Dodge Durango
I have all of the paper work of when the D was taken into the dealer. All of that info. has been submited to the the company that handles the Arbitration. I have contacted the #1 lemon law Attorney in my area and he is charging $500 just to hear my case and then $2,500 if he thinks this is a good case. Does this sound reasonable? I have never delt with an Attorney before.
Any lawyers here think $500 "just to hear the case" is reasonable?
Steve
Can anyone give me any suggestions where I might find some? Thanks
Second I was thinking about upgrading from 16" rims to 17" or 20". Will that improve my ride?What are the benefits or problems with doing so.
Also how can I improve my fuel mpg? I have a 4.7 that gets an 12.8 avg. Suggestions beside laying off the gas and speed!
I will try www.durangoclub.com for more info. and keep everyone interested up to date.
Has anyone ever had air problems with there durango? I have a 2000 dodge durango with continuous air problems the dealer has replace the compressor at least 8 times. The air temperature coming out of the left front vent is about 65-75 degrees. They have installed larger fans in the engine compartment in hopes that this would solve the problem. They have at one point replaced the whole air system. Hoping some one might have had the same problem and figured out what was going on.
On another note, I just got my truck back after having to have the rear differential reconstructed and both upper and lower ball joints on the front replaced. From what my mechanic has told me, the ball joint thing is a problem with the Durango. The differential was a disappointment and surprise since I don't tow anything and rarely carry anything heavy enough to tax the thing. I've had the truck 18 months and it has been in the shop for almost 3 of them.
Grand High Poobah
The Fraternal Order of Procrastinators
Grand High Poobah
Steve
Grand High Poobah
Steve
Anybody have 2 cents' worth of advice - I'm coming off a 1999 BMW Coupe lease, so I am changing my vehicle perspective considerably.............:-)
Thanks !!!
I would suggest you get the rear A/C unit (one just doesn't seem to be enough for the rear on really hot days), as big of brakes with ABS that are available (mine is short on brakes often, it's a big and heavy truck), third row seat (your child will thank you so they can invite ALL of their friends), 4.6L engine (good performance with far better gas mileage)and replace the OE tires (the Goodyears are absolutely awful for traction, hydroplaning and ride). I hope this helps and good luck.
Grand High Poobah
Grand High Poobah
Living in a mountain area, I am considering to buy a SUV. I do not need a truck for towing, but it should be capable in bad weather, snow and reasonable off road excursions. Of course there are all the nice Japanese and German SUVs (very expensive) as well as Explorers and Jeeps, however, I somehow fell in love with the D and would go for a SLT or SLT+, FT4WD. I just wonder if I should by a very good used one, say a 2001 model, or brand new one.
There are no official dealerships in Europe but only workshops that do direct imports from the US, I wonder if somebody could explain the advantages or disadvantage of some options one can choose when ordering:
- Transfer case: ?Part time shift on the fly? or ?electronic full time on the fly?
- Rear axle ratio: 3.55 or 3.92
- Limited slip differential (does it make
sense on a FT4WD?
Also, I understood from some postings that Goodyear tires are not a real hit on the D. Is this true for all Goodyear tires? The Durangos I have seen here had the Wrangler RT/S on.
Could anybody make out a difference between the new 5 speed automatic and the older 4 speed? How good are the head lamps and do they need some pep up (I used to own a Seville, wonderful car but the head lamps were more than lousy).
Does anybody know when the 2003 model will be available and what will be the changes to the 2002?
A lot of questions. Have tried to read through the postings and various sites but things are not 100pct clear. Thanks for your input
Bob
caddream - If you need the size and can afford the gas (I'm assuming you're in Switzerland), yes I guess the D is a viable choice. It looks great, but because of the size, weight and (IMO) poor braking it can be very difficult in snow and rain. Either way, I would highly recommend getting rid of the OE tires.
Grand High Poobah
Bob
Bob
By far the best vehicle I've owned.
12 mpg city, 15mpg highway (this is the same as my silverado p/u 6.0)
However, regarding the poor breaking I am a bit puzzled. I checked some tests to compare the ratings of other cars (SUVs, Sedans etc). and found that in the latest comparison test (Mid-size SUVs) from Edmunds in the 60-to-0-mph breaking part, the D scored 128 ft just behind the best in this field, the new Explorer with 125 ft (which is not that much better) all others were worse.
In comparison a 2001 Minivan test brought results between best Mazda MPV (128 ft)and worst Pontiac Montana (138 ft), a 2002 Sport Hatchbacks Test with much lighter vehicles showed Ford Focus (118 ft best and Honda Civic (129ft) worst.
So, looking purely at figures the D's performance is not out of the world, admitting that rear drums aren't a high tech sign.
Do you have 4 wheel ABS or only rear ABS, which could be an explanation for the difference in breaking performance, I definitely don't want to buy an unsafe car.
By the way what is IRS. and is there somewhere on the net a photo of the new D?
Steve
IMO, because of the height, size and weight with this type of brakes (2 wheel disks) you are at a disadvantage. You MAY be able to stop in a straight line in the same distance as some other vehicles, but I would be surprised. I also usually need to steer/turn while I'm braking hard to avoid a situation and this is where the size puts these brakes at a disadvantage. I know that rear brakes only help approximately 20% in braking, but when the vehicle weighs 4600 lbs and rides high, that 20% is huge. Don't get me wrong, I like my truck and just have to be aware of its limits when I drive. If I could choose again, I would get 4 wheel discs with full ABS.
WRT the powerbox, I found this on the web:
http://www.dodge.com/inside/concept_vehicles/power_box.html
One last thing, If you're concerned about safety find out if this has been corrected in the new D. In my truck the engine mounts were NOT designed to drop out in case of an accident. That means that in case of a full or mostly full front collision the engine will be pushed back into the passenger compartment instead of dropping off of the frame and sliding under the compartment. My understanding is that this is why the D didn't do as well as some other vehicles in the crash tests for front passengers. Good luck let us know what you choose to do and if you need anything else feel free to contact me or post here.
Grand High Poobah
Tomorrow, I'll see a dealer and test drive the car. I'll definitely ask about the engine mounts and whether the motor will drop out in an accident. I keep you updated about my impressions and my choice
The gas we are FORCED to use is at Amoco Octane rating of 93, at $1.70 per Gallon here in the motor city.
Grand High Poobah
Gas mileage on the Durango is about the same as a Chvy tahoe or any other V8 SUV.
Grand High Poobah
biz.yahoo.com/ap/020613/daimlerchrysler_engine_2.html
This is the website I got from the Durango club. DC has been ablt to increase the fuel efficiency of it's 4.7 liter motor by 14%. They said it was only 200.00 worth of changes. If this is true I am getting that motor when it arrives or have mine modified. I love my D.
Dodge dealer some where near Peabody, MAss.
So my wife picks out the used lease Durango (2000 34K) and on Sunday "purchases" the vehicle. After wading thru the layers of sales staff she is told to get it Friday. I drop off trade in Friday 10:AM and car isn't ready (dirty and other things)........
Come to find out:
1. When Saturday, I originally test drove the vehicle, a tire had a plug in the sidewall (Previous Owner?) So I told the sales kid who's dad work there too, unacceptable: replace it. So anticipating a switch I crawl under to check the spare - NEW so I -keep an eye on it-.
When I return Friday the "new" tire is on the truck and the plugged tire is under in the spare location (GRRRRRRRRRRRR)
2. Car is dirty. Appears only tire has been done. ohhhh but a new crack in the grill.
3. Waiting in the showroom sales staff apologizes for the "come get it Friday" from a sales staffer because:
At best the car will be ready @ 5:PM!
But that is if the TITLE shows up in the mail!
So I ask for a dealer plate for the July 4th weekend or a rental car. They do neither and strand us at 6:PM when the truck isn't ready.
(trade in had bad motor)
But they say we can have the truck if we take the plates off the trade in and apply them to the Truck..........
Cool except then there is NO INSURANCE and what if the cops pull us over for a traffic stop?
Cash (financing) in hand and three days to get their act together. WHY DO THEY THINK CUSTOMERS ARE SO FLIP TOWARDS DEALERS??????????????
Get a clue. Another Durango? ......Hopefully for Chrysler, but talk about shaking our confidence in their products because WE have to deal with their dealer network..........
-Scott in BOSTON
Today is Tuesday July 9 and the title is still not in. And we had to lean on them to do the $3000 deposit credit card refund. Plus we need to go back for a check for the other monies......
Mine is an SLT "Plus" with the 5.2L, leather, third row seat, rear a/c.
I don't go off-road or tow anything, I just load it up with 7 passengers occasionally.
Overall, I am satisfied with the build quality.
It's been reliable throughout the 32,000 miles I've driven it. The size of the vehicle is just right for my needs. It holds passengers comfortably, it's not a high climb into the seats, and the ride is civilized for a truck-based vehicle. While headroom is fine, the high "beltline" makes the windshield small. I have to duck down a bit to look up at the traffic light I've stopped at. The 2nd and 3rd row seats fold down nicely to make cargo space. As for gas mileage I get around 12 mpg in mixed driving (well, at least it takes regular). On the road I am impressed with its steering response. The steering setup in later models is different, but I think this one works fine. It has ABS only in the rear drums. I think that is the setup picked up from the Dakota. You see, Pick-ups have an empty or light payload most of the time, and without much weight over the rear wheels, there is a greater possibility of skidding in the rear. That's no good for a more evenly weighted SUV. 4 wheel ABS was an option. Anyway, the lack of ABS in front has the front wheels sliding over painted road stripes when stopping at a light or toll plaza even when it's dry. The Good Year tires that came with it are partly to blame. They might be fine off-road but have poor grip on pavement.
Overall, I can't really complain about the truck. I chose it because it was the only reasonably sized SUV that offered third row seating. I didn't want to be seen in a minivan-but paid for that in gasoline. And I must admit it looks great. I am looking into the Honda Pilot as my next SUV. As I don't go off-road and am interested in safety and better fuel economy, it's really a better choice for me. The only deficiencies in the Pilot are a lack of heated outside mirrors, and having to remove the headrests from the 2nd and 3rd row seats to fold them down.
Anyway, I hope these observations are helpful.
Grand High Poobah
imgmoney27: Yes you can take your D to any Dodge dealer.
The climate control lights on the dash on our 2002 SLT (with 47 miles) do indeed light up. In fact, the climate control panels for the second and third seat rows also light up when the headlights are on. They're also tied into the dimmer switch.
Good luck....
Peace & Chicken-Grease
We also asked them to check as to why the a/c intermittently switches on and off when the climate control setting is not set to max (recirc), but on fresh air a/c, only on the lowest fan setting. The dealer misunderstood our complaint and did not address the problem. We now notice that a/c does not function at all on the first fan speed (when not on MAX position).
And now a question. We experienced some transmission noise on the highway, which appeared to sound as if the transmission had down shifted, but it hadn't. Now we were travelling at high speed (80 mph) on the freeway at 106 degrees, so I expect this to be quite a load on the truck, but since returning home from vacation and travelling around town in cooler temps we are still experiencing the increased transmission noise. Has anyone else experienced this?
