Mazda MX-5 Miata (2005 and earlier)
1454648505186
  • maltbmaltb Member Posts: 3,572
    I've been driving a Miata for that last two weeks in which I have used it twice legitimately. Not sure if it's my more aggressive driving in that car or the fact that I'm harder to see.
  • daysailerdaysailer Member Posts: 720
    that on my first drive to work after installing the new horn, a driver tried to change lanes into the space occupied by my Miata. I brief tap of the "improved" horn was sufficient cause him to immediately swerve back to his lane - and then pull off the road!? I assume that he must have spilled his coffee and/or dropped his cell 'phone.
    Might have damaged his ear drums, perhaps brain damage. Such power must be used wisely. I learned that in the Spiderman movie.
  • freddy_kfreddy_k Member Posts: 376
    If you use your horn regularly you might want to analyse your driving style. Always have a way out, and never drive beside other cars. I've actually used my horn once in the year I've had my car because the guy didn't see me passing. I was moving quick, and I always expect every car I pass to pull that same move.
    He he, with power comes responsibility. :-)
    -juice
  • lngtonge18lngtonge18 Member Posts: 2,228
    In my area, it's a necessity to warn drivers you are coming down the road. I drive regularly on a "canopy" 2 lane road. Because of the thick trees, people have very limited visibility pulling out of side streets. There is nowhere to go to avoid an accident unless you want to end up in a head on collision, slam into a tree, or end up in a steep ditch. Damn Florida and protecting those canopy roads. They are pretty roads though, LOL. I was driving my Hyundai down this road when someone tried to pull out in front of me. My horn failed to work (bad relay) and she was halfway in my lane before she saw me and stopped. I had to swerve around her blindly or broadside her. If my horn had worked, she would have never pulled out. Anyway, horns come in handy for me and are used quite often.
  • sphinx99sphinx99 Member Posts: 776
    With loud horns come great responsibility!
  • mtfcpamtfcpa Member Posts: 2
    We have just purchased a beautiful, mint condition, 1997 M-Series 5-speed with just 26K miles. We love this car except for the radio and c/d player, and speakers. Does anyone know an after market seller that has a system that does not entail major surgery to the car (both radio and speakers)?
    Thanks for any help.
    I do get intimidated sometimes in the Miata. For some reason, people tend to tailgate me more than in the other cars. If I get a semi alongside of me on the freeway, I really get nervous.
    Almost like riding a motorcycle. I do try to stay away from situations where I'm hard to see.
    Maybe I should get a killer horn. The wimpy one the car came with is almost a joke!
  • WarpDriveWarpDrive Member Posts: 506
    Thinks that make you go hmmmmmm
  • logic1logic1 Member Posts: 2,433
    Actually, the Miata does not go hmmm. It has a regular cylinder engine, not the rotary that inspired the hmmm commercials.
    I meant the person, not the car.
  • bjrichbjrich Member Posts: 125
    It has been about 6 weeks since I have driven my crystal blue. My back went out and on thursday i will be having back surgery.(Micro disk-ectomy) The pain firing down the right side of my righ leg is awsome and I have been living on Mophine about 6 times a day. Started on perkacet but the doctor moved it up. I have high hopes and high prayers.
    My baby is just sitting on the garage getting very dusty. I sure need this surgery to work out, and am looking forward getting out the bucket and hose and vacume and having all ship shaped again
    It has been about 6 weeks since I have driven my crystal blue. My back went out and on Thursday I will be having back surgery.(Micro disk-ectomy) The pain firing down the right side of my right leg is awesome and I have been living on Morphine about 6 times a day. Started on perkacet but the doctor moved it up. I have high hopes and high prayers.My baby is just sitting on the garage getting very dusty. I sure need this surgery to work out, and am looking forward getting out the bucket and hose and vacume and having all ship shaped again
    Bummer
    Look on the bright side though, when you finally drive her again it will be like a new experience again!
    (She is properly stored, right?)
    Although it was my left leg affected making clutch work difficult. I had surgury just one year ago this month. I found that my condition was (and is) improved by seating which raises the butt relative to the knees and opens the angle between spine and thighs. I found a wedge shaped cushion with a relief opening under the cocyx that helps and I use it all our cars ("Tush-Cush" at www.vitalityweb.com). Better lumbar support is also important and in the Miata (at least M1) can be achieved by inserting a rolled towel or other padding behind the seat center panel, which is not fastened to the side bolsters. I didn't find this sufficient, however, and I use a separate lumbar pad as well.
    I'm considering removing the Miata seat to facilitate permanent modifications to the padding.
    Hope you have a successful surgery and a quick recovery.
    -juice
  • dsattlerdsattler Member Posts: 135
    Many door speakers are a five-minute drop-in replacement. The only skills needed are soldering the wires to an adaptor if needed. I bought some Blaupunkts from Crutchfield and had them in in 15 minutes, including soldering. The stereo itself is not a difficult install, but you do have to take a lot of stuff off to get to it. Around here, Circuit City and Best Buy seem to periodically have a free installation deal going. Either way, the only "surgery" (at least in my case) was replacing the stock cubby under the stock tape player with a different one. No big deal. Get something with a lot of power if you want to listen to your stereo on the highway!
    Went by a Mazda dealer yesterday to try a new Miata. I have a 1993 C package. Drove a basic model with the standard 15" rims and a 5 speed.
    It's interesting. I thought I'd like it more. Maybe it's because I'm quite happy with mine, or maybe it's because they improved it in areas that honestly don't matter to me (noise, ride). But I hopped back in mine, and didn't feel the new one was any better for my needs and wants.
    The ride is definitely smoother, impressive because it had 15" rims and mine are 14". Definitely more control, refinement, quiet cruising. It's just not a priority for me.
    Acceleration was a tad better, but hardly noticeable IMO. It felt heavier, my main dislike. The engine takes a while to reach its sweet spot, and only gets truly quicker at very high rpm.
    Handling felt about the same. My wife came along and she's 8 months pregnant, so it's not like I could push it to the limit.
    The one I drove had cloth seats, which I found less comfortable than mine (I have leather). I felt like I had a small lump in the middle of my back, like I had to recline my upper half too much (even with the seat all the way back). Recline it less and you lose precious leg room, which isn't any better than my '93. My legs were still splayed out to the sides.
    In the showroom I then sat in a model with leather, and indeed it was more comfortable. This is odd because I usually prefer cloth.
    The sun visor is still useless. In the down position it completely blocks the road. I don't like the hump on the trunk lid, it looks like a blister. The midnight Blue color was gorgeous and sort of hid that.
    The spare and battery are tucked in nicely, and trunk space is better. No unzipping to fold the top, a big plus. The glass window is smaller, though, so blind spots are still there.
    So not bad, but it didn't make we want to upgrade just yet. In fact I think I'll wait until the prices on the 99s drop a little more, then trade up for that. They hold up so well I don't see a need to buy new.
    I think it's a tribute to how well Mazda conceived the original. It's hard to improve on it.
    -juice
    For the extra money of a new car you can do so much to(with) your '93. (including larger rims)
    I considered an older model when I bought my '99 last summer, but the two things that threw me off the most - plastic window and barn door lights. Every now and then I think to myself that if I had bought and older one I'd have more cash for extras. Then I get into the car and think 'wait a minute, who needs the extras' :-)
    I agree, they keep making the car more refined, more solid, and overall more drivable, but at the unfortunate expense of the true spirit of the car.
    you cheated yourself.
    Go drive a new LS. Optional 6spd that has better action than the 5spd and the VVT really makes a difference in those ratios. 16" wheels with 205/45 tires vs. 15s with 195/50s. Much better stereo. Windblocker. Limited Slip Diff.
    I drove an LS for a few weeks and then a base for a couple weeks. After the LS, I hated the base. I have been in an LS now for 3 weeks and just love it. Bummer is that I give it up in another week or so.
    No need for bigger rims, the ride would get too harsh. I commute with it daily, and don't autocross (at least not yet).
    I'm a card-carrying member of the barn door fan club. When down, the car just looks much better. I still can't get used to the cat's eye headlamps on the new one. I could tolerate it I guess, but I prefer the clean look of the barn doors (when closed, at least). 99% of my driving is done in the day time.
    The LS would actually have been cheating. I wanted to compare a similar model, and I have 14" rims and a 5 speed, so this was closer.
    I did notice the 16" rims, that's a pretty low profile without much sidewall, I'll tell you that. The shifter is already "like buttah" so I didn't feel it could get any better.
    The test car had the wind blocker. I don't want one. Gimme wind. My hair is short. Toss it and save the weight and cost.
    LSDiff I'll take, thanks. But I didn't drive hard enough to need it.
    -juice
  • locke2clocke2c Member Posts: 5,038
    maltb,
    I respectfully disagree. The six speed is slick, no doubt. But if anything the 16" wheels are a hinderance due to their weight. I've noted no handling squirm from "only" 195/50-15s.
    I also didn't think the VVT engine made much difference. Obviously it is only rated what 3 HP more than the 2000? But the midrange felt about the same to me too.
    An aluminum engine block and real HP would be a welcome change!
    -Colin
    The 15s seemed fine combined with the new suspension tuning. I think it may be that my shocks (on the '93) are toast, because even with 14s the ride is stiffer.
    Where does that 3 extra HP appear? 6000 rpm? See, why bother? I think with VVT came higher compression and the recommendation to use premium fuel. That's why I'd probably look for a '99.
    -juice
    You can get a '99 with the six speed-- most people ask a premium for them though since it's the 10th Anniversary Edition. Gorgeous blue paint...
    -Colin
    Yeah, but I'll wait a while, maybe a year or two. Find one at the right price and snap it up.
    I'd like to get one without too many miles for about $10-11 grand (optimistic), and then sell mine for about $8 grand (even more optimistic). I have just 34k miles, and no problem lining up interested buyers.
    -juice
    I have driven a ton of Miatas since the '97 MY and while the VVT only shows 3 more ponies, the engine feels more comfortable and more powerful in the higher RPM range than the non-VVT, IMO.
    Interesting about the tire/wheel weight...I have no idea what the difference is...has anybody ever checked?
    Juice, about the power only happening at 6k...where else would you drive a Miata? ;-)
    I can't tell the difference, and I truly believe that people honestly believe they feel a difference, but I doubt they really can.
    (now assuming a defensive crouch) :-)
    I redline mine at least once a day (exercise is good, as they say), but it's getting up to 6000rpm that takes a while, and that I'd like to address if I could change anything.
    Hmm, how much are those Jackson Racing S/C kits? ;-)
    -juice
  • brutus85brutus85 Member Posts: 11
    Big thanks to all of you! I have been reading your posts for a while. I just bought a 2002 Miata LS yesterday. It's silver with 6-speed, side sills(?), & mud guards as the only options. The appearance package options didn't impress me much when I was test driving but I think it really makes a difference by giving the car a more substantial look. I wanted ABS but due to some time contraints/personal logistic I'll have to do w/out it. I got the car for about 200-300 over invoice. I bought it from my brother who is a car salesman & didn't want to get into nickel & dime-ing w/family even though I knew we could get lower. Anyway, I have driven the car for almost 400 (top down) miles so far and I am in heaven! It handles great! It comfortable. I was driving a Nissan Altima. Which is not bad car for what it is but the whole convertible thing is unbelievable. It's another world all together. I gonna hate when winter comes & I have to put the top up.
    I was looking for a mid-life crisis car. I considered BMW 3 series (used!), MR2, Passat, Jetta, Subaru WRX, Acura RSX...ok darn near everything. Finally, I limited my choice to MR2 & Miata. Test drove the MR2. Really not a bad car. I liked the look of the Miata better. And the LS with the tan leather, two-tone interior, Bose stereo system sold me. FWIW I didn't think the MR2 was a bad car or even ugly but the Miata had a much more...ok expensive or classy look. When you put your good money down & you want to feel that you are getting your money's worth. Oh yeah, the $1000 rebate helped a lot too. So, I'm looking forward to years of fun driving now. Yep, I'm in heaven. Thanks again!
    Oh, a couple questions. I don't have alarm. Do I need it even though I have engine immobilizer? Second, how to do work the leaving the top up/down thing. I mean, when you park the car, do you always put the top to discourage ...whatever or are the cars pretty much left alone so you just leave the top down until your are ready to wrap it up for the evening? Just curious.
  • smarssmars Member Posts: 32
    I use a tonneau and just leave the top down most of the time (it hasn't been up since mid April). I got cought in a thunder shower while parked once, and don't believe any water got in. I do leave a rolled up towel over the console just in case, and I also try to park on an incline (sloping away from the windshield).
    Do yourself a favor and take the three seconds to put up your top. People who don't deserve to live often have fun placing things in your car that don't belong - gobs of spit, lit cigarettes etc. Also, birds. Birds just don't have the same respect for nice cars as we do :-)
    As for an alarm, opinions differ. I've got something better then an alarm... it's called insurance. I also never, ever leave anything worth anything in the car.
    I like freddy's advice, being the daily driver that he is. Leave the valuables at home. Every CD in the car is a copy from the original at home so I don't worry about losing them.
    If I'm just running into a store, the top stays down. If I plan on being more than a half an hour it goes up to discourage tampering.
    Twenty four hours covering the disc=ectomy and am home. hurting all over and need time to recoup and get back into my re -hap program in 10 days .Mrs. BJrich helped me wash the Crystal Blue. She is a dear one. Had a difficulte time entering but exiting was okay.. Hope to take a ride to the Sonic after the evening traffic. Thank you for the good advise and well wishes. This was my first surgery, (except the x4 bypas bypass ) and this one feels tougher. Going to have a large coney at Sonic with my soul mate,
    tonite. Take care, Bob.
    Twenty four hours covering the disc=ectomy and am home. hurting all over and need time to recoup and get back into my re hap program in 10 daysss.Mrs. BJBjrichelped me wash the Drcrystallue. She is a dear one.Had a diffdifficulte inteentering exiting was okay.. Hope to take a ride to the Sonic after the evening traffic. Thank you for the good advise and well wishes. This was my first surgery, (except the x4 bypas bypass ) and this one feels tougher. Going to have a large coney at Sonic wwith mywith mate tonite.
    I installed an Alpine alarm in my wife's miata. It has a very intelligent dual-zone radar that can protect the car when the top is down.
    Which only gets used when we will be away from the car for a very short time. Say a visit to Baskin Robbins? At any other time the top goes up when parking.
    -Colin
    thoughts for a quick recovery...take care.
    Alright. I think I got. I got insurance. Long term - Up. Short term - Down. I'm still in heaven!! Thanks again guys.
  • pitt3pitt3 Member Posts: 4
    Just picked up a Base 2000 miata - 10, 500 miles. I'm getting a vibration through the shifter about 65/70 mph. Any ideas why (wheels have been checked for balance)?
    How much was that Alpine alarm and how does the radar work? Where did you get it and did you install it yourself? That sounds like a good system that would allow you to keep the top down more without worrying about it. Would appreciate some more info.
    Uggh...My Panasonic gel cell battery croaked. Thank God for manual tranmissions and their ability to push start!
    What do ya know...the Miata can hit 130mph with the A/C. It was remarkably steady but not a place I wanted to hang out for too long.
    the alpine alarm was about $450 installed. alpine only makes two alarms these days so if it comes with one radar sensor and a remote display unit, that's the right one. call around your local car audio & security shops to find alpine-- none of the radars offered by competitors are as good.
    it reaches outside the vehicle to provide proximity warn-away (unless disabled, it's illegal in NY) and then if something reaches inside the car at any time it goes into full alert. the larger proximity zone actually shrinks any time there is a warn-away, and if it continues to trip it stays "inside" the vehicle for progressively longer times. in short, it works great even if the car is being rained on.
    BUT I still wouldn't leave the top down unattended for long periods, even if you are in a "safe" area there is considerable risk of vandalism.
    -Colin
    I autoxd for this weekend for the first time. Lots of types of cars, but the largest number of any one kind were Miatas. The 3rd fastest time of the day was a Miata with a STOCK engine, a '99 LS - only 140 hp with upgraded shocks and springs, ended up spanking Vettes, WRXs, S2000, and other respectable cars. The driver was incredible, I got to ride shotgun and he was FAST - I never knew my car had so much potential. Yet again, after owning my car for a full year, I find myself impressed. :-)
    riding with any fast driver is like that no matter the car. but there's no doubt, a Miata is well-equipped for autocross.
    -Colin
    And he had a 2nd passenger as ballast. That is impressive.
    -juice
    True but good drivers are like that. The 2001 D Stock national champ is from my region and he can drive the pants off most anything after just a few runs. Also have the 98-99 F Stock ladies national champ in my region but unfortunately I haven't ridden with Jean. She drives quite well though.
    After watching a Porsche documentary on SPEED, I've decided that taking a lap around Laguna Seca with Hurley Haywood in a Boxster S might make my life complete. ;-) Miatas are tons of fun too, especially when used for motorsport. Not that they make bad Sunday cruisers!
    -Colin
  • olyeller1olyeller1 Member Posts: 4
    Drove a miata for the first time today (99 LS). Loved it. Two complaints: definitely needs a tilt wheel and some sort of deployable windblocker on top of the header. Temporarily used my hand as one and it nicely negated the wind's attempt to blow the top of my scalp off (I'm well under 6'). Anybody make such a thing? Otherwise, buffeting at speed was unobjectionable. Wind blocker didn't block anything. Ride was not nearly was rough as i had expected.
    P.S. - Why is this board so hard to find?
    The LS uses the stock shocks and springs. They are pretty soft and comfortable for a sports car. I personally think that it is the best setup you can have for cruising the streets. Now that I'm autoxing though, I'll be looking for something a litlle more.. um.. uncomfortable :-)
    Also, being well under 6' myself I find the wind to be very tolerable, and have successfully worn a baseball cap up to 180km/h. (112 mph) Besides, I always thought 'wind through the hair' was supposed to be part of the experience.
    Can't be too hard, we all found it. :-)
    Try driving with one window down, the other one up. For some reason this leaves less of a draft for both passengers, vs. both windows open or both closed. I don't have any wind blocker at all, too.
    -juice
