Chevy S10 - GMC S15 and Sonoma Engine and Underhood Problems
                    i have a 99 sonoma 4.3 2wd  recently my oil has sludged up three to for times within 2 weeks when i would start the truck in the morning it sounded like the motor was coming apart Any one know if the oil cooler can crack inside the radiator causing coolant to get in the oil????al the sludge seems to be around the filter and in the cooler lines
What should I check next? Which is f/pump relay? Where is ECM B fuse?
Is something wrong??
It is 4WD, but I would think that I should not get 6 MPG less beacuse of that. It is a small truck.
thanx
My cracked manifold has air injection system ports. Unfortunately this manifold is rather rare and expensive ($276). I can get a standard manifold for $130 in town. The standard manifold doesn't have air injection system. Is the computer expecting this input to the exhaust? There's an oxygen sensor(s) downstream. The dealership thinks it's a CA emissions thing. Does the standard engine and the air injection engine use the same computer?
Also there's a nearly empty white plastic jug on the front right side, just behind the battery. What is supposed to go in there? My guess is coolant since its around where the coolant place was for my car, and I didnt see anything else around that held coolant.
It seems like any 4.3 L should work, if I just used the long block. With my intake and throttle body.
I'm new to this truck so not sure what will work.
Any help will be appreciated. :sick:
Messages
It ended up being a distributor problem - which became a bigger problem with the limited production run of these engines.
I ended up installing a Multiple Spark Discharge - distributorless spark delivery system.
Now the truck runs like a dream...a little 4 banger pounding along like a v6 - I recommend the MSD for ANYONE with spark issues in the the older s series trucks.
Looking for any help or advice that might be out there.
Sounds like you might have a 99 cent problem. Remove your distributor cap and peek behind at the base of the distributor to see if oil is seeping from there. You might have to use a small mirror and flashlight to look back there. If so remove your distributor (make sure and turn crank to TDC and mark direction of rotor before removing) and replace the rubber O-ring on the distributor housing. This O-ring will cost about 99 cents at your local auto parts shop. Bring the distributor with you to the parts shop so they can match up the right O-ring. They usually carry an assortment of different sizes. I had a similar problem recently on my '93 Sonoma (2.8 V6) and was relieved to find out it wasn't the rear main seal. Hope this helps you out.
Sincerely,
elfeo
Good luck
I'm still not sure from your answer whether the plug is cracking inside the cylinder or outside. I'm not aware of anything that can be wrong with the engine that would cause the plug to crack on the outside of the cylinder. Inside is a different story...detonation, backfiring etc......several things can crack a plug internally.
It was running great when one very cold morning on the way to work it died and blew oil out of the dip stick and all over the motor.
When I restarted the truck, it was very hard to get started. It was missing terribly and the crank case pressure was so high that it blows the dip stick out. A pressure test was good except one cylinder was getting so much fuel that it was making my compression gage shoot up to 300 psi.
I was told o change the fuel regulator, which is in the fuel filter. I should mention that this truck has California Emmissions. After that the truck still ran like one cylinder was missing. I cahnged the plugs, coils, ignition module and catalytic converter with no success.
If the truck is setting idling in park and you rev it up, it begins cutting out and will begin to puffing smoke out of the dip stick. At one point it was so bad that it blew the dipstick out so hard that it knocked a chunk out of my wall.
Does anyone have any ideas? I am stumped, frustrated and about broke! The truck ran beautiful until that morning. I did have one code present P0410 "secondary air injection malfunction" after I replaced the fuel regulator this code went away and I have no codes present.
I did read that you can get this code if you are getting excessive fuel.
I need help!!!!!!!
I am in the process of taking the head off. I'll let you know what I find.
