Toyota Highlander
1134135137139140211
  • runpantherrunpanther Member Posts: 44
    Don't fall for the dealer scam that they need to program the remote. They're looking for more ways to draw money out of you
    Instructions are in the user manual and are simple to follow.
    They're looking for more ways to draw money out of you.
    They provide a service that people are willing to pay for. Unclogging a drain is even easier but many choose to call a plumber.
  • dougweaverdougweaver Member Posts: 48
    Are Mud Flaps a must have on the HL? I did a special order a few weeks ago and I forgot to consider the Mud flaps. Thanks dpw
  • toyotakentoyotaken Member Posts: 897
    I wouldn't say they are a MUST have, but highly recomended. They keep the road spray as well as debris like stones etc. from kicking up on the bottom and sides of your new vehicle. I personally would just get a set from the parts department and put them on myself unless you still have time to have them put on the vehicle you're ordering. I wouldn't necessarily spend the money to have the dealership install them as it's a pretty easy job to do and it would probably cost you between $50 and $100 on top of the parts cost to have them do it.
  • nimrod99nimrod99 Member Posts: 343
    Thanks for the post - but I have a owners manual and it doesn't have instructions for programming the remotes
    I will look in my serivce manual tonight to see if its in there
  • gwkisergwkiser Member Posts: 326
    Well, I have to disagree. I'd call up our service writer first and then arrange a time/appointment at which time they can take care of it for me while I wait. Ours has done similar things for n/c. It's a 3 minute operation at best and my dealer won't bother with paperwork on such a short job. Give it a shot....you should't pay a dime.
  • lexus_addictedlexus_addicted Member Posts: 24
    Something I don't understand about Toyota engines and their emissions certification.
    HL's V6 and Camry's V6 and Lexus ES300's V6 are the same 1MZ-FE design except that Camry's V6 still doesn't come with VVT-i.
    How come the 1MZ-FE in Camry and ES300 come with a ULEV cerfication and HL's V6 is only LEV?
    Isn't the addition of VVT-i help reducing emissions?
    Thanks everyone. I didn't realize but the procedure is in the service manual (which I have).
    I can write up the steps - should people want to know how to add extra remotes, or replace a damaged remote, or even clear the old code with a fresh one. I don't trust service people with my vehicles - just had too many bad experiences.
  • 03bluestone03bluestone Member Posts: 47
    I have brand new set of mudflaps that came off my 2003 when the dealerr put the flares on. Anyone interested in purchasing them cheap?
  • bojack1bojack1 Member Posts: 23
    If you would, please post the procedure on programming the remote. I think it will be good information to have. Thanks
  • candyman85233candyman85233 Member Posts: 43
    Here is a link to my 2001 Highlander in the Az desert! I love my Highlander!
    http://community.webshots.com/user/candyman85233
    Enjoy!
  • hlronhlron Member Posts: 113
    Great photos, candyman! In addition to the Highlander, your good photos of Molly - who is a very spoiled dog, is my guess - brings up a somewhat sad issue I had today with my Highlander (which I like a lot, too)...actually, it was me, not the HL. The back seats of my HL are usually in the down position with a bed for my spoiled lab, Dottie. Except today, I had people in my car, and so had the seats up. So, when I got home, Dottie dog jumps in for the nightly trip to the park before I put both seats down for her, and when I put the second seat down...ouch! Her leg got caught between the seats and she started howling! I had to go around and release the seat back up. But, again, that is not an HL issue, it is a "dad" paying attention issue! Anyway, to keep on subject, I do like my Highlander (2001 FWD) and it is a great vehicle for a spoiled dog, too!
    /Ron
    I do not accept any responsibility for any issues arising from following these instructions.
    I recommend going to a Toyota Service dept, or buy a service manual
    The add mode is used to register a new recognition code while still retaining codes already registered. This mode is used to add a new transmitter. If the number of registered codes exceeds 4, the previously registered codes will be erased in order starting from the first registered code.
    The rewrite mode is used to erase all previously registered codes in order to register all new recogition codes. This mode exchange the transmitter or door control receiver for a new one
    The prohibition mode is used to erase all the registered codes and disables the wireless door lock function. Use this mode when the transmitter is lost.
    The confirmation mode is used to confirm how many recognition codes have already been registered before the additional registration of the recognition codes.
    A) Make sure the vehicle fulfills the following conditions
    1) No key is inserted in the ignition
    2) The driver side door glass is fully open
    3) the driver side door is open(the other doors are closed)
    4) the driver side door is unlocked (the other doors are locked)
    b) Select a Mode
    1) Insert the key into the ignition key cylinder, then pull it out (perform this operation once again within 5 seconds)
    2) Close and open the drivers door twice
    3)insert the key into the ignition key cylinder, then pull it out
    4) Close and open the driver side door twice.
    5) Insert the key plate into the ignition key cylinder, then close the door
    6) To select a mode, turn the ignition switch from ON to LOCK at approximately 1 second intervals as follows
    Add mode: lock-on-lock
    Rewrite mode: lock-on-lock-on-lock
    Confirm mode: lock-on-lock-on-lock-on-lock
    Prohibition mode: lock-on-lock-on-lock-on-lock-on-lock-on-lock.
    7) within 3 seconds after a mode has been selected, the mpx ecu automatically performs lock-unlock operation to inform the operator which mode has benn selected. (the lock - unlock sequence will match the lock-on sequence numbers.
    Hint when the confirmation mode has been selected and 0 codes are registered, lock-unlock operation is automatically performed 5 times.
    When the confirmation code is selected and the lock-unlock operation has been performed twice as shown in the illustration below, the number of registered codes is 2 (not the timing will be 2 second intervals not 1 second).
    c) Register the transmitter
    1) within 40 seconds after the add mode or the rewrite mode has been selected, simultaneously press the lock and unlock switches (transmitter) for 1 to 1.5 seconds. Then press either one of the switches for more than 1 second
    I will post the procedure for calibrating the Auto dimming mirror soon.
  • tommyg12tommyg12 Member Posts: 158
    After 18K trouble free miles, I was taking a peek under the hood and noticed that the fluid in the master cylinder was down slightly. Doesn't this occur as a result of normal brake wear? If this is the case, then I will not top it off. Thanks.
    yes - this is normal.
    As the pads wear - the caliper pistons move to keep the pads close to the disk. The increase in volume behind the piston requires extra brake fluid. Thats why the reservoir goes down.
    I wouldn't add fluid to the reservoir unless its below minimum. When it comes time to replace your brake pads - the pistons have to be pushed back into the calipers. The extra fluid had to go back into the reservoir - you may overflow the reservoir.
  • n17n17 Member Posts: 6
    Hi All-
    Does anyone have any experience/insight regarding HL performance on sand? We live on long Island, NY and drive on the beach in the summer - tire pressure is lowered to 15psi - I have been in a subaru outback AWD that went fine on the beach ...any information would help. thanks
  • pepsi5manspepsi5mans Member Posts: 3
    Can a new remote (non-toyota, aftermarket) added with your programming listed provided the new remote has the same function/capacibility?
    Yes, Molly is a very spoiled dog, and we also keep the rear seats down for her trips to the "Bark Park." She is a lab/bassett mix and we rescued her from the pound 6 years ago (she is 8). We throw her round bed in the back of the HL when we take her on road trips, and she loves it.
    We have 34,000 miles on our 2001 and haven't done any major services yet. I am not planning on doing any major services until about 60,000. What do y'all think?
    Happy HL'ing :)
    would be my choice
  • brad_22brad_22 Member Posts: 154
    I had a 30K mile service recently done on mine since the 'check engine' light came on (I have ~34K). Toyota couldn't find anything in the computer error log, so hopefully it was just a fluke (and it wasn't because of the gas cap - I've already been through that one).
    The service was expensive, though. I probably could've done most of it myself.
    are you sure camry does not have VVti? I thought most of the Toyota cars did by now.
    Variable valve timing helps reduct emissions, yes, but a big piece of it is also the number and type of catalytic converters used, as well as little things like how quickly the converters light off (a function of where they are located in the exhaust line) as well as how the car is programmed to run when it is cold (when most of the emissions occur) and other stuff like that. All those factors are bound to vary a little between models.
    don't fix it.
    Maybe I will wait until 90k to get any major service...who knows.
    HEY! My check engine light came on also, and they said it was the gas cap thing too! Must be standard training for the service techs. Turned out to be a disconnected hose that somehow came loose in the engine compartment.
  • reddevilfishreddevilfish Member Posts: 9
    Any suggestions on how I can preserve the front leather seats for my Highlander? I have looked into seat covers, but since the vehicle is equipped with side airbags this is not recomended.(safety reasons) Thanks.
    Why did you get leather - if you are going to cover them with a seat cover?
    Just keep them clean using a good leather cleaner/preserver and enjoy.
    No, the current V6 1MZ-FE in the Camry still doesn't have VVT-i. That is why the Camry is stuck with only 192 HP and 209 lb-ft of torque. Strangely, the 2.4 liter 4 cylinder does have VVT-i.
    Solara is in the same situation, its version of the 1MZ-FE also lacks VVT-i.
    Camry's V6 is praised by all the online reviews for its quietness and smoothness and it is powerful enough, but bashed for its lack of power when compared to competing V6s like Honda's and Nissan's.
    The 1MZ-FE in HL, RX300, ES300, Avalon, Sienna all have VVT-i though.
    My question is why Camry's V6 lacks VVT-i, but still get a ULEV certification, but HL's V6 has VVT-i, but only with a LEV certification. Toyota currently has only one V6, the 1MZ-FE.
    Lexus IS300 and GS300 get the inline 6 cylinder.
    Part of why they didn't take the time to actually put all of the engineering to get the lower emissions standard on the Camry is because from what I have heard, they are replacing that engine in the Camry. Actually from what it looks like, December's productions schedule is showing the new model codes with a new V6 engine and 5sp automatic transmission.
  • hawkeye70hawkeye70 Member Posts: 43
    Our '01 HL with 18k had the check engine light (CEL) come on recently. I checked the gas cap, which was properly installed. The CEL remained on constantly for about 1-1/2 days. Then I checked the fusebox under the hood, removing and reseating fuses that I thought might be related to engine management functions. When I started the engine after that, no more CEL. I wonder if having power removed from certain circuits caused something to reset. Ever since that time, about a month ago, there hasn't been any more CEL warnings.
  • micropterusmicropterus Member Posts: 1
    I am contemplating purchase of a V6 Highlander and am still deciding between 2WD & 4WD. Has anyone ordered a 2WD with vehicle skid & traction control? Comments good or bad much appreciated.
    Read my recent post over on the RX300 thread. The HL and the RX are virtually alike.
    I had asked earlier about adding mud flaps to our special order HL. I checked with my dealer and he added them when he did the original order at no additonal cost, so I am not interested in buying any. Thanks anyway. dpw
    That title is so all of you doubting thomases can bail now.
    For many months now I have been theorizing that the Chrysler T&C minivan's AWD system is greatly superior to that of the RX and the HL. My theory was based on the fact that the T&C AWD system had a method for uncoupling the two drivelines, front and rear, when the brakes are applied resulting in the need for disparate rotational rates front to rear.
    The front brakes do about 80% of the work required to stop the vehicle and in so doing they very often turn very slowly. If that slow rate of rotation were to be coupled to the rear driveline then loss of control would oftentimes be the result.
    The T&C has an over-running clutch in the rear driveline for just that purpose, allowing the rear wheels to turn at a higher rate than the front during braking.
    But, up until this morning I had no T&C with which to prove out my theory. My daughters 98 is here at the moment.
    So I jacked it up so all four wheels were off the ground and repeated the shade-tree mechanic's AWD test that I performed on the 01 AWD RX300.
    As it happened I was not able to block the rear wheels from turning in exactly the same manner as the RX. The 98 T&C wheels do not have wide enough openings to insert the light pine 1X2' with the thin dimension to "shear". So in this case the T&C had to shear the 2" dimension if the rear wheels were to turn.
    With my foot firmly on the brake and the engine at idle I shifted the transmission into gear and then started releasing the brakes. The right rear 1X2 sheared virtually instantly, at engine idle. To be sure this wasn't a fluke I blocked the right rear with an oak 1X2. The left rear 1X2 sheared virtually the instant I started releasing the brakes.
    I repeated the test one more time just as assurance.
    The RX300 rear wheels would not shear the thin dimension of the 1X2 even with the engine RPM raised to 2000.
  • megawattbluesmegawattblues Member Posts: 66
    Last January - just after purchasing our V6, 4WD, non-VSC, HL, we got about the only snow of the season around here. About 4 or 5 inches of wet & heavy stuff that the body shops must all like.
    Anyway, I just had to try the one place that was always a challenge in either my wife's Camry, or my old RWD Volvo 945T (LSD). My daughter's old daycare driveway - a steep hill with a nice off-camber entrance apron.
    First, I was able to negotiate the off-camber entrance with no problems. I came to a stop at the bottom of the hill, and just punched it. Up the drive it went. No wheels spinning, no theatrics. Just dug in and went.
    Good enough test for me. The Camry might have made it, but not without finessing the gas pedal. The Volvo wagon (best rear-wheel-drive car in snow I've ever had), would have been stuck.
    My old '85 Cherokee was great in 4WD, but really terrible in 2WD. I remember always shifting in & out of 4WD with that thing between the slippery spots and the dry spots to avoid adding stress to, and winding up the gear-driven mechanical components.
    No need to worry about any of that with an always-on, fluid-coupled system.
  • cmunizcmuniz Member Posts: 604
    That's the difference between lab tests and the real world.....
  • kywstbridekywstbride Member Posts: 2
    A dealer tried to talk me out of the silver color HL saying that there's problems with it! Has anyone heard of such a thing?!?!?!? Unprofessional on their part..but true? Also, has color ever been an issue with price if I wait for one? Does it hurt with negotiating?
  • cliffy1cliffy1 Member Posts: 3,581
    The only reason for a dealer to tell you there is a problem with silver is if they can't get one. If that is the case, they will probably charge you more for it due to the scarcity. They should just be honest and tell you it is in such high demand that they can't seem to get enough in that color to fill the demand. That would allow you to make a more educated decision.
    Just curious ... we get snow and ice occasionally, so how does the FWD HL do in these conditions? Does it perform about the same as other FWD vehicles? Thanks for any info. dpw
    I have a silver HL and have never had any problems with the paint.
    Silver in the 70's used to have a fading problem, but with the modern clear coat paint systems, no color should be a problem. When I was looking for a base HL with side airbags, 7 out of 8 cars the dealer found in a 5 state area, were Silver - so availability should be no problem. My dealer did a dealer traded and trailered a Limited HL 500 miles for a judge who wanted a red one.
    with VSC and Trac will very likely outperform MOST other FWD vehicles not of the SUV class.
    Just don't drive it downhill on that snow and ice before checking that your insurance is fully paid up.
    The salesperson was not being truthful. If you want to buy a vehicle from that dealership you should insist on working with another salesperson that is honest. Let them know that you inquired about the silver color problems and owners on Edmunds thought that was a bunch of bunk. They need to understand they are dealing with an informed consumer. Secondly, you generally get the best prices on vehicles that are in stock regardless of color. If you insist on a specific color you need to be a good negotiator to be able to get the same deal as you would on a vehicle on their lot. Good dealerships/salespeople will accomodate buyers anyway they can and be honest with them. Many dealers just want to sell cars and will do what they think they have to to convince buyers they should buy a car today and that they are getting a good deal. It's up to you to tell the difference. Your best tactic is to be informed like you are doing by asking questions here.
    It should do as well as most FWD cars. It may do better as it has a little bit of additional ground clearance so if snow is a bit deeper, it may not rub the undercarriage as quickly. As for wwest's comment about going downhill, I don't understand that at all. Just remember that it is bigger, heavier and a bit less manuverable than most cars and keep that in mind when you're driving.
    Thanks guys ... like other vehicles the best advice I guess in snow and ice is slow .. steady .. and stay off the brake as much as possible. And also put it in snow mode so it starts off in 2nd gear. I need to pass this on to my wife who will be driving it the most. dpw
  • gwleonggwleong Member Posts: 36
    OK, so I'm lazy....can someone direct me to the postings for the remedy for the dreaded glovebox rattle?
    Thanks in advance!
    Gary
    2001 H/L V6 2WD 'Base'
    Millennium Silver
    on snow and/or ice. When you lift your foot from the throttle you are effective BRAKING the front wheels. ONLY the front wheels.
    On a slippery downhill surface inertia will oftentimes cause the rear of the vehicle to pivot around the "braking" point.
    The "home" remedy is described in this post:
    trdgt Mar 2, 2002 6:50pm
  • landdriverlanddriver Member Posts: 607
    Another noteworthy solution can be found in post "Re: Glove Box Rattle," Jul 26, 2002 in discussion "Toyota Highlander Owners: Problems & Solutions." (Sorry I don't have the technical skill to create a link to it like Steve.)
  • thensleythensley Member Posts: 4
    Greetings. I have been reading for over a year(March 01 just before I bought a 2001 unlimited 4cyl) and now have a couple of questions to post.
    I have seen mentions of an error code associated with the gas cap. I looked back through a bunch of pages but could not find that subject. If someone has a link or message number or synopsis I would appreciate it. Also would like to know where the diagnostic port on the HL is located and if the error codes for the HL are the same as most other Toyota models.
    Allow me (right click copy shortcut the post number in most browsers)
    goldston "Toyota Highlander Owners: Problems & Solutions" Jul 26, 2002 2:14pm
  • scannerscanner Member Posts: 295
    Steve,
    You mean there's something else besides Microsoft's Internet Explorer? Better not tell Bill Gates. :-)
    Dave
    With the $500 over invoice silver HL.
