Classic? Collectible? Special Interest? Just Old?
A CJ7 price will vary considerably with equipment, as many people add all kinds of things to these vehicles. But if it's a regular CJ and in normal street condition, good but not pristine, probably something like $4,500.
jo39
Thanks in advance
adarnell
In 1970, the Sonnett III had a revised fiberglass body, and in 1971 a slightly larger 75HP V-4 was fitted.
The car was never a big seller and was withdrawnn from the US market.
As far as value, it is marginal, in that it fits into the "curios collectible" category along with other unusual but not terribly popular cars. I think they can be fun to drive and they are quite sturdy aside from the chronic Saab transmission weaknesses, but if you restored it you'd have to accept that you would lose most of your money if you decided to sell. These cars aren't all that scarce (over 10,000 made), are considered somewhat unattractive by most people (not me, but I wouldn't call it a beauty either) and generally around $6,000-6,500 seems to be absolute top dollar for a restored one. So you can see that restoration would be for love, not for profit.
So I'd say tidy it up and enjoy it, but think twice about a full-bore restoration. I don't see the market for this car improving in the future, and if you want to really get into a restoration project, you'd have an easier time and come out better with a chrome-bumpered MGB.
Just my two cents. Enjoy the car--it's interesting!
What all this means is that the car should do well in tight autocross courses in the SSB (Showroom Stock Bizarre) class.
I refer you to the 1973 road test annual, pg3: "The R&T steering index is a number we have devised to measure maneuverability or steering quickness."
Oddly enough, I can't find an explanation of how they calcuated it. I must have dreamt up that bit about dividing turning circle by steering wheel turns. It doesn't work.
But they do list the Sonnett III as having a very small turning circle (26.1 ft) and very few turns (2.7 turns). However they figured the 'R&T Steering Index', the Sonnett's was 0.71; lowest in that issue. The Elan Sprint measured 0.80. Most other cars, including expensive sportscars, were well over 1.2 / 1.3.
So a huge turning circle and a steering wheel like that on a large ship (that just keeps spinning with minimal effect on the machine's direction), would presumably result in a high 'steering index'. An F1 car, with less than 1 full turn lock to lock and a small turning circle should have a low number I guess. It measures how much 'turn' of the car you get per 'turn' of the wheel.
I dunno. You're the one who has contact with these guys. Ask em what the hell it meant.
PS
The Lotus Europa, which didn't have a full test and therefore didn't have the 'calculated data' like the steering index, had fewer turns lock to lock than the Sonnett, but a *44-ft* turning circle.
PPS
The Europa is a perennial on my list of cars desired only by me, and nobody else. In fact that's part of the appeal. I'm just afraid people would think I'm Diana Rigg.
A 44ft turning radius? Good grief, how did they manage to DO that on a car that was only 13 feet long?
Kenny Roberts was demonstrating one for a news crew once. He showed how when you turn the handlebar, the front wheel can turn only a degree or 2 before it hits the stops, but even that was more than necessary. "you steer that hard in racing and you'll high-side", he said.
Maybe Chapman just figured a good driver would just kick the tail out when necessary. True, it had no power, but hey; it had no adhesion either.
Seriously, I'm sure that both measurements were taken at virtually zero mph. I'll bet the Sonnett's turning radius would grow pretty fast as the speed rose, whereas the Lotus' might not increase very much even at pretty high speed.
I was looking at a "how to buy a used Lotus" book recently. I figured that with a fiberglas body, the Elan might be relatively rust-resistant. But apparently the "backbone frame" is very rust-prone, due to lack of drainage.
Thanks for the info. I bought the car in '90 for $900 and drove it until it died, now it sits in a barn awaiting someones loving care. For now it will have to wait. Thanks again for your help.
adarnell
All original, Heads, 2-bbl Carter carb., exhaust
manifold, A.I.R. Pump and hoses, Plus I have the 2 Speed Powerglide.
What are each of these worth??
Does anyone know what the 2 speed powerglide tranny out of the same car is worth?
Does anyone care?
Let's assume that you're not worried about entering any concours. Original appearance is not important.
Pick a nice, desirable old coupe that's almost undriveable in the summer in a warm climate. How about a nice Alfa GTV 1750? You find a nice, modern rotary compressor, a condenser, some tubing; you fabricate some ductwork and brackets.
Is it feasible?
Also, is it possible to have the compressor driven by an electric motor (like in your house) instead of by the engine via a V-belt and clutch?
But sure, anyone clever enough could retrofit something. I'm sure you'd need to fabricate the brackets, of course, and the double pulley system too, no doubt.
If so, somebody could market a complete kit with adapters for a wide range of cars. As long as you can find a place to stash the condenser, you could put A/C in almost anything.
Sound possible? Worthwhile?
Sounds like a scheme we could sell stock in and then everyone but us would lose money.
True, you wouldn't mess with a classic, but a fun old runner with unmatching numbers, that will never be worth much except to the owner,...
Here's a variation on the theme:
I once paid to have a dealer-installed unit *removed* from a mid-70's Dascher. When it was "working" it would spit ice and ice water on your legs. When it wasn't, it would emit a HUGE, dense cloud of white smoke out the tailpipe. I'm not exaggerating to say that I could not see the car behind me. That only happened once though. Didn't turn it on again after that.
Saw one on the road today. Separate fenders. I'd estimate that it was a late 50's model; possibly a 60's.
It really looked quite beautiful, dignified and actually very discrete. It didn't scream opulance like some modern, vulgar cars do. It was a simple, straightforward, not that huge (no bigger than an average SUV), honest piece of steel, wood and leather.
Think of all the pitiful neo-Rollers that are trying so hard to imitate that style: SUV's of the same length, twice the width, with acres of leather and veneer. Same weight, twice the power and 4WD. And no class.
Some people would also vote for the 62-65 Silver Cloud III dropheads, which are quite rare and valuable (about 50 made, others have been converted out of factory and are not as valuable).
I myself would never own a Rolls although I've had the opportunity to buy a number of good-looking cripples (they're cheap), but I really like the Bentley Continental Fastback from the early 50s...I just don't happen to have an extra 150K around.
Well, for vintage cars you folks in the Midwest have the big Kruse Auction in Auburn every year. I've seen some good buys there...but you're right, you don't see many decent old foreign cars being dragged out of barns and garages in middle America.
As I recall is was a recycled oil for use in cars that would consume oil. It was like a dime a quart in the 60's out here in AZ and CA.
Does this have any collectors value or is it just another old car?
But they are still a nice ride and will always be worth somewhat more than an ordinary 1977 sedan.
You should advertise this car in Hemmings Motor News--their website is (hemmings.com) and Sports Car Market Magazine --their e-mail is: (mail@sportscarmarket.com).
Both these publications are inexpensive but they aim directly at the type of buyer you need...your price is ballpark but would have to be extremely nice to sell at that price, neaer show quality...still, you have to start somewhere, and that seems reasonable asking price for a nice car. The active range for them seems to be $6,500-8,500.
good luck,
My question: Do any of you have knowledge of the MB 180D/190D? I like their looks and I know many junkers are out there for parts. I know also they are among the slowest of cars ever made. I've driven Saab 96's with the 3-cylinder 1 carb setup and found them to be fun and powerful enough, though I suppose they are a bit lighter in weight. I'm thinking of buying one for enjoyment but wonder if they're enough fun/reliable with their underpowered plant.
Think of it as VW performance at Mercedes prices.
How about a Volvo 120 series (Amazon). One tough car, easy to fix, plenty of parts, and fun to drive, and attractive. Try it, you'll like it.
FYI - "carnut4," the 48 Cadillac was the first year for the tail fins, and I believe it was a better looking car (especially the Sedanette), however the 48 had the old flat head V-8, which was slower and ate more gas.
And "dbruland" that color, kind of a tan-rose was used on the entire Olds line from about 80-84. Sherwin-Williams made the paint - you could probably find out with a phone call. Still drive my '84 -98; it's bullet-proof!
Yes, you're right, should I buy one I'll always have to remember whether I'm in the Buick or the Alfa before I hit the freeway exit!
Thanks for the tip-off, I'm on my way there!
Shifty
