Can you say Opera?
Or how about NetScape and it's next incarnation, Mozilla! :-)
I won't tell Bill if you won't!
Why haven't you put a pic of your new ride up in Toyota Highlander Owners: Photo Gallery yet Scanner?
Buzz (RX300 owner who seriously considered the Highlander, and who is very tired of Williard West!)
wink, nudge
(oh yeah, the down arrow still works for those messages you'd rather ignore)
I would expect if the VC was after the front transaxle - you would get the effect wwest proclaims (90-10 front to rear torque distribution). However as the VC is between the transmission and both front and rear drive trains - then each would get a 50-50 split.
But now let's say one front wheel hits a spot of ice and begins to spin. Left to itself the center open diff'l (along with the front open diff'l)would simply route ALL of the available engine torque to that one wheel.
In the RX and HL the VC is connected between the two output shafts of the center diff'l and if it had the correct fluid formulation it would very quickly "stiffen up", effectively "locking" the two center diff'l output shafts together. Moderate locking at first and then if the condition persisted the VC fluid would increase the locking coefficient to the point wherein 50% of the engine torque would become available to the rear driveline.
The problem Lexus had to overcome was if the driver suddenly and severely applied the brakes while the VC locking coefficient was fairly high then the severe braking on the front wheels would be coupled through the locked drive train to the rear wheels. Forcing the rear wheels to turn as slowly as the front during braking can oftentimes lead to loss of control.
Some vehicles with a VC for center diff'l "locking" use an over-running clutch in the rear driveline so the rear wheels can "over-run" the front wheels during severe braking while the center diff'l is (partially) locked.
Lexus chose the "docility", SOFT, route to overcome the potential for this problem. The native, initial VC coupling coefficient is practically non-existant, and the attack rate at which the VC increases its coupling coefficient with disparate traction front to rear is very shallow.
I and several other people posting here have given multiple examples of how the AWD systems in these vehicles work effectively and efficiently. How you get yourself into these situations that you say that you do and as often as you do continually amazes me. These are not built to traverse the antarctic. If you wanted to own a vehicle that will do so, buy a Landcruiser or LX470.
My mouse has a wheel that let's me scroll past stuff I don't want to read by simply turning it with my index finger! Works great!
Yes/no?
They were used in the "olden" days to proportion the brake pressure so the rear wheel brakes didn't recieve as much pressure as the front.
Early ABS? Typically rear braking only.
Today we have automatic brake pressure distribution electronically.
Modern day anti-lock braking cannot work on the rear wheels/tires if the front wheels are turning slower and are coupled to the rear wheels via a "locked" center diff'l.
That's one of the reasons we're seeing many new 4WD vehicles that will only fully lock the center diff'l in low (granny grunt) range, and other that automatically unlock when the brakes are applied.
But in fairness, neither do the self-indulgent monologues of an expatriate from another board...
In fairness, I won't mention the names of those whose posts were removed - end of story.
(waving arm and frantically jumping up and down in the back of the room)
CAN I??!!!
-how to get access to the underside of the dash
-how to get access to the interior of the console
-how to remove the radio
-a convenient point to tap into always-on 12v.
I want to install a neat, semi-permanent cable set for a Garmin StreetPilot III GPS, with power cable, speaker lead, and external antenna lead.
Hoping someone can help.
Cheers
G
I tried your method with my BMW E36, and got really frustrated (black screw heads w. covers, black plastic, dark garage, etc). A web search helped enormously, but the HL has not been out long enough or it attracts a different type of owner.
There are plugs on the sides of the console, obviously covering screw heads, and I can see the screws that need to come out to move the lower dash panel. Just trying to avoid excessive disassembly.
Trying NOT to run a 12V line from the other side of the firewall.
I cannot understand why Toyota has BOTH 12V outlets switched with the key. At least one should be live at all times for low-current applications such as mobile phone chargers, GPS etc. They should learn from the Germans.
G
BTW, how do you like the Garmin? My dealership doesn't do a huge amount of aftermarket accessories but the dealership my girl friend does. I was telling her about the Garmin unit and she is thinking about offering them to her customers as an after sale. It seems a natural on things like the HL and Sequoia where you can't get factory navigation.
To protect the type of person who would plug in a coffee pot on a timer I'm sure is mostly why. Toyota has a lot of room when it comes to figuring out the electrical little things.
"how to get access to the underside of the dash."
Put your head on the floor and look up to access the lower dash area. Access to the upper dash area is slightly more difficult. The dash is actually one big piece, though it appears to be upper and lower halfs.
"how to get access to the interior of the console."
I have a 2001 that doesn't have a full console, but my shifter cover was held on with screw head clips that pop loose with a good tug in the right place. Be careful, as there was a lot of metal inside of mine.
"how to remove the radio."
To access the radio, simply pry loose the inserts in correct order that surround the radio/climate control. Be careful not to scratch anything.
"a convenient point to tap into always-on 12v."
You're on your own with this one. I'm sure there are several possibilities, but I would use the inconvenient + terminal on the battery with a in line fuse.
Seen one... you've seen them all.
Just imagine your typical HL with break dust on the wheels. :-)
Screen is great! Highly visible in almost any light, and automatically switches to light-on-dark night mode at local twilight. Backlight has to be turned almost off for night driving.
Display is only configurable to a degree. Some of Garmin's other units let you choose which data fields you have on screen, but this one does not. I like to see altitude and heading but you only get speed, direction of travel or to next turn etc.
128 MB of downloadable maps means you pretty much have to have access to a laptop when you travel long distances.(Whole US + limited CDN coverage on 2 CDs)
Voice prompting works well. Optional UK voice gives it a bit of "weakest link" flavour.
Mounting on the HL is not that hard. I used a couple strips of superlock fastener (plastic velcro-like stuff from RS) to stick a RAM mount centrally over the clock area. Using the longer RAM arm, you can move it freely so that the passenger or the driver, or even both, can see it and use the controls. Power cable and custom speaker cable snake down the right side of the dash, held in place by tap-in coax clips. Speaker is stuck under the console, in the tunnel, with more superlock.
GPS Rcvrs are nice for us Canadians when we travel in the US, so we can get a nice, visible, speed readout in those old-fashioned units folks use down there.
BMW Motorcycles is now marketing the unit with their machines as well.
Is there a fuse block inside the passenger area? I used this in my 4Runner. Internal lights work without the key in the ignition - locate the terminal on the fuse block. Pull the fuse. Wrap the exposed wire around one leg of the fuse. Plug it back into the fuse block with your wire on the downstream (after the fuse) side - this protects your Garmin... or you can just use an inline fuse on the Garmin and not worry about upstream, downstream. When you push the fuse in, the pinching secures the wire in place. Just be sure not to short the fuse with your wire - it defeats the protection of the fuse. Worst case, you may burn your fuse out and have to switch to the next bigger size, but I don't think your Garmin will draw more than my Passport radar detector - and that's how it was wired for 8 years.
I haven't seen the type of fuse you are thinking about used in vehicles for quite some time. Anyway, exercise extreme caution when attempting to tap in to a multiplexed electrical system.
Gosh, was it what I said or my tone of voice?
1. Remove the decorative hammered metal or woodgrain plastic bezel encompassing the gear shift lever by pulling straight up on it from the inside, remove the connectors to the cigarette lighter and 12V outlet, and remove the three screws securing the console to the dash.
2. Snap-off the two plastic caps on the bottom of either side of the console and remove the screws.
3. Remove the felt from the bottom of the inside of the main storage compartment in the console and remove the two bolts.
4. Remove the console while disconnecting the connector between the dash and the console. I believe either one of the front seats, or one or both of the armrests attached to the front seats, will need to be removed; otherwise the console will be trapped by the armrests attached to the front seats.
One place an always-on 12V line exists is where the main 12V power line enters the radio/cassette/CD player (blue and yellow wire; pin 1 on Limited models; pin 4 on non-limited models); this line connects to the 25A RADIO NO. 1 fuse in the engine compartment.
I was thinking of running the power from one of the reading lights or from the garage door opener in the sunshade. Console sounds simpler. Might grab power for a radar detector up top, though.
What exactly do you want to know about fuel cap error codes?
The ODB II port is located at the bottom of the dash, close to the hood release. I would imagine that the codes are still the same.
Just wanted to know if there was some error code associated with the fuel cap. Found on another group that leaving cap loose could cause a check engine light. That is all I needed to know.
Thank you again for the location of the port. I am used to finding them under the hood and also had one vehicle where it was under the top edge of the carpet. I do admit to only making a cursory effort to find it and apologize for that.
I HAVE DRIVEN SEVERAL 2002 HL W/6CYL. ENGINE AND I CAN DEFINITLY FEEL THE ENGINE RUNNING WHILE SITTING AT A LIGHT IN DRIVE WITH THE FOOT ON THE BRAKE, BUT THE ONE I OWN IS WITHOUT A DOUBT THE VERY WORST. sINCE BRAND NEW, IT HAS BEEN BACK TO THE DEALER FOR THIS SEVERAL TIMES, BUT THE DEALER SAYS ITS OK.
I CAN'T ACCEPT A $30k PLUS VEHICLE WHICH IS SO CRUDE, BUT UNLESS I WANT TO TRY AND LEMON LAW THE VEHICLE, THERE IS NO SOLUTION EVEN THOUGH TOYOTA MUST KNOW THEY ALL VIBRATE TO SOME DEGREE. ANYONE HAVE ANY THOUGHTS ON THIS PROBLEM. I SUSPECT A BAD MOTOR MOUNT(S). ANY TSB ON THIS??
Residual value alone doesn't mean everything since its based on MSRP. In my area a $35K MDX goes for $35K, but a $31K HL can be had for $28.5K all day long.
Vehicle.....MSRP.....Capitalized Cost.....Residual Value......Real World Cost
HL............$31K........$28.5K.................$17K @ 55%.........$11.5K
MDX.........$35K........$35K....................$21.7K @ 62%......$13.3K
http://www.edmunds.com/finance/leasing/articles/43093/article.html
Go shopping and negotiate some real world values to be certain.
If you have a 2002/3 and would like the walk-through aisle we could arrange a trade. These are all just bolt-in plastic pieces for the most part.
I would also appreciate it if anyone could let me know of any of these that might have been totaled and sitting in a salvage yard somewhere.
I can best be reached at:
slund347 "at" ieee "dot" org <-- some assembly required due to SPAM prevention!
Steve
Do you think Toyota will manage to add a 3rd row in the current HL design or will Toyota wait for the HL redesign to add a 3rd row seat?
