BMW 335i 2007+
So sorry I dropped the ball on you. This was my first time posting in this forum, and frankly, have been side tracked! You are supposed to get this cable FREE from BMW. I got it right from the parts department. Yes, it's fantastic! Much better than the aux only. You see the playlists, artists, songs, the whole thing! Yes, mine is in the center console too. Hopefully by this time you've already resolved this issue. Sorry again for the delay.
Adam
Thanks so much for your reply. After your post I spoke with BMW and described what you had and they are over nighting it to me today..The parts dept. guy says it has a usb port on one end and then a USB port for the i-Pod and aux cable. Is that the same as what works for you? I am a little unclear though if you don't mind..I have a i-Pod Video 60gig..the parts guy said I hook the usb port with the Aux port on the i-Pod Is that on the top or bottom of the i-pod? is the aux on the I-pod the head phone jack? Looking at the I-pod I would think the usb port is on the bottom, but there is some tiny, and I mean tiny looking usb port on top too..please if you have a moment just describe where I should put the cable. Really, really appreciate your help with this..
and thanks for your time.
Lucky you, are you driving a 335i? What other features did you get in your car -- and which are your favorites? I can tell when it comes to music and cars we think alike.:)
Donna
OW
You'll totally understand once you get it. The end that connects to the iPod is not a usb, rather it connects to the bottom of the iPod using the same connection as you use to hook it to the computer. The other splits into two - the aux and the usb that both go into the car. Once you have it in hand, it'll become very clear, there's only one way to connect it.
Adam
Any recommendations for good driving music?
Donna
Enjoy your ride. I also enjoy your posts and have learned a lot from you. Drive with passion!
OW
Adam
Thanks for everything,
Donna
Thanks and Regards,
OW
You may remember our previous story about the BMW 335i being run on a dynometer and displaying some impressive figures. In the earlier tests, the 335i made 275hp and 406Nm torque at the wheels. Estimating drive-train loss of roughly 20-25%, this equates at close to 350hp and 480Nm of torque at the flywheel.
Automobile mag went back to the dynometer and tested the 335i again, this time under cooler conditions that would yield better figures. The 335i managed to get 285hp, then 282hp, and finally 287hp, which is even more impressive than the last unit. Finally, they found one case where the 335i peaked at almost 300hp at the wheels, which puts actual output at close to 375hp. It looks like BMW engineers have seriously underrated this engine.
OW
That seems like an excessive estimate of drive train loss for a manual transmissioned RWD car.
Last year a friend of mine turned in his leased 2001 911 Turbo. He had a couple of approved modifications - larger turbochargers, revised programming, exhaust system, clutch, etc. Before turning it in, he took it to a nearby track and also had it dyno'd. It showed 520+ hp at the wheels. If you apply the 20-25% loss factor, that would equate to 650-690 hp at the flywheel. He thought 15% loss (610 hp) would be more like it. The car did run a 1/4 mile in 10.55, for what it's worth.
He later took the 2006 911S he purchased to the same shop. It's rated at 355 hp and showed an average of 313 hp at the wheels (12% loss). Interestingly, a previously tested 911 C4S (AWD) showed 300 hp at the wheels (16% loss), which equates roughly to the 4-5% additional drive train loss my dealer estimated on the AWD models. Also, a previous generation M5 (rated at 394 hp) showed 325 hp at the wheels (17% loss).
It does seem that both Porsche and BMW tend to be conservative on their horsepower and performance ratings. But I don't think 20-25% drivetrain loss would be considered normal, unless they are testing a slushbox equiped AWD car. If anyone is more technically knowledgeable about "drive train loss", I'll stand aside.
That sounds like a 600HP+ car! I'm not sure about the $/HP cost, but that is an outstanding upgrade on a very capable chassis. Did he think about keeping it at any point? The thing is, if he already invested, what was his motivation to turn it back in? I assume future cost-to-repair or the urge of a new model.
BTW, I'll wager it costs a lot more for many capable stock cars to get the E.T. in the mid-10's. That is Super Stock/Super Comp times according to the N.H.R.A....and those cars can only do real good going straight! (and cost big $ to boot).
You know what you can do with a 911 at the end of a long straightaway!
In 5 years, he only put 11,000 miles on the car. It might have had bragging rights at the track, but it was definitely not a friendly daily driver. He let me drive it once and I don't think I stalled out as much with my very first manual transmission 30+ years ago. The clutch was a bear. And once you did get it going, hitting a pebble on the road would rattle your fillings. He decided to let it go and get a new 911S Coupe. Not nearly as intense, but he drives it everywhere.
I will double check that 1/4 mile time, but I am pretty sure it's correct. In addition to 520 hp at the wheels, it was estimated to have 520+ ft. lbs of torque at the wheels. That's considerably more than the Carerra GT and, with the Turbo's AWD, all of that power went into forward motion. I did let him give me a taste of it on an empty road. I can honestly say that I've never experienced anything like it. My eyeballs felt like they were being pushed back in my head and I must have looked like I was going to black out, because he looked over at my white face after the short blast of a run and apologized. My own 911S (which according to road tests is capable of 3.9 to 4.2 seconds 0-60) felt absolutely anemic for the next week or two.
At some point however, you have to wonder where the performance - and specifically horsepower/acceleration - will end. Another friend of mine called me a couple of weeks ago from Chicago to gush over his new Mercedes E63. Claims with 500+ horsepower that it's faster (in a straight line) than my 911S. He's probably right. But he was calling me from a cell phone going 30 mph in bumper to bumper traffic. When I called him back a couple days ago, I asked him how his new car was. "Not so good - I only got 11 mpg on my first two tanks of gas" (he has a 50 mile roundtrip commute). I resisted the urge to remind him that the E350 Bluetec cost $30k less, gets 30+ mpg and can still significantlty outaccelerate my old 1984 Toyota Supra (the car he always envied).
I appreciate your feedback on the HP issue. For the 335 six, 300+ HP is quite good and darn close to the previous M version. Now the M will get the V8 so no end in sight there.
I assume it will be similar in cycle at the end of the 60's when environmental and energy conservation ended the then famous HP wars. I had a '77 Pontiac GP with a 400 C.I. V-8 with only 180HP that would have had at least 350 HP in 1969.
As gas creeps ever so humbly to the $4/gal. mark and beyond, the E63 your friend has will cost over $70 to fill up every 200 or so miles. It's nice to have the power but I'd call it an imbalance and so goes the energy use and the costs follow. A wolf in sheep's clothing is still a wolf. Sedans with 500+ HP will become very rare relative to the cost of energy. "Yous gets what yous pay for!"
OW
While it is true that the smogging of our cars in the mid 1970s did emasculate them from a performance perspective, what is often missed it these types of discussions is that the horsepower wasn't created equally. IIRC, horsepower numbers from the 1960s were calculated with the bare engine sitting on a stand and hooked to a dynamometer, no exhaust, no alternator, no coolant and fuel pumps, and sure as hell no A/C need apply for that job. By something like 1973, the automakers were coerced to provide real world(ish) HP numbers by testing the complete engine as it was installed in the vehicle, complete with exhaust system.
So, saying that the 400 in you 1977 Grand Prix only had 180 HP while that same engine in the 1960s had more like 350 is missing the mark a bit. ;-)
Best Regards,
Shipo
Put another way, a 1970 GP with the same C.I. engine put much more power to the road than the 1977 version (sometime between then and now HP was changed from being measured in Gross terms to Net HP today). In fact, everything by 1973 was pretty much deneutered in the power department, IMO. Not until the mid-90's did the U.S. mfg's figure out a better balance in HP/torque. Then again, weight problem in most U.S. cars went under the same knife, and a lot of design muscle went down the drain, IMO. The rest of the world was insanely more successful in the total package during the last 30 years!
I agree 300 horsepower today is not = to 300 HP in the '60's
OW
"Not until the mid-90's did the U.S. mfg's figure out a better balance in HP/torque."
Hmmm, the 2.2 liter engine in my 1985 Dodge Daytona had 150 HP and 168 lb-ft of torque. That same engine in my 1989 Chrysler LeBaron GTC had 174 HP and 200 lb-ft of torque. Both were strong and reliable engines, each delivering 100,000 miles before I traded them in.
Best Regards,
Shipo
The past/current generation M3 (stock) are running low to mid 13 second E.T.'s also.
Case closed. Go figure!
OW
Same applies to the 335i.
There are after market brake pad suppliers that reduce brake dust you can investigate after your warranty expires...
I assume that you are referring to the brake rotors, as the hubs are not visible once the rotors and wheels are fitted. As for the rust, ome BMW rotors do, some don't. If it really bothers you, simply pull the wheels, mask off the rotor discs and give the center hat a shot of high temperature engine or caliper paint. Or do what I do: drive the car the way Munich intended- any rusty area will soon be coated with black brake dust...
Best Regards,
Shipo
Cast iron rusts.
The sun comes up in the East.
Go figure.
OW
But, I went out and looked at our E46, and sure enough, you can see the hub.. And, while I know that where the mounting plate of the wheel meets the hub is extremely rusty (which you can see with the wheel off), the visible part of our hubs aren't. Just a dull dark gray..
I'm used to seeing rusty brake rotors from overnight condensation, etc... But, I'm not sure I would like seeing those rusty hubs on my new $50K BMW, either..
Just seems weird, as I've never noticed it on other BMWs, and most of them have pretty open wheel designs.
Maybe there is some kind of electrostatic paint that you could apply, since the area doesn't have any contact with moving parts? Similar to how they paint brake calipers?
regards,
kyfdx
(not the host here)
I suggested that, but the OP wasn't interested. That said, I put new BMW rotors on my 3er several months ago, and the OEM gray paint on the hubs still looks good.
OW
I would throw a fit with bmw na and service manager to see what they can do. For a car that is price this high and have visible rust is no excuse. I own x5 and previous 325 and never seen this problem on the rotor hubs before.
-Paul
