Thank You! :confuse:
Thank You and good luck to you.
But, wild guesses - a plugged up fuel filter - oh, never mind I see you've changed that.
Or a failing fuel pump. Get a pressure gauge and screw into the fitting on the fuel line under the hood. Find out somewhere what the pressure should be. I think it probably needs about 45 pounds of pressure.
With ribbed belts, they don't slip often. But if you've got oil or something on the belt driving the alternator, that might be the problem.
The truck has not been used in two weeks and I just checked the blinkers to confirm my description was correct. To my surprise, EVERYTHING IS WORKING FINE. This is frustrating. I should mention that I replaced the multifuntion switch on the steering column, however, this did not solve the problem initially.
I know your post is a couple of months old, however, were you able to fix the problem?
It sounds like the wires are possibly exposed and touching somewhere. I'm not sure where to start troubleshooting this. Instead of taking it to a shop where they'll charge $100/hr, I turn to you guys for advice. Thanks much!
I have an 07 Ford Ranger, my battery light started coming on, which then turned into losing all dash lights around 2k rpms. I took it to Autozone the battery and alternator test fine. The truck went about a week to a week and a half without anything happening again.
Driving home tonight the battery light started flickering again and when it did all the lights dash and headlights got brighter. If I turn the dome light on it sounds like the inside fuse panel on the passenger side is clicking.
what could this be? Any suggestions would be great.
Anubis
An on-line mechanic told me the problem was in the multi function switch. I replaced it but there was no improvement. Next I replaced the brake switch. From the wiring diagram, it appeared to be a potential source of the short. No effect. Finallly I changed the turn signal flasher relay. It still did not solve the problem, however, a week later the problem disappeared and the electronics have been working without issue since. This is hard to explain what actually fixed the problem.
This is Seni with Ford Customer Service. I am sorry your Ranger is not performing to your expectation. We recommend that your truck be inspected by a Ford dealership to determine the cause of any symptoms it may be experiencing. If there is no coverage under applicable warranties, recalls, or ESPs, repairs and services would be your responsibility. As you mentioned, the problem may be intermittent, but that doesn’t mean it’s not a problem. Your next step is to make an appointment with your servicing dealership to have your vehicle diagnosed. Please contact the Customer Relations Center at 800-392-3673, if further assistance is needed. Thank you.
Seni
Ford Customer Service Division
the locks work and the side mirrow work as well does the passenger side window but driver side stop working
did you get any info
Did I tell you about the $700 I had to spend on the A/C or the recent problem where the brake line behind the gas tank rusted through. The worst part was the rear brakes were so rusted, that I could not loosed the bleeder valves. I had to replace both brake pistons. Fun owning an old truck!
I just replaced the timing belt, water pump, and all the top end gaskets. The timing marks are spot on so it is not my timing. It is not getting any spark... I need help cause i am stumped it seems like this thing has ghosts in it hahaha!
My wild guess - fuel pump relay and/or corrision where relay plugs in.
Next WAG, weak fuel pump. Can you hear pump running? Running pump mean relay is ok.
Maybe a plugged up fuel filter.
Reread your note. I think remote starts and add-on security systems are just a problem waiting to happen. Think about it, this is cut into factory wiring. If the added wiring fails, or the little black box associated with this ad-on fail, it's going to cause grief.
pump running,checked relay,recent tune up.
remote start disconnected, but theft light still flashes and think it is factory.
I would start diagnoising this problem by talking to the service department at the local ford dealer to see if a failed transponder key will allow the engine to turn over and not start. I might also ask if they have ever heard of an intermitant anti theft (transponder) circuit.
There are ways to bypass the transponder anti-theft circuit in the ranger. You can buy kits if you are electrically inclined. An alternative would be to have a lock smith install a bypass key. My ranger is getting old. If I start to have trouble with the transponder key, I will bypass. Who would want to steal an old truck anyway! Good luck.
I started having a problem where i would insert the key and hear spme subtle shocking sounds, while all the lights on the dash flicker intermittently. you attempt to turn the key and absolutely nothing happens. Not so much as an attempt to start.
I have a brand new battery. I disconnected the power to the battery and put it back after a few seconds, and it worked fine. Then a few weeks later the same thing happened. Disconnecting the battery fixed the problem again.
Last night, while driving all electronics in the car flickered twice, (headlights, dash lights, radio, everything.)
Then all of a sudden the truck just dies. All power went out and the engine quit. It was like a complete blackout. The emergency flashers would not come on, head and tail lights were out. It was completely dead. Luckily i coasted to a stop sign, jumped out pulled off the power cable at the battery, put it back and then got in the truck, and it started right up.
When it came on i noticed the temperature gage showed the truck overheating. I was able to make it another block to my house, where i noticed the water reservoir was empty.
I do not know if these problems are related, as i had the radatior replaced a recently, after a rock took out my old one. So that could just be an issue related to the replacement.
The electrical problems scare me. Anyone know where to start to diagnose the issue?
Has anyone else experienced this?
You should also report your vehicle fire to them. If people don't report this stuff, then recalls will never be done. Somewhere on the site it will also tell you how to make a report.
Are you still under warranty? If so, get Ford involved in this.
Have had numerous problem with the light on the horn starts blowing and now this.
Engine lights frequently comes on and disconnect the batter take that light off ( when it first came on, I took it to the dealer, warranty had just expired, and cost me over $200 for some kind of part and before I got home, the light was back on. So not wanting to deal with the Ford Service dept.
Noticing that others have had these problems also, does anyone know of a solution?
Is there a wire terminal or bus somewhere under the daskh or hood that may be shorted out? My Haynes manual i sno help here! I can't figure this out.
Dutch
