Scion xB Accessories & Modifications
                    This is the place to talk about what you're doing to "tweak" your xB to get it just the way you like it!
Mike
Only aftermarket is available right now.
Then again, I don't know about opening the rear hatch upwards with a hitch-mounted rack and bikes in place. Any comments?
Are these hitch-mounted?
Can you suggest a couple manufacturers who offer these kinds of racks?
TIA
For suspsension mods, I did these myself (age 63) and highly recommend them:
- Changing the rear shocks to softer SensaTracs. Softens the bumpy rear.
- Adding a rear sway bar. Flattens the curves some more, and makes the handling neutral.
Here's two albums I made for my xB photos:
Scenic shots:
http://s49.photobucket.com/albums/f280/vintagefortytwo/Scion%20xB/
Changing transmission oil:
http://s49.photobucket.com/albums/f280/vintagefortytwo/xB%20Trans%20Oil%20Change- /
On a 2003 Echo, I swapped out the stock struts/shocks for Sensatracs - to firm up the ride (the Echo was too wallowy!).
(The Sensatracs are made by Monroe's European subsidiary and the valving is firm to satisfy European tastes - apparently on your xB the extra firmness is offset by the extra xB weight and gives you just the ride you want! That's a great user tip, by the way.)
The kind that slip into the window channel can interfere with the closing of the window. The kind that stick onto the outside of the door can leave residue when removed. Some people found their rear shades did not fit the window. Some people returned their shades.
No answer there, so I took some photos of my xB and used Photoshop to change the skirts and lips to black. Looked pretty good, so I took the car to the Line-X shop that did my truck bedliner, and had them spray the skirts and lips:
I also added a sunroof and wood dash:
http://s49.photobucket.com/albums/f280/vintagefortytwo/xB%20Sunroof%20and%20Dash- /
Then had leather put on the seats:
http://s49.photobucket.com/albums/f280/vintagefortytwo/xB%20Leather%20Seats/
And drove to Scion Exposed 2006:
http://i49.photobucket.com/albums/f280/vintagefortytwo/Scion%20Exposed%2006/0Exp- osed06Flyer.jpg
Where the car won "2nd Most Unique xB":
http://s49.photobucket.com/albums/f280/vintagefortytwo/Scion%20Exposed%2006/
http://www.hitchsource.com/classitrailerhitch-p-27266.html?osCsid=8f80bf184f853d- 9a7e44fb3646ba0f12
Bike rack for hitch from Rack Warehouse:
http://www.rackwarehouse.com/yakima-hitch-racks.html
I have found the xB's low beams to be really nice for non-HID lights.
You could:
Get over wattage bulbs - those will produce more light but may melt the light wiring (unless you install new wires and a relay). They could also melt or darken the headlight lens to due the higher temps.
Get aftermarket HID replacement bulbs. You will get LOTS of light but at a fairly high price. You will also dazzle oncoming drivers since the light is too bright and scattered. You can put an "eyebrow" on the lights to cut down on the scatter and might be OK. If you don't pay extra for bi-xenon lights you will lose the high beams.
Get driving lights, maybe even HID driving lights. This would seem to be the best solution - bright, extra light down the road when you need it with no blinding other cars when you don't.
Dennis
The lack of light up front seems to be the number one complaint on the xB. The one light does no good up front - and when looking for something under the lift-gate does not do much back there either.
Dennis
From Amazon.com or from your local Meijer, Target, Wal-Mart, K-Mart, etc:
http://www.amazon.com/Sylvania-Self-Adhesive-Bright-White-Silver/dp/B000CNB6VW/s- r=8-2/qid=1169757497/ref=pd_bbs_sr_2/105-8291921-0032404?ie=UTF8&s=automotive
My questions are: Are there different models of the cd players for the xB's?
Or does his sound THAT much better and seem to have that much more power solely based on the TUBE?
The xB's that come with the tubes do they also come with amps or something? Because his xB Pioneer sounds A HELL of a lot louder than mine, hard to believe it's based on the tube alone. And does the dealer install now after I bought it? (Just bought it a week ago:)
There are usually several of these on sale on ebay (along with a bunch of the older pre-06 radios) - just go there and search on scion pioneer and you should find some pictures.
I don't have the specs in front of me, but I think Scion claims "160 watts" for either of the models - the differences being the design, ipod, and colors.
What you can try - in your friend's xB hit the center DSP button and see if it is in "hear" or "feel" mode and set yours to the same.
Another thing to try - make sure your dealer (and his dealer) set the unit to the proper car. I think you push and HOLD the DSP/SSP button and it will come up and say either "xA", "xB" or "tC". The same radio/cd is used in all three and needs to be programmed to match the car they stuck it in. One of those settings sounds really bad in an xB and the other two are similar. Check your friend's and yours to see if they are set the same - and see which you like better in your box. Mine came set wrong (on the car that sounds bad in an xB) so once I changed it was happier with the sound. If I recall, you use the volume control to change the car type. This works in any generation Scion/Pioneer unit: the old ones, the new non-ipod, and the ipod one. A ton of Scions are driving around with this set wrong.
The Scion 8" bazooka tube is $429 + install (full price) from a Scion dealer and most folks seem to think it is not worth the money. You can get an aftermarket sub and amp installed for the same or less money that will sound a lot better.
Dennis
That is another thing to note - with standard halogen bulbs the longer you use the them the less the light output. So if you replace old bulbs with new ones (any kind) they COULD produce more light that the ones you replaced. If you put in a new OEM type bulb and a new "blue" bulb the OEM type should produce more light.
Dennis
This was BIG. Mine was set to tC and it sounded like a tin trash can. In fact a friend at work that HAS a tC I told this to him in hopes maybe he could adjust his... well, his was also set to tC, though it still sounded weak. He instantly changed it to xA. Mine xB on xB makes a world of diff but I'm still getting the tube:) Thanks Dennis:))
Praise be the xB:)
As to the alarm system, any good shop (and even CC and BB) can hook you up with an alarm system that ties into the keyless entry so you will have an alarm and door lock and unlock. If you xB is an auto, for a little more you can get a remote start added to it. The xB does not use in anti-theft code keys so remote start does not cost much extra. Most folks I talk to are partial to the products from Directed Electronics (Python, Viper, etc).
You can buy the OEM system from a discount Scion parts dealer for around $240 or so and have it put in, but I think you will find you could get a two-way Viper or Python system installed for about the same price.
Dennis
Did it sound a lot better when you changed it to xB ? After I posted that tip I checked mine and the tC was the setting that sounds the worst in an xB, the xA and xB settings are similar.
Dennis
They are:
4x100 Bolt Pattern, 15"x6" with a +38 offset
The OEM xB tire size is 185/60R15
You can check The TireRack and Discount Tire Direct and many other places for replacement wheels - all a lot cheaper than the 15" OEM Scion alloy wheels. You can get 15" 6 or 6.5" alloys for as low as $67 to $79 per wheel plus shipping. Your OEM size tires should fit on these fine, but you will have to pay a local installer to mount and balance them. This may be $15-25 per wheel. If you go with a 15" that is 7" or wider the OEM tires may not fit - call them to check on that. Both sites have "show this wheel on my ride" functions so you can get an idea how they will look on your xB.
To save on the install costs, you can get a wheel and tire combo and they will come pre-mounted and balanced for no extra charge - but shipping will be more than just wheels would be. If you do this you could get wider tires or go with a +1 or +2 or +3 upgrade (16" - 18" wheels and tires). The larger the wheel the lower profile the tire and the better the handling (generally) and the worse the ride and the chance a pot hole with bend a rim. The larger wheels and tires generally cost a good bit more too.
You have to be careful of wheel offset too - since the wrong offset will cause uneven wear and/or alignment problems. Generally if TireRack or Discount says it is "OK" then it should be. They will also supply (for free) the proper lug nuts and a hub ring, if needed. Some other wheel sites may not - so you will pay extra and have to wait before you can complete the install.
Dennis
They quoted me $55 for the work and materials, which I don't think is too bad. They have been around for years and just did 2 cars from a buddy of mine - and it was nice work.
I also have a custom cut Covercraft UVS100 sunshade I pop in the front window. I have used these in other cars and have purchased them for my kid's cars - and they work really well. Click here for Covercraft's page They do not have one for the 08 xB yet, but check back with them later and I am sure they will.
Dennis
I would have thought the tint place could have done that top windshield thing for you quick and cheap while you were getting the windows done. I had one of those years (and years) ago that *I* put on an 83 GTI and it was a pain in behind to get on and get all the bubbles/creases/ripples out of.
Dennis
Can you still see the back in the rearview mirror?
I am looking at Audiovox Shuttle system from Bestbuy and Circuitcity, but I don't know if it will block the rearview.
I would not worry about it that much and I for sure would not buy the OEM alloys, find something you like from TireRack or DiscountTire and have the tires swapped yourself. On both sites the actual wheel weight is listed, just check the details. I think most would be under 20 lbs.
The OEM alloys are grossly overpriced and much cheaper alternatives can be found without much trouble.
I put some MB wheels on my 06 xB that I got from DiscountTireDirect. They were $75 each plus shipping and I got a nice discount off that price too. They look a lot nicer than the OEM wheels and where less than 1/2 the price.
Dennis
2008 Scion xB wheel & tire chart
I didn't want to bother you again with alloy questions, but looks like no one else there has the answers for me... So, my present pick for 2008 xB is either Enkei J10 or MB Tucson. I think, they look cool. Prices are similar ($127 and 107), but weighs are not - 17 and 23 lbs for these wheels. MB has a structural life-time warranty, but Enkei only 1-year for finish... This Enkei model seems to be the older one, so I couldn't find out whether it is forged or cast and thus, how strong it is. MB is probably strong, but much heavier. So, here is my dilemma - I want to get a light wheel, but don't want to compromise on the strength (I drive around New York, so pot hols are a real menace...). Also, original steelies are 16x6.5, while alloys are 16x17. The original tires I intend to keep are 205/55/16R - rather a low profile tires. Is it really O.K. to put these tires on a wider rim - what could be the effect on car handling or even tire strength? If you have any thoughts, I appreciate it!
Yuri.
You have to worry about either getting a spare wheel or making sure they don't go out of production on you. You spend the money now and bend a rim down the road and find you can't get a replacement wheel so you have to buy 4 new ones. Another reason to get an inexpensive wheel
7" or even 7.5" wide wheels should be fine with the OEM tires. On TireRack 205/55/16 is the recommended size for 16" rims for the xB in widths of 7 or 7.5".
55 seems like a low profile tire - it you are old like me and remember when 60 series tires were "performance", but with today's tires those are not that "low". Be sure to keep them aired up and dodge what holes you can.
Dennis
