Toyota Highlander
1151152154156157211
  • brad_22brad_22 Member Posts: 154
    Have you taken your HL in for a realignment? Misaligned wheels are often the cause of the vibrations you're speaking about.
  • rmui1rmui1 Member Posts: 48
    This sound like warped front brake rotors. That's why it only happen when braking, and most noticable at higher speeds. Usually caused by the front wheels lug nuts not having been tightened with a torque wrench for even tightness. Can also be caused by overheating the front rotors (disks) such as when going down a long steep mountain road and riding the brake etc., but of course this is rare. Many car shop do not torque the wheels so I always retorque them myself. Once warped, the only long term fix are new rotors, thought you might try retorquing the wheels and wait a couple of months to see if they straighten themselves out. This worked for me once when the condition just started and was very mild. Car shops usually want to turn (shave the metal from) the rotors to straighten them (straight on outside but still warped inside because front rotors are hollowed inside for cooling), but this causes even thickness of the rotors (because of hollow interior) and will typically warp again soon after because the uneven thickness of the rotor tend to warp itself when heated even from normal braking.
  • brupopbrupop Member Posts: 63
    Try lubing the seat belt attachment. That is what was causing the squeak on my 02 HL.
    GregB
  • tombuchtatombuchta Member Posts: 11
    Interesting coincidence, I was about to post regarding warped fron rotors.
    This has happened to me twice no on my 2001 Highlander, although its possible that the first time was due to over-tightening lug nut (mechanics claimed this could not happen on the HL) the second time was due to towing a trailer, with trailer brakes, not riding the brakes....At this point I am of the opinion that the front rotors on the HL are thin and prone to warping. The first time service turned the rotors under warrantee but charged the second time...and I expect to be buying new rotors the next time it happens..
  • rfhourfhou Member Posts: 47
    Any thoughts on being able to retro fit the HL with HID's? Any way to use Rex parts? Hids4less says their parts are Not DOT approved.
    Thanks in advance.
    Check ssssteve's most recent post over on the RX300/330 thread. DOT approval probably means autoleveling which is only available via OEM so far.
  • capnkirkcapnkirk Member Posts: 10
    My 2001 Highlander developed warped brake drums at 30,000 mi. Took it to the dealer, who charged me $35 to road test the rig and tell me there was nothing wrong. The brake shop diagnosed and fixed the problem (turned the rotors) for $70. Too bad such a nice rig gets such a rotten Service Department at the dealership.
  • kstittkstitt Member Posts: 9
    Has Toyota announced a target release date for the planned Highlander Hybrid? Does anyone have any information on this future hybrid. As a satisfied owner of a Prius, I am interested in a hybrid Highlander.
  • awchan13awchan13 Member Posts: 44
    My rotors got warped around 30K also. I called around to a few shops, 5 to be precise (trying to price the 30K maint. service). The first 4 confirmed that what I was experiencing was a rotor problem, but they would have to check it and then they could quote me on fixing it. The last guy agreed it was a rotor problem. Then asked my again how many miles I had on the vehicle. I told him, and he informed me that the it would be covered under the vehicle's warranty and to take it to the dealership. I took it to the dealership, they did my maint. service for $100 bucks. They also ground the rotors and fixed my squeeking sunroof all under warranty. I was even surprised to find my car washed. The dealership was Superstition Toyota in Mesa, AZ. I'm glad I took the time to call around and find an honest mechanic...saved me a lot of $$$! After the dealership fixed the rotors, it also solved the problem of my vehicle vibrating at high speeds (without applying pressure to the breaks).
  • cliffy1cliffy1 Member Posts: 3,581
    I keep hearing rumors of a hybrid Highlander but I don't have a time frame on it. I'll try to remember to ask our district rep the next time I see him.
    Rumors are that the RX version is at least a year away.
    But given that the HL has a 4 cylinder option it might be the more appropriate "first" platform.
  • smpoolsmpool Member Posts: 33
    Motor Trends May edition says there will be an all new Highlander for 2004. Does anybody know anything about it, i.e. what changes are in store?
  • jeff186jeff186 Member Posts: 95
  • nimrod99nimrod99 Member Posts: 343
    Recently drove to Las Vegas from N California (about 530 miles each way)
    2003 AWD Ltd V6, at about 80-85 mph, I got 17 - 18 mpg going up the grade to Nevada. On the return leg - at 85 mph, on the down grade it was about 19 - 20 mpg.
    Around town and commute traffic I average about 18 mpg.
    Anybody have similar mpg averages?
  • skyrebskyreb Member Posts: 129
    nimrod99 - Sorry, no experience with 85 mph. I routinely get 22-23 mpg on the highway, but at 65-70 mph. It certainly makes the point that mileage decreases as speed increases.
    Paint: Some time back there were comments on this thread re Toyota's paint, and the fact that it is thin. I somewhat discounted the comments. However, with winter now past, I really cleaned my 2001 up, and was dismayed to find numerous scratches and abrasions in the paint along leading edges ... they all seem to be consistent with the slipstream (they are not, in my opinion, intentional scratches) Rather, they seem to be caused by sand and small stones imbeded in snow and slush that was splashed on the HL from passing vehicles.
    I suppose the paint is thin, and it does seem to be easily scratched. I am wondering: Doesn't it have a clear cote over the color cote? I wonder if I should have a paint shop apply another clear cote layer while the paint still looks fairly good, and before it gets too scratched.?
    I wonder why Toyota would use such a paint? Saves weight? Cost? Is it less prone to fade? I am just guessing, I have no idea, and would like to hear others opinions.
    Happy HL'ing to all.
  • buster36buster36 Member Posts: 2
    I have a 2003 HL Limited with leather seats.
    When I bought it I read a description on the Toyota Highlander Options page that described "front fore and aft adjusting head restraints." Mine only adjust for height.
    Is it only the factory leather package that has the back-and-forth moveable head rests, mine is port-installed, or should all Limited's have this feature?
  • toystoys Member Posts: 5
    Having read the messages on this board since its inception I decided to buy myself a birthday present (69) and just recently brought home my 03 2WD Ltd and couldn't be happier. My only issue is that I think that Toyota should have made the exterior readily recognizable as a Ltd. Fender flares standard?
  • dpg19582000dpg19582000 Member Posts: 1
    Just purchased a new 2003 highlander. First of all, this is one nice utility vehicle. I did not purchase the Limited model, but it does have the V6 and AWD and many options.
    I was driving a 1988 Chevy P/U 2WD ext. cab, long bed. What a difference. I needed a vehicle that rode smoothly, had decent power, all weather capabilities, and seating for 5. I test drove the Honda Pilot as a comparison first.
    After reading all the reviews (Consumer Reports, etc.) I figured my number one choice was the Pilot. I was wrong. I have no great use for a third row of seating, the Pilot seemed larger than I needed, felt like a rougher ride and the seats felt kind of odd (can't explain, seemed like the head rests were to far back or something. Don't get me wrong, the pilot is a very good vehicle. The major problem was that I could not get one for 2 months!! Plus the dealer was charging MSRP and no negotiations. I said "let's go to Toyota".
    I'll start with the dealer Herb Chambers in Auburn Mass.
    The salesman did not pull the high pressure pitch, but I haggled over the price for 4 hours. Good thing I did my homework at Edmunds for the prices. One thing that bugged me that I didn't notice when I test drove the vehicle was the mileage. I looked at the odometer and it said 0.1 miles. I thought " hmmm, brand spankin' new". Then when I signed the papers the listed reading was 300 miles. I realized that the little sneak pressed the trip odometer and rest (reads in LCD display in the same place. Oh well. The sticker price was $30,541. I had them put a trailer hitch on so I could pull a popup camper. Added about $300. Total $30,841. I negotiated a price of $27,800. I was also able to finance through Toyota for 1.9%, 3 years.
     Have been driving the truck for a week now and have 500 miles on it. No opinion on traction in the snow - NO SNOW NOW!
    PRO -
    good power, good ride (it is still an SUV not a caddy) all weather, tow a trailer, seats 5, storage in back, no sqweaks rattles or noises, quiet cabin, decent stereo, split and reclining rear seats, plenty of room, not to large.
    CON - (these are not major, just a pain in the neck)
    #1 : Seating position - I am tall, 6'2" with long legs, 36". I find that when I push the seat back far enough to be comfortable and recline the seat back a little, I have a hard time reaching the steering wheel at the top or 10 - 2 position. My arms are straight out and get tired fast. If I try to move the seat in closer, my knees press against the door panel on the left and the center console on the right. I end up holding the wheel at the bottom - not too safe. TOYOTA, TAKE NOTE: A TELESCOPING WHEEL WOULD HELP!!!! The technology is availabe and for this price should be standard on this vehicle!! Also, the seat is too short. Not enough thigh support for taller people. I own 4 Toyota's and this is typical. You would think the Japanese would get a clue and realize not all Americans are 5 feet tall....
    #2 :If you have the arm rest down, it can be a pain to access the seatbelt buckle because it is in the way.
    #3 :I'm not to keen on the cup holder cover that sticks up when open. A design like the storage bin behind it with the double opening doors that disappear when open would be much better.
    #4 :Have a slight vibration in the steering wheel at highway speed. I looked at the tires and noticed that three have a small balance weights and one front has a much larger weight. I will probably switch that tire with the spare to see if it is a wheel balance problem.
    #5 :Same problem as everyone else, when you put a back window down, the noise is very bad.
    #6 :More padding in the door arm rest please!
    Just my experience with this vehicle so far.
  • landdriverlanddriver Member Posts: 607
    Whether the seats are factory leather is the determining factor as to whether the headrests will be tiltable; Limiteds without factory leather will not have the tiltable headrests.
    I wouldn't worry about it personally as I have the tiltable headrests but never use this feature -- I've always left the headrests in the full upright position.
  • osoriobosoriob Member Posts: 44
    I went on a road trip this week and noticed my front rotors seem to have warped; I also have a little over 32K on my 2001 HL. I have not taken the vehicle to the dealer yet. I experienced this problem on a previous vehicle I had (NISSAN) that was very prone to warped rotor problem the only solution was to replace them. I'm told that this should be covered under the vehicle's warranty and to take it to the dealership.
    By the way the steering shakes when braking hard at highway speeds above 70-80Mph.
    I will make an App. this week and see what happens.
  • jrdowneyjrdowney Member Posts: 96
    Driving at that speed is irresponsible and selfish! You deserve every ticket you get!
    Thanks for your comments - who appointed you the moral authority?
    Can you tell me why it is irresponsible and selfish?
    I would assume you are one of those people who cruise arrogantly in the left lane at the posted speed limit, causing faster traffic to undertake you, which IS selfish and irresponsible
    PS never had a ticket or accident - mostly because I drive at an appropriate speed for the conditions (traffic density, weather, visibility). And I consider myself an advanced driver (having taken the IAM Institute of advanced motoring course). I have been driving for 25 years.
    Its tough driving at 80-85 and I am the slowest car (in the right hand lane) on the highway.
    Years ago when cars first came out - they had a flag bearer walk in front of the car to "warn" people. Some even believed that going faster than 12 mph would cause massive bodily injuries.
    Sorry to go off topic but here in NJ, where the top speed on some but not all of our highways is 65 mph, 80-85 MPH is the norm during commuting time. It works well, except when some left lane "richard" is doing 65 and refuses to let others pass.
  • vinod_s3vinod_s3 Member Posts: 12
    Which is why you get to see all those terrible accidents and NJ insurance premium rates are so ridiculously high...
    Highlander, X5 or RX: irresponsible Speed kills.
    Drove almost 2000 miles on the autobahn, 130MPH+ mostly, I'm sure I seemed slow to some of the traffic. Motorcycles passing me at 150+
    Before MT speed limits 100MPH+ lots of miles.
    Speed has its place(s).
  • retropiaretropia Member Posts: 41
    I've got a highway vibration problem with my 2001 Highlander, AWD V6, that I bought new. It just turned over 20,000 miles. Toyota can't figure it out; they replaced my steel wheels with factory alloys, and that seemed to make it go away but now it's coming back. My independent mechanic thinks there is a defect in the right front axle shaft. The dealer said they replaced it but I later found out they only installed a kit. I'm trying to decide whether to ask Toyota to do the fix correctly, or head back to arbitration.
    The whole story goes on for thousands of words as I've been dealing with this for almost two years, but I thought I'd share the abridged version for anyone in a similar situation.
  • scooter_462scooter_462 Member Posts: 1
    My wife says she was locked out of our 03 HL Limited for a while. Neither the key or the remote would unlock the rear hatch. Then started working later. Anyone else with a similar experience?
    wouldn't 35 be even more safe? How about 15? I'll be the safety record of the HL would be perfect if everybody were forced to obey a 15 MPH law!
    Is that we obey the traffic laws and get back to discussing the Highlander.
    So what, if anything, is going to change for the HL in MY '04? I keep hearing a 5-speed auto tranny is a go ala Lexus.
  • tommyg12tommyg12 Member Posts: 158
    Does the vibration occur at or above a certain speed and do you feel it throught the steering wheel only?
    I had that happen on the front passenger door once. I think the electronics between the factory electric locks and the alarm lock control confused each other temporarily. Was OK after I opened the driver's door and unlocked all doors with the door switch on the drivers door.
  • gwkisergwkiser Member Posts: 326
    Now, really, must you be the party pooper??!!
    My vote is to let vinod s3 walk on the shoulder and the rest of us drive like hell!! ;-)
    It's in my job description - we don't allow the promotion of illegal conduct :-)
    Still zooming around San Anton eh?
    Well, I took my HL today to the dealer and they took care of my problem, as previously suspected the front rotors were in fact warped.
    The Technician did not replace them, he instead shaved the surface and made them flat again.
    I hope this is a permanent fix and not temporary one.
    Any comments?....
    my guess is that he mesured the thickness of the rotors and based on that decided against replacement.
    Hope this helps someone else in the future
    Y'all didn't get this link from me:
    Beat Your Ticket
    My highway vibration starts above 60 mph. Before they replaced the steel wheels with alloys, at it's worst, I could feel it around 40 mph. Most people couldn't notice it until it hit around 65 mph.
    The vibration comes and goes while you are driving. It's not constantly on. It doesn't specifically relate to engine load, road incline, road condition, curve in road, anything.
    The problem first appears as the steering wheel vibrates left and right. It's starting to do that for me again at around 72 mph. As it gets worse, there is a vibration in the pedals and floorboard. At the worst, the CD jewel boxes would rattle and the back seat shoulder belts were visibly shaking.
    My theory (and that of one dealer's service manager) is that the alloy rim masks the vibration better than does the steel rim. However, as the problem gets worse, no wheel will mask it forever.
    I've heard of another local 2001 with the same problem. It is also a V6 AWD with steel wheels, and the owner noticed it beginning at 15,000 miles.
    Toyota has spent a lot of money attempting to fix my vehicle, so I think they would fix it if they knew what to do.
    I'm trying to decide if I want to go through another round of trying to fix it, or go back to arbitration and hope the arbitrator agrees it's time for Toyota to buy it back.
    My vehicle has the extended 8-year 100,000-mile drivetrain warranty due to the oil sludge problem, but it's getting to be a major hassle.
    You may want the dealer to check the CV joints on the front axles. They may have too much slop in them, which could cause the symptoms you mention
  • stevesr1stevesr1 Member Posts: 28
    Does anyone know if the Toyoguard package includes any additional rustproofing / undercoating? If so is it specific to a port or region? Is all of the "factory" undercoating installed at the factory or the port?
    The reason that I ask is that my 2001 Highlander (which came through Jacksonville, FL) did not come with this package and I have noticed that the "factory" undercoating missed a lot of places. The worst area was the rear fender lip. Has anybody else noticed this?
    I have since gone back and added undercoating to these areas that were previously missed. I used the Dupli-Color rubberized professional version. I found this at Autozone but should be available elsewhere.
    Yep. Hope all's well in your neighborhood.
    Regarding the tickets, I get one that's usually 10-15 over about every 3 years. It's amazing. Like friggin' clockwork. I used to go to traffic school to get it dismissed. Between taking up a whole Saturday and the poor excuse for humor in the comedy schools, it was too much to sacrifice! The last time I needed to get one dismissed (OMG! Almost 3 years ago!), I found an online site : http://www.defensivedriving.com/ddo/index.html
    I pay the $40 + fine and get it over with. It's simply not worth my time to go downtown to attempt to beat it. Bottom line, if I'm caught and I did it, I'll pay up without argument.
    My independent mechanic determined the right front inner cv joint had too much play. The same joint in a new Highlander is tight. Dealer said some slop is normal, but agreed to my request to replace the entire right front axle shaft. However, after I picked it up, the joint was tighter, but it was obvious to me they reused the existing axle shaft (it had been cleaned but nothing visible was new), and it still vibrated. I'm still not sure exactly what they did to my axle shaft.
    I heard third hand about the owner of the other 2001 Highlander with the same problem. He requested replacement, and marked his existing axle. Got it back with the same markings, confronted the service mgr. who confronted the mechanic, who said he didn't have the right tool. (The same mechanic "worked" on mine.)
    Of course, I'm guessing Toyota corporate was charged with replacing the entire axle, since that is what was indicated on my warranty invoice.
    So now I have to go back to the dealer and try to convince them to replace it correctly . . . again . . . or go back to arbitration.
  • williadaywilliaday Member Posts: 10
    Hi--
    For my price (under 25K) I'm looking at the Toyota Highlander base 2WD, Hyundai Santa Fe LX AWD, and the Subaru Forester XS AWD. I live in the Washington DC area (this past winter was heavy for us). I wanted to know if anyone has a HL 2WD in this area and how did it far during the winter? Has anyone else compare these models, and what did you choose?
    There has to be a driveline "imbalance" somewhere. My friend has a '02 Grand Prix GTP that had very similar symptoms. GM replaced the axles, wheels, steering rack, and struts but the symptoms remained. GM was very close to replacing the car but decided to replace the transmission and mounts first. The problem went away. Unfortunately since both parts were replaced together, its hard to tell which part(s) was the "golden" fix.
    Hang in there. The HL's are a great car and it is unfortunate that your ownership experience has been tainted with this issue for so long. Please keep us posted and good luck.
  • paulekpaulek Member Posts: 16
    I live N.E of Baltimore, we had the same snow you did. My 2002 2wd with Goodyear Integity, got me through 8 inch fresh loose snow with no problem. How ever when the snow got to 24 inches , no way. I went 30 feet then bogged down, had to back it up to the drive way. Stayed home that day. Once the snow gets above the bumper, better get behind a snow plow!
  • wbeacheywbeachey Member Posts: 3
    I just purchased a 2003 Highlander Ltd. with all the bells and whistles (at dealer invoice, by the way). The deluxe audio system (6 CD changer & cassette) is supposed to have 8 speakers, but I can only find 6: one in each lower door area (4 total) and two tweeters, one in each front door upper area. Does anyone know where the other two speakers are?
    This question gets posted every once in a while. The rear speakers are coaxial, meaning that each consists of two speakers, a tweeter mounted in the center of a woofer.
    (Some of the less popular (and utterly untrue) answers to this question are:
    1. Toyota assumes that most owners are either so euphoric over their purchase that they never get around to counting their speakers until long after the warranty expires, or those that do notice it however refrain from broaching the question of the Toyota Service Manager out of fear that they will be labeled "technologically challenged."
    2. There is a typo on the sticker, and Toyota still hasn't got around to correcting it.
    3. On non-limited models, the remaining two speakers are located on the outside of the vehicle, in the front bumper behind those louvered insets.)
    ROFLMAO!!!
  • rphillips2rphillips2 Member Posts: 40
    Just thought I would add my warped brake rotors to the list. Mine first showed signs of warping at 17K (pulsating brake pedal) and I finally took it in around 25K and the dealer turned all the rotors and replaced the front pads at no charge.
    They warped again at 30K and I took it in around 32K and they turned the front and rear rotors again at no charge. I'm worried that this may become a 10-15K experience and it could be costly after the warranty expires.
    Be sure someone isn't resting their foot lightly on the brake pedal. Not really noticeable except from behind, brake lights, or at 15k intervals.
    I drive the car all the time. No resting on the brake pedal.
    My last vehicle was a Nissan PU that I drove to 130K and never even had the rotors turned. Only went through 2 sets of pads.
    Some vehicles seem to be rotor eaters and others never have any problems unless you let the pads wear too far.
