The brakes on the tahoe are stiking or dragging. I took the the truck to a local shop and they adjusted the rear parking brakes. last night when I drove the truck it felt heavy, and whe we got home the wheel were very hot.
This morning I raised the front wheel of the truck and its spins fine so I don't think its the wheel bearing and I don't think there is an adjustment for the brakes.
Any help will be appreciated.
If it is the fronts that were hot, try jacking up the car and turning the wheels after the wheels are hot.....as opposed to when they've cooled down overnight. I suspect you'll find one or both hard to turn. If so, you'll want to replace your front calipers, and might as well do new pads while you have everything apart. Check the front rotors for heat spots, replace rotors if heat spots....or, if you have brake pulsating while stopping.
Make sure they flush the brake system with new brake fluid.
All 4 wheels were hot. I took the truck to local auto parts store and they pointed to the brake booster, I went back to the local shop and they said that the brakes don't have adjustment(I knew that), then he said that problem seems to be the brake booster or the master cylinder.
A friend of mine that works on cars also pointed to the booster. He also said that he would help me install the unit at no charge! It will be in tomorow.
I will post in a couple of days..
I talked to the autoparts store and it will be replace with another unit.
Thanks on the master cylinder suggestion, I think I'm going to replace that also.since I'm already there.
Any others out there with the same problem??
Also, can anyone tell me how to determine whether or not the rotor is a factory original? I bought the car with 19K on it and I know that they were resurfaced by my dealer but never replaced.
Many thanks
AJG
I am not aware of any TSB.
The front brakes are critical to keep in excellent shape, because of the vehicle weight, the rear drum brakes, and the smaller size of the discs.
Do NOT go cheap on the the rotor replacement. You can get relatively cheap rotors at the chain autoparts stores, but it pays to upgrade to Bendix (they may have to special order it in). I read a comparison years ago, and the metallic makeup and manufacturing heating and cooling process reduces warping of the rotors that can occur under a heavy braking situation.
I dont' remember the prices, but I think like a regular rotor is like 30 or 40 bucks, and a Bendix like 50 or 60 each Having replaced a number of the cheaper ones after warping, I can tell you the labor/hassle savings is well worth the $$'s.
I personally would not consider your original equipment rotors defective having lasted 12-13 years, I'm surprised they haven't been replaced once or twice already.
I have a 1997 4x4 Tahoe. - 5.7 The other day when I drove it, it came to a complete slow stop on it's own. When I tried to force it to move, I went about 30 feet and the brakes started to smoke along with that wonderful 'burnt brake' smell.
All 4 wheels seem to be locked up. If I let it sit overnight, they release, but when I try to drive it they lock up again. It happens slowly, it's not a sudden neck jerking stop. I took out the ABS fuse ... didn't help. ANYONE have any ideas as to what this might be?
Although I am mechanically inclined, I don't have the time, so I would refuse such an attempt.
On the other hand, after spending about $4500 on brakes in three years, I am not longer driving the vehicle...this will be the subject of another posting. Nobody can fix my brakes and they have been worth crap for three years. It's a worthless vehicle now and dangerous to drive.
Anyone know of an aftermarket system from master cylinder all the way through calipers pad, drums, rotors that will work here?
But you need to make sure the parking brake is off, and remove any push nuts from the wheel studs (if there are any).
Whack the end of the hub with a deadblow hammer, if you have to, to separate the rotor from the hub.
At any rate, at 70K miles, dealer says rear brake pads need replacement. Wanted $400. Then said "brake fluid looks really dark, needs replacement" for another $175. The pads don't surprise me (though the price does). However, is the "dark brake fluid" the typical dealer scam? There's no mention of fluid replacement requirement in manual. Or is this a real problem? I took it home anyway as I figure I can get this done cheaper at an independent shop.
PS: did you change brake fluid? When is it necessary?
If you did it yourself, sounds like you didn't get something back together correctly....or you have used the wrong parts.
