Report magazine while I'm at it and correct their data collectors. "Recommended Buy" what the hell are they talkin' about!!!
    wwest take care...by the way we are going to kick some American A** in Hockey on Sunday!!!
    You can be the Superpower of the world...all we want is Superpower of the hockey world!!!
    Check (against the boards) you later!!!
  • tccmn1tccmn1 Member Posts: 278
    I can only tell you that I test drove both units several times. I was leaning towards the 4banger for a bit until I started thinking resale. I keep vehicles for 7-8 yrs. Take good care of them and change oil 3K miles. So practically EVERYONE said, get the 6 and you'll be happier in the long haul. However, lower maint. tune-ups, etc. would be the rule with a 4banger. I have a 99 4-Camry, and the tune-up is less than a 6 for many reasons. I think if you go with a unit like the Highlander at 3700lbs, you shout count on a 6.
    The camry, at closer to 3100lbs or so, can take a 4 much better...along with better gearing.
    I've "been told" that the stickers on the windows don't lie. They state 22-27mpg for a 4, then that's about what you'll get. If you get a FWDV6, you'll get the 18-24mpg. 4x4v6=a mile or 2 lower mpg. Of course, the perverbial driving habits may affect outcome applies.
  • haubjhaubj Member Posts: 4
    After months of researching and vacillating about the expense, I just took delivery of a Bluestone LTD (long term debt), earlier this week. I want to report an unusually pleasant purchase experience at White River Toyota, White River Jct., Vermont.
    I was convinced that I would have to travel nearly 1000 miles, or more to purchase at a reasonable price. I was passing by the area recently and decided to just check out the lot. A check late last fall, revealed no Highlanders on the lot and a comment that "we can order one and should be able to save you a couple hundred dollars"
    Big change now, very pleasant sales girl (Maggie Millen), said she thought she could beat any quote. She took my best quote and thought she would beat it by $400. Her sales manager (Daryl Johnson) approved $200. under. When the actual vehicle was found (at the POE), it had an additional $400. in options. Daryl, still held the quoted price!
    When I went to sign papers, I expected a big push to an overpriced warranty. Business manager (Gene Martin, extremely polite and efficient) handed me the warranty booklet and told me that if I wanted an extended warranty, I had 3 yrs. Or 36K to decide and he recommended Platinum package. He quoted same price as www.toyotawarranty.com!!
    After the sale, and dinner nearby, I realized that tank had not been filled. New kid had forgotten to do that. I returned as they were turning out lights and locking up. Pete Stoddard (General Manager) came back to front door and welcomed me in. Big apology and Maggie escorted me to local station where they paid for fill up and apologized again.
    An overall unusually good experience with the nicest, well informed staff that I have ever encountered in my many years of buying many automobiles. As Maggie said, "Just give us a chance." This is an unsolicited endorsement offered due to the outstanding staff, I have no ties or compensation (your mileage may vary, but I suggest you check them out!)
    Jeff Haubrich
    ps
    I am not posting the actual price paid for two reasons; 1) Someone will invariably tell me that they did better (or that I should have bought and Aerostar) and 2) The price may have been due to special dealer incentives or bonus. A good knowledge of price structure and advertising costs will help you get the best deal.
  • bexleybexley Member Posts: 10
    Haubj, Thank you for your purchase experience. It seems that the only time people come to the message boards is when they are upset, and wish to vent their frustrations with companies, vehicles, or dealers. After awhile, you start to think that everyone is out to get you, and all the cars are junk. Good for you to share your positive experience. I too have looked at the Highlander and RX300 (also the Acura MDX), for my wife. We're considering all three but will probably be more inclined to purchase a sedan. I just wanted to share two things:
    1. I was extremely impressed with the Highlander from a quality standpoint. For this price, there is nothing else out there like it. I was amazed at how luxurious the AWD Limited Highlander I test drove was for $32000, it was a deal. I was impressed with the RX300 just as much (more for its luxurious interior), however for the money, the Highlander seems the better deal. Also, the Acura MDX is nice, but pricey, and I feel that in terms of quality it was more on the level of the Highlander rather than the RX300. The third row seat is nice to have, but I don't think I would use it enough to merit the purchase of this vehicle.
    2. A friend of mine has a Highlander 4cylinder, Front-wheel drive (with virtually no options that he picked up for $25k). He took me seriously off-roading in it two weeks ago (unpaved dirt areas, rocks, and steep 45degree inclines). I was amazed at the offroad ability of a FWD, 4 cylinder. The vehicle had no problems escalating (no pun intended) inclines, and rough roads, even took to situations with left or right side vehicle inclines with no worries. The ride was smooth and quiet the whole time too! If a 4cylinder front wheel drive can do that, I'd love to see the V6 AWD offroad!
  • gwkisergwkiser Member Posts: 326
    Thank you...
    I couldn't have said it better!
    Toyota/Lexus doesn't market a 4cyl/AWD HL in Canada, and unlike in the US the Canadian LS430 is equipped with an electrically heated windshield for defrost/defog/demist.
    Would it be out-landish to suggest that the Canadian HL VC actually WORKS?
    Or maybe the VC fluid has been drained (so it doesn't interfere with the ABS) and they use the brakes, TRAC, to apportion engine torque to ANY wheel or wheels, like the X5 or ML. ??
  • ltw1ltw1 Member Posts: 22
    OK guys, hope you don't mind a femine approach to this debate but I'm a snowmobiler and guess where I go to do this... Now I tow my 1200 lb sleds and trailer up to the mountains and this thing performs almost as good as my sleds but you know what sometimes there are conditons that are just too bad for any vehicle and that's why I have a SNOWMOBILE!
    ltw
  • PeterunPeterun Member Posts: 83
    Hi again - Am definately purchasing the HL FWD. Cannot make up my mind on the 4 cyl vs. the 6 cyl. The four drives surprisingly well, perhaps the smoothest most vibration free four I've ever been in. Felt the power was there. What am I missing here? The extra mileage, the initial savings . . . Any ideas on this will be helpful to me. Thanks in advance. Pete
    If the Rx came with a 4cyl that what I would have bought. If my 6cyl ever gets sludged up.....
    Peter. I have tested both at length. I've bounced between the 4 for economy and adequate power and the 6 (because I was use to having them in my DCvan.
    Then, I asked the dealer to let me take the 6 on my own for a longer drive. I loaded the family in it and some extra items - namely some drum equipment (I play in a band) that added weight made my decision to go with the 6. I keep my cars for 7+ years avg. and the resale value of having a 6,plus the power to tow and carry more weight has made up my mind. Even the 6 grunted a little by the time I was done:) But, if you're just tooling around town and some lighter trips, the 4 IS a nice unit and quite smooth at that.
    One thing that did surprise me is how much LESS room there really is in one of these SUV's than in a minivan!! Truly, the mini's are more versatile for hauling stuff inside and with seats removed have an awesome amount of cargo hold compared to the HL and others. When hauling my gear, it was a REAL stretch to get it all in the HL compared to my old 95 DC (Shorty sport model).
    So, THAT may be something else to think about. These SUV's are cool to drive and look at, but if you want to haul stuff (INSIDE), a mini has the room hands-down. (And priced lower when loaded too)
  • mcmattmcmatt Member Posts: 80
    Our 02 2WD Ltd heater doesn't work when you first start driving. You can wait 20 or 30 minutes and it is still cold. Turning the temp up or down or the unit off/on doesn't help. BUT, if you turn the car off and back on, the air is immediately warm or even hot.
    Any similar experiences???
  • gambiamangambiaman Member Posts: 131
    I own an RX300 and need a replacement AC filter and I live much closer to the Toyota dealer than the Lexus dealer and most Lexus parts are identical to Toyota parts except with a price increase. The AC filter is behind the glove box. Does the Highlander have a filter in that location that is about 8X9inches? I took mine out and all the parts to get it out were labeled Toyota.
  • jreajrea Member Posts: 26
    I think you should have your heater checked out. My '01 Ltd. heater turns on like clockwork approximately 3 minutes after starting. In fact, I've been amused that I can now anticipate the exact moment it will kick on at the same spot on the road each day.
    Have driven both of these vehicles . . . and cannot decide. Yes, I know they're different sizes - but not in class. I can buy the Highlander for $500 above invoice. I can buy the CR-V EX for $500 below MSRP. The Highlander would be the FWD; The CR-V, the 4-wheel. The CR-V has the side bags, the 6 cd player, and a much stronger feeling to it. The fit and finish of the CR-V is better, I believe. Anyone have any ideas on this? Pete
  • regularguyregularguy Member Posts: 29
    I was in the same position as you, liking the feel of the CR-V better in some ways (and its bang-for-the-buck in a lot of ways). I chose the Highlander for the shallowest of reasons: Looks.
    Here are my problems with the Honda: I disliked the spare tire on the back. I disliked the roof. I dislike the dashboard shifter on the automatic (and the lack of an armrest on the manual).
    Other than that, there was only the engine size issue, and I could have lived just fine with the CRV's decent pick-up (felt a stronger than the 4-cyl HL I tested). The HL's 6-cyl power will come in handy then it's loaded with family and stuff and climbing a mountain, but the great majority of my miles are solo commuting.
    Bottom line: If I liked its looks a little more, I would definitely have chosen the CR-V
    I came very close to buying a CRV. Its a great vehicle and has some wonderful features, like the sliding back and forth rear seat (like the RX 300). In the end, I chose the HL on account of more interior room, more power (V6), more towing capacity and a slightly better AWD system (always on as opposed to reactive in the "V"). One thing that I thought I would miss was the gas mileage of the Honda....but on reading the CRV board here at Edmunds, the CRV folks (2002 model) aren't doing a whole lot better than even my HL V6. All in all though, I think the CRV is a great vehicle. I do think they need to lose that externally mounted rear spare.
  • lott42lott42 Member Posts: 13
    We'll after a few weeks of researching, I've decided that the HL is the SUV for me and my girlfriend(actually it's hers...I just want to drive it every now and then). We live in So. Cal. and we don't need the AWD so were getting the 2WD V6. Were going either with the silver and charcoal or Bluestone and charcoal(I haven't yet seen this color. Is it nice??? would you say its more dark or a little lighter of a color???). With the 2WD do I need Traction Control??? How does it work any ways??? After reading other posts it sounds like up to 750 over invoice is not unheard of from a dealer. Would most agree with this???
    Thanks for any info you may give, Larry
  • wildcorgiswildcorgis Member Posts: 84
    I saw the Bluestone at the San Diego Car Show and loved it. I bet car makers display their best colors at the show and the two HL there I believe were silver and bluestone.I haven't seen any other blue (on cars ) that's like it. It's metallic in nature and not at all dark that's the indigo ink. It looks like it had flecks of gray in it. I would love to have traction control on my future? HL but it is impossible to find on 2WD not-Limited.
    I've been checking internet pricing and unfortunately have not found a price as good as 750 over invoice.Which leads to a question, Is everyone out there quoting price over invoice like found on Kelly Blue Book or is it dealer's invoice which has advertising or whatever fees added to KBB invoice?
    Anyway the best prices I've gotten so far are from longotoyota.com and carsontoyota.com. Both also have large inventories of HL whereas in San Diego most places have only two or three in stock.
    Steve
    I had the same thought as you... a 2WD, non-limited, 6-cyl, with traction control. Unfortunately, the only way to get it is a special order, and I wasn't willing to wait 3 - 4 months. Decided to forgo the traction control, and I've been happy with the way it drives.
    Got mine in Indigo, BTW, and I like the way it looks. Bluestone was the top of my list when the salesman was searching for a car that met my specs (an additional requirement was a vehicle right off the truck... no test drives by anyone but me). Indigo was #2 on the list. The advantage of Bluestone is it doesn't show dirt as easily as a darker color.
  • maxintoshmaxintosh Member Posts: 39
    TRAC brakes a slipping wheel when accelerating under 9 mph to transfer the power to the side with more traction. It's good to control launches when in slippery conditions.
    VSC applies brakes to individual wheels when the car is skidding to "correct" it. For example, if the back was sliding out (oversteer) the rear wheels would be braked to keep the vehicle from sliding all over the road. It's a safety feature which helps in high-speed manuevers, especially in rain, snow, and ice.
    The way the 2001 RX300 shop manual reads is a little confusing but it appears to say that engine dethrottling is used to counteract slippage of the "driven" wheels. Braking is not mentioned at all in the TRAC description.
    Differential braking of the front wheels could be dangerous to someone not aware of the need to keep thumbs and fingers "clear".
  • cliffy1cliffy1 Member Posts: 3,581
    Wwest, would you mind describing this? I've seen you use this term before, but I must say that I have never seen a differential with a brake on it.
    braking means braking the right front "slipping" wheel vs not braking the left that has traction (maybe). "Different" braking one side vs the other, differential.
    Thanks for the reply to some of my questions.
    Seeing out here we don't get snow/ice sometimes rain, I guess I'll only get the Trac control is the HL is pre-loaded already.
    I'm going to take a look at the BlueStone Thursday(I'll keep you posted on how we(I) like the color.)
    Still haven't decided on the Limited or not. I'm not sure for you get with it, justifies the extra dollars
    Larry
    Does anyone know if you can get the VD option on a FWD-V6? I've been told by a local dealer that it's not possible; must have 4WD.
    I believe I could special order it (may have been mentioned in a post?)But, the dealer was adament about only 4WD's getting this option. It doesn't sound to me like it has anything to do with the transmission...it's the braking that is the key to this option...right?
  • lbags48lbags48 Member Posts: 17
    I don't think your dealer knows what he's talking about. We special ordered a 4x2 V6 with VSC about a month ago. Our order was not rejected by Toyota. Received confirmation of a March build date.
    We own a 2wd Ltd with most options including VD with no problem. I have had several dealers say , "that's not possible." What they really meant was, "I won't be getting anything like that in my next 2 months worth of allocations. Look around. Find a large dealer that trades cars between regions. We are in GST, but we got our Highlander from California due to a dealership trade.
    You can find it on the 2WD Limited without special ordering, but not on the base model. (At least that's what I was told.) I didn't think the Ltd was worth the considerable extra money, and I was too impatient to special-order.
  • gwleonggwleong Member Posts: 36
    Anyone out there know how to remove any of the H/L's door panels? (without breaking anything) Was interested in upgrading the speakers on the non-Ltd. sound system.
    Please advise.
    Gary
  • tommyg12tommyg12 Member Posts: 158
    For some reason I've noticed that when my fuel light is on, it only takes about 15.5 gallons of gas to fill up. I'm still getting 19 MPG, but have about 100 miles less on the trip odometer. I know something has changed or broken. Can someone verify how many gallons it takes to top off the tank when the gauge is low? Thanks very much.
    Toyota is very conservative on these warning lights. In general, you still have 3 to 4 gallons remaning when the light appears.
    Some low fuel warning system use a self heating thermister that remains "cooled" when submerged in the fuel, but once no fuel cooling is left its resistance lowers as its temperature rises and the lower resistance triggers "low fuel".
    Slow thermal response of this type of sensor prevents false triggering due to sloshing.
    These systems can give significantly different indications in COLD weather vs warm or hot.
  • eenglisheenglish Member Posts: 22
    If you are looking for replacement speakers or replacement receiver/CD, you might check out a mail order place, Crutchfield (www.crutchfield.com). My son has gotten several components from them and they seemed to be good. They include directions and have tech support if you run into difficulties.
    I had test driven a Highlander with the standard Radio/CD/speakers and was disappointed with the sound: very boomy and not that clear. My wife's 96 Camry basic system is better. I recently pulled off a door panel to replace a side mirror (garage casualty) and found that they were only single speakers with no tweeters, so the speakers in the Highlander must be REALLY cheap. I got the info for the door removel from a $15 book at the local parts store but I doubt they would have one for the Highlander yet. I did see several pretty cheap but good 2-way and 3-way speakers for the highlander at Crutchfieland and I will probably get speakers from Crutchfield when I buy a Highlander. They also list the available speakers by ease of installation from "E-Z" (Easiest [factory size]), "E-Z Plus" (Installed with supplied adapters) to "M" Modifications (some surgery). The basic size for the front and rear doors are 6.5" or 6.75".
    Good luck and I hope to hear a report on the replacement. Although there have been several postings here relating to the speakers, I haven't seen any postings where the change had actually been made.
    What type of unleaded gas do most of you guys/girls use?? Regular or Supreme??
  • bikerjohnbikerjohn Member Posts: 52
    I've tried to top my tank several times after the fuel light comes on. The auto shut off on the pump first stops at around 17.5 gallons. I usually end up with 19 - 19.5 gallons and have yet to actually top off the tank.
    My conclusion is therefore different than Cliffy's. The tank holds 19.8 and the filler tube must hold a gallon(?). I'm guessing there is not much more than a gallon left when the light comes on.
  • hlronhlron Member Posts: 113
    Regarding the question: " What type of unleaded gas do most of you guys/girls use?? Regular or Supreme??" I use regular, with no problems...at least none apparent to me. (2001 HL, V-6, with 12,800 miles).
  • brad_22brad_22 Member Posts: 154
    My fuel light went on once when I only used 16 gallons. Go figure.
    Still, I appreciate the feature. Imagine the trouble we would be in if a fuel light actually meant we were out of gas!
    I would like to ask this knowledgeable group about preferences for tow hitches. I am looking at the Hidden Hitch (70777) from Bageco. Anyone else have an experience to share with me? Is it hard to hook the wiring up to the converter box under the spare? Thanks!
  • mikey00mikey00 Member Posts: 462
    The Hidden Hitch 70777 is a excellent unit. I installed one and read posts from several others who were pleased with it. It is a very easy install (4 bolts--existing holes).
    If your HL has the towing prep option, there is a plug in connector in that black plastic box under the spare. It may even be there without the towing prep option, I am not sure. If you want to e-mail me I can send you a scan of the plug in wiring kit directions that www.toyotaguys.com sells. (mnovak999@yahoo.com)
