Dodge Durango
I will be looking for a new SUV myself in May of 2005. The Durango Hemi is on the top of my list. The only problem I have is the gas milage. Could you tell me please what your milage was on you trip. Thanks,
Horst
The Monster Cable charger and FM transmitter combo may work ok for you. However, all of the radio transmitters will get some radio interference. For reviews of the radio transmitters check out the reviews section of ipod lounge at www.ipodlounge.com.
I also know that Alpine is now producing an Ipod adapter for use with their head units. However, I'm not ready to throw away my OEM 6 disk changer just yet. If you choose to go this route check out the specs at www.crutchfield.com.
Let me know if you end up trying any of these.
I have the rear entertainment system, which has some rca jacks,
do you think i could find a coonection that would go from the mini headphone jack to rca??
There are a couple on ebay for sale priced below mopar, but needs antenea,bezel,dvd, and installation.
Well, I removed the rack this fall and the noise continued. I went back to the dealership. It turns that the Mopar Bug Shied had been improperly installed. There is a rubber seal that holds the shield tightly to hood. This was missing on the original install causing lots of play in the screen and hence the noise. No such problem with the new one.
So, if you have the Mopar Bugshield and are getting wind noise at highway speeds, you may want to check and see that the shield was properly installed.
Has anyone had a similar problem?
Sorry I took so long to reply. Been really happy with my Durango and just haven't checked.
CWO FERG
But -- want a new car! If I could buy a Caprice Wagon or equivalent, would do so in a heartbeat.
Since that is not possible, am considering subject 3 cars Magnum w 3.5L V-6, Durango w 4.7L V-8). I've given each a short test drive and decided I can fit my arthritic 6'2" frame with 35" inseam in all three as long as they have a tilt wheel. (Toyata Sienna and H. Odessey are out because I can't do that).
I haul long or big stuff not infrequently and haul a lot of luggage, etc on quarterly trips between Florida, Virginia, and Texas. Have no need for a 3rd seat and like the Stow & Go of the G. Caravan.
Seldom have 2nd seat passengers, but, of course, need comfort there for when I do. I almost never do off-road driving, do not plan to tow anything, and avoid snow like the plague.
Have never owned a truck or SUV and do not know if I will like the Durango (although the short test ride was very good). Am now in process of arranging a 1-day rental for each of these (no mean feat, especially for Magnum).
Will also look at Taurus Wagon as a friend has had excellent experience with a 98 and I like to drive her car.
Overall cost to own is important to me (but over a 10-year period).
Would love to hear opinions as to what I should consider and watch out for. (Will also post this on specific car sites).
Is traction control worth it with AWD that comes with Hemi? and
I plan to stick with 3.55 rear end. Any reason to try to get 3.92 rear end?
Thanks. Dave.
I answered this in post #116, replying to lucaja's same question. I have pasted it below. Hope it helps. I ordered mine from the factory with the 3.92, I have it and I am glad I do. The vehicle is quicker off the line and exhibits more torque than the 3.55 I test drove. With me towing a 6,000-lb travel trailer, I am glad I got it. Here it is:
Did you opt for the 3.92 axle ratio? For others thinking the same thing, some things to keep in the back of your head: (1) these things supposedly have a governed top speed of 112 mph (anybody test it yet?), so the lower gearing won't affect that. (2) Fuel economy, yes the engine will turn a slightly higher RPM, BUT it won't be working as hard, so it is a wash. (3) You never know when the wife (or husband) is going to decide they want a travel trailer, toy hauler, horse trailer, boat, etc!!! Get the lower gears (3.92), it's only $40. That's right, $40! Always better to have it and not need it, then need it and not have it!! Good luck to all
Does someone know where the IOD fuse is located? There is nothing to indicate where that is on either panel cover, or in the manual.
Thank you so much.
I still don't know which socket the IOD fuse is in, in case I ever need to pull it, as manual says "cavity 12" but doesn't indicate which panel. The inside fuse panel says that is for the starter only, and the under hood panel doesn't have numbers on the sockets. Oh well.
I just have one problem - there never seems to be a good/safe place to quickly store the headphones.
Also, what's with having to go back to the dealer everytime you want to configure simple pleasures; like having the rearview mirrors automatically dip down when in reverse or the seats automatically move back when you enter and exit?
I'd also like to be able to decide for myself whether I want my horn to sound when I remote lock the doors. These seem to be adjustments that the owner's manual states must be configured by the dealer. Bummer.
Here in Toronto the Belkin does a good job with my iPod but I hear the iTrip is better, though I've never tried it.
Otherwise, my new Durango Limited with the amazing HEMI is a pleasure. I've almost stopped missing my Jeep Grand Cherokee that I traded in. I see a multitude of them on the road and a scant amount of Durangoes.
They must not be a hot seller.
I own a 2001 Dodge Durango. About 6 months ago my check engine lit went on and I was stuck with a bill for $1426.00 because of transmission issues. The dealership was awful to deal with and so was Dodge. I have owed many cars and never had a car with 50,000 miles on it , have transmission problems. I should have gotten rid of it then. Now we find out that about this huge recall. I won't be able to give it away. I wonder how long it will take to get the recall letter and then try to get into the dealership for service. GOOD LUCK. I live on Long Island in New York and my dealership was more than happy to sell me a car, but thats about it.I was through with Dodge 6 months ago, now I am really done with them.
I can't wait to get rid of the SUV and go back to NISSAN.
The rotors are already warped at 4k miles?? Moderately severe shaking when stopping. I am taking in for warranty. Also the rear bumper (just below the rear hatch) is discolored (many white splotches and should be black). Dealer says this is a warranty item and happens on many Durango's. Just was wondering if anyone else has experienced this??
I am sorry for your transmission issues, but again, things happen. Our neighbor also has a Durango and he had to have his rear end replaced relatively early in his ownership of the truck. He still has his and now has over 120K miles on it. It remains his daily driver.
My 2003 Durango has this recall as well as a recall for the winshield wiper module. I will get them taken care of at some point but I am not too concerned about the recalls. The recalls have little, if any, direct effect on resale. I still enjoy my truck and would not hesitate to look at another Chrysler vehicle in the future.
We also leased a '95 Jeep Grand Cherokee Laredo 4x4 back in July of '95. 24-month lease. Only 2 problems (coolant hose came loose and needed to be reattached and rear suspension squeaked). Other than that the truck was great and we missed it when the lease was up (leased a '97 Explorer after the Jeep and it was a good truck...the Jeep was more fun overall). We also owned a 2000 Dodge Stratus. Put 60,000 miles on it in 3 years and had no problems with it (traded it last year for a 2003 Saturn VUE). The only time the Stratus went back to the dealer was for routine maintenance. The Saturn, on the other hand, had some "teething" issues but it is now fine and is a great vehicle.
If I recall, Edmunds long term Intrepid a few years ago was one of their more reliable vehicles. It had a couple of little problems, but Edmunds came away favorably impressed with the car.
I have owned 2 Pontiacs that were nightmares, a VW that was terrible, a couple of really bad Fords, a Chevy that was no problem, a Plymouth that was okay, and another Chevy that was pretty bad.
Dear Dodge Representative,
In November I purchased a 2004 Dodge Durango from Lawrence Marshall Dodge in Hempstead, TX. This was a demonstrator with approximately 6000 miles. Over the Thanksgiving holiday we drove 2500 miles to visit relatives. After that trip I noticed severe shaking when stopping the vehicle due to the rotors being warped. I checked the pads and they showed normal wear. Since I am an engineer the only other reason for warped rotors is excessive heat build up. I do not do a lot of stop and go driving, and I am certain the heat build up occurred during the trip (1000 miles one way and 17 hours) and caused the rotors to warp. This is due to either a rotor design problem (too small), rotors having inferior metal content to withstand the heat and/or the ABS system causing too much drag on the rotors and the heat building up over the long drive.
I recently took the vehicle in for a warranty claim and told the dealer about the brake problem. When I returned, the service department had only replaced the pads and turned the rotors. I explained this is only a temporary fix until we go on another extended trip. They said that there are no upgraded rotors at this time and they could only replace the pad and turn the rotors within the warranty. They further stated that brakes are only warranted for the first 12,000 miles.
Please advise if there is an upgrade to the rotors being addressed. I believe the dealer did what they could at this time, but I am certain this problem will happen again once we go on another extended trip (which we do twice per year). If this does occur again I would expect Dodge to repair/replace the rotors as a warranty item.
Sincerely.
In looking at the Dodge site, it does not appear to be an option. I don't understand why is not a least an option, really it should be Standard.
I'm not sure if that not having ESC and MDS would keep me from trying to cut a great deal on an 05 or not.
Mega rebates and financing deals make the Durango look like quite a bargain at the moment. Plus some people are getting the friends/family discounts too if they ask.
My wish list for '06 is the cylinder deactiviation & stability control. Ok, a rear view camera would be nice too (like in the 4Runner, or MDX, or FX, or Sienna, etc), but I think that can be added aftermarket if you get the NAV system?
I definitely want the UConnect. They have great examples of how it works over at Dodgeboy.
Tonight I test drove a '05 Limited w/ Hemi, dang I was impressed. For some reason last Aug. I was not impress that much. Maybe it was the SLT vs. the Limited or 04 vs 05 with some minor tweakes.
