Visitor Agreement.
4WD means nothing without traction. Hopefully, everyone goes through safely this winter.
(P.S.: The stock Bridgestones are doing just fine out here.)
That is correct. It is an excellent way of monitoring tire pressure. That's why GM calls it a "Tire pressure monitoring system". I had a slow leak 3 different times and the system saved me each time.
Both get pretty decent reviews on the tire rack site, with the AT supposedly better in the snow.
Also, how do you rate the tires all-around (ride, handling, noise, etc.)?
Thanks...
Their use is not proven to be safer - and I will wear out my alternator sooner, use more gas, and burn up more bulbs?
http://www.lightsout.org/index.html
Prevent me from being in an accident: not likely (but possible). Prevent 'grampa' from entering the roadway in front of me and my spending the next 5 minutes doing 20 in a 40 zone: worth a few extra bulbs over the years.
That's why I've always said that ABS should be "coupled" to VSC so that it doesn't activate unless directional control is "threatened".
I rewired mine so the fog lamps come on at full voltage for "DRL". Also allows me to have the fogs on without the interference of the low beams.
Please advise. Thanks!
Are the needed on a sunny summer day? Highly doubtful, but, "Is it dark enough to use headlights?" is a dangerous judgement question. At 6:30 am, a driver may think they don't need them. But, if you're coming the other way, their silver car is against a snow covered background on a salt covered road... throw in a little fog...
I have my regular lights come on as soon as I turn the car on. I may be burning through my light bulbs a wee bit faster, and may use a drop more fuel, but I can live with that.
But.
Full brightness high beams would be offensive to many so reduced brightness is the order of the day.
I know my fogs aren't likely to be visible at the great distance of low voltage high beams but it was a good compromise.
There is a little more road noise than the stock Bridgestones, but you get used to it quickly.
Ride and handling are excellent.
I am very pleased - its great.
I only have two minor issues or questions.
1) after backing out of a parking space, then moving forward, after a few seconds I can hear a buzzer / whirring noise from the engine compartment. It only lasts 1/2 a second. Any konw what this is?
2) Have a slight buzzing rattle coming from the center of the dash. Only does it on rutted roads or crossing freeway lanes with those dividing bumps. Anyone have a similiar issue
alimin
The sensor is a little microphone that is tuned to detect the particular pitch of the glass breaking, and if it does detect that, it will set off the alarm, immobilizing the vehicle and sounding the audible alarm.
You can test it by setting the alarm and then tapping the window glass with your car key. Be prepared with the remote for when the alarm goes off - the alarm is VERY LOUD!
I was hitting the glass so hard - I thought my window would break. It never went off.
I found out the real test is to roll the window down and clap your hands in the window.
Sorry, Nimron99, thought you already owned a HL and noticed the GBS wasn't located by the alarm status LED as noted in the alarm manual. BTW, I've never been able to make my alarm go off by tapping on the window, either. Just another reason why I perfer a motion sensor.
http://rav4world.com/brochure/alarms/rs3200plus/page2_3.jpg
http://www.rav4world.com/brochure/alarms/rs3200plus/rs3200plus.html
Nitpicking would be the lack of individual reading lights for driver and passenger, no timed auto off feature for the headlights or reading lights, the short timer on the ignition key light, the way the headrest don't lock in the upward direction, 60 MPH not being at 12 O'clock on the speedometer, the way the rear seatbelts flap around in the wind if not buckled, the lame cup holders (I have a 2001), the mediocre AC, the noisy fuel injectors when it's cold outside, and last but not least, the omission of a flip up rear window (even Steve's minivan has this feature.) :-)
On the positive side when it comes to the little things, I do find the dotted pattern on the windshield above the rearview mirror to be a clever feature that's very effective at blocking sun glare.
I just call em' as I see em'.
Its the auto-dimming mirror. There is a plastic cover over where it mounts to the window (presume its the compass). This is whats buzzing. Great - everything on my car is now perfect.
I tested the glass breakage sensor by clapping my hands inside the vehicle with the alarm on.
The only thing I can't figure out is the noise from the engine compartment which happens about 5 seconds after driving forward. It sounds like a the noise from a washer fluid pump motor. It only lasts about 1/2 second. Anyone know what this could be for - some kind of relay?
It might sound silly, but once you have one of these (and they seem quite accurate), you find yourself looking for one in every other car you get in to.
I might add - I have an '02 non-limited...
no timed auto off feature for the headlights or reading lights - the headlights as far as I know are auto-off
the short timer on the ignition key light - at least they have one, unlike most other cars on the road today, but I'll give you 1/2 a point for that one *hehe*
the way the headrest don't lock in the upward direction - convenience vs. safety. going down without locking would be unsafe for whiplash, but being able to adjust them upwards without pushing the button is convenient
60 MPH not being at 12 O'clock on the speedometer - what does that have to do with anything? Alot of highways still are 55mph and alot more are 65mph speed limits.
the way the rear seatbelts flap around in the wind if not buckled - there's a clip next to the side seat cushion.
the lame cup holders (I have a 2001) - made to accomodate mugs (I still don't get the whole cup-holder wars going on in cars)
the mediocre AC - this is an SUV (or tall wagon depending on who you talk to) and has ALOT more space to heat or cool. However, in most Toyota's, including the HL, I've found the A/C will freeze you out and the heat will toast you on the highest settings.
the noisy fuel injectors when it's cold outside - haven't noticed this one.
and last but not least, the omission of a flip up rear window - Toyota doesn't do this on almost any of their vehicles for a couple of reasons. First, for the rattles they almost always cause and secondly, when they're flipped up, they have a knack for catching rocks that have kicked up over the vehicle and shatter. I do wish they used the power rear window design from the 4Runner and Sequoia there though.
I haven't found any vehicle out in the market yet that I think is ABSOLUTELY perfect, but that's part of shopping around, finding one that the benefits outweigh the drawbacks. Be well.
Ken
If its a loud click you're hearing from the engine compartment when you first start driving then this is the self-test of the ABS system; the owner's manual mentions this.
megawattblues:
Wasn't sure if you were aware of it but Limited models have an outside temperature indicator.
My nitpick:
On Limited models, the screwy user-interface on the climate control system (at least on the 2001; maybe they've improved it on subsequent model years):
a. If you hit the AC button the AC will not come on unless if the fan is already on.
b. If the AC is on when the fan is turned off, it is re-activated the next time the fan is turned on.
c. If the fan isn't on you can't change the temperature setting even though it is affecting the temperature of the air entering the vehicle. You have to turn the fan on, adjust the temp, then turn the fan off again.
d. To turn the fan on, you have to turn the fan knob, and to turn it off, you have to press the "fan off" button; you can't turn the fan on by hitting the button nor can you turn it off by turning the knob.
I know it shouldn't, but it drives me crazy if I think about it too much; its as though it was designed by committee. I understand they're trying to achieve an automatic climate control system, but I personally like to control it manually rather than activate the auto feature and have the fan go full blast in my face when I start the car on a warm day.
What year is yours? - maybe they have changed it on the newer models (and yours is a 2001?)
And I do not own this HL, it is a company vehicle that I drive in the week. Since I am pretty much the only one that drives it, I get to take it for service when that time rolls around...it is a 2001.
Sounds pretty horrible.
1. The RX300 was designed.
2. The HL was designed based on the RX300 after stretching the wheelbase 4".
3. The RX330 was designed based on the HL (and thus with the longer wheelbase accounting for its larger size when compared with the RX300).
There is an RX330 edmunds.com discussion; see post Lexus RX330 Dec 05, 2002 in this discussion. RX330's interior looks like a high-class version of Highlander's.
I think it would be cool if they came out with a sport edition of the Highlander; something that exhibited more character and pizzazz, perhaps by two-toneing it and/or enhancing the grill design.
What bolt are they referring too?
Anyone know what this is?
Not being an audio-phile - I think the sound is great. Just wondering if it is made by Nakamichi?
The best bet would be to take it easy and you won't have to worry about any noises.
Ken
GregB
PS. Thanks mikey00 for the tech info.
Weird! Mine don't do dat.
Seriously, I think someone should take a look at your struts. There should be enough damping to keep the springs from slamming the shock into an uplock that quickly.
Have you looked at the bolts at the strut bearings under the hood? Battery clamped down good? Can you make it happen by bouncing the car at the bumper?
I'd almost bet that it's something else that's loose, but I don't know what else to suggest. I have driven over all road conditions (& speed bumps), and have absolutely no suspension noise. Hope you find it.
Glen
My HL ltd V6 is 3 days old. I went to the dealer and drove another one from their lot - exact same thing happened. Therefore its not my vehicle - but seems to be common to all. Don't get me wrong - 95% of the time - they won't extend to their maximum. Only if I hit the speed bump at a certain speed. If I go really fast - the body stays level and the wheel does all the work (no noise). If I go at the critical speed where the body (front end) is pushed up, as the wheel crests the bump - it is pushed down really hard by the spring and causes the shock to extend to maximum. If I go really slow - ther is no noise. I also managed to recreate the noise while driving up a multi-level parking lot. As I crested the ramp - "thunk" the wheel extended to maximum.
I'm talking more about control and confidence, than the ability to just get going. The (AWD)HL gets going ok.
I recently pulled the trigger on a set of 4 Michelin Arctic Alpins mounted on take-off HL steel wheels from tire rack. When I get them, and I get a chance to check 'em out in the ice & snow, I will post my findings here.
That's if I don't manage to stuff it in the sleet & freezing rain we're now getting here in CT (even more predicted for the weekend).
I was sitting on a fence with this, trying to decide on dedicated winter tires vs. "the perfect tire", such as a set of Cross-Terrains. But the Duelers are actually pretty good on dry roads, and I've had no issues in the (non-freezing)rain. So in the spring (or before), I will take the Alpins off and stick the Duelers back on, with their nice, pretty alloy rims.
Glen
For anyone looking for the "problems" discussion, here's the link:
Toyota Highlander Owners: Problems & Solutions
They use so much d*mn salt here in Milwaukee, I also have mine in at least once a week, with no problems at all.
The mirror rattle I referred to earlier - I thought it was the magnetic housing on the mount - well it was actually the mirror. It wasn't installed properly at the port. The securing screw wasn't even tight - the mount was rattling on the dove-tail base. I mounted it securely and tightened the "torks" screw. So far - no more rattles.
The front suspension noise - which happens when the front struts extend to maximum when the front end gets light. I drove another HL from the dealership and the same noise occurred.
I found if I take the bump fast enough - the front body never lifts up - only the wheels move up and down. The noise does not occur. I have to take the speed bump at 35-40 mph and all is well. 5 mph is OK but 10-25 mph causes the loud "thunk" sound.
My first gas fill up at 250 miles averaged 17.8mpg, the second fill up (322 miles) averaged 19.4 but the display read 19.9 mpg (ref: AWD V6 Ltd, mostly commute and a stretch of highway at 85-90 mph).
All I can say - I love the HL. At 85 mph on the freeway - its one of the quietest cars I have been in. The power is good (Still breaking it in - so I am being light footed). The handling is also great - cornering - there is hardly any body roll. Tires are great (Bridgestone HT's).
The only real disappointment is the front strut noise - which should not happen on an SUV of this quality. My CRV never made any noises on the same commute route I have been driving for 8 years.
I finally opted for the Crossterrains, and so far I'm very pleased, the seem to handle well in the rain and are very quiet and stable on dry pavement, I plan on taking them to the snow, up north, during the holidays and see how they handle then.
The Crossterrains are a bit pricey, but I have always been a firm believer of "you get what you pay for"
Please remember that the Crossterrains are considered a premium tire amongst all the other tires.
Happy holiday's driving to everyone and thanks for all of your inputs to the HL TownHall
