Visitor Agreement.
Scared to death but believe in Dodge Products
please let me no wut u did. u can write me at jovaughn333@yahoo.com my car will not start in park only in neutral.
Thanks in advance
Eve
I took it to the dealer they tell me that it will cost
over $1100 to fix,because the redesigned the
rack, plus you need to get a new shaft for the steering
coloumn. I think their should be a recall on the 2004-2006.
Anyone with similar problem please let me know. I also had
a 1998 durango slt. with intake manifold problems.
SUVs and Smart Shopper
KYLE
Thanks Greg :
I have the same exact issue with my '04 Durango Hemi and two different dealerships haven't been able to fix it. Did you ever get it worked out? Thanks in advance for any info.
Eric
MODERATOR /ADMINISTRATOR
Review your vehicle
yes the truck is out of warranty.
thanks Larry Philadelphia
kman10@snip.net
farout
Changers are tough to "reboot" though. Your best bet may be to replace it with an aftermarket stereo.
Recently, my compressor broke and took the A/C clutch with it. Fortunately, I had it under the extended warranty plan and it cost me nothing to repair. I thought my A/C would finally work well. It still doesn't. Hhhhmmm.
To set things in a proper light: I have another Dodge/Plymouth vehicle and the A/C works great!!! So great in fact that I sometimes have to move it a bit off the coldest setting to keep from getting too cold. I didnt think that was possible with Dodge/Chrysler/Plymouth vehicles, but it is.
Anyway, using a thermometer, I tested the temperature on the coldest setting both at idle as well as while the car was moving. My Plymouth vehicle's A/C blows at 40 degrees Fahrenheit! Very nice! In contrast, the Durango blows at 60 degree Fahrenheit. OMG! Not good at all, especially when combined with the low blow from all the vents.
I opened the hood and used thermal insulating tape to wrap the cold side piping from the compressor including the dryer and the pipes going into the firewall. There is an obvious design defect in that these cold A/C pipes pass within about 8 inches of the exhaust manifold that is usually somewhere in the neighborhood of 400 degrees. There is no shroud between them. Not a good design.
Anyway, by wrapping the cold A/C piping I was able to lower the temperature of the air blowing from the fans by 8 degrees! If I can just increase the amount of air blowing into the car I'll be happy enough, but it still won't be great. I'm still going to try and drop the temperature further, but unsure how to proceed or where to look.
Just sharing.
We have a 2004 durango with 66000 miles at time of service.
During a bunch or repairs ball joints, brakes, sway bar bushings.... the dealer noticed the pinion seal was leaking. They replaced it.
the invoice didn't mention anything about oil added or crush washer replacement. My wife drives this vehicle mostly in town. 4000 miles later at 70000 I towed our popup camper on the interstate for 3 hours and a very noticeable humming sound started a couple hours into the trip. I stopped at a lube center (No dodge dealership around) and they ended up putting in 2 quarts of gear oil in the differential and noted there was no signs of leaking. I am working with the dodge dealership that did the repairs and they claim there is no way the vehicle could have left their shop that low on oil, stating that it would have burned up much sooner if that was the case. Is it possible that the vehicle drove that far that low on gear lube. The big question is where did the oil go? Is there any way that replacing a pinion seal could have resulted in this happening?
Tom
How To Find Your Car Owner's Manual Online
What I felt during the test drive was vehicle moving slowly. I mean it’s slow compared to my car. First, I tried it on 2 wheel drive, then I put it on 4 WD, but it’s moving very slowly (EVEN IF I GIVE ENOUGH THROTTLE). I asked this to the sales person (owner?), but his answer is like ' YOUDON’T KNOW HOW TO DRIVE a 4 WHEEL DRIVE'. I am just wondering about his answer. Is that true that driving a Durango wouldn’t be smooth like driving a car?
Mine was used extensively to pull a 22' aluminum car trailer with either a CRX autocross car, or my 06 Corvette to track day events at various race tracks. Pulling the CRX, highway mileage was always 18mpg, and on level ground could log as much as 19. The 1000lb heavier Corvette dropped mileage by 1 to 1.5 mpg respectively. My spouse loved that vehicle more than she did her first new SUV, a 1995 GC with 5.2V8, which was a fine automobile for the 5 years we owned it. MPG is significantly better with the Hemi... In 68000 miles, the only thing I had to do to this Durango is install new tires at 58000 miles, and new front brake pads at 60000, plus routine maintenance and oil changes every 5000 miles, and I used Mobil 1 oil exclusively...as I do in all my vehicles. I can't speak for the newer models you are seeking, but my 05 is probably the best overall vehicle I have owned...Corvette excepted... 8)
