any help would be greatly appreciated. :P
It makes a whine in 1, 2, and 3 gears. When I push in the clutch it go's away.
When I am at a stop, put it in neutral the whine is back, after I let off the clutch.
I was wondering if it is my clutch, and throw-out bearing, or if it is my transmission going out. I want to get some input before I tear it apart. Only want to do it once.
First time poster, long time lurker. I"ve got a issue with my '01 Dak 4x4 and am hoping for a little help here gents so here goes...
Pooched reverse in the 42re and initial findings after dropping the pan and screen showed good fluid, no shavings, minimal material on the magnet (looked like a3/32 covering of fine "never seize") but I did find what appears to be part of of the (I'm guessing a bit here) the direct clutch waved ring. All forward gears and TC work well however no reverse and no engine braking in 1st gear manual, pointing to low/reverse-band/servo failure.
Long story short guys, tranny has 150k on it and I've found a low mileage 2wd 42re for short money. Is a housing/tail shaft swap with my 4x4 setup as doner feasible IE a simple swap out or does it require a internal tranny break down. Thanks for any insight.
Charlie
Please help.
Paul
Paul
I have a 4x4 1989 Dodge Dakota 3.9L V6. Recently, I have been experiencing a loud whizzing/vibration noise around my transfer case which only occurs from 60mph and up. The engine and transmission both seem to be running fine, but I was just concerned about the noise from the transfer case.
Just as an added note, when I move the transfer shifter up just a tad at the 2WD position, the noise becomes higher pitched.
I just replaced the front and rear seals along with filter and fluid. The transmission has 75,000 miles on it. It worked fine before changing these items. Now it does not upshift to 3-4 or lockup unless I turn the OD off and then back on. Any suggestions?
kcram - Pickups/Wagons Host
I did find the 8 pin plug on my 2000 Dakota and sure enough it had fluid in it. I tried to clean it out and plugged it back in but still got the solenoid code. The Dodge mechanic said it was definitely an electrical issue and 9 times out 10 it is the solenoid. But do you think I should replace the plug first?
Paul
Is this difficult to reprogram or replace?
You sure seem to know your dodge transmissions.
Today I took it out and drove it around 5-6 miles to get it hot to check the fluid. It wasn't slipping at all today but was very sluggish (especially when first starting) It seemed like it took forever to get up to speed. I took it to advance auto and got the code that it was throwing.
1762 The Governor Pressure Sensor input was too high or too low for 3
consecutive park/neutral calibrations.
I've had trouble with it before down shifting when the slightest bit of extra throttle was applied and when using the cruise control. I adjusted the throttle position cable going to the tranny and it worked fine after that.
Any suggestions would be much appreciated!
Jeremy
Thank you for any suggestions....
Please Help!!!!!!!!
"The trans will only operate in 2nd and 3rd".High gear starts usually is a bad governor pressure solinoid.No upshift from first is usually a governor pressure sensor.As far as changing the plug it comes as one piece with the internal wire harness and the overdrive cancel and TCC solinoid.It is not very hard to replace.First you drop the valve body.You may have to turn the drive shaft slightly to remove thr park pawl shaft{and to reinstall it}I have found its easier to leave the park rod on the valve body rather than try to mess with the E clip holding it on.Once the valve body is down you will need a 25 torx bit to remove the internal harness assembaly.
For me it was 1762 - Governor Pressure Sensor
I replaced the Governor Pressure Sensor and the Governor Pressure Solenoid when my truck was doing the same thing and it fixed it right up. Might as well replace the filter while you are in there and the filter comes with a new gasket. It is a rubber gasket so don't over tighten the bolts or you will have leaks. Just a little more than snug does the trick.
If you are going to replace the pressure sensor you should go ahead and relace the solenoid as well. From everything I have read they go out in pairs and it would stink to replace one and it really be the other that is giving you the problem.
Let me know if you have any questions about this because I just did it a week ago and it is still fresh in my head.
I have to increase the rpm's and then when they decrease it will go into gear. It's and automatic.
Should I have the trans fluid changed and refilled or what ?
